Select gpio PAD wakeup for those i.MX8 platforms with
system controller present.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit 61f3cc34747e5c8db1578c8aba5bd9592533cede)
Add i.MX8MM SoC support.
Add Kconfig and DTS support for i.MX8QP with a simplified structure
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Squashed into a single commit during 4.14 rebase.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Select KEYBOARD_SNVS_PWRKEY for i.MX8MQ by default.
Enable i.MX8MQ pinctrl driver by default.
Add i.MX8QM/QXP/MQ support by default.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[ Upstream commit 7db7a8f5638a2ffe0c0c0d55b5186b6191fd6af7 ]
A number of the Rockchip-specific drivers (IOMMU, display controllers)
are now assuming that CONFIG_PM is set, and may completely misbehave
if that's not the case.
Since there is hardly any reason for this configuration option not
to be selected anyway, let's require it (in the same way Tegra already
does).
Pull ARM/arm64 Devicetree updates from Olof Johansson:
"As usual, device tree updates is the bulk of our material in this
merge window. This time around, 559 patches affecting both 32- and
64-bit platforms.
Changes are too many to list individually, but some of the larger
ones:
New platform/SoC support:
- Automotive:
+ Renesas R-Car D3 (R8A77995)
+ TI DT76x
+ MediaTek mt2712e
- Communication-oriented:
+ Qualcomm IPQ8074
+ Broadcom Stingray
+ Marvell Armada 8080
- Set top box:
+ Uniphier PXs3
Besides some vendor reference boards for the SoC above, there are also
several new boards/machines:
- TI AM335x Moxa UC-8100-ME-T open platform
- TI AM57xx Beaglebone X15 Rev C
- Microchip/Atmel sama5d27 SoM1 EK
- Broadcom Raspberry Pi Zero W
- Gemini-based D-Link DIR-685 router
- Freescale i.MX6:
+ Toradex Apalis module + Apalis and Ixora carrier boards
+ Engicam GEAM6UL Starter Kit
- Freescale i.MX53-based Beckhoff CX9020 Embedded PC
- Mediatek mt7623-based BananaPi R2
- Several Allwinner-based single-board computers:
+ Cubietruck plus
+ Bananapi M3, M2M and M64
+ NanoPi A64
+ A64-OLinuXino
+ Pine64
- Rockchip RK3328 Pine64/Rock64 board support
- Rockchip RK3399 boards:
+ RK3399 Sapphire module on Excavator carrier (RK3399 reference design)
+ Theobroma Systems RK3399-Q7 SoM
- ZTE ZX296718 PCBOX Board"
* tag 'armsoc-devicetree' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (559 commits)
ARM: dts: at91: at91sam9g45: add AC97
arm64: dts: marvell: mcbin: enable more networking ports
arm64: dts: marvell: add a reference to the sysctrl syscon in the ppv2 node
arm64: dts: marvell: add TX interrupts for PPv2.2
arm64: dts: uniphier: add PXs3 SoC support
ARM: dts: uniphier: add pinctrl groups of ethernet phy mode
ARM: dts: uniphier: fix size of sdctrl nodes
ARM: dts: uniphier: add AIDET nodes
arm64: dts: uniphier: fix size of sdctrl node
arm64: dts: uniphier: add AIDET nodes
Revert "ARM: dts: sun8i: h3: Enable dwmac-sun8i on the Beelink X2"
arm64: dts: uniphier: add reset controller node of analog amplifier
arm64: dts: marvell: add Device Tree files for Armada-8KP
arm64: dts: rockchip: add Haikou baseboard with RK3399-Q7 SoM
arm64: dts: rockchip: add RK3399-Q7 (Puma) SoM
dt-bindings: add rk3399-q7 SoM
ARM: dts: rockchip: enable usb for rv1108-evb
ARM: dts: rockchip: add usb nodes for rv1108 SoCs
dt-bindings: update grf-binding for rv1108 SoCs
ARM: dts: aspeed-g4: fix AHB window size of the SMC controllers
Select PINCTRL for ZTE platform, so that we can have ZX pinctrl driver
options available for enabling.
Add a configuration option for the R-Car D3 SoC.
Note that r8a77995 is the first Renesas "r8a<n>" SoC using a 5 digit
number in its Kconfig symbol, as r8a77990 will be a different SoC.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Pull ARM SoC 64-bit updates from Arnd Bergmann:
"Changes to platform code for 64-bit ARM platforms.
