Disable the L1SS feature in default.
Please remove this patch, if L1SS is required, and make sure
that the HW supports L1SS.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Jun Li <jun.li@nxp.com>
(cherry picked from commit 2843e1e62c991aab16150a56508d415fd43f3fbc)
(cherry picked from commit 268df946aca1035818afbec42538e6bbb47378bf)
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
Specify the clock rate and parent of i.MX8MQ/MM PCIe clocks.
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
(cherry picked from commit 5c9865f4184ad9251d147126814a36e193226aae)
(cherry picked from commit 768c144fca6f3ba4285e80e09e4aec803ffea1a7)
Set the parent clock for PCIE_AUX clock firstly, then set the rate of
the PCI_AUX clock to 10MHZ.
Reviewed-by: Peter Chen <peter.chen@nxp.com>
(cherry picked from commit c787efe575330e538cc92da0dde49255bdc80c94)
(cherry picked from commit 855ad0c9b3e9ea03f34c70332a2175cd604acf6c)
Add nxp 88w8987 wireless support on imx8mm lpddr4 evk:
- covert to use pwrseq instead of regulator
- enable 32Khz input
- set 16k sample rate for bt sco
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
changed to pca9450 pmic for new i.mx8mm-evk board.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
of pcie nodes
Remove the reserved-region property of pcie nodes for imx8m and imx8
platform since for the new pcie frame, we don't need them any more.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
Add IR support for i.MX8MM/MN/MQ.
Signed-off-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Add the PCIe EP mode on iMX8MQ/MM/MP platforms.
And enable the EP mode on EVK boards.
Add missing vcc-supply assing buck4_reg which corresponds
to VDD_3V3 from pmic, fixes probe pca6416 driver
Reviewed-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
Enable sai6 for monitorring spdic rx clock
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Reviewed-by: Viorel Suman <viorel.suman@nxp.com>
Correct ldo1/ldo2 voltage as below:
ldo1 --NVCC_SNVS_1V8
ldo2 --VDD_SNVS_0V8
(cherry picked from commit 6e1db954c1261c9a8a40f7c4e33f03173c4d05b6)
(cherry picked from commit c159238cd48be1814736ed1eed8905572777d195)
Change sai to master for bt-sco to resolve the long latence issue
for uplink
enable sound card for bt-sco
With these two parameters tuning, it can pass USB eye diagram at evk board.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
The 'attach-bridge' property for dsi port@1 can be used
to assit the dsim bridge to check if the port is used to
attach to the next bridge display device(e.g. adv7511).
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
Reviewed-by: Robby Cai <robby.cai@nxp.com>
Enable the imx pcie ep verification solution.
After commit f7907e57aea2 ("regulator: fixed: add off-on-delay"), user
can use "off-on-delay-us" to define the regulator off-delay time.
For SD card, according to the spec requirement, for sd card power reset
operation, it need sd card supply voltage to be lower than 0.5v and keep
over 1ms, otherwise, next time power back the sd card supply voltage to
3.3v, sd card can't support SD3.0 mode again.
This patch add the off-on-delay-us to each board, make sure the sd power
reset behavior is align with the specification. Without this patch, when
do quick system suspend/resume test, some sd card can't work at SD3.0 mode
after system resume back.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Acked-by: Leonard Crestez <leonard.crestez@nxp.com>
Put assigned clocks of audio PLLs in imx8mm-evk.dts, which conflict
with the assigned clocks in imx8mm.
Fixes: 77b5daa55e63 ("ARM64: dts: imx8mm: Enable AK4497/AK4458/AK5558/SPDIF/MICFIL")
Add usdhc1 node which represent wifi device.
(cherry picked from commit ae940d9d4393b7b1fa68faf61f4755310d0f564c)
Add dai-tdm-slot-num and dai-tdm-slot-width for sound-wm8524
(cherry picked from commit 874740c7dcceb0704e68cacf57b3ea907c3b2710)
enable csi bridge, mipi csi and mipi camera ov5640
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Add gpu in device tree:
arch/arm64/boot/dts/freescale/imx8mm.dtsi
arch/arm64/boot/dts/freescale/imx8mm-evk.dts
Signed-off-by: Ella Feng <ella.feng@nxp.com>
[ Aisheng: remove unecessary new blank line ]
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
enable 845 h1 in device tree
Signed-off-by: Zhou Peng <eagle.zhou@nxp.com>
enable 845 g1/g2 in device tree
Enable PCIe on iMX8MM platforms.
- enable VDDIO as 1v8
- disable the PHY EEE mode
Add interrupt and related pinctrl properties for ADV7535,
the interrupt can be used for hotplug, edid ready and etc
in the adv bridge driver.
Create a new dts 'fsl-imx8mm-evk-rm67191.dts' to support panel
'RM67191' display which is attached to DSIM controller directly.
So the corresponding panel device node is defined as the child
of 'mipi_dsi' node under the DRM DSI framework. Since the
'adv_bridge' and 'RM67191' should be enabled exclusively, so
disable 'adv_bridge' when enable 'RM67191'.
Enable the whole display pipeline 'LCDIF --> MIPI DSI --> ADV7535'
on IMX8MM EVK board.
enable fspi in imx8mm DT file
Signed-off-by: Han Xu <han.xu@nxp.com>
Enable uart1 and uart3 ports, uart1 port is for Bluetooth.
[ Aisheng: fix small conflicts during upgrade ]
All these at803x properties are not documented anywhere, so
just remove them.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
USB1 port has typec connector with power delivery support:
- Dual data role: host and device.
- Dual power role: source and sink, prefer power sink.
Signed-off-by: Li Jun <jun.li@nxp.com>
i.MX8MM has one wm8524 audio codec connected with
SAI3 digital audio interface.
This patch uses simple-card machine driver in order
to enable wm8524 codec.
We need to set:
* SAI3 pinctrl configuration
* codec reset gpio pinctrl configuration
* clock hierarchy
* codec node
* simple-card configuration
Signed-off-by: Daniel Baluta <daniel.baluta@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
The SNVS power key depends on board design, by default it should
be disabled in SoC DT and ONLY be enabled on board DT if it is
wired up.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
The BUCK2 regulator is used for cpufreq voltage control, otherwise
configuration is mostly static.
This uses the newly-implemented rohm,reset-snvs-powered property to
properly handle the SNVS state of imx8mm.
Between BD71837 and BD71847 the BUCK3/4 regulators were removed but
datasheet and board schematics kept the names for BUCK5/6/7/8. The
driver however renumbered 5/6/7/8 to 3/4/5/6. Use the names from DT
bindings and add comments to signal this.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Acked-By: Matti Vaittinen <matti.vaittinen@fi.rohmeurope.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Add basic dts support for i.MM8MM LPDDR4 EVK.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
