This is the 5.4.109 stable release
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit 9c3a16f88385e671b63a0de7b82b85e604a80f42 upstream.
Crypto engine (CAAM) on LS1046A platform is configured HW-coherent,
mark accordingly the DT node.
As reported by Greg and Sascha, and explained by Robin, lack of
"dma-coherent" property for an IP that is configured HW-coherent
can lead to problems, e.g. on v5.11:
> kernel BUG at drivers/crypto/caam/jr.c:247!
> Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
> Modules linked in:
> CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.11.0-20210225-3-00039-g434215968816-dirty #12
> Hardware name: TQ TQMLS1046A SoM on Arkona AT1130 (C300) board (DT)
> pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
> pc : caam_jr_dequeue+0x98/0x57c
> lr : caam_jr_dequeue+0x98/0x57c
> sp : ffff800010003d50
> x29: ffff800010003d50 x28: ffff8000118d4000
> x27: ffff8000118d4328 x26: 00000000000001f0
> x25: ffff0008022be480 x24: ffff0008022c6410
> x23: 00000000000001f1 x22: ffff8000118d4329
> x21: 0000000000004d80 x20: 00000000000001f1
> x19: 0000000000000001 x18: 0000000000000020
> x17: 0000000000000000 x16: 0000000000000015
> x15: ffff800011690230 x14: 2e2e2e2e2e2e2e2e
> x13: 2e2e2e2e2e2e2020 x12: 3030303030303030
> x11: ffff800011700a38 x10: 00000000fffff000
> x9 : ffff8000100ada30 x8 : ffff8000116a8a38
> x7 : 0000000000000001 x6 : 0000000000000000
> x5 : 0000000000000000 x4 : 0000000000000000
> x3 : 00000000ffffffff x2 : 0000000000000000
> x1 : 0000000000000000 x0 : 0000000000001800
> Call trace:
> tasklet_action_common.constprop.0+0x164/0x18c
> tasklet_action+0x44/0x54
> __do_softirq+0x160/0x454
> __irq_exit_rcu+0x164/0x16c
> irq_exit+0x1c/0x30
> __handle_domain_irq+0xc0/0x13c
> gic_handle_irq+0x5c/0xf0
> el1_irq+0xb4/0x180
> arch_cpu_idle+0x18/0x30
> default_idle_call+0x3c/0x1c0
> do_idle+0x23c/0x274
> cpu_startup_entry+0x34/0x70
> rest_init+0xdc/0xec
> arch_call_rest_init+0x1c/0x28
> start_kernel+0x4ac/0x4e4
> Code: 91392021 912c2000 d377d8c6 97f24d96 (d4210000)
Cc: <stable@vger.kernel.org> # v4.10+
Fixes: 8126d88162a5 ("arm64: dts: add QorIQ LS1046A SoC support")
Link: https://lore.kernel.org/linux-crypto/fe6faa24-d8f7-d18f-adfa-44fa0caa1598@arm.com
Reported-by: Greg Ungerer <gerg@kernel.org>
Reported-by: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
Acked-by: Greg Ungerer <gerg@kernel.org>
Acked-by: Li Yang <leoyang.li@nxp.com>
[ Upstream commit aa880c6f3ee6dbd0d5ab02026a514ff8ea0a3328 ]
Dcfg was overlapping with clockgen address space which resulted
in failure in memory allocation for dcfg. According regs description
dcfg size should not be bigger than 4KB.
Signed-off-by: Zyta Szpak <zr@semihalf.com>
Since dwc3 cache type has been set to cacheable, apply dma-coherent to
all dwc3 nodes accordingly.
Note: For LS1043A and LS1046A, since QE-HDLC still doesn't support
dma-coherent, we cannot directly revert cd1a4f3c (sdk: dts: ls104x move
dma-coherent from soc to its child nodes) to recover dma-coherent for
soc.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
nodes
To allow USB dwc3 driver to conduct some chip-scpeific configuring.