Andreas Färber adds two new platforms with initial code: Realtek
RTD1295 and Action Semi S900. Both are fairly similar chips, used
mainly in set-top-boxes, but with other possible applications, and
additional members in the respective product families that could be
added in the future. The code here is fairly minimal, as all the
interesting parts are in device drivers and dts files.
The Broadcom Vulcan platform gets dropped, as no products ever became
available, and Cavium integrated the platform under a new name.
Among some other defconfig changes, Timur Tabi enables a number of
options that are typically required for server platforms"
* tag 'armsoc-arm64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: defconfig: remove duplicate entry
arm64: defconfig: enable Qualcomm Technologies EMAC and some PHY drivers
arm64: defconfig: enable QCOM_L2_PMU and QCOM_L3_PMU
arm64: defconfig: enable EDAC options
arm64: defconfig: enable APEI and GHES features
arm64: defconfig: enable support for PCIe hotplug
arm64: defconfig: enable EFI_CAPSULE_LOADER
arm64: defconfig: enable BLK_DEV_NVME
arm64: defconfig: enable ACPI_CPPC_CPUFREQ
arm64: marvell: enable ICU and GICP drivers
arm64: marvell: enable the Armada 7K/8K pinctrl driver
arm64: Prepare Actions Semi S900
ARM64: defconfig: enable meson SPICC as module
ARM64: defconfig: enable IR core, decoders and Meson IR device
arm64: defconfig: enable Simple Sound Card support
arm64: defconfig: Enable ARCH_BRCMSTB
arm64: defconfig: drop ARCH_VULCAN
arm64: disable Broadcom Vulcan platform
MAINTAINERS: Add Realtek section
ARM64: Prepare Realtek RTD1295
git://git.kernel.org/pub/scm/linux/kernel/git/afaerber/linux-actions into next/arm64
Pull "Actions Semi ARM64 SoC for v4.13" from Andreas Färber:
This adds a Kconfig symbol for DTs and drivers being added.
* tag 'actions-arm64-soc-for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/afaerber/linux-actions:
next/arm64
Pull "mvebu arm64 for 4.13 (part 1)" from Gregory CLEMENT
- enable the ICU and GICP drivers for Armada 7K/8K
- enable the pinctrl driver for Armada 7K/8K
* tag 'mvebu-arm64-4.13-1' of git://git.infradead.org/linux-mvebu:
This commit enables the newly introduced Marvell GICP and ICUs driver
for the 64-bit Marvell EBU platforms.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This commit makes sure the drivers for the Armada 7K/8K pin controllers
are enabled.
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Add ARCH_ACTIONS.
Signed-off-by: Andreas Färber <afaerber@suse.de>
The config option name is now renamed to 'TIMER_OF' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
into next/arm64
Realtek ARM64 SoC for v4.12
This adds a Kconfig symbol for DTs being added, plus a MAINTAINERS entry.
* tag 'realtek-arm64-soc-for-4.12' of git://github.com/afaerber/linux:
Disable the option ARCH_VULCAN as a step towards deleting it entirely.
There is still a reference in the kernel tree for ARCH_VULCAN, so we
have to keep the config option around until that reference is removed.
Signed-off-by: Jayachandran C <jnair@caviumnetworks.com>
Add a Kconfig option ARCH_REALTEK.
Merge "mvebu arm64 for 4.12" from Gregory CLEMENT:
enable the Armada 37xx pinctrl driver
* tag 'mvebu-arm64-4.12-1' of git://git.infradead.org/linux-mvebu:
arm64: marvell: enable the Armada 37xx pinctrl driver
The sunxi clk driver causes a link error when the reset controller
subsystem is disabled:
drivers/clk/built-in.o: In function `sun4i_ve_clk_setup':
:(.init.text+0xd040): undefined reference to `reset_controller_register'
drivers/clk/built-in.o: In function `sun4i_a10_display_init':
:(.init.text+0xe5e0): undefined reference to `reset_controller_register'
drivers/clk/built-in.o: In function `sunxi_usb_clk_setup':
:(.init.text+0x10074): undefined reference to `reset_controller_register'
We already force it to be enabled on arm32 and some other arm64 platforms,
but not on arm64/sunxi. This adds the respective Kconfig statements to
also select it here.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This commit makes sure the driver for the Armada 37xx pin controller is
enabled.
