The dprX_channelY, pixel-combiner and prgX nodes need to be enabled
to use the g2d functionality.
Thus move those nodes into the common fsl-imx8qxp-colibri-eval-v3.dtsi, so that
fsl-imx8qxp-colibri-eval-v3.dts also gets them enabled.
NXP driver gpio-mxc requires to set gpio pad properly up
to use it as wakeup source.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Replace legacy gpio-key,wakeup property with wakeup-source one.
Just a tiny cosmetic fix.
Make panel definition generic and default to VESA VGA display timings.
For fsl-imx8qxp-colibri-lvds-single-eval-v3.dts now use
logictechno,lt170410-2whc compatible which is the panel inside our
Capacitive Touch Display 10.1" LVDS.
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
This fixes the following error during boot:
[ 1.588204] fsl_lpspi 5a020000.lpspi: chipselect 0 already in use
[ 1.594461] spi_master spi0: spi_device register error
/lpspi@5a020000/spidev@0
[ 1.601850] spi_master spi0: Failed to create SPI device for
- Remove Lontium V1.0 board settings
- Disable RGB display
- Add eval.dtsi
And remove unnecessary enabled hardware
This commit only creates fsl-imx8qxp-colibri-eval-v3.dtsi and moves
code.
It does not change code.
gpio_bl_on is used as output to enable linked consumers of eLCDIF: panel or
bridge. Fix pinmux mode for this pin.
Add VDD regulator for VGA encoder ADV7125.
Related to: #42565
Copied from toradex_imx_4.14.78_1.0.0_ga-bring_up.