Cover all arm64 based Layerscape SoCs.
Reviewed-by: Jun Li <jun.li@nxp.com>
Reviewed-by: Leo Li <leo.li@nxp.com>
ftm_alarm0
The patch replaces ftm0 with ftm_alarm0 DT node
- replace ftm0 with ftm_alarm0
- add new rcpm node
- remove old rcpm node
- aliases ftm_alarm0 as rtc1
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Remove entire backplane support from device tree for all supported platforms
Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com>
Cover LS1012A, LS1043A, LS1046A, LS1088A, LS208xA, LX2160A
Limit the dma mask size for sata to 40 bits to match the actual address
size generated towards the interconnect. Re-use the already existing
auxiliary simple bus meant for usb but drop the usb reference from the
node name.
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
To enable all the supported thermal sensors, add sensor id information
to thermal zone node.
Dts for ls1012a, ls1046a, ls1043a, ls1088a are updated.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Wrap the usb controllers in an intermediate simple-bus and use it to
constrain the dma address size of these usb controllers to the 40 bits
that they generate toward the interconnect.
This is required because the SoC uses 48 bits address sizes and this
mismatch would lead to smmu context faults because the usb generates
40-bit addresses while the smmu page tables are populated with 48-bit
wide addresses.
Suggested-by: Robin Murphy <robin.murphy@arm.com>
These SoCs are really completely dma coherent in their entirety so add
the dma-coherent property at the soc level in the device tree and drop
the instances where it's specifically added to a few select devices.
The pci controllers are also behind the smmu so add the iommu-map
property to reflect this. The bootloader needs to patch the stream id
ranges to some sane values.
These chips have a 48-bit address size so make sure that the dma-ranges
reflects this. Otherwise the linux kernel's dma sub-system will set
the default dma masks to full 64-bit, badly breaking dmas.
The StreamID entering the SMMU is actually a concatenation of the
SMMU TBU ID and the ICID configured in software.
Since the TBU ID is internal to the SoC and since we want that the
actual the ICID configured in software to enter the SMMU witout any
additional set bits, mask out the TBU ID bits and leave only the
relevant ICID bits to enter SMMU.
This allows for the SMMU device to be probed by the SMMU kernel driver.
commit 118e2f48ee8da3f5547c24888bd6fdb78f03b7ce
Author: Peng Ma <peng.ma@nxp.com>
Date: Wed Jul 25 08:53:07 2018 +0000
dts: fsl-ls1021a, fsl-ls1043a, fsl-ls1046a: add multi block node
support
add block-offset to support different virtual block offset for qdma
base on soc;
the interrupt named "qdma-queueN(N:0,1,2,3)" correspond to a virtual
block,N based on block number of qdma;
Signed-off-by: Peng Ma <peng.ma@nxp.com>
commit 46123df3a174f0d76c8b954a0386e64841453836
Author: Florinel Iordache <florinel.iordache@nxp.com>
Date: Thu Aug 9 12:29:18 2018 +0300
arm64: dts: updates for Unified Backplane driver
commit c08136017e8b18eb58b153129487c5dc760afd20
Date: Thu Aug 9 12:23:42 2018 +0300
arm64: dts: ls1046: add support for 10GBase-KR
commit 8473f478783f6f601e1c6d7e6afba49a13f3a6a3
Author: Zhang Ying-22455 <ying.zhang22455@nxp.com>
Date: Mon Apr 2 16:24:33 2018 +0800
arm64: dts: ls1046a: add dts entry for A-010650
Signed-off-by: Zhang Ying-22455 <ying.zhang22455@nxp.com>
commit 3159fe9263fb145601ccb07fcb9336a68fba4e08
Author: Bao Xiaowei <xiaowei.bao@nxp.com>
Date: Fri Oct 13 11:04:39 2017 +0800
arm64: dts: ls1046a: add the property of IB and OB
Add the property of inbound and outbound windows number for ep
driver.
