This commit adds WiFi module support for the Firefly-RK3399.
Signed-off-by: Shohei Maruyama <cheat.sc.linux@outlook.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
This commit adds led support for the Firefly-RK3399. The board has two
leds, this commit enables them.
This commit adds power button support for the Firefly-RK3399.
The soc spdif and i2s controllers always only have one compontent, so
always require #sound-dai-cells to be 0. Therefore there is no need to
duplicate this property in individual boards.
So move them to rk3399.dtsi.
Update all 64bit rockchip devicetree files to use SPDX-License-Identifiers.
All devicetrees claim to be either GPL or X11 while the actual license
text is MIT. Therefore we use MIT for the SPDX tag as X11 is clearly
wrong.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Acked-by: Brian Norris <briannorris@chromium.org>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Douglas Anderson <dianders@chromium.org>
Commit c301b327aea898af ("arm64: dts: rockchip: add usb3-phy otg-port
support for rk3399") caused a regression regarding the USB3. During boot,
the following message appears a few times:
dwc3: failed to initialize core
The driver is deferred waiting for the typec-phy, but this never happens
beause is disabled. So, enable it.
The offending commit was reverted in 4.16-rc but can be re-applied
after enabling the typec phys.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Pull ARM device-tree updates from Arnd Bergmann:
"We add device tree files for a couple of additional SoCs in various
areas:
Allwinner R40/V40 for entertainment, Broadcom Hurricane 2 for
networking, Amlogic A113D for audio, and Renesas R-Car V3M for
automotive.
As usual, lots of new boards get added based on those and other SoCs:
- Actions S500 based CubieBoard6 single-board computer
- Amlogic Meson-AXG A113D based development board
- Amlogic S912 based Khadas VIM2 single-board computer
- Amlogic S912 based Tronsmart Vega S96 set-top-box
- Allwinner H5 based NanoPi NEO Plus2 single-board computer
- Allwinner R40 based Banana Pi M2 Ultra and Berry single-board computers
- Allwinner A83T based TBS A711 Tablet
- Broadcom Hurricane 2 based Ubiquiti UniFi Switch 8
- Broadcom bcm47xx based Luxul XAP-1440/XAP-810/ABR-4500/XBR-4500
wireless access points and routers
- NXP i.MX51 based Zodiac Inflight Innovations RDU1 board
- NXP i.MX53 based GE Healthcare PPD biometric monitor
- NXP i.MX6 based Pistachio single-board computer
- NXP i.MX6 based Vining-2000 automotive diagnostic interface
- NXP i.MX6 based Ka-Ro TX6 Computer-on-Module in additional variants
- Qualcomm MSM8974 (Snapdragon 800) based Fairphone 2 phone
- Qualcomm MSM8974pro (Snapdragon 801) based Sony Xperia Z2 Tablet
- Realtek RTD1295 based set-top-boxes MeLE V9 and PROBOX2 AVA
- Renesas R-Car V3M (R8A77970) SoC and "Eagle" reference board
- Renesas H3ULCB and M3ULCB "Kingfisher" extension infotainment boards
- Renasas r8a7745 based iWave G22D-SODIMM SoM
- Rockchip rk3288 based Amarula Vyasa single-board computer
- Samsung Exynos5800 based Odroid HC1 single-board computer
For existing SoC support, there was a lot of ongoing work, as usual
most of that concentrated on the Renesas, Rockchip, OMAP, i.MX,
Amlogic and Allwinner platforms, but others were also active.
Rob Herring and many others worked on reducing the number of issues
that the latest version of 'dtc' now warns about. Unfortunately there
is still a lot left to do.
A rework of the ARM foundation model introduced several new files for
common variations of the model"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (599 commits)
arm64: dts: uniphier: route on-board device IRQ to GPIO controller for PXs3
dt-bindings: bus: Add documentation for the Technologic Systems NBUS
arm64: dts: actions: s900-bubblegum-96: Add fake uart5 clock
ARM: dts: owl-s500: Add CubieBoard6
dt-bindings: arm: actions: Add CubieBoard6
ARM: dts: owl-s500-guitar-bb-rev-b: Add fake uart3 clock
ARM: dts: owl-s500: Set power domains for CPU2 and CPU3
arm: dts: mt7623: remove unused compatible string for pio node
arm: dts: mt7623: update usb related nodes
arm: dts: mt7623: update crypto node
ARM: dts: sun8i: a711: Enable USB OTG
ARM: dts: sun8i: a711: Add regulator support
ARM: dts: sun8i: a83t: bananapi-m3: Enable AP6212 WiFi on mmc1
ARM: dts: sun8i: a83t: cubietruck-plus: Enable AP6330 WiFi on mmc1
ARM: dts: sun8i: a83t: Move mmc1 pinctrl setting to dtsi file
ARM: dts: sun8i: a83t: allwinner-h8homlet-v2: Add AXP818 regulator nodes
ARM: dts: sun8i: a83t: bananapi-m3: Add AXP813 regulator nodes
ARM: dts: sun8i: a83t: cubietruck-plus: Add AXP818 regulator nodes
ARM: dts: sunxi: Add dtsi for AXP81x PMIC
arm64: dts: allwinner: H5: Restore EMAC changes
The vcc_sd or vcc_sdio used for IO voltage for sdmmc and sdio
interface on rk3399 platform have a limitation that it can't be
larger than 3.0v, otherwise it has a potential risk for the chip.
Correct all of them.
Fixes: 171582e00db1 ("arm64: dts: rockchip: add support for firefly-rk3399 board")
Fixes: 2c66fc34e945 ("arm64: dts: rockchip: add RK3399-Q7 (Puma) SoM")
Fixes: 8164a84cca12 ("arm64: dts: rockchip: Add support for rk3399 sapphire SOM")
Cc: stable@vger.kernel.org
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Add a pinctrl setting to configure the cec pin to the correct function.
Signed-off-by: Pierre-Hugues Husson <phh@phh.me>
The Firefly-RK3399 uses serial2 with 1,500,000 baud by default
for communication in U-Boot and in the vendor provided distros.
So let us set the same default in the Linux kernel.
Enable the graphics-related nodes on the rk3399-firefly which makes
it possible to see output on the on-board hdmi output.
Add opp tables for cpu cluster0 and cluster1 by including
rk3399-opp.dtsi.
Signed-off-by: Jianqun Xu <jay.xu@rock-chips.com>
This allows basic support for SD highspeed cards but no UHS-I mode
got ready due to the propagated defer-probe error from RK805.
Cc: Kever Yang <kever.yang@rock-chips.com>
pcie_clkreqn actually doesn't work at all, so replace it with
pcie_clkreqn_cpm.
keep-power-in-suspend was invented for SDIO only, so it should
not be used for eMMC node.
This allows basic usage of usb3 devices but no typec specific things yet.
The power-tree on the rk3399-firefly did not completely match the
documentation and vendor devicetree. It was also missing some
supply-hirarchy information and some regulator-gpio names did not
match the schematics. Fix this for the existing regulators before
introducing new things.
Firefly-rk3399 is a bord from T-Firefly, you can find detail about
it here:
http://en.t-firefly.com/en/firenow/Firefly_RK3399/
This patch add basic node for the board and make it able to bring
up.
Peripheral works:
- usb hub which connect to ehci controller;
- UART2 debug
- eMMC
- PCIe
Not work:
- USB 3.0 HOST, type-C port
- sdio, sd-card
Not test for other peripheral:
- HDMI
- Ethernet
- OPTICAL
- WiFi/BT
- MIPI CSI/DSI
- IR
- EDP/DP
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
