Add default clock rate for usdhc nodes.
Reviewed-by: Frank Li <frank.li@nxp.com>
Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com>
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
This is a temporary fix after rebasing the linux-nxp/dts/imx8
on top of next-20210514. The reason we're doing the switch is to
keep the dts working. The upstream version of the dts files already
use clock-indices. The NXP's tree needs to become ready to do so
too.
Signed-off-by: Abel Vesa <abel.vesa@nxp.com>
Remove all MLB related nodes and dts file.
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
Commit ee96e9f815d6 ("MLK-24368-1 arm64: dts: imx8qm: Add support for USBH1")
caused i.MX8DXL USB PHYs to not go into low power mode via runtime suspend.
Fix it by moving the usbh1, usbmisc2 and usbphynop2 to the specific
imx8qm-ss-conn.dtsi file.
While at it, change the usbphynop2 status as disabled.
Reviewed-by: Jun Li <jun.li@nxp.com>
Tested-by: Sebastien Haezebrouck <sebastien.haezebrouck@nxp.com>
Reported-by: Sebastien Haezebrouck <sebastien.haezebrouck@nxp.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Add support for USBH1 on imx8qm, USBH1 is a HSIC controller
CC: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Alifer Moraes <alifer.moraes@nxp.com>
Change board dts as well to avoid bisect break, the main changes are
as belows:
- Add iommus phandle for core device
- delete core device node for xen dts
- Support mek board by adding Type-C support
Add mlb dts file for imx8qxp-lpddr4-val platform.
Acked-by: Fugang Duan <fugang.duan@nxp.com>
add gpmi-nand dts for nand support on imx8qxp val
Signed-off-by: Han Xu <han.xu@nxp.com>
Add Cadence USB3 support
fully switched to new clk binding
Add NXP USB2 controller and PHY node
Add SD3.0 support, and make usdhc support eMMC V5.1
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
[ Aisheng: fix minior conflicts due to 3944b454f7fa
("arm64: dts: imx8qxp: Move usdhc clocks assignment to board DT") ]
Sign-off-by: Dong Aisheng <aisheng.dong@nxp.com>
enet_clk_ref actually is sourced from internal gpr clocks
which needs a default rate. Also update enet lpcg clock
output names to be more straightforward.
Cc: Abel Vesa <abel.vesa@nxp.com>
Cc: Stephen Boyd <sboyd@kernel.org>
switch to new lpcg clock binding
switch to two cell scu clock binding
Add conn lpcg clocks
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: devicetree@vger.kernel.org
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
MX8 SoC is comprised of a few HW subsystems while some of them can be
reused in the different SoCs. So let's re-orginize them into subsystems
in device tree as well for the possible reuse of the common part.
Note, as there's still no devices of hsio subsys, so removed it
first instead of creating a subsys headfile with no devices.
They will be added back when new devices added.