Signed-off-by: Bao Xiaowei <xiaowei.bao@nxp.com>
Acked-by: Minghuan Lian <minghuan.Lian@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
commit c8fed58f3c9a0219fda0467791f61abd86eb97f3
Author: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Date: Wed Jan 24 22:56:48 2018 +0530
arm64: dts: freescale: ls1046a: Modify DT nodes for qspi
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
commit 96558859ea3a4af44c0b25441f7574ae6222509a
Author: Ran Wang <ran.wang_1@nxp.com>
Date: Fri Jan 5 15:17:23 2018 +0800
arm64: dts: ls1046a: Enable usb3-lpm-capable for usb3 node
Enable USB3 HW LPM feature for ls1046a and active patch for
snps erratum A-010131. It will disable U1/U2 temperary when
initiate U3 request.
commit 9b17a5fcf8da5656ff99ebef3d63ba040e9f676d
Date: Tue Jun 13 13:14:26 2017 +0800
arm64: dts: correct the register range of dcfg
commit 67c82e3c7b376139d7cee624589bedbc311f8868
Author: jiaheng.fan <jiaheng.fan@nxp.com>
Date: Thu May 11 17:36:33 2017 +0800
arm64: dts: ls1021/ls1043/ls1046: add qdma nodes
Signed-off-by: jiaheng.fan <jiaheng.fan@nxp.com>
commit 4a6cef0c83748ee4f6641489fc324bd64095485d
Author: Chenhui Zhao <chenhui.zhao@nxp.com>
Date: Fri May 5 17:53:27 2017 +0800
arm64: dts: ls1046a: add ftm0 node
Remove the num-lanes property to avoid the driver setting the
link width.
On FSL Layerscape SoCs, the number of lanes assigned to PCIe
controller is not fixed, it is determined by the selected SerDes
protocol in the RCW (Reset Configuration Word).
The PCIe link training is completed automatically through the selected
SerDes protocol - the link width set-up is updated by hardware after
power on reset, so the num-lanes property is not needed for Layerscape
PCIe.
The current num-lanes property was added erroneously, which actually
indicates the maximum lanes the PCIe controller can support up to,
instead of the lanes assigned to the PCIe controller. The link width set
by SerDes protocol will be overridden by the num-lanes property, hence
the subsequent re-training will fail when the assigned lanes do not
match the value in the num-lanes property.
Remove the property to fix the issue
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Andrew Murray <andrew.murray@arm.com>
After switching to the new FSL QSPI driver the properties
'fsl,qspi-has-second-chip' and 'big-endian' are not used anymore.
The driver now uses the 'reg' property to determine the bus and
the chipselect. The endianness is selected by the driver depending
on which SoC is used.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- Use match_string() instead of reimplementing it (Andy Shevchenko)
- Enable SERR# forwarding for all bridges (Bharat Kumar Gogada)
- Use Latency Tolerance Reporting if already enabled by platform (Bjorn
Helgaas)
- Save/restore LTR info for suspend/resume (Bjorn Helgaas)
- Fix DPC use of uninitialized data (Dongdong Liu)
- Probe bridge window attributes only once at enumeration-time to fix
device accesses during rescan (Bjorn Helgaas)
- Return BAR size (not "size -1 ") from pci_size() to simplify code (Du
Changbin)
- Use config header type (not class code) identify bridges more
reliably (Honghui Zhang)
- Work around Intel Denverton incorrect Trace Hub BAR size reporting
(Alexander Shishkin)
- Reorder pciehp cached state/hardware state updates to avoid missed
interrupts (Mika Westerberg)
- Turn ibmphp semaphores into completions or mutexes (Arnd Bergmann)
- Mark expected switch fall-through (Mathieu Malaterre)
- Use of_node_name_eq() for node name comparisons (Rob Herring)
- Add ACS and pciehp quirks for HXT SD4800 (Shunyong Yang)
- Consolidate Rohm Vendor ID definitions (Andy Shevchenko)
- Use u32 (not __u32) for things not exposed to userspace (Logan
Gunthorpe)
- Fix locking semantics of bus and slot reset interfaces (Alex
Williamson)
- Update PCIEPORTBUS Kconfig help text (Hou Zhiqiang)
- Allow portdrv to claim subtractive decode Ports so PCIe services will
