This is the 5.4.193 stable release
arch/arm64/boot/dts/freescale/fsl-ls1028a-qds.dts
drivers/edac/synopsys_edac.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/mmc/host/sdhci.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
sound/soc/codecs/msm8916-wcd-analog.c
[ Upstream commit 99a7cacc66cae92db40139b57689be2af75fc6b8 ]
According to Documentation/devicetree/bindings/watchdog/arm,sp805.yaml
the compatible is:
compatible = "arm,sp805", "arm,primecell";
The current compatible string doesn't exist at all. Fix it.
Signed-off-by: Michael Walle <michael@walle.cc>
This is the 5.4.153 stable release
[ Upstream commit f2dc2359b75e1fd345fd710862f73db20dc55864 ]
The SP805 binding sets the order of the clock-names to be: "wdog_clk",
"apb_pclk" (in exactly that order).
Change the order in the DTs for Freescale platforms to match that. The
two clocks given in all nodes are actually the same, so that does not
change any behaviour.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Use compatibles as "jedec,spi-nor" to probe flash without displaying
warning: found s25fs512s, expected m25p80.
Also remove "fsl,qspi-has-second-chip" property as new driver doesn't use
it anymore.
Update dtsi compatibles to use "fsl,ls2080a-qspi".
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
(cherry picked from commit 7afe154e046717c9c6249ac7ded256563236811a)
Since dwc3 cache type has been set to cacheable, apply dma-coherent to
all dwc3 nodes accordingly.
Note: For LS1043A and LS1046A, since QE-HDLC still doesn't support
dma-coherent, we cannot directly revert cd1a4f3c (sdk: dts: ls104x move
dma-coherent from soc to its child nodes) to recover dma-coherent for
soc.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
nodes
To allow USB dwc3 driver to conduct some chip-scpeific configuring.
Cover all arm64 based Layerscape SoCs.
Reviewed-by: Jun Li <jun.li@nxp.com>
Reviewed-by: Leo Li <leo.li@nxp.com>
Add little-endian property of rcpm for ls1028a,ls1088a,ls208xa
Signed-off-by: Biwen Li <biwen.li@nxp.com>
ftm_alarm0
The patch replaces ftm0 with ftm_alarm0 DT node
- replace ftm0 with ftm_alarm0
- add new rcpm node
- remove old rcpm node
- aliases ftm_alarm0 as rtc1
Remove entire backplane support from device tree for all supported platforms
Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com>
when compiling dts file using DTC_FLAG='-@', the device tree compiler
reports these warnings:
Warning (simple_bus_reg): /soc/mdio@0x8c0b000: simple-bus unit address
format error, expected "8c0b000"
Warning (unit_address_format): /pfe@04000000: unit name should not have
leading 0s
Fixed the node names to silence these warnings.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
Cover LS1012A, LS1043A, LS1046A, LS1088A, LS208xA, LX2160A
This change is required to specify that serdes HW peripheral is little-endian.
To enable all the supported thermal sensors, add sensor id information
to thermal zone node.
Dts for ls1012a, ls1046a, ls1043a, ls1088a are updated.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
commit f967940f2fb73bc7ec676dbad9f32fbf4e7fea2b
Author: Pengbo Mu <pengbo.mu@nxp.com>
Date: Fri Jul 13 16:19:36 2018 +0800
arm64: dts: ls1088a: add snps incr burst type adjustment in usb0 &
usb1
This property could fix the defect that external usb device always
prints this error log --- 'reset SuperSpeed USB device number n
using
xhci_hcd' when system power on.
Signed-off-by: Pengbo Mu <pengbo.mu@nxp.com>
commit 46123df3a174f0d76c8b954a0386e64841453836
Author: Florinel Iordache <florinel.iordache@nxp.com>
Date: Thu Aug 9 12:29:18 2018 +0300
arm64: dts: updates for Unified Backplane driver
commit 3b214bd42d47ebe7b6af925a3ffcf09aaaaabfb9
Author: Nipun Gupta <nipun.gupta@nxp.com>
Date: Sat Apr 28 00:20:48 2018 +0530
arm64: dts: ls1088: add dma-cohernet property in fsl-mc node
Signed-off-by: Nipun Gupta <nipun.gupta@nxp.com>
commit 240b04a98171f6774d1c3c498f8cb21f4411ac5f
Author: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Date: Thu Apr 26 12:26:54 2018 +0300
arm64: dts: ls1088a: move fsl-mc node as a child of soc
Move the fsl-mc hardware manager node in the soc node because all
the
soc settings (such as 'dma-ranges') also apply to the fsl-mc and
need
to be propagated to it.
