This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit 61ae1321f06c4489c724c803e9b8363dea576da3 ]
Enable CPU vulnerabilty show functions for spectre_v1, spectre_v2,
meltdown and store-bypass.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Add Kconfig and DTS support for i.MX8QP with a simplified structure
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Squashed into a single commit during 4.14 rebase.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Add i.MX8QM/QXP/MQ support by default.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
commit f52bb98f5aded4c43e52f5ce19fb83f7261e9e73 upstream.
Commit 6d526ee26ccd ("arm64: mm: enable CONFIG_HOLES_IN_ZONE for NUMA")
only enabled HOLES_IN_ZONE for NUMA systems because the NUMA code was
choking on the missing zone for nomap pages. This problem doesn't just
apply to NUMA systems.
If the architecture doesn't set HAVE_ARCH_PFN_VALID, pfn_valid() will
return true if the pfn is part of a valid sparsemem section.
When working with multiple pages, the mm code uses pfn_valid_within()
to test each page it uses within the sparsemem section is valid. On
most systems memory comes in MAX_ORDER_NR_PAGES chunks which all
have valid/initialised struct pages. In this case pfn_valid_within()
is optimised out.
Systems where this isn't true (e.g. due to nomap) should set
HOLES_IN_ZONE and provide HAVE_ARCH_PFN_VALID so that mm tests each
page as it works with it.
Currently non-NUMA arm64 systems can't enable HOLES_IN_ZONE, leading to
a VM_BUG_ON():
| page:fffffdff802e1780 is uninitialized and poisoned
| raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
| page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p))
| ------------[ cut here ]------------
| kernel BUG at include/linux/mm.h:978!
| Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
| CPU: 1 PID: 25236 Comm: dd Not tainted 4.18.0 #7
| Hardware name: QEMU KVM Virtual Machine, BIOS 0.0.0 02/06/2015
| pstate: 40000085 (nZcv daIf -PAN -UAO)
| pc : move_freepages_block+0x144/0x248
| lr : move_freepages_block+0x144/0x248
| sp : fffffe0071177680
| Process dd (pid: 25236, stack limit = 0x0000000094cc07fb)
| Call trace:
| steal_suitable_fallback+0x100/0x16c
| get_page_from_freelist+0x440/0xb20
| __alloc_pages_nodemask+0xe8/0x838
| new_slab+0xd4/0x418
| ___slab_alloc.constprop.27+0x380/0x4a8
| __slab_alloc.isra.21.constprop.26+0x24/0x34
| kmem_cache_alloc+0xa8/0x180
| alloc_buffer_head+0x1c/0x90
| alloc_page_buffers+0x68/0xb0
| create_empty_buffers+0x20/0x1ec
| create_page_buffers+0xb0/0xf0
| __block_write_begin_int+0xc4/0x564
| __block_write_begin+0x10/0x18
| block_write_begin+0x48/0xd0
| blkdev_write_begin+0x28/0x30
| generic_perform_write+0x98/0x16c
| __generic_file_write_iter+0x138/0x168
| blkdev_write_iter+0x80/0xf0
| __vfs_write+0xe4/0x10c
| vfs_write+0xb4/0x168
| ksys_write+0x44/0x88
| sys_write+0xc/0x14
| el0_svc_naked+0x30/0x34
| Code: aa1303e0 90001a01 91296421 94008902 (d4210000)
| ---[ end trace 1601ba47f6e883fe ]---
Remove the NUMA dependency.
Link: https://www.spinics.net/lists/arm-kernel/msg671851.html
Cc: <stable@vger.kernel.org>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Pavel Tatashin <pavel.tatashin@microsoft.com>
Tested-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: James Morse <james.morse@arm.com>
commit a725e3dda1813ed306734823ac4c65ca04e38500 upstream.
As for Spectre variant-2, we rely on SMCCC 1.1 to provide the
discovery mechanism for detecting the SSBD mitigation.
A new capability is also allocated for that purpose, and a
config option.
Reviewed-by: Julien Grall <julien.grall@arm.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
commit ece1397cbc89c51914fae1aec729539cfd8bd62b upstream.
Some variants of the Arm Cortex-55 cores (r0p0, r0p1, r1p0) suffer
from an erratum 1024718, which causes incorrect updates when DBM/AP
bits in a page table entry is modified without a break-before-make
sequence. The work around is to skip enabling the hardware DBM feature
on the affected cores. The hardware Access Flag management features
is not affected. There are some other cores suffering from this
errata, which could be added to the midr_list to trigger the work
around.
Cc: ckadabi@codeaurora.org
Reviewed-by: Dave Martin <dave.martin@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Commit 0f15adbb2861 upstream.