work for them (Honghui Zhang)
- Report PCIe links that become degraded at run-time (Alexandru
Gagniuc)
- Blacklist Gigabyte X299 Root Port power management to fix Thunderbolt
hotplug (Mika Westerberg)
- Revert runtime PM suspend/resume callbacks that broke PME on network
cable plug (Mika Westerberg)
- Disable Data Link State Changed interrupts to prevent wakeup
immediately after suspend (Mika Westerberg)
- Extend altera to support Stratix 10 (Ley Foon Tan)
- Allow building altera driver on ARM64 (Ley Foon Tan)
- Replace Douglas with Tom Joseph as Cadence PCI host/endpoint
maintainer (Lorenzo Pieralisi)
- Add DT support for R-Car RZ/G2E (R8A774C0) (Fabrizio Castro)
- Add dra72x/dra74x/dra76x SoC compatible strings (Kishon Vijay Abraham I)
- Enable x2 mode support for dra72x/dra74x/dra76x SoC (Kishon Vijay
Abraham I)
- Configure dra7xx PHY to PCIe mode (Kishon Vijay Abraham I)
- Simplify dwc (remove unnecessary header includes, name variables
consistently, reduce inverted logic, etc) (Gustavo Pimentel)
- Add i.MX8MQ support (Andrey Smirnov)
- Add message to help debug dwc MSI-X mask bit errors (Gustavo
Pimentel)
- Work around imx7d PCIe PLL erratum (Trent Piepho)
- Don't assert qcom reset GPIO during probe (Bjorn Andersson)
- Skip dwc MSI init if MSIs have been disabled (Lucas Stach)
- Use memcpy_fromio()/memcpy_toio() instead of plain memcpy() in PCI
endpoint framework (Wen Yang)
- Add interface to discover supported endpoint features to replace a
bitfield that wasn't flexible enough (Kishon Vijay Abraham I)
- Implement the new supported-feature interface for designware-plat,
dra7xx, rockchip, cadence (Kishon Vijay Abraham I)
- Fix issues with 64-bit BAR in endpoints (Kishon Vijay Abraham I)
- Add layerscape endpoint mode support (Xiaowei Bao)
- Remove duplicate struct hv_vp_set in favor of struct hv_vpset (Maya
Nakamura)
- Rework hv_irq_unmask() to use cpumask_to_vpset() instead of
open-coded reimplementation (Maya Nakamura)
- Align Hyper-V struct retarget_msi_interrupt arguments (Maya Nakamura)
- Fix mediatek MMIO size computation to enable full size of available
MMIO space (Honghui Zhang)
- Fix mediatek DMA window size computation to allow endpoint DMA access
to full DRAM address range (Honghui Zhang)
- Fix mvebu prefetchable BAR regression caused by common bridge
emulation that assumed all bridges had prefetchable windows (Thomas
Petazzoni)
- Make advk_pci_bridge_emul_ops static (Wei Yongjun)
- Configure MPS settings for VMD root ports (Jon Derrick)
* tag 'pci-v5.1-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (92 commits)
PCI: Update PCIEPORTBUS Kconfig help text
PCI: Fix "try" semantics of bus and slot reset
PCI/LINK: Report degraded links via link bandwidth notification
dt-bindings: PCI: altera: Add altr,pcie-root-port-2.0
PCI: altera: Enable driver on ARM64
PCI: altera: Add Stratix 10 PCIe support
PCI/PME: Fix possible use-after-free on remove
PCI: aardvark: Make symbol 'advk_pci_bridge_emul_ops' static
PCI: dwc: skip MSI init if MSIs have been explicitly disabled
PCI: hv: Refactor hv_irq_unmask() to use cpumask_to_vpset()
PCI: hv: Replace hv_vp_set with hv_vpset
PCI: hv: Add __aligned(8) to struct retarget_msi_interrupt
PCI: mediatek: Enlarge PCIe2AHB window size to support 4GB DRAM
PCI: mediatek: Fix memory mapped IO range size computation
PCI: dwc: Remove superfluous shifting in definitions
PCI: dwc: Make use of GENMASK/FIELD_PREP
PCI: dwc: Make use of BIT() in constant definitions
PCI: dwc: Share code for dw_pcie_rd/wr_other_conf()
PCI: dwc: Make use of IS_ALIGNED()
PCI: imx6: Add code to request/control "pcie_aux" clock for i.MX8MQ
Add the PCIE EP node in dts for ls1046a.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Reviewed-by: Minghuan Lian <minghuan.lian@nxp.com>
Reviewed-by: Zhiqiang Hou <zhiqiang.hou@nxp.com>
Reviewed-by: Rob Herring <robh+dt@kernel.org>
Add this property to all layerscape platforms to improve USB read write performance.