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/arm64
Samsung ARM64 update for v4.12:
1. Exynos power management drivers support now ARMv8 SoC - Exynos5433 - so
select them in ARCH_EXYNOS.
2. Enable few Exynos drivers for supported ARMv8 SoCs.
* tag 'samsung-soc64-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
arm64: defconfig: Enable video, DRM and LPASS drivers for Exynos5433 and Exynos7
arm64: exynos: Enable Exynos PMU and PM domains drivers
Enable EXYNOS_PM_DOMAINS because recently Exynos5433 got support for
Power Management domains. The Exynos5433 pinctrl driver requires
EXYNOS_PMU to get the syscon-regmap for PMU address space.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Alim Akhtar <alim.akhtar@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
As the pinctrl driver selecting is refactored in Kconfig file of
pinctrl-sunxi, now we can select only PINCTRL for Allwinner platform,
and the default value of several pinctrl drivers useful on ARM64
Allwinner SoCs will become Y.
This is the situation of 32-bit ARM ARCH_SUNXI option.
Drop the select of per-SoC pinctrl choices, but keep selecting PINCTRL.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add support for ThunderX2 CN99XX arm64 server processors.
Introduce a new arm64 platform config option ARCH_THUNDER2 for these
processors.
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- A new driver for the power management controller on TI Keystone
- Support for the prerelease "SCPI" firmware protocol that ended up
being shipped by Amlogic in their GXBB SoC.
- A soc_device can now be matched using a glob from inside the
kernel, when another driver wants to know the specific chip it is
running on and cannot find out from DT, firmware or hardware.
- Renesas SoCs now support identification through the soc_device
interface, both in user space and kernel.
- Renesas r8a7743 and r8a7745 gain support for their system
controller
- A new checking module for the ARM "PSCI" (not to be confused with
"SCPI" mentioned above) firmware interface.
- A new driver for the Tegra GMI memory interface
- Support for the Tegra firmware interfaces with their power
management controllers
As usual, the updates for the reset controller framework are merged
here, as they tend to touch multiple SoCs as well, including a new
driver for the Oxford (now Broadcom) OX820 chip and the Tegra bpmp
interface.
The existing drivers for Atmel, Qualcomm, NVIDIA, TI Davinci, and
Rockchips SoCs see some further updates"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
misc: sram: remove useless #ifdef
drivers: psci: Allow PSCI node to be disabled
drivers: psci: PSCI checker module
soc: renesas: Identify SoC and register with the SoC bus
firmware: qcom: scm: Return PTR_ERR when devm_clk_get fails
firmware: qcom: scm: Remove core, iface and bus clocks dependency
dt-bindings: firmware: scm: Add MSM8996 DT bindings
memory: da8xx-ddrctl: drop the call to of_flat_dt_get_machine_name()
bus: da8xx-mstpri: drop the call to of_flat_dt_get_machine_name()
ARM: shmobile: Document DT bindings for Product Register
soc: renesas: rcar-sysc: add R8A7745 support
reset: Add Tegra BPMP reset driver
dt-bindings: firmware: Allow child nodes inside the Tegra BPMP
dt-bindings: Add power domains to Tegra BPMP firmware
firmware: tegra: Add BPMP support
firmware: tegra: Add IVC library
dt-bindings: firmware: Add bindings for Tegra BPMP
mailbox: tegra-hsp: Use after free in tegra_hsp_remove_doorbells()
mailbox: Add Tegra HSP driver
firmware: arm_scpi: add support for pre-v1.0 SCPI compatible
"Changes to platform code for 64-bit ARM platforms. We are not adding
any new platforms that require code or Kconfig changes this time, so
it's basically just defconfig changes to enable support for more
drivers used on the existing platforms.
This is mainly interesting for the Raspberry Pi 3, which should now
work much better with the default build"
arm64: defconfig: drop GPIO_SYSFS on multiplatforms
arm64: defconfig: Do not lower CONFIG_LOG_BUF_SHIFT
arm64: defconfig: allow rk3399-based boards to boot from mmc and usb
arm64: defconfig: enable RK808 components
arm64: defconfig: enable I2C and DW MMC controller on rockchip platform
arm64: defconfig: Enable Tegra186 SoC
ARM64: configs: Activate Internal PHY for Meson GXL
arm64: qcom: enable GPIOLIB in Kconfig
arm64: configs: enable configs for msm899(2/4) basic support
ARM64: bcm2835: add thermal driver to default config
ARM64: configs: Add Platform MHU in defconfig
MAINTAINERS: Update Broadcom Vulcan maintainer email
arm64: defconfig: enable EEPROM_AT25 config option
arm64: Enable HIBERNATION in defconfig
arm64: defconfig: Enable DRM DU and V4L2 FCP + VSP modules
ARM64: defconfig: Enable MMC related configs
arm64: Add BCM2835 (Raspberry Pi 3) support to the defconfig
Identify the SoC type and revision, and register this information with
the SoC bus, so it is available under /sys/devices/soc0/, and can be
checked where needed using soc_device_match().
