Verify the PCIe PLL_SYS reference clock source on EVK board.
The external OSC clock is used as PCIe REF clock source in default.
NOTE: Change the ext_osc of pcie/pcie_phy to '0' when enable SYS_PLL
clock mode.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit 1bda33273eccae3c0d878d34660eca9da1765db0)
With the driver now supporting the phy-supply property, remove the
regulator-boot-on property.
The driver does not support the 'sleep' state pinctrl. Remove it.
The PHY connected to the FEC doesn't have a seperate switchable rail.
Only the Development Board gives access to the native hdmi signals.
Move the nodes into imx8mp-verdin-dev.dtsi.
RX and TX seem to be swapped and the function is currently not
implemented. Mux the pins as GPIOs to ensure to not have two
connected outputs.
Use the correct clk as the mclk.
Additionally set the mux pad values to a more sensible value, i.e.
for inputs enable the pullup.
On the i.MX 8M Plus the 3rd LCDIF drives an on-SoC Samsung HDMI PHY
giving us native HDMI functionality.
At least the following of the configured devices work:
- Console
- eMMC
- ETH0
- ETH1
- SD_1
- USB_1 as peripheral, USB_2 as host
- CAN_1, CAN_2
Everything else is either known to not work or untested.
toradex_5.4-2.1.x-imx
Use the predefined resource name of the PMIC thermal sensor.
Related-to: ELB-3037
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Update 5.4-2.1.x-imx to v5.4.74 from [1].
[1] https://github.com/Freescale/linux-fslc
The VPU subsystem uses hardware Messaging Units (MU) for inter processor
communication with the controlling OS. The driver for the MU is implemented
as a Linux mailbox.
Enable the VPU MU in the device-tree.
Related-to: ELB-3196
This is the 5.4.76 stable release
- drivers/tty/serial/fsl_lpuart.c:
Fix merge conflict of upstream patches [86875e1d6426] and [8febdfb5973d],
which contradicted with patch [cde0cb39c0e8e] from NXP.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit b64d814257b027e29a474bcd660f6372490138c7 upstream.
Espressobin boards have 3 ethernet ports and some of them got assigned more
then one MAC address. MAC addresses are stored in U-Boot environment.
Since commit a2c7023f7075c ("net: dsa: read mac address from DT for slave
device") kernel can use MAC addresses from DT for particular DSA port.
Currently Espressobin DTS file contains alias just for ethernet0.
This patch defines additional ethernet aliases in Espressobin DTS files, so
bootloader can fill correct MAC address for DSA switch ports if more MAC
addresses were specified.
DT alias ethernet1 is used for wan port, DT aliases ethernet2 and ethernet3
are used for lan ports for both Espressobin revisions (V5 and V7).
Fixes: 5253cb8c00a6f ("arm64: dts: marvell: espressobin: add ethernet alias")
Cc: <stable@vger.kernel.org> # a2c7023f7075c: dsa: read mac address
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Andre Heider <a.heider@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
[pali: Backported Espressobin rev V5 changes to 5.4 and 4.19 versions]
[ Upstream commit a1afbbb0285797e01313779c71287d936d069245 ]
This adds the missing perpheral clock for the RNG for Amlogic G12. As
stated in amlogic,meson-rng.yaml, this isn't always necessary for the
RNG to function, but is better to have in case the clock is disabled for
some reason prior to loading.
Signed-off-by: Scott K Logan <logans@cottsay.net>
Suggested-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Link: https://lore.kernel.org/r/520a1a8ec7a958b3d918d89563ec7e93a4100a45.camel@cottsay.net
Fork and tune the device trees to support iMXQP SoC on modules
Apalis-iMX8QP.
Related-to: ELB-3036
Removed the duplicate "toradex,apalis-imx8" entries in "compatible"
strings set.
Remove iMX8QP variant from the model string as it takes its own device
tree files.
Apalis iMX8QM and iMX8QP are almost the same. Separate the common part
of device tree to use it for both these modules.
The device tree of Apalis Ixora v1.1 board is common for both
Apalis iMX8QM and Apalis iMX8QP modules. Rename the device tree
to further use it for both modules.
The device tree of Apalis Evaluation board is common for both
Currently the PCIe switch on the eval-board is not working. As the
carrier-board reset is controlled by the PCIe driver this reset
never gets deasserted.
This is a workaround until PCIe works properly.
When fsl,mii-exclusive is not specified the driver only uses the
MII bus of the fec device with dev_id=0 for both fec1 and fec2.