Disable the UARTs by defaultto avoid registering unused UARTs. This
effectively change the number of registered UARTS for the RDB and QDS from
4 to 2 but this seems the right thing to do.
It is especially useful when connecting other 8250 uart on PCIe for example
as the default maximum number of 8250 UARTs that can be registered is 4.
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Set the Integrated Flash Controller status to disabled so each board has
the option to enable it. All the existing users have status = "okay" so
there is no functional change.
Add num-viewport property for PCIe DT nodes to specify how many
viewports are implemented.
add the qDMA device tree nodes for LS1046A devices.
Signed-off-by: Wen He <wen.he_1@nxp.com>
Each CPU can (and does) participate in cooling down the system but the
DT only captures a handful of them, normally CPU0, in the cooling maps.
Things work by chance currently as under normal circumstances its the
first CPU of each cluster which is used by the operating systems to
probe the cooling devices. But as soon as this CPU ordering changes and
any other CPU is used to bring up the cooling device, we will start
seeing failures.
Also the DT is rather incomplete when we list only one CPU in the
cooling maps, as the hardware doesn't have any such limitations.
Update cooling maps to include all devices affected by individual trip
points.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Removed the wrong compatible string "snps,dw-pcie", in case
match incorrect driver.
Add the status property disable the PCIe, the property will be enable
by bootloader.
dtc has new checks for I2C and SPI buses. Fix the SPI bus node names
and warnings in unit-addresses.
arch/arm64/boot/dts/freescale/fsl-ls1046a-rdb.dtb: Warning (i2c_bus_reg): /soc/i2c@2180000/eeprom@57: I2C bus unit address format error, expected "53"
arch/arm64/boot/dts/freescale/fsl-ls1046a-rdb.dtb: Warning (i2c_bus_reg): /soc/i2c@2180000/eeprom@56: I2C bus unit address format error, expected "52"
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Li Yang <leoyang.li@nxp.com>
Signed-off-by: Rob Herring <robh@kernel.org>
As per IFC binding, Absence of "little-endian" field causes registers
access in big-endian mode.
So no need to set explicit big-endian field IFC node for LS1043A and
LS1046A.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Pull ARM SoC late updates from Olof Johansson:
"A couple of late-merged changes that would be useful to get in this
merge window:
- Driver support for reset of audio complex on Meson platforms. The
audio driver went in this merge window, and these changes have been
in -next for a while (just not in our tree).
- Power management fixes for IOMMU on Rockchip platforms, getting
closer to kexec working on them, including Chromebooks.