Aliasing attacks against CPU branch predictors can allow an attacker to
redirect speculative control flow on some CPUs and potentially divulge
information from one context to another.
This patch adds initial skeleton code behind a new Kconfig option to
enable implementation-specific mitigations against these attacks for
CPUs that are affected.
Co-developed-by: Marc Zyngier <marc.zyngier@arm.com>
Commit 0617052ddde3 upstream.
Although CONFIG_UNMAP_KERNEL_AT_EL0 does make KASLR more robust, it's
actually more useful as a mitigation against speculation attacks that
can leak arbitrary kernel data to userspace through speculation.
Reword the Kconfig help message to reflect this, and make the option
depend on EXPERT so that it is on by default for the majority of users.
Commit 084eb77cd3a8 upstream.
Add a Kconfig entry to control use of the entry trampoline, which allows
us to unmap the kernel whilst running in userspace and improve the
robustness of KASLR.
Tested-by: Laura Abbott <labbott@redhat.com>
Tested-by: Shanker Donthineni <shankerd@codeaurora.org>
Commit d1777e686ad1 upstream.
We rely on an atomic swizzling of TTBR1 when transitioning from the entry
trampoline to the kernel proper on an exception. We can't rely on this
atomicity in the face of Falkor erratum #E1003, so on affected cores we
can issue a TLB invalidation to invalidate the walk cache prior to
jumping into the kernel. There is still the possibility of a TLB conflict
here due to conflicting walk cache entries prior to the invalidation, but
this doesn't appear to be the case on these CPUs in practice.
Commit 27a921e75711 upstream.
With the ASID now installed in TTBR1, we can re-enable ARM64_SW_TTBR0_PAN
by ensuring that we switch to a reserved ASID of zero when disabling
user access and restore the active user ASID on the uaccess enable path.
Commit 376133b7edc2 upstream.
We're about to rework the way ASIDs are allocated, switch_mm is
implemented and low-level kernel entry/exit is handled, so keep the
ARM64_SW_TTBR0_PAN code out of the way whilst we do the heavy lifting.
It will be re-enabled in a subsequent patch.
commit 932b50c7c1c65e6f23002e075b97ee083c4a9e71 upstream.
The ARM architecture defines the memory locations that are permitted
to be accessed as the result of a speculative instruction fetch from
an exception level for which all stages of translation are disabled.
Specifically, the core is permitted to speculatively fetch from the
4KB region containing the current program counter 4K and next 4K.
When translation is changed from enabled to disabled for the running
exception level (SCTLR_ELn[M] changed from a value of 1 to 0), the
Falkor core may errantly speculatively access memory locations outside
of the 4KB region permitted by the architecture. The errant memory
access may lead to one of the following unexpected behaviors.
1) A System Error Interrupt (SEI) being raised by the Falkor core due
to the errant memory access attempting to access a region of memory
that is protected by a slave-side memory protection unit.
2) Unpredictable device behavior due to a speculative read from device
memory. This behavior may only occur if the instruction cache is
disabled prior to or coincident with translation being changed from
enabled to disabled.
The conditions leading to this erratum will not occur when either of the
following occur:
1) A higher exception level disables translation of a lower exception level
(e.g. EL2 changing SCTLR_EL1[M] from a value of 1 to 0).
2) An exception level disabling its stage-1 translation if its stage-2
translation is enabled (e.g. EL1 changing SCTLR_EL1[M] from a value of 1
to 0 when HCR_EL2[VM] has a value of 1).
To avoid the errant behavior, software must execute an ISB immediately
prior to executing the MSR that will change SCTLR_ELn[M] from 1 to 0.
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
Cc: Timur Tabi <timur@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux into for-next/core
* 'arm64/vmap-stack' of git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux:
arm64: add VMAP_STACK overflow detection
arm64: add on_accessible_stack()
arm64: add basic VMAP_STACK support
arm64: use an irq stack pointer
arm64: assembler: allow adr_this_cpu to use the stack pointer
arm64: factor out entry stack manipulation
efi/arm64: add EFI_KIMG_ALIGN
arm64: move SEGMENT_ALIGN to <asm/memory.h>
arm64: clean up irq stack definitions
arm64: clean up THREAD_* definitions
arm64: factor out PAGE_* and CONT_* definitions
arm64: kernel: remove {THREAD,IRQ_STACK}_START_SP
fork: allow arch-override of VMAP stack alignment
arm64: remove __die()'s stack dump
This patch enables arm64 to be built with vmap'd task and IRQ stacks.
As vmap'd stacks are mapped at page granularity, stacks must be a multiple of
PAGE_SIZE. This means that a 64K page kernel must use stacks of at least 64K in
size.
To minimize the increase in Image size, IRQ stacks are dynamically allocated at
boot time, rather than embedding the boot CPU's IRQ stack in the kernel image.