Identification is done using the Product Register or Common Chip Code
Register, as declared in DT (PRR only for now), or using a hardcoded
fallback if missing.
Example:
Detected Renesas R-Car Gen2 r8a7791 ES1.0
# cat /sys/devices/soc0/{machine,family,soc_id,revision}
Koelsch
R-Car Gen2
r8a7791
ES1.0
While debugging a kernel image size issue, I discovered that if all
non ARCH_QCOM configs in the ARM64 defconfig are disabled, the QCOM
pinctrl drivers will not be built.
The QCOM pinctrl drivers have a dependency on GPIOLIB which was being
selected when other ARCH configs were enabled, but ARCH_QCOM doesn't
select GPIOLIB directly. Let's select GPIOLIB here to ensure the pinctrl
drivers are built for QCOM platforms.
Signed-off-by: Michael Scott <michael.scott@linaro.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
The UniPhier reset driver (drivers/reset/reset-uniphier.c) has been
merged. Select ARCH_HAS_RESET_CONTROLLER from the SoC Kconfig.
Pull ARM 64-bit DT updates from Arnd Bergmann:
"The 64-bit DT changes are surprisingly small this time, we only add
two SoC platforms: the ZTE ZX296718 Set-top-box SoC and the SocioNext
UniPhier LD11 TV SoC, each with their reference boards.
There are three new machines added for existing SoC platforms:
- The Marvell Armada 8040 development board is an impressive
quad-core Cortex-A72 machine with three 10gbit ethernet interfaces
- Qualcomms DragonBoard 820c single-board computer is their current
high-end phone platform in the 96boards form factor
- Rockchip: Tronsmart Orion r86 set-top-box is a popular mid-range
Android box based on the 8-core rk3368 SoC"
* tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (91 commits)
arm64: dts: berlin4ct: Add L2 cache topology
arm64: dts: berlin4ct: enable all wdt nodes unconditionally
arm64: dts: berlin4ct: switch to Cortex-A53 specific pmu nodes
arm64: dts: Add ZTE ZX296718 SoC dts and Makefile
arm64: dts: apm: Add DT node for APM X-Gene 2 CPU clocks
arm64: dts: apm: Add X-Gene SoC hwmon to device tree
arm64: dts: apm: Fix interrupt polarity for X-Gene PCIe legacy interrupts
arm64: dts: apm: Add APM X-Gene v2 SoC PMU DTS entries
arm64: dts: apm: Add APM X-Gene SoC PMU DTS entries
arm64: dts: marvell: enable MSI for PCIe on Armada 7K/8K
arm64: dts: ls2080a: Add 'dma-coherent' for ls2080a PCI nodes
arm64: dts: rockchip: add Type-C phy for RK3399
arm64: dts: rockchip: enable the gmac for rk3399 evb board
arm64: dts: rockchip: add the gmac needed node for rk3399
arm64: dts: rockchip: support the pmu node for rk3399
arm64: dts: rockchip: change all interrupts cells to 4 on rk3399 SoCs
arm64: dts: rockchip: add the tcpc for rk3399 power domain
arm64: dts: rockchip: add efuse0 device node for rk3399
arm64: dts: rockchip: configure PCIe support for rk3399-evb
arm64: dts: rockchip: add the PCIe controller support for RK3399
Nearly all of these are defconfig updates to enable new drivers or old
drivers still used on these 64-bit platforms.
Aside from that, we gain initial support for two set-top-box
platforms, both of which already have 32-bit support in arch/arm:
- Broadcom adds abstract support for the bcm7xxx/brcmstb platform,
presumably the respective dts files and more information will
follow at a later point.