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
commit 3f2f50950f763d1335181ce374a11ed118abf0fa
Date: Wed Apr 25 09:43:47 2018 +0530
arm64: dts: ls1088: add dma ranges property
commit 6afd0157e8fa2510790537855c86f8a7c1431abe
Author: Zhang Ying-22455 <ying.zhang22455@nxp.com>
Date: Mon Apr 2 16:25:38 2018 +0800
arm64: dts: ls1088a: add dts entry for A-010650
Signed-off-by: Zhang Ying-22455 <ying.zhang22455@nxp.com>
commit 0f8432c30c44771f9180aa7bf7580ad1d7e7c9d3
Date: Mon Feb 26 10:40:37 2018 +0530
arm64: dts: ls1088a: add dma coherent property in smmu node
commit 6417c66b823ab380cf73ee252a998d98b28f0180
Author: Suresh Gupta <suresh.gupta@nxp.com>
Date: Fri Feb 2 00:04:41 2018 +0530
arm64: dts: freescale: ls1088a: Modify DT nodes for qspi
Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com>
Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com>
commit 01a1ea9e781d307ab87da95043ec898736495fff
Date: Thu Nov 2 10:36:48 2017 +0800
arm64: dts: ls1088a: correct the i2c clock to 1/8 platform pll
commit 60122f1192e1cc23e5952468cc5a884287d64907
Author: Bharat Bhushan <Bharat.Bhushan@nxp.com>
Date: Thu Sep 7 10:08:31 2017 +0530
arm64: dts: ls1088a: Add iommu-map property for pci
This patch adds iommu-map property for PCIe, which enables
SMMU for these devices on LS1088.
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@nxp.com>
commit 43c4d0cf074106b411280c5b2be75d5d6e63fb01
Author: Iordache Florinel-R70177 <florinel.iordache@nxp.com>
Date: Mon Aug 21 11:43:07 2017 +0300
arm64: dts: ls1088a: add backplane support
Signed-off-by: Iordache Florinel-R70177 <florinel.iordache@nxp.com>
commit 57d49424694f72adbf7cf1dbeff38704f0d65359
Author: Ashish Kumar <Ashish.Kumar@nxp.com>
Date: Mon Jun 19 18:32:13 2017 +0530
arm64: dts: ls1088: Add Reboot node in dtsi
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
commit ee950989a7babc240153a20fe468573e13d61f98
Date: Thu May 11 14:59:28 2017 +0800
arm64: dts: ls1088a: add ftm0 nodes
commit 6d3a96446a7ffccb0b9936b616d855c8d5572bce
Author: Bogdan Purcareata <bogdan.purcareata@nxp.com>
Date: Wed May 3 14:26:35 2017 +0000
arm64: dts: fsl/ls1088,ls208x: Add mdio and phy nodes
Add mdio and phy nodes for the following FSL platforms:
- LS1088A RDB
- LS2080A QDS & RDB
- LS2088A QDS, RDB & simu
Contains contributions from patches by the following authors:
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
Signed-off-by: Rai Harninder <harninder.rai@nxp.com>
Signed-off-by: Pratiyush Mohan Srivastava
<pratiyush.srivastava@nxp.com>
Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com>
Signed-off-by: Santan Kumar <santan.kumar@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Signed-off-by: Ashish Kumar <ashish.kumar@nxp.com>
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Signed-off-by: Ioana Radulescu <ruxandra.radulescu@nxp.com>
Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com>
commit 971ff2e74cfebb84286ec3e191f5910dded4bd41
Date: Thu May 4 18:04:44 2017 +0530
arm64: dts: ls1088a: Add QSPI node for QDS, RDB
This is temporary patch, will rewrite for open source
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
commit c61036e6dfe264d61cc213293040d873d863e8ac
Date: Thu Apr 27 23:35:15 2017 +0530
arm64: dts: add iommu-map property in fsl-mc node
commit a4412cc510162a900d10c8ca4add71defb3f2d97
Date: Wed Apr 19 22:26:15 2017 +0530
arm64: dts: add smmu device node in LS1088 devicetree
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Enumeration:
- Consolidate _HPP/_HPX stuff in pci-acpi.c and simplify it
(Krzysztof Wilczynski)
- Fix incorrect PCIe device types and remove dev->has_secondary_link
to simplify code that deals with upstream/downstream ports (Mika
Westerberg)
- After suspend, restore Resizable BAR size bits correctly for 1MB
BARs (Sumit Saxena)
- Enable PCI_MSI_IRQ_DOMAIN support for RISC-V (Wesley Terpstra)
Virtualization:
- Add ACS quirks for iProc PAXB (Abhinav Ratna), Amazon Annapurna
Labs (Ali Saidi)
- Move sysfs SR-IOV functions to iov.c (Kelsey Skunberg)
- Remove group write permissions from sysfs sriov_numvfs,
sriov_drivers_autoprobe (Kelsey Skunberg)
Hotplug:
- Simplify pciehp indicator control (Denis Efremov)
Peer-to-peer DMA:
- Allow P2P DMA between root ports for whitelisted bridges (Logan
Gunthorpe)
- Whitelist some Intel host bridges for P2P DMA (Logan Gunthorpe)
- DMA map P2P DMA requests that traverse host bridge (Logan
Gunthorpe)
Amazon Annapurna Labs host bridge driver:
- Add DT binding and controller driver (Jonathan Chocron)
Hyper-V host bridge driver:
- Fix hv_pci_dev->pci_slot use-after-free (Dexuan Cui)
- Fix PCI domain number collisions (Haiyang Zhang)
- Use instance ID bytes 4 & 5 as PCI domain numbers (Haiyang Zhang)
- Fix build errors on non-SYSFS config (Randy Dunlap)
i.MX6 host bridge driver:
- Limit DBI register length (Stefan Agner)
Intel VMD host bridge driver:
- Fix config addressing issues (Jon Derrick)
Layerscape host bridge driver:
- Add bar_fixed_64bit property to endpoint driver (Xiaowei Bao)
- Add CONFIG_PCI_LAYERSCAPE_EP to build EP/RC drivers separately
(Xiaowei Bao)
Mediatek host bridge driver:
- Add MT7629 controller support (Jianjun Wang)
Mobiveil host bridge driver:
- Fix CPU base address setup (Hou Zhiqiang)
- Make "num-lanes" property optional (Hou Zhiqiang)
Tegra host bridge driver:
- Fix OF node reference leak (Nishka Dasgupta)
- Disable MSI for root ports to work around design problem (Vidya
Sagar)
- Add Tegra194 DT binding and controller support (Vidya Sagar)
- Add support for sideband pins and slot regulators (Vidya Sagar)
- Add PIPE2UPHY support (Vidya Sagar)
Misc:
- Remove unused pci_block_cfg_access() et al (Kelsey Skunberg)
- Unexport pci_bus_get(), etc (Kelsey Skunberg)
- Hide PM, VC, link speed, ATS, ECRC, PTM constants and interfaces in
the PCI core (Kelsey Skunberg)
- Clean up sysfs DEVICE_ATTR() usage (Kelsey Skunberg)
- Mark expected switch fall-through (Gustavo A. R. Silva)
- Propagate errors for optional regulators and PHYs (Thierry Reding)
- Fix kernel command line resource_alignment parameter issues (Logan
Gunthorpe)"
* tag 'pci-v5.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (112 commits)
PCI: Add pci_irq_vector() and other stubs when !CONFIG_PCI
arm64: tegra: Add PCIe slot supply information in p2972-0000 platform
arm64: tegra: Add configuration for PCIe C5 sideband signals
PCI: tegra: Add support to enable slot regulators
PCI: tegra: Add support to configure sideband pins
PCI: vmd: Fix shadow offsets to reflect spec changes
PCI: vmd: Fix config addressing when using bus offsets
PCI: dwc: Add validation that PCIe core is set to correct mode
PCI: dwc: al: Add Amazon Annapurna Labs PCIe controller driver
dt-bindings: PCI: Add Amazon's Annapurna Labs PCIe host bridge binding
PCI: Add quirk to disable MSI-X support for Amazon's Annapurna Labs Root Port
PCI/VPD: Prevent VPD access for Amazon's Annapurna Labs Root Port
PCI: Add ACS quirk for Amazon Annapurna Labs root ports
PCI: Add Amazon's Annapurna Labs vendor ID
MAINTAINERS: Add PCI native host/endpoint controllers designated reviewer
PCI: hv: Use bytes 4 and 5 from instance ID as the PCI domain numbers
dt-bindings: PCI: tegra: Add PCIe slot supplies regulator entries
dt-bindings: PCI: tegra: Add sideband pins configuration entries
PCI: tegra: Add Tegra194 PCIe support
PCI: Get rid of dev->has_secondary_link flag
add ls1088a gpio specify compatible.
Signed-off-by: Song Hui <hui.song_1@nxp.com>
This patch adds the DSPI controller node for ls1088a boards.
Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com>
Remove the num-lanes property to avoid the driver setting the
link width.
On FSL Layerscape SoCs, the number of lanes assigned to PCIe
controller is not fixed, it is determined by the selected SerDes
protocol in the RCW (Reset Configuration Word).
The PCIe link training is completed automatically through the selected
SerDes protocol - the link width set-up is updated by hardware after
power on reset, so the num-lanes property is not needed for Layerscape
PCIe.
The current num-lanes property was added erroneously, which actually
indicates the maximum lanes the PCIe controller can support up to,
instead of the lanes assigned to the PCIe controller. The link width set
by SerDes protocol will be overridden by the num-lanes property, hence
the subsequent re-training will fail when the assigned lanes do not
match the value in the num-lanes property.