This patch was co-authored by Ard Biesheuvel and Mark Rutland.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Cc: James Morse <james.morse@arm.com>
Implement the set of copy functions with guarantees of a clean cache
upon completion necessary to support the pmem driver.
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Add a clean-to-point-of-persistence cache maintenance helper, and wire
up the basic architectural support for the pmem driver based on it.
[catalin.marinas@arm.com: move arch_*_pmem() functions to arch/arm64/mm/flush.c]
[catalin.marinas@arm.com: change dmb(sy) to dmb(osh)]
This adds support for compiling with a rough equivalent to the glibc
_FORTIFY_SOURCE=1 feature, providing compile-time and runtime buffer
overflow checks for string.h functions when the compiler determines the
size of the source or destination buffer at compile-time. Unlike glibc,
it covers buffer reads in addition to writes.
GNU C __builtin_*_chk intrinsics are avoided because they would force a
much more complex implementation. They aren't designed to detect read
overflows and offer no real benefit when using an implementation based
on inline checks. Inline checks don't add up to much code size and
allow full use of the regular string intrinsics while avoiding the need
for a bunch of _chk functions and per-arch assembly to avoid wrapper
overhead.
This detects various overflows at compile-time in various drivers and
some non-x86 core kernel code. There will likely be issues caught in
regular use at runtime too.
Future improvements left out of initial implementation for simplicity,
as it's all quite optional and can be done incrementally:
* Some of the fortified string functions (strncpy, strcat), don't yet
place a limit on reads from the source based on __builtin_object_size of
the source buffer.
* Extending coverage to more string functions like strlcat.
* It should be possible to optionally use __builtin_object_size(x, 1) for
some functions (C strings) to detect intra-object overflows (like
glibc's _FORTIFY_SOURCE=2), but for now this takes the conservative
approach to avoid likely compatibility issues.
* The compile-time checks should be made available via a separate config
option which can be enabled by default (or always enabled) once enough
time has passed to get the issues it catches fixed.
Kees said:
"This is great to have. While it was out-of-tree code, it would have
blocked at least CVE-2016-3858 from being exploitable (improper size
argument to strlcpy()). I've sent a number of fixes for
out-of-bounds-reads that this detected upstream already"
[arnd@arndb.de: x86: fix fortified memcpy]
Link: http://lkml.kernel.org/r/20170627150047.660360-1-arnd@arndb.de
[keescook@chromium.org: avoid panic() in favor of BUG()]
Link: http://lkml.kernel.org/r/20170626235122.GA25261@beast
[keescook@chromium.org: move from -mm, add ARCH_HAS_FORTIFY_SOURCE, tweak Kconfig help]
Link: http://lkml.kernel.org/r/20170526095404.20439-1-danielmicay@gmail.com
Link: http://lkml.kernel.org/r/1497903987-21002-8-git-send-email-keescook@chromium.org
Signed-off-by: Daniel Micay <danielmicay@gmail.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Daniel Axtens <dja@axtens.net>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Merge misc updates from Andrew Morton:
- a few hotfixes
- various misc updates
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits)
mm, memory_hotplug: move movable_node to the hotplug proper
mm, memory_hotplug: drop CONFIG_MOVABLE_NODE
mm, memory_hotplug: drop artificial restriction on online/offline
mm: memcontrol: account slab stats per lruvec
mm: memcontrol: per-lruvec stats infrastructure
mm: memcontrol: use generic mod_memcg_page_state for kmem pages
mm: memcontrol: use the node-native slab memory counters
mm: vmstat: move slab statistics from zone to node counters
mm/zswap.c: delete an error message for a failed memory allocation in zswap_dstmem_prepare()
mm/zswap.c: improve a size determination in zswap_frontswap_init()
mm/zswap.c: delete an error message for a failed memory allocation in zswap_pool_create()
mm/swapfile.c: sort swap entries before free
mm/oom_kill: count global and memory cgroup oom kills
mm: per-cgroup memory reclaim stats
mm: kmemleak: treat vm_struct as alternative reference to vmalloc'ed objects
mm: kmemleak: factor object reference updating out of scan_block()
mm: kmemleak: slightly reduce the size of some structures on 64-bit architectures
mm, mempolicy: don't check cpuset seqlock where it doesn't matter
mm, cpuset: always use seqlock when changing task's nodemask
mm, mempolicy: simplify rebinding mempolicies when updating cpusets
Pull KVM updates from Paolo Bonzini:
"PPC:
- Better machine check handling for HV KVM
- Ability to support guests with threads=2, 4 or 8 on POWER9
- Fix for a race that could cause delayed recognition of signals
- Fix for a bug where POWER9 guests could sleep with interrupts pending.
