path: root/arch/arm64/boot/dts/al/alpine-v2.dtsi
2019-01-30arm64: dts: Remove inconsistent use of 'arm,armv8' compatible stringRob Herring
The 'arm,armv8' compatible string is only for software models. It adds little value otherwise and is inconsistently used as a fallback on some platforms. Remove it from those platforms. This fixes warnings generated by the DT schema. Reported-by: Michal Simek <michal.simek@xilinx.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Acked-by: Antoine Tenart <antoine.tenart@bootlin.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Acked-by: Chanho Min <chanho.min@lge.com> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Gregory CLEMENT <gregory.clement@bootlin.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Tero Kristo <t-kristo@ti.com> Acked-by: Wei Xu <xuwei5@hisilicon.com> Acked-by: Liviu Dudau <liviu.dudau@arm.com> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Scott Branden <scott.branden@broadcom.com> Acked-by: Kevin Hilman <khilman@baylibre.com> Acked-by: Chunyan Zhang <zhang.lyra@gmail.com> Acked-by: Robert Richter <rrichter@cavium.com> Acked-by: Jisheng Zhang <Jisheng.Zhang@synaptics.com> Acked-by: Dinh Nguyen <dinguyen@kernel.org> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-02-26arm64: dts: alpine: add the MSIX node in the Alpine v2 dtsiAntoine Tenart
Following the addition of the Alpine MSIX controller driver, add the corresponding node in the Alpine v2 device tree. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Tsahee Zidenberg <tsahee@annapurnalabs.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-02-26arm64: dts: add the Alpine v2 EVPAntoine Tenart
This patch adds the initial support for the Alpine v2 EVP board from Annapurna Labs (Amazon). Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Barak Wasserstrom <barak@annapurnalabs.com> Signed-off-by: Tsahee Zidenberg <tsahee@annapurnalabs.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