Remove the property to fix the issue
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Andrew Murray <andrew.murray@arm.com>
Ls1088a platform, the i2c input clock is actually platform pll CLK / 8
(this is the hardware connection), other clock divider can not get the
correct i2c clock, resulting in the output of SCL pin clock is not
accurate.
Acked-by: Li Yang <leoyang.li@nxp.com>
Since fsl-ls1088a Soc GPIO registers are used as little endian,
the patch adds the little-endian attribute to each gpio node.
Add the console device tree node for the following
DPAA2 based platforms: LS1088A, LS2080A, LS2088A and LX2160A.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
This patch is to add ptp timer device tree node for dpaa2
platforms(ls1088a/ls208xa/lx2160a).
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Add this property to all layerscape platforms to improve USB read write performance.
This patch also adds the iommu-map property in fsl-mc node, so
that fsl-mc can use iommu.
Add num-viewport property for PCIe DT nodes to specify how many
viewports are implemented.
LS1088A has a 48-bit address size so make sure that the
dma-ranges property reflects this.
The fsl-mc node should sit under the soc node, so move it to
its proper location.
Fixes: ac7c9ff741fb ("arm64: dts: ls1088a: add fsl-mc hardware resource manager node")
Each CPU can (and does) participate in cooling down the system but the
DT only captures a handful of them, normally CPU0, in the cooling maps.
Things work by chance currently as under normal circumstances its the
first CPU of each cluster which is used by the operating systems to
probe the cooling devices. But as soon as this CPU ordering changes and
any other CPU is used to bring up the cooling device, we will start
seeing failures.
Also the DT is rather incomplete when we list only one CPU in the
cooling maps, as the hardware doesn't have any such limitations.
Update cooling maps to include all devices affected by individual trip
points.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Removed the wrong compatible string "snps,dw-pcie", in case
match incorrect driver.
Add the status property disable the PCIe, the property will be enable
by bootloader.
Signed-off-by: Bao Xiaowei <xiaowei.bao@nxp.com>
The cooling device properties, like "#cooling-cells" and
"dynamic-power-coefficient", should either be present for all the CPUs
of a cluster or none. If these are present only for a subset of CPUs of
a cluster then things will start falling apart as soon as the CPUs are
brought online in a different order. For example, this will happen
because the operating system looks for such properties in the CPU node
it is trying to bring up, so that it can register a cooling device.
Add such missing properties.
Do minor rearrangement as well to keep ordering consistent.
Replace license text with corresponding SPDX identifiers and update the
format of existing SPDX identifiers to follow the new guideline
Documentation/process/license-rules.rst.
Note that some of the files mentioned X11 license previously but the
license text actually matches MIT license.
Signed-off-by: Li Yang <leoyang.li@nxp.com>
According to PSCI standard v0.2, for CPU_SUSPEND call, which is
used by cpu idle framework, bit[16] of state parameter must be 0.
So update bit[16] of property 'arm,psci-suspend-param', which is
used as state parameter, to 0.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Move cpu_thermal node from soc node to root node.
cpu_thermal node does not have any register properties and thus
shouldn't be placed on the bus.
This fixes the following build warnings with W=1:
arch/arm64/boot/dts/freescale/fsl-ls1088a-qds.dtb: Warning (simple_bus_reg): Node /soc/thermal-zones missing or empty reg/ranges property
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
There are eight cores in ls1088a and each core has an watchdog,
ls1088a can use sp805-wdt driver, so we just add DT node for it.
Add USB support on ls1088ardb
Signed-off-by: yinbo zhu <yinbo.zhu@nxp.com>
Add the fsl-mc node in the LS1088A device tree.
Add debug configuration node(DCFG) in dtsi, helps guts driver to
print the following information in kernel boot log
[ 0.526649] Machine: LS1088A RDB Board
[ 0.530430] SoC family: QorIQ LS1088A
[ 0.534115] SoC ID: svr:0x87030010, Revision: 1.0
Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com>
The LS1088a implements 3 PCIe 3.0 controllers.
Add ITS device tree node, which will be used by PCIe controller.
Add optee device tree node on ls1012a, ls1043a, ls1046a, ls1088a
and ls208xa.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
ls1088a supports another cpu idle state which is ph20 which saves
more power when cpu is idle.
It was implemented through psci firmware.
LS1088A has a SEC v5.3 security engine.
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
1. Remove ls1043a compatible string from node
2. Fix the sata ecc register address error
Add nodes and properties for thermal management support.
1. Sata ecc should be disabled due to a erratum.
Provide the ecc register address for driver to use.
2. Enable dma coherence operation
LS1088AQDS consist of NOR, NAND and FPGA connected over IFC
LS1088ARDB consist of NAND and FPGA connected over IFC.
So add flash information in ifc node of device tree.
Add esdhc node for ls1088a and enable it on both RDB and QDS boards.