ARM:
- VCPU request overhaul
- allow timer and PMU to have their interrupt number selected from userspace
- workaround for Cavium erratum 30115
- handling of memory poisonning
- the usual crop of fixes and cleanups
s390:
- initial machine check forwarding
- migration support for the CMMA page hinting information
- cleanups and fixes
x86:
- nested VMX bugfixes and improvements
- more reliable NMI window detection on AMD
- APIC timer optimizations
Generic:
- VCPU request overhaul + documentation of common code patterns
- kvm_stat improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (124 commits)
Update my email address
kvm: vmx: allow host to access guest MSR_IA32_BNDCFGS
x86: kvm: mmu: use ept a/d in vmcs02 iff used in vmcs12
kvm: x86: mmu: allow A/D bits to be disabled in an mmu
x86: kvm: mmu: make spte mmio mask more explicit
x86: kvm: mmu: dead code thanks to access tracking
KVM: PPC: Book3S: Fix typo in XICS-on-XIVE state saving code
KVM: PPC: Book3S HV: Close race with testing for signals on guest entry
KVM: PPC: Book3S HV: Simplify dynamic micro-threading code
KVM: x86: remove ignored type attribute
KVM: LAPIC: Fix lapic timer injection delay
KVM: lapic: reorganize restart_apic_timer
KVM: lapic: reorganize start_hv_timer
kvm: nVMX: Check memory operand to INVVPID
KVM: s390: Inject machine check into the nested guest
KVM: s390: Inject machine check into the guest
tools/kvm_stat: add new interactive command 'b'
tools/kvm_stat: add new command line switch '-i'
tools/kvm_stat: fix error on interactive command 'g'
KVM: SVM: suppress unnecessary NMI singlestep on GIF=0 and nested exit
This moves the #ifdef in C code to a Kconfig dependency. Also we move
the gigantic_page_supported() function to be arch specific.
This allows architectures to conditionally enable runtime allocation of
gigantic huge page. Architectures like ppc64 supports different
gigantic huge page size (16G and 1G) based on the translation mode
selected. This provides an opportunity for ppc64 to enable runtime
allocation only w.r.t 1G hugepage.
No functional change in this patch.
Link: http://lkml.kernel.org/r/1494995292-4443-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- RAS reporting via GHES/APEI (ACPI)
- Indirect ftrace trampolines for modules
- Improvements to kernel fault reporting
- Page poisoning
- Sigframe cleanups and preparation for SVE context
- Core dump fixes
- Sparse fixes (mainly relating to endianness)
- xgene SoC PMU v3 driver
- Misc cleanups and non-critical fixes
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (75 commits)
arm64: fix endianness annotation for 'struct jit_ctx' and friends
arm64: cpuinfo: constify attribute_group structures.
arm64: ptrace: Fix incorrect get_user() use in compat_vfp_set()
arm64: ptrace: Remove redundant overrun check from compat_vfp_set()
arm64: ptrace: Avoid setting compat FP[SC]R to garbage if get_user fails
arm64: fix endianness annotation for __apply_alternatives()/get_alt_insn()
arm64: fix endianness annotation in get_kaslr_seed()
arm64: add missing conversion to __wsum in ip_fast_csum()
arm64: fix endianness annotation in acpi_parking_protocol.c
arm64: use readq() instead of readl() to read 64bit entry_point
arm64: fix endianness annotation for reloc_insn_movw() & reloc_insn_imm()
arm64: fix endianness annotation for aarch64_insn_write()
arm64: fix endianness annotation in aarch64_insn_read()
arm64: fix endianness annotation in call_undef_hook()
arm64: fix endianness annotation for debug-monitors.c
ras: mark stub functions as 'inline'
arm64: pass endianness info to sparse
arm64: ftrace: fix !CONFIG_ARM64_MODULE_PLTS kernels
arm64: signal: Allow expansion of the signal frame
acpi: apei: check for pending errors when probing GHES entries
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the big driver core update for 4.13-rc1.
The large majority of this is a lot of cleanup of old fields in the
driver core structures and their remaining usages in random drivers.
All of those fixes have been reviewed by the various subsystem
maintainers. There's also some small firmware updates in here, a new
kobject uevent api interface that makes userspace interaction easier,
and a few other minor things.