- The ZTE ZX296718 SoC for set-top-boxes, a relative of the 32-bit
ZX296702 SoC that we already support"
arm64: add ZTE ZX SoC family
arm64: defconfig: enable ZTE ZX related config
arm64: defconfig: enable common modules for power management
arm64: defconfig: enable meson I2C
arm64: defconfig: enable meson SPI as module
arm64: defconfig: enable meson WDT as modules
arm64: defconfig: enable HW random as module
arm64: defconfig: Enable SDHI and GPIO_REGULATOR
arm64: configs: enable PCIe driver for Aardvark
Kconfig: ARCH_HISI: Add PINCTRL to HISI platform
arm64: defconfig: enable bluetooth supports as modules
arm64: defconfig: enable CONFIG_INPUT_HISI_POWERKEY for HiKey
arm64: defconfig: Enable HiSilicon kirin drm, adv7533 for HiKey
arm64: defconfig: Enable Hisi SAS and HNS
arm64: defconfig: Enable QDF2432 config options
arm64: sunxi: Kconfig: add essential pinctrl driver
arm64: defconfig: Add Renesas R-Car HSUSB driver support as module
arm64: Add Broadcom Set Top Box Kconfig entry point
arm64: defconfig: enable xhci-platform
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.9 series:
Subsystem improvements:
- do away with the last users of the obsolete Kconfig options
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter
always sounded like an item on a wishlist to Santa Claus to me). We
can now select GPIOLIB and be done with it, for all archs. After
some struggle it even work on UM. Not that it has GPIO, but if it
wants to, it can select the library.
- continued efforts to make drivers properly either tristate or bool.
- introduce a warning for drivers assigning default triggers to their
irqchip lines when probed from device tree, so we find and fix
these ambigous drivers. It is agreed that in the OF config path,
the device tree defines trigger characteristics.
- the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips.
- we introduce the ability to mark certain IRQ lines as "unusable" as
they can be taken by BIOS/firmware, unrouted in silicon and
generally nasty if you use them, and such things. This is put to
good use in the STMPE driver and also in the Cherryview pin control
driver.
- a new "mockup" virtual GPIO device that can be used for testing.
The plan is to add unit tests under tools/* for exercising this
device and verify that the kernel code paths are working as they
should.
- make memory-mapped I/O-drivers depend on HAS_IOMEM. This was
implicit all the time, but when people started building UM with
allyesconfig or allmodconfig it exploded in their face.
- move some stray bits of device tree and ACPI HW description
callbacks down into their respective implementation silo. These
were causing issues when compiling on !HAS_IOMEM as well, so now
eventually UM compiles the GPIOLIB library if it wants to.
New drivers:
- new driver for the Aspeed GPIO front-end companion to the pin
controller merged through the pin control tree.
- new driver for the LP873x PMIC GPIO portions.
- new driver for Technologic Systems' I2C FPGA GPIO such as TS4900,
TS-7970, TS-7990 and TS-4100.
- new driver for the Broadcom BCM63xx series including BCM6338 and
BCM6345.
- new driver for the Intel WhiskeyCove PMIC GPIO.
- new driver for the Allwinner AXP209 PMIC GPIO portions.
- new driver for Diamond Systems 48 line GPIO-MM, another of these
port-mapped I/O expansion cards.
- support the STMicroelectronics STMPE1600 variant in the STMPE
driver.
Driver improvements:
- the STMPE driver now supports rising/falling edge detection
properly for IRQs.
- the PCA954x will now fetch and enable its VCC regulator properly.
- major rework of the PCA953x driver with the goal of eventually
switching it over to use regmap and thus modernize it even more.
- switch the IOP driver to use the generic MMIO GPIO library.
