This is the 5.4.148 stable release
- drivers/dma/imx-sdma.c:
Following upstream patches are already applied to NXP tree:
7cfbf391e870 ("dmaengine: imx-sdma: remove duplicated sdma_load_context")
788122c99d85 ("Revert "dmaengine: imx-sdma: refine to load context only
once"")
- drivers/usb/chipidea/host.c:
Merge upstream commit a18cfd715e91 ("usb: chipidea: host: fix port index
underflow and UBSAN complains") to NXP version.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
[ Upstream commit c1a6018d1839c9cb8f807dc863a50102a1a5c412 ]
ls1046afrwy and ls1046ardb boards have CAT24C04[1] and CAT24C05[2]
eeproms respectively. Both are 4Kb (512 bytes) in size,
and compatible with AT24C04[3].
Remove multi-address entries, as both the boards have a single chip each.
[1] https://www.onsemi.com/pdf/datasheet/cat24c01-d.pdf
[2] https://www.onsemi.com/pdf/datasheet/cat24c03-d.pdf
[3] https://ww1.microchip.com/downloads/en/DeviceDoc/doc0180.pdf
Signed-off-by: Raag Jadav <raagjadav@gmail.com>
Acked-by: Li Yang <leoyang.li@nxp.com>
add micron nor flash support for ls1046a frwy board.
Signed-off-by: Ashish Kumar <ashish.kumar@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
ls1046afrwy board is based on nxp ls1046a SoC.
Board support's 4GB ddr memory, i2c, microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