All of these have been in linux-next for a long while with no reported
issues"
* tag 'driver-core-4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (56 commits)
arm: mach-rpc: ecard: fix build error
zram: convert remaining CLASS_ATTR() to CLASS_ATTR_RO()
driver-core: remove struct bus_type.dev_attrs
powerpc: vio_cmo: use dev_groups and not dev_attrs for bus_type
powerpc: vio: use dev_groups and not dev_attrs for bus_type
USB: usbip: convert to use DRIVER_ATTR_RW
s390: drivers: convert to use DRIVER_ATTR_RO/WO
platform: thinkpad_acpi: convert to use DRIVER_ATTR_RO/RW
pcmcia: ds: convert to use DRIVER_ATTR_RO
wireless: ipw2x00: convert to use DRIVER_ATTR_RW
net: ehea: convert to use DRIVER_ATTR_RO
net: caif: convert to use DRIVER_ATTR_RO
TTY: hvc: convert to use DRIVER_ATTR_RW
PCI: pci-driver: convert to use DRIVER_ATTR_WO
IB: nes: convert to use DRIVER_ATTR_RW
HID: hid-core: convert to use DRIVER_ATTR_RO and drv_groups
arm: ecard: fix dev_groups patch typo
tty: serdev: use dev_groups and not dev_attrs for bus_type
sparc: vio: use dev_groups and not dev_attrs for bus_type
hid: intel-ish-hid: use dev_groups and not dev_attrs for bus_type
Merge in arm64 ACPI RAS support (APEI/GHES) from Tyler Baicar.
ARM APEI extension proposal added SEA (Synchronous External Abort)
notification type for ARMv8.
Add a new GHES error source handling function for SEA. If an error
source's notification type is SEA, then this function can be registered
into the SEA exception handler. That way GHES will parse and report
SEA exceptions when they occur.
An SEA can interrupt code that had interrupts masked and is treated as
an NMI. To aid this the page of address space for mapping APEI buffers
while in_nmi() is always reserved, and ghes_ioremap_pfn_nmi() is
changed to use the helper methods to find the prot_t to map with in
the same way as ghes_ioremap_pfn_irq().
Signed-off-by: Tyler Baicar <tbaicar@codeaurora.org>
CC: Jonathan (Zhixiong) Zhang <zjzhang@codeaurora.org>
Reviewed-by: James Morse <james.morse@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
To avoid issues with the /proc/kcore code getting confused about the
kernels block mappings in the VMALLOC region, enable the existing
facility that describes the [_text, _end) interval as a separate
KCORE_TEXT region, which supersedes the KCORE_VMALLOC region that
it intersects with on arm64.
Reported-by: Tan Xiaojun <tanxiaojun@huawei.com>
Tested-by: Tan Xiaojun <tanxiaojun@huawei.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Reviewed-by: Jiri Olsa <jolsa@kernel.org>
ACPI IORT is an ACPI addendum to describe the connection topology of
devices with IOMMUs and interrupt controllers on ARM64 ACPI systems.
Currently the ACPI IORT Kbuild symbol is selected whenever the Kbuild
symbol ARM_GIC_V3_ITS is enabled, which in turn is selected by ARM64
Kbuild defaults. This makes the logic behind ACPI_IORT selection a bit
twisted and not easy to follow. On ARM64 systems enabling ACPI the
kbuild symbol ACPI_IORT should always be selected in that it is a kernel
layer provided to the ARM64 arch code to parse and enable ACPI firmware
bindings.
Make the ACPI_IORT selection explicit in ARM64 Kbuild and remove the
selection from ARM_GIC_V3_ITS entry, making the ACPI_IORT selection
logic clearer to follow.
Acked-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Some Cavium Thunder CPUs suffer a problem where a KVM guest may
inadvertently cause the host kernel to quit receiving interrupts.
Use the Group-0/1 trapping in order to deal with it.
[maz]: Adapted patch to the Group-0/1 trapping, reworked commit log
Tested-by: Alexander Graf <agraf@suse.de>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Christoffer Dall <cdall@linaro.org>
This patch provides all required callbacks required by the generic
get_user_pages_fast() code and switches x86 over - and removes
the platform specific implementation.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20170606113133.22974-2-kirill.shutemov@linux.intel.com
Declare ARCH_SUPPORTS_MEMORY_FAILURE, as arm64 does support
memory failure recovery attempt.
Signed-off-by: Jonathan (Zhixiong) Zhang <zjzhang@codeaurora.org>
(Dropped changes to ACPI APEI Kconfig and updated commit log)
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Steve Capper <steve.capper@arm.com>
Tested-by: Manoj Iyer <manoj.iyer@canonical.com>
CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for
several 64-bit architectures : mips, parisc, tile.
At the moment and for those architectures, calling in 32-bit userspace the
keyctl syscall would return an ENOSYS error.
This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to
make sure the compatibility wrapper is registered by default for any 64-bit
architecture as long as it is configured with CONFIG_COMPAT.
[DH: Modified to remove arm64 compat enablement also as requested by Eric
Biggers]
Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
cc: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Currently, dynamic ftrace support in the arm64 kernel assumes that all
core kernel code is within range of ordinary branch instructions that
occur in module code, which is usually the case, but is no longer
guaranteed now that we have support for module PLTs and address space
randomization.