- move the ages old HTC EGPIO (extended GPIO) GPIO expander driver
over to this subsystem from MFD, achieveing some separation of
concerns"
* tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits)
gpio: add missing static inline
gpio: OF: localize some gpiochip init functions
gpio: acpi: separation of concerns
gpio: OF: separation of concerns
gpio: make memory-mapped drivers depend on HAS_IOMEM
gpio: stmpe: use BIT() macro
gpio: stmpe: forbid unused lines to be mapped as IRQs
mfd/gpio: Move HTC GPIO driver to GPIO subsystem
gpio: MAINTAINERS: Add an entry for GPIO mockup driver
gpio/mockup: add virtual gpio device
gpio: Added zynq specific check for special pins on bank zero
gpio: axp209: Implement get_direction
gpio: aspeed: remove redundant return value check
gpio: loongson1: remove redundant return value check
ARM: omap2: fix missing include
gpio: tc3589x: fix up complaints on unsigned
gpio: tc3589x: add .get_direction() and small cleanup
gpio: f7188x: use gpiochip_get_data instead of container_of
gpio: tps65218: use devm_gpiochip_add_data() for gpio registration
gpio: aspeed: fix return value check in aspeed_gpio_probe()
Pull EDAC updates from Borislav Petkov:
"A lot of movement in the EDAC tree this time around, coarse summary
below:
- Altera Arria10 enablement of NAND, DMA, USB, QSPI and SD-MMC FIFO
buffers (Thor Thayer)
- split the memory controller part out of mpc85xx and share it with a
new Freescale ARM Layerscape driver (York Sun)
- amd64_edac fixes (Yazen Ghannam)
- misc cleanups, refactoring and fixes all over the place"
* tag 'edac_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (37 commits)
EDAC, altera: Add IRQ Flags to disable IRQ while handling
EDAC, altera: Correct EDAC IRQ error message
EDAC, amd64: Autoload module using x86_cpu_id
EDAC, sb_edac: Remove NULL pointer check on array pci_tad
EDAC: Remove NO_IRQ from powerpc-only drivers
EDAC, fsl_ddr: Fix error return code in fsl_mc_err_probe()
EDAC, fsl_ddr: Add entry to MAINTAINERS
EDAC: Move Doug Thompson to CREDITS
EDAC, I3000: Orphan driver
EDAC, fsl_ddr: Replace simple_strtoul() with kstrtoul()
EDAC, layerscape: Add Layerscape EDAC support
EDAC, fsl_ddr: Fix IRQ dispose warning when module is removed
EDAC, fsl_ddr: Add support for little endian
EDAC, fsl_ddr: Add missing DDR DRAM types
EDAC, fsl_ddr: Rename macros and names
EDAC, fsl-ddr: Separate FSL DDR driver from MPC85xx
EDAC, mpc85xx: Replace printk() with pr_* format
EDAC, mpc85xx: Drop setting/clearing RFXE bit in HID1
EDAC, altera: Rename MC trigger to common name
EDAC, altera: Rename device trigger to common name
Pull irq updates from Thomas Gleixner:
"The irq departement proudly presents:
- A rework of the core infrastructure to optimally spread interrupt
for multiqueue devices. The first version was a bit naive and
failed to take thread siblings and other details into account.
Developed in cooperation with Christoph and Keith.
- Proper delegation of softirqs to ksoftirqd, so if ksoftirqd is
active then no further softirq processsing on interrupt return
happens. Otherwise we try to delegate and still run another batch
of network packets in the irq return path, which then tries to
delegate to ksoftirqd .....
- A proper machine parseable sysfs based alternative for
/proc/interrupts.
- ACPI support for the GICV3-ITS and ARM interrupt remapping
- Two new irq chips from the ARM SoC zoo: STM32-EXTI and MVEBU-PIC
- A new irq chip for the JCore (SuperH)
- The usual pile of small fixlets in core and irqchip drivers"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (42 commits)
softirq: Let ksoftirqd do its job
genirq: Make function __irq_do_set_handler() static
ARM/dts: Add EXTI controller node to stm32f429
ARM/STM32: Select external interrupts controller
drivers/irqchip: Add STM32 external interrupts support
Documentation/dt-bindings: Document STM32 EXTI controller bindings
irqchip/mips-gic: Use for_each_set_bit to iterate over local IRQs
pci/msi: Retrieve affinity for a vector
genirq/affinity: Remove old irq spread infrastructure
genirq/msi: Switch to new irq spreading infrastructure
genirq/affinity: Provide smarter irq spreading infrastructure
genirq/msi: Add cpumask allocation to alloc_msi_entry
genirq: Expose interrupt information through sysfs
irqchip/gicv3-its: Use MADT ITS subtable to do PCI/MSI domain initialization
irqchip/gicv3-its: Factor out PCI-MSI part that might be reused for ACPI
irqchip/gicv3-its: Probe ITS in the ACPI way
irqchip/gicv3-its: Refactor ITS DT init code to prepare for ACPI