On the Apalis iMX8 hardware design a potential second PHY is
connected to the second MAC's MII bus.
This property is needed to select the MDIO bus coupled with fec2, if
fec2 is used. We put it in fec1 for customers so they automatically
inherit this property if they placed a PHY on their carrier-board
and copied the fec1 node.
Compare with commit 9801f2e913a2 ("net: fec: reinit MAC0 MII bus to
be used by MAC1 after resume back")
Related-to: ELB-3177
This is the 5.4.75 stable release
- drivers/i2c/busses/i2c-imx.c:
Drop NXP changes, which are covered by commit [2c58d5e0c754c] from
upstream.
- drivers/net/can/flexcan.c:
Keep NXP implementation, patch [ca10989632d88] from upstream is covered
in the NXP tree.
- drivers/usb/host/xhci.h:
Fix merge fuzz for upstream commit [2600a131e1f61]
[ Upstream commit 992d7a8b88c83c05664b649fc54501ce58e19132 ]
Add full-pwr-cycle-in-suspend property to do a graceful shutdown of
the eMMC device in system suspend.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Link: https://lore.kernel.org/r/1594989201-24228-1-git-send-email-yoshihiro.shimoda.uh@renesas.com
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
lpuart2 is the only UART where DMA request works and linux tries to use
a DMA. However this DMA does not work and output hangs, disbling the DMA
works for now.
Related-to: ELB-3178
Add initial version of LVDS panel support. Note it should
be enabled in a corresponding overlay.
Related-to: ELB-2943
This is the 5.4.73 stable release
- arch/arm/boot/dts/imx6sl.dtsi:
Commit [a1767c90194e2] in NXP tree is now covered with commit [5c4c2f437cead]
from upstream.
- drivers/gpu/drm/mxsfb/mxsfb_drv.c:
Resolve merge hunk for patch [ed8b90d303cf0] from upstream
- drivers/media/i2c/ov5640.c:
Patch [aa4bb8b8838ff] in NXP tree is now covered by patches [79ec0578c7e0a]
and [b2f8546056b35] from upstream. Changes from NXP patch [99aa4c8c18984] are
covered in upstream version as well.
- drivers/net/ethernet/freescale/fec_main.c:
Fix merge fuzz for patch [9e70485b40c83] from upstream.
- drivers/usb/cdns3/gadget.c:
Keep NXP version of the file, upstream version is not compatible.
- drivers/usb/dwc3/core.c:
- drivers/usb/dwc3/core.h:
Fix merge fuzz of patch [08045050c6bd2] together wth NXP patch [b30e41dc1e494]
- sound/soc/fsl/fsl_sai.c:
- sound/soc/fsl/fsl_sai.h:
Commit [2ea70e51eb72a] in NXP tree is now covered with commit [1ad7f52fe6683]
from upstream.
The touchscreen is a part of display panels, so move enabling it
to an overlay.
In favor to enabling in overlay, disable an lvds panel.
Make lvds panel accessible by a symbolic name.
[ Upstream commit 35292518cb0a626fcdcabf739aed75060a018ab5 ]
DT binding permits only one compatible string which was decribed in past by
commit 63cab195bf49 ("i2c: removed work arounds in i2c driver for Zynq
Ultrascale+ MPSoC").
The commit aea37006e183 ("dt-bindings: i2c: cadence: Migrate i2c-cadence
documentation to YAML") has converted binding to yaml and the following
issues is reported:
...: i2c@ff030000: compatible: Additional items are not allowed
('cdns,i2c-r1p10' was unexpected)
From schema:
.../Documentation/devicetree/bindings/i2c/cdns,i2c-r1p10.yaml fds
...: i2c@ff030000: compatible: ['cdns,i2c-r1p14', 'cdns,i2c-r1p10'] is too
long
The commit c415f9e8304a ("ARM64: zynqmp: Fix i2c node's compatible string")
has added the second compatible string but without removing origin one.
The patch is only keeping one compatible string "cdns,i2c-r1p14".
Fixes: c415f9e8304a ("ARM64: zynqmp: Fix i2c node's compatible string")
Link: https://lore.kernel.org/r/cc294ae1a79ef845af6809ddb4049f0c0f5bb87a.1598259551.git.michal.simek@xilinx.com
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 4bb1eb3cd4bd6241d5e5f99bbfd801ea5a007b6c ]
After commit 7cdf8446ed1d ("arm64: dts: actions: Add pinctrl node for
Actions Semi S700") following error has been observed while booting
Linux on Cubieboard7-lite(based on S700 SoC).