- Another pass updating "arm,psci" -> "psci" for some properties that
have snuck in since last time it was done"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
iommu/rockchip: Move irq request past pm_runtime_enable
iommu/rockchip: Handle errors returned from PM framework
arm64: rockchip: Force CONFIG_PM on Rockchip systems
ARM: rockchip: Force CONFIG_PM on Rockchip systems
arm64: dts: Fix various entry-method properties to reflect documentation
reset: imx7: Fix always writing bits as 0
reset: meson: add meson audio arb driver
reset: meson: add dt-bindings for meson-axg audio arb
The idle-states binding documentation[1] mentions that the
'entry-method' property is required on 64-bit platforms and must be
set to "psci".
commit a13f18f59d26 ("Documentation: arm: Fix typo in the idle-states
bindings examples") attempted to fix this earlier but clearly more is
needed.
Fix the cpu-capacity.txt documentation that uses the incorrect value so
we don't get copy-paste errors like these. Clarify the language in
idle-states.txt by removing the reference to the psci bindings that
might be causing this confusion.
Finally, fix devicetrees of various boards to reflect current
documentation.
[1] Documentation/devicetree/bindings/arm/idle-states.txt (see
idle-states node)
Signed-off-by: Amit Kucheria <amit.kucheria@linaro.org>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
The cooling device properties, like "#cooling-cells" and
"dynamic-power-coefficient", should either be present for all the CPUs
of a cluster or none. If these are present only for a subset of CPUs of
a cluster then things will start falling apart as soon as the CPUs are
brought online in a different order. For example, this will happen
because the operating system looks for such properties in the CPU node
it is trying to bring up, so that it can register a cooling device.
Add such missing properties.
Do minor rearrangement as well to keep ordering consistent.
Replace license text with corresponding SPDX identifiers and update the
format of existing SPDX identifiers to follow the new guideline
Documentation/process/license-rules.rst.
Note that some of the files mentioned X11 license previously but the
license text actually matches MIT license.
Signed-off-by: Li Yang <leoyang.li@nxp.com>
The memory node in fsl-ls1046a.dtsi has no 'reg' property, and causes
the dtc warning below.
Warning (unit_address_vs_reg): Node /memory@80000000 has a unit name, but no reg property
Let's add a 'reg' property with dummy memory size, since bootloader will
need to fill the correct one per board memory configuration anyway.
Cc: Mingkai Hu <Mingkai.Hu@nxp.com>
According to PSCI standard v0.2, for CPU_SUSPEND call, which is
used by cpu idle framework, bit[16] of state parameter must be 0.
So update bit[16] of property 'arm,psci-suspend-param', which is
used as state parameter, to 0.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Move cpu_thermal node from soc node to root node.
cpu_thermal node does not have any register properties and thus
shouldn't be placed on the bus.
This fixes the following build warnings with W=1:
arch/arm64/boot/dts/freescale/fsl-ls1046a-qds.dtb: Warning (simple_bus_reg): Node /soc/thermal-zones missing or empty reg/ranges property
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Pull ARM device-tree updates from Arnd Bergmann:
"We add device tree files for a couple of additional SoCs in various
areas:
Allwinner R40/V40 for entertainment, Broadcom Hurricane 2 for
networking, Amlogic A113D for audio, and Renesas R-Car V3M for
automotive.