Since on arm64, all patching of branch instructions involves function
calls to the same entry point [ftrace_caller()], we can emit the modules
with a trampoline that has unlimited range, and patch both the trampoline
itself and the branch instruction to redirect the call via the trampoline.
[will: minor clarification to smp_wmb() comment]
arm and arm64 share lot of code relative to parsing CPU capacity
information from DT, using that information for appropriate scaling and
exposing a sysfs interface for chaging such values at runtime.
Factorize such code in a common place (driver/base/arch_topology.c) in
preparation for further additions.
Suggested-by: Will Deacon <will.deacon@arm.com>
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Pull arm64 updates from Catalin Marinas:
- kdump support, including two necessary memblock additions:
memblock_clear_nomap() and memblock_cap_memory_range()
- ARMv8.3 HWCAP bits for JavaScript conversion instructions, complex
numbers and weaker release consistency
- arm64 ACPI platform MSI support
- arm perf updates: ACPI PMU support, L3 cache PMU in some Qualcomm
SoCs, Cortex-A53 L2 cache events and DTLB refills, MAINTAINERS update
for DT perf bindings
- architected timer errata framework (the arch/arm64 changes only)
- support for DMA_ATTR_FORCE_CONTIGUOUS in the arm64 iommu DMA API
- arm64 KVM refactoring to use common system register definitions
- remove support for ASID-tagged VIVT I-cache (no ARMv8 implementation
using it and deprecated in the architecture) together with some
I-cache handling clean-up
- PE/COFF EFI header clean-up/hardening
- define BUG() instruction without CONFIG_BUG
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits)
arm64: Fix the DMA mmap and get_sgtable API with DMA_ATTR_FORCE_CONTIGUOUS
arm64: Print DT machine model in setup_machine_fdt()
arm64: pmu: Wire-up Cortex A53 L2 cache events and DTLB refills
arm64: module: split core and init PLT sections
arm64: pmuv3: handle pmuv3+
arm64: Add CNTFRQ_EL0 trap handler
arm64: Silence spurious kbuild warning on menuconfig
arm64: pmuv3: use arm_pmu ACPI framework
arm64: pmuv3: handle !PMUv3 when probing
drivers/perf: arm_pmu: add ACPI framework
arm64: add function to get a cpu's MADT GICC table
drivers/perf: arm_pmu: split out platform device probe logic
drivers/perf: arm_pmu: move irq request/free into probe
drivers/perf: arm_pmu: split cpu-local irq request/free
drivers/perf: arm_pmu: rename irq request/free functions
drivers/perf: arm_pmu: handle no platform_device
drivers/perf: arm_pmu: simplify cpu_pmu_request_irqs()
drivers/perf: arm_pmu: factor out pmu registration
drivers/perf: arm_pmu: fold init into alloc
drivers/perf: arm_pmu: define armpmu_init_fn
Pull timer updates from Thomas Gleixner:
"The timer departement delivers:
- more year 2038 rework
- a massive rework of the arm achitected timer
- preparatory patches to allow NTP correction of clock event devices
to avoid early expiry
- the usual pile of fixes and enhancements all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits)
timer/sysclt: Restrict timer migration sysctl values to 0 and 1
arm64/arch_timer: Mark errata handlers as __maybe_unused
Clocksource/mips-gic: Remove redundant non devicetree init
MIPS/Malta: Probe gic-timer via devicetree
clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK
acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver
clocksource: arm_arch_timer: add GTDT support for memory-mapped timer
acpi/arm64: Add memory-mapped timer support in GTDT driver
clocksource: arm_arch_timer: simplify ACPI support code.
acpi/arm64: Add GTDT table parse driver
clocksource: arm_arch_timer: split MMIO timer probing.
clocksource: arm_arch_timer: add structs to describe MMIO timer
clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call
clocksource: arm_arch_timer: refactor arch_timer_needs_probing
clocksource: arm_arch_timer: split dt-only rate handling
x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks
unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks
um/time: Set ->min_delta_ticks and ->max_delta_ticks
tile/time: Set ->min_delta_ticks and ->max_delta_ticks
score/time: Set ->min_delta_ticks and ->max_delta_ticks
all architectures converted
'uaccess.arm64', 'uaccess.avr32', 'uaccess.bfin', 'uaccess.c6x', 'uaccess.cris', 'uaccess.frv', 'uaccess.h8300', 'uaccess.hexagon', 'uaccess.ia64', 'uaccess.m32r', 'uaccess.m68k', 'uaccess.metag', 'uaccess.microblaze', 'uaccess.mips', 'uaccess.mn10300', 'uaccess.nios2', 'uaccess.openrisc', 'uaccess.parisc', 'uaccess.powerpc', 'uaccess.s390', 'uaccess.score', 'uaccess.sh', 'uaccess.sparc', 'uaccess.tile', 'uaccess.um', 'uaccess.unicore32', 'uaccess.x86' and 'uaccess.xtensa' into work.uaccess
This patch adds support for parsing arch timer info in GTDT,
provides some kernel APIs to parse all the PPIs and
always-on info in GTDT and export them.