[ 0.257415] pinctrl-s700 e01b0000.pinctrl: can't request region for
resource [mem 0xe01b0000-0xe01b0fff]
[ 0.266902] pinctrl-s700: probe of e01b0000.pinctrl failed with error -16
This is due to the fact that memory range for "sps" power domain controller
clashes with pinctrl.
One way to fix it, is to limit pinctrl address range which is safe
to do as current pinctrl driver uses address range only up to 0x100.
This commit limits the pinctrl address range to 0x100 so that it doesn't
conflict with sps range.
Fixes: 7cdf8446ed1d ("arm64: dts: actions: Add pinctrl node for Actions
Semi S700")
Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Suggested-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
[ Upstream commit c91dfc9818df5f43c10c727f1cecaebdb5e2fa92 ]
According to Technical Update TN-RCT-S0352A/E, MSIOF1 DMA can only be
used with SYS-DMAC0 on R-Car E3.
Fixes: 62c0056f1c3eb15d ("arm64: dts: renesas: r8a774c0: Add MSIOF nodes")
Link: https://lore.kernel.org/r/20200917132117.8515-3-geert+renesas@glider.be
[ Upstream commit 453802c463abd003a7c38ffbc90b67ba162335b6 ]
Fixes: 8517042060b55a37 ("arm64: dts: renesas: r8a77990: Add DMA properties to MSIOF nodes")
Link: https://lore.kernel.org/r/20200917132117.8515-2-geert+renesas@glider.be
[ Upstream commit 027cca9eb5b450c3f6bb916ba999144c2ec23cb7 ]
The mdss node sets #interrupt-cells = <1>, so its interrupts
should be referenced using a single cell (in this case: only the
interrupt number).
However, right now the mdp/dsi node both have two interrupt cells
set, e.g. interrupts = <4 0>. The 0 is probably meant to say
IRQ_TYPE_NONE (= 0), but with #interrupt-cells = <1> this is
actually interpreted as a second interrupt line.
Remove the IRQ flags from both interrupts to fix this.
Fixes: 305410ffd1b2 ("arm64: dts: msm8916: Add display support")
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Link: https://lore.kernel.org/r/20200915071221.72895-5-stephan@gerhold.net
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
[ Upstream commit c2f0cbb57dbac6da3d38b47b5b96de0fe4e23884 ]
Tha parent node of "wcd_codec" specifies #address-cells = <1>
and #size-cells = <0>, which means that each resource should be
described by one cell for the address and size omitted.
However, wcd_codec currently lists 0x200 as second cell (probably
the size of the resource). When parsing this would be treated like
another memory resource - which is entirely wrong.
To quote the device tree specification [1]:
"If the parent node specifies a value of 0 for #size-cells,
the length field in the value of reg shall be omitted."
[1]: https://www.devicetree.org/specifications/
Fixes: 5582fcb3829f ("arm64: dts: apq8016-sbc: add analog audio support with multicodec")
Link: https://lore.kernel.org/r/20200915071221.72895-4-stephan@gerhold.net
[ Upstream commit e6859ae8603c5946b8f3ecbd9b4f02b72955b9d0 ]
Commit fe2aff0c574d2 ("arm64: dts: qcom: msm8916: remove unit name for thermal trip points")
removed the unit names for most of the thermal trip points defined
in msm8916.dtsi, but missed to update the one for cpu0_1-thermal.
So why wasn't this spotted by "make dtbs_check"? Apparently, the name
of the thermal zone is already invalid: thermal-zones.yaml specifies
a regex of ^[a-zA-Z][a-zA-Z0-9\\-]{1,12}-thermal$, so it is not allowed
to contain underscores. Therefore the thermal zone was never verified
using the DTB schema.
After replacing the underscore in the thermal zone name, the warning
shows up:
apq8016-sbc.dt.yaml: thermal-zones: cpu0-1-thermal:trips: 'trip-point@0'
does not match any of the regexes: '^[a-zA-Z][a-zA-Z0-9\\-_]{0,63}$', 'pinctrl-[0-9]+'
Fix up the thermal zone names and remove the unit name for the trip point.