As usual, lots of new boards get added based on those and other SoCs:
- Actions S500 based CubieBoard6 single-board computer
- Amlogic Meson-AXG A113D based development board
- Amlogic S912 based Khadas VIM2 single-board computer
- Amlogic S912 based Tronsmart Vega S96 set-top-box
- Allwinner H5 based NanoPi NEO Plus2 single-board computer
- Allwinner R40 based Banana Pi M2 Ultra and Berry single-board computers
- Allwinner A83T based TBS A711 Tablet
- Broadcom Hurricane 2 based Ubiquiti UniFi Switch 8
- Broadcom bcm47xx based Luxul XAP-1440/XAP-810/ABR-4500/XBR-4500
wireless access points and routers
- NXP i.MX51 based Zodiac Inflight Innovations RDU1 board
- NXP i.MX53 based GE Healthcare PPD biometric monitor
- NXP i.MX6 based Pistachio single-board computer
- NXP i.MX6 based Vining-2000 automotive diagnostic interface
- NXP i.MX6 based Ka-Ro TX6 Computer-on-Module in additional variants
- Qualcomm MSM8974 (Snapdragon 800) based Fairphone 2 phone
- Qualcomm MSM8974pro (Snapdragon 801) based Sony Xperia Z2 Tablet
- Realtek RTD1295 based set-top-boxes MeLE V9 and PROBOX2 AVA
- Renesas R-Car V3M (R8A77970) SoC and "Eagle" reference board
- Renesas H3ULCB and M3ULCB "Kingfisher" extension infotainment boards
- Renasas r8a7745 based iWave G22D-SODIMM SoM
- Rockchip rk3288 based Amarula Vyasa single-board computer
- Samsung Exynos5800 based Odroid HC1 single-board computer
For existing SoC support, there was a lot of ongoing work, as usual
most of that concentrated on the Renesas, Rockchip, OMAP, i.MX,
Amlogic and Allwinner platforms, but others were also active.
Rob Herring and many others worked on reducing the number of issues
that the latest version of 'dtc' now warns about. Unfortunately there
is still a lot left to do.
A rework of the ARM foundation model introduced several new files for
common variations of the model"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (599 commits)
arm64: dts: uniphier: route on-board device IRQ to GPIO controller for PXs3
dt-bindings: bus: Add documentation for the Technologic Systems NBUS
arm64: dts: actions: s900-bubblegum-96: Add fake uart5 clock
ARM: dts: owl-s500: Add CubieBoard6
dt-bindings: arm: actions: Add CubieBoard6
ARM: dts: owl-s500-guitar-bb-rev-b: Add fake uart3 clock
ARM: dts: owl-s500: Set power domains for CPU2 and CPU3
arm: dts: mt7623: remove unused compatible string for pio node
arm: dts: mt7623: update usb related nodes
arm: dts: mt7623: update crypto node
ARM: dts: sun8i: a711: Enable USB OTG
ARM: dts: sun8i: a711: Add regulator support
ARM: dts: sun8i: a83t: bananapi-m3: Enable AP6212 WiFi on mmc1
ARM: dts: sun8i: a83t: cubietruck-plus: Enable AP6330 WiFi on mmc1
ARM: dts: sun8i: a83t: Move mmc1 pinctrl setting to dtsi file
ARM: dts: sun8i: a83t: allwinner-h8homlet-v2: Add AXP818 regulator nodes
ARM: dts: sun8i: a83t: bananapi-m3: Add AXP813 regulator nodes
ARM: dts: sun8i: a83t: cubietruck-plus: Add AXP818 regulator nodes
ARM: dts: sunxi: Add dtsi for AXP81x PMIC
arm64: dts: allwinner: H5: Restore EMAC changes
Use constants in the interrupt description.
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
LS1046a implements 3 PCIe 3.0 controllers.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Add optee device tree node on ls1012a, ls1043a, ls1046a, ls1088a
and ls208xa.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
LS1046a includes 3 MSI controllers.
Each controller supports 128 interrupts.
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Add "dis_rxdet_inp3_quirk" boolean property to USB3 node. This property
is used to disable rx detection in P3 PHY mode.
Add the DPAA 1.x FMan device tree nodes for LS1046A boards.
Add the QBMan device tree nodes for LS1046A devices.
Signed-off-by: Roy Pledge <roy.pledge@nxp.com>
This patch is to enable SD UHS-I mode and eMMC HS200 mode on
LS1046ARDB in dts. Also, the eSDHC peripheral clock must be used
instead of platform clock to support these modes.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Integrated flash controller present in LS1043A and LS1046A is big endian.
So add big endian property in the devive tree.
Update the copyright claims to comply with company policy.
For ls1046 sata, ecc should be disabled due to a erratum.
Provide the ecc register address for driver to use.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