By this driver, we can simplify arm_arch_timer drivers, and
separate the ACPI GTDT knowledge from it.
Signed-off-by: Fu Wei <fu.wei@linaro.org>
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Tested-by: Xiongfeng Wang <wangxiongfeng2@huawei.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Arch-specific functions are added to allow for implementing a crash dump
file interface, /proc/vmcore, which can be viewed as a ELF file.
A user space tool, like kexec-tools, is responsible for allocating
a separate region for the core's ELF header within crash kdump kernel
memory and filling it in when executing kexec_load().
Then, its location will be advertised to crash dump kernel via a new
device-tree property, "linux,elfcorehdr", and crash dump kernel preserves
the region for later use with reserve_elfcorehdr() at boot time.
On crash dump kernel, /proc/vmcore will access the primary kernel's memory
with copy_oldmem_page(), which feeds the data page-by-page by ioremap'ing
it since it does not reside in linear mapping on crash dump kernel.
Meanwhile, elfcorehdr_read() is simple as the region is always mapped.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Pull arm64 fixes/cleanups from Catalin Marinas:
"In Will's absence I'm sending the arm64 fixes he queued for 4.11-rc3:
- fix arm64 kernel boot warning when DEBUG_VIRTUAL and KASAN are
enabled
- enable KEYS_COMPAT for keyctl compat support
- use cpus_have_const_cap() for system_uses_ttbr0_pan() (slight
performance improvement)
- update kerneldoc for cpu_suspend() rename
- remove the arm64-specific kprobe_exceptions_notify (weak generic
variant defined)"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: kernel: Update kerneldoc for cpu_suspend() rename
arm64: use const cap for system_uses_ttbr0_pan()
arm64: support keyctl() system call in 32-bit mode
arm64: kasan: avoid bad virt_to_pfn()
arm64: kprobes: remove kprobe_exceptions_notify
As is the case for a number of other architectures that have a 32-bit
compat mode, enable KEYS_COMPAT if both COMPAT and KEYS are enabled.
This allows AArch32 programs to use the keyctl() system call when
running on an AArch64 kernel.
On Qualcomm Datacenter Technologies QDF2400 SoCs, the ITS hardware
implementation uses 16Bytes for Interrupt Translation Entry (ITE),
but reports an incorrect value of 8Bytes in GITS_TYPER.ITTE_size.
It might cause kernel memory corruption depending on the number
of MSI(x) that are configured and the amount of memory that has
been allocated for ITEs in its_create_device().
This patch fixes the potential memory corruption by setting the
correct ITE size to 16Bytes.
Cc: stable@vger.kernel.org
- Errata workarounds for Qualcomm's Falkor CPU
- Qualcomm L2 Cache PMU driver
- Qualcomm SMCCC firmware quirk
- Support for DEBUG_VIRTUAL
- CPU feature detection for userspace via MRS emulation
- Preliminary work for the Statistical Profiling Extension
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (74 commits)
arm64/kprobes: consistently handle MRS/MSR with XZR
arm64: cpufeature: correctly handle MRS to XZR
arm64: traps: correctly handle MRS/MSR with XZR
arm64: ptrace: add XZR-safe regs accessors
arm64: include asm/assembler.h in entry-ftrace.S
arm64: fix warning about swapper_pg_dir overflow
arm64: Work around Falkor erratum 1003
arm64: head.S: Enable EL1 (host) access to SPE when entered at EL2
arm64: arch_timer: document Hisilicon erratum 161010101
arm64: use is_vmalloc_addr
arm64: use linux/sizes.h for constants
arm64: uaccess: consistently check object sizes
perf: add qcom l2 cache perf events driver
arm64: remove wrong CONFIG_PROC_SYSCTL ifdef
ARM: smccc: Update HVC comment to describe new quirk parameter
arm64: do not trace atomic operations
ACPI/IORT: Fix the error return code in iort_add_smmu_platform_device()
ACPI/IORT: Fix iort_node_get_id() mapping entries indexing
perf: xgene: Include module.h
Pull networking updates from David Miller:
"Highlights:
1) Support TX_RING in AF_PACKET TPACKET_V3 mode, from Sowmini
Varadhan.
2) Simplify classifier state on sk_buff in order to shrink it a bit.