Cc: Amit Kucheria <amit.kucheria@linaro.org>
Fixes: fe2aff0c574d2 ("arm64: dts: qcom: msm8916: remove unit name for thermal trip points")
Link: https://lore.kernel.org/r/20200915071221.72895-3-stephan@gerhold.net
[ Upstream commit 791619f66843a213784efb2f171be98933bad991 ]
The i.MX General Power Controller v2 device node was missing interrupts
property necessary to route its interrupt to GIC. This also fixes the
dbts_check warnings like:
arch/arm64/boot/dts/freescale/imx8mq-evk.dt.yaml: gpc@303a0000:
{'compatible': ... '$nodename': ['gpc@303a0000']} is not valid under any of the given schemas
arch/arm64/boot/dts/freescale/imx8mq-evk.dt.yaml: gpc@303a0000: 'interrupts' is a required property
Fixes: fdbcc04da246 ("arm64: dts: imx8mq: add GPC power domains")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
[ Upstream commit 2933bf3528007f834fb7f5eab033f9c5b0683f91 ]
H5's Mali GPU PMU is not present or working corretly although
H5 datasheet record its interrupt vector.
Adding this module will miss lead lima driver try to shutdown
it and get waiting timeout. This problem is not exposed before
lima runtime PM support is added.
Fixes: bb39ed07e55b ("arm64: dts: allwinner: h5: Add device node for Mali-450 GPU")
Signed-off-by: Qiang Yu <yuq825@gmail.com>
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
Link: https://lore.kernel.org/r/20200822062755.534761-1-yuq825@gmail.com
[ Upstream commit 1f9d87d08e4a2299e86f8a1600aedf87ecd3b636 ]
The LEDs on the vim3 are active when the gpio is high, not low.
Fixes: c6d29c66e582 ("arm64: dts: meson-g12b-khadas-vim3: add initial device-tree")
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Link: https://lore.kernel.org/r/20200803141850.172704-1-jbrunet@baylibre.com
Add aliases for the RTCs. This sets /dev/rtc0 to represent the external
RTC, potentially backuped by a coin cell on the carrier and /dev/rtc1
representing the SoC provided RTC not backuped.
Related-to: ELB-2757
This commit updates the assigned-clocks property. This commit does
multiple things:
* It changes the clocks from 12.288MHz to 12MHz as it has been on kernel
4.14 due to issues with the USB hub with 12.288MHz
* It also adds all the clocks to usb3803 node as they are used there too
Related-to: ELB-3154
the old flag power-polarity-active-high; is no longer supported by
this kernel
to which usb node they actually belong
Adds the ADC. The ADC TI TLA2024 is used. Currently there is no specific
driver for the chip and we use the ADS015 which has a compatible
programming model..
The ADS1015 additionally comparator features which are not available in
the TLA2024.
Related-to: ELB-3132
This is used to connect to the on module ADC.
This is the 5.4.71 stable release
Add a gpio pinmuxing to the i2c nodes which will allows the I2C driver
to recover from stuck communication signals.
This reworks the dtsi files to allow to also build device trees for
Verdin iMX8MM V1.1 hardware.
The module level device tree for V1.1 HW is imx8mm-verdin-v1.1.dtsi,
for V1.0 HW the imx8mm-verdin.dtsi is reworked to include the V1.1 dtsi
and then it deletes and adds whatever is different.
This commit incorporates the following HW changes:
- Changed PMIC
- Removal of ADC MAX11607 (The replacement TI TLA2024 is not yet added)
- Removal of external PCIe PHY Clock in favour of SoC provided one
- Prepare for not stuffed security alternatives SE050, ATTPM20P
- Changed pin usage, see below
Pin usage changed from V1.0 to V1.1 HW:
To ease creation of V1.0 and V1.1 device trees move all pin groups,
also wifi and nonwifi ones, into imx8mm-verdin-v1.1.dtsi and change
them as needed in imx8mm-verdin.dtsi for V1.0 HW.
The eMMC reset is now connected to the SD1_RESET_B ball.
Add it to the eMMC pin groups for V1.1.
CTRL_FORCE_OFF_MOCI# used to be controlled by SAI5_RXC in V1.0 HW. In V1.1
HW it is no longer under SW control.
Delete the unused pin group for V1.1.
Wi-Fi_WKUP_WLAN used to be controlled by SD1_RESET_B in V1.0 HW. In V1.1
HW it is controlled by SAI5_RXC.
Update the pin group for V1.1.
Related-to: ELB-3130, ELB-3136, ELB-3150
commit 263a0269a59c0b4145829462a107fe7f7327105f upstream.
Add status = "okay" to QSPI node.
Fixes: 0cb140d07fc75 ("arm64: dts: stratix10: Add QSPI support for Stratix10")
Cc: linux-stable <stable@vger.kernel.org> # >= v5.6
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
[iwamatsu: Drop arch/arm64/boot/dts/altera/socfpga_stratix10_socdk_nand.dts]
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