irqchip/gicv3-its: Cleanup for ITS domain initialization
PCI/MSI: Setup MSI domain on a per-device basis using IORT ACPI table
ACPI: Add new IORT functions to support MSI domain handling
into irq/core
Pull irqchip core changes for v4.9 from Jason Cooper
- jcore: Add AIC driver
- mips-gic: Use for_each_set_bit
- mvebu: Add PIC driver
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/arm64
Pull "ZTE arm64 SoC changes for 4.9" from Shawn Guo:
- Add a Kconfig option for ZTE ZX SoC family support
* tag 'zte-soc64-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
This patch introduces ARCH_ZX to add the support of the ZTE ZX SoC
family for the arm64 architecture.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into next/arm64
Pull "Allwinner ARM64 Kconfig changes" from Maxime Ripard:
Select the pinctrl driver in kconfig
* tag 'sunxi-config64-for-4.9' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
into next/arm64
Pull "Broadcom soc-arm64 changes for 4.9" from Florian Fainelli:
This pull request contains Broadcom ARM64-based SoC changes for 4.9, please pull
the following:
- collective effort from Florian, Doug and Markus to add the ARCH_BRCMSTB Kconfig
symbol to the ARM64 kernel build, which is purposedly the same as the ARM/Linux
one in order not to update any driver dependencies
* tag 'arm-soc/for-4.9/soc-arm64' of http://github.com/Broadcom/stblinux:
into next/arm64
Pull "ARM64: hisilicon: defconfig updates for 4.9" from Wei Xu:
- Enable hisilicon SAS and XGE for hip05 and hip06
- Enable drm, powerkey, bluetooth and adv7511/adv7533 for hikey
- Add PINCTRL to HISI platform
* tag 'hisi-defconfig-for-4.9' of git://github.com/hisilicon/linux-hisi:
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/dt64
Pull "arm64: tegra: Device tree changes for v4.9-rc1" from Thierry Reding:
Add a couple of devices (AGIC, ADMA) on Tegra210 and enable them on
Smaug. Also enable DPAUX on Smaug to allow the I2C bus that shares pads
with the DPAUX to be used to access various audio devices. Furthermore,
enable the XUSB controller on Smaug for USB 3.0 support.
Finally, select PM_GENERIC_DOMAINS for 64-bit Tegra devices to make sure
devices are probed only after their power partitions have been enabled.
* tag 'tegra-for-4.9-arm64-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
arm64: tegra: Select PM_GENERIC_DOMAINS
arm64: tegra: Enable XUSB controller on Tegra210 Smaug
arm64: tegra: Add the various audio devices for Tegra210 Smaug
arm64: tegra: Enable DPAUX for Tegra210 Smaug
arm64: tegra: Add ACONNECT, ADMA and AGIC nodes Tegra210 Smaug
arm64: tegra: Add SOR power-domain for Tegra210
arm64: tegra: Add ADMA node for Tegra210
arm64: tegra: Add AGIC node for Tegra210
arm64: tegra: Drop clock and reset names for XUSB powergates
arm64: tegra: Simplify Tegra210 GPIO compatible value
Linux 4.8-rc2
Add DDR EDAC driver for ARM-based compatible controllers. Both
big-endian and little-endian are supported, as specified in device tree.
Signed-off-by: York Sun <york.sun@nxp.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/1471990465-27443-1-git-send-email-york.sun@nxp.com
Enable PM_GENERIC_DOMAINS for 64-bit Tegra devices. This is required to
ensure that devices dependent upon a particular power domain are probed
only after that power domain has been powered up.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Things won't work if PINCTRL isn't enabled,
so make sure to explicitly set it rather
then betting that we have some other platform
configed in which selects it.
Cc: Wei Xu <xuwei5@hisilicon.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
The pinctrl driver is essential for the Allwinner SoCs to work.
Add the driver's config symbol to the Kconfig entry to always compile
it in. We can't use the arm approach to make the _driver's_ Kconfig
symbol def_bool, because we lack the MACH_* symbols in arm64.
That line was in the original pinctrl driver patch, but got removed
to avoid the dependency on the Kconfig patch [1].
Also add the general PINCTRL symbol, which isn't selected automatically
for the same reason.
Reported-by: Jeroen Dekien <dekien@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[1]: http://lists.infradead.org/pipermail/linux-arm-kernel/2016-March/414086.html
This commit makes sure the driver for the Marvell PIC interrupt
controller (used on Marvell Armada 7K/8K) is enabled.
Link: https://lkml.kernel.org/r/1470408921-447-4-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