From Willem de Bruijn.
3) Introduce SIPHASH and it's usage for secure sequence numbers and
syncookies. From Jason A. Donenfeld.
4) Reduce CPU usage for ICMP replies we are going to limit or
suppress, from Jesper Dangaard Brouer.
5) Introduce Shared Memory Communications socket layer, from Ursula
Braun.
6) Add RACK loss detection and allow it to actually trigger fast
recovery instead of just assisting after other algorithms have
triggered it. From Yuchung Cheng.
7) Add xmit_more and BQL support to mvneta driver, from Simon Guinot.
8) skb_cow_data avoidance in esp4 and esp6, from Steffen Klassert.
9) Export MPLS packet stats via netlink, from Robert Shearman.
10) Significantly improve inet port bind conflict handling, especially
when an application is restarted and changes it's setting of
reuseport. From Josef Bacik.
11) Implement TX batching in vhost_net, from Jason Wang.
12) Extend the dummy device so that VF (virtual function) features,
such as configuration, can be more easily tested. From Phil
Sutter.
13) Avoid two atomic ops per page on x86 in bnx2x driver, from Eric
Dumazet.
14) Add new bpf MAP, implementing a longest prefix match trie. From
Daniel Mack.
15) Packet sample offloading support in mlxsw driver, from Yotam Gigi.
16) Add new aquantia driver, from David VomLehn.
17) Add bpf tracepoints, from Daniel Borkmann.
18) Add support for port mirroring to b53 and bcm_sf2 drivers, from
Florian Fainelli.
19) Remove custom busy polling in many drivers, it is done in the core
networking since 4.5 times. From Eric Dumazet.
20) Support XDP adjust_head in virtio_net, from John Fastabend.
21) Fix several major holes in neighbour entry confirmation, from
Julian Anastasov.
22) Add XDP support to bnxt_en driver, from Michael Chan.
23) VXLAN offloads for enic driver, from Govindarajulu Varadarajan.
24) Add IPVTAP driver (IP-VLAN based tap driver) from Sainath Grandhi.
25) Support GRO in IPSEC protocols, from Steffen Klassert"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1764 commits)
Revert "ath10k: Search SMBIOS for OEM board file extension"
net: socket: fix recvmmsg not returning error from sock_error
bnxt_en: use eth_hw_addr_random()
bpf: fix unlocking of jited image when module ronx not set
arch: add ARCH_HAS_SET_MEMORY config
net: napi_watchdog() can use napi_schedule_irqoff()
tcp: Revert "tcp: tcp_probe: use spin_lock_bh()"
net/hsr: use eth_hw_addr_random()
net: mvpp2: enable building on 64-bit platforms
net: mvpp2: switch to build_skb() in the RX path
net: mvpp2: simplify MVPP2_PRS_RI_* definitions
net: mvpp2: fix indentation of MVPP2_EXT_GLOBAL_CTRL_DEFAULT
net: mvpp2: remove unused register definitions
net: mvpp2: simplify mvpp2_bm_bufs_add()
net: mvpp2: drop useless fields in mvpp2_bm_pool and related code
net: mvpp2: remove unused 'tx_skb' field of 'struct mvpp2_tx_queue'
net: mvpp2: release reference to txq_cpu[] entry after unmapping
net: mvpp2: handle too large value in mvpp2_rx_time_coal_set()
net: mvpp2: handle too large value handling in mvpp2_rx_pkts_coal_set()
net: mvpp2: remove useless arguments in mvpp2_rx_{pkts, time}_coal_set
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull rodata updates from Kees Cook:
"This renames the (now inaccurate) DEBUG_RODATA and related
SET_MODULE_RONX configs to the more sensible STRICT_KERNEL_RWX and
STRICT_MODULE_RWX"
* tag 'rodata-v4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
arch: Rename CONFIG_DEBUG_RODATA and CONFIG_DEBUG_MODULE_RONX
arch: Move CONFIG_DEBUG_RODATA and CONFIG_SET_MODULE_RONX to be common
Currently, there's no good way to test for the presence of
set_memory_ro/rw/x/nx() helpers implemented by archs such as
x86, arm, arm64 and s390.
There's DEBUG_SET_MODULE_RONX and DEBUG_RODATA, however both
don't really reflect that: set_memory_*() are also available
even when DEBUG_SET_MODULE_RONX is turned off, and DEBUG_RODATA
is set by parisc, but doesn't implement above functions. Thus,
add ARCH_HAS_SET_MEMORY that is selected by mentioned archs,
where generic code can test against this.
This also allows later on to move DEBUG_SET_MODULE_RONX out of
the arch specific Kconfig to define it only once depending on
ARCH_HAS_SET_MEMORY.
Suggested-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
