Since CONFIG_IR_GPIO_CIR=y depends on RC_CORE we shouldn't explicitly
define CONFIG_RC_CORE=y in defconfig, otherwise it generates a
difference between the output of "make savedefconfig" and the actual
defconfig.
Fixes: 35c88640b846 ("MLK-20946-3: arm64: defconfig: add IR support for imx8")
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Enable RPBUS(i2c-rpmsg-imx.c) and RPMSG functions.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
Set IR built-in on imx8 boards.
Signed-off-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Enable pcie hif config for brcmfmac.
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Add spi slave mode supprot and enable spi slave time/system control
functions.
- Slave time:
The host sends 8 bytes of dummy data to get the current time
that the slave starts counting after powering on.
- System control:
The host controls the slave to shut down, restart and so on
by sending 2-byte special data.
For more details of these two functions, please see the head of
spi-slave-time.c and spi-slave-system-control.c files.
Remove explicit 'CONFIG_SND_SOC_FSL_DSP=y' because
it is already selected SND_SOC_IMX_DSP.
Reported-by: Jana Build <jana.build@nxp.com>
Reviewed-by: Cosmin-Gabriel Samoila <cosmin.samoila@nxp.com>
Signed-off-by: Daniel Baluta <daniel.baluta@nxp.com>
Add Seiko 43WVF1G panel to our defconfig.
Needed for QXP eLCDIF.
Signed-off-by: Robert Chiras <robert.chiras@nxp.com>
Finally! We register DSP as a sound card.
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com
Select I2C backend driver.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Remove explicit CONFIG_CRYPTO_SHA1=y because it is already a requirement
of other options. This makes `make savedefconfig` on arm64 have zero
diffs from arch/arm64/configs/defconfig.
Fixes: 368968e7acc2 ("MLK-16951 security: Add tcrypt to be built out as
module and other modules")
Reviewed-by: Daniel Baluta <daniel.baluta@nxp.com>
i.MX ARM64 platforms do NOT support HIBERNATION, remove
CONFIG_HIBERNATION to make the "cat /sys/power/state"
ONLY return available power states to avoid confusion.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Bai Ping <ping.bai@nxp.com>
Enable CONFIG_CRYPTO_TEST=m needed by Test / Validation Team, and then
other needed modules used by tcrypt are enbled.
Signed-off-by: Aymen Sghaier <aymen.sghaier@nxp.com>
(cherry picked from commit dcae3b446bdb542122eca2debc974e6528ff137b)
Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
For mfgtool (UUU) requirement, it needs to build in IPv6 for nfs
rootfs mount.
Generated with the following commands:
make defconfig
make savedefconfig
cp defconfig arch/arm64/configs/defconfig
Reviewed-by: Frank Li <frank.li@nxp.com>
Add support in defconfig file to enable flexcan module on imx8qm/qxp
boards
enable i2s over rpmsg
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Reviewed-by: Viorel Suman <viorel.suman@nxp.com>
(cherry picked from commit 0ee32296ec540e5c11c627012656f0373317eaac)
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS"
This reverts commit 735d90236c17c17978db9a7965d190c4e561c55d.
The change has already integrated to 4.14 kernel.
Compile tcrypt as loadable module.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Acked-by: Leonard Crestez <leonard.crestez@nxp.com>
Disable the SECT_4K setting for UBIFS test
Signed-off-by: Han Xu <han.xu@nxp.com>
Acked-by: Frank Li <frank.li@nxp.com>
(cherry picked from commit 3260c2119e21900baff5f70e903e8cf28af12068)
enable flexspi in default config file
(cherry picked from commit 81288f210cf24edfc250a7b0ea1e0c3306e737ef)
Enable ivshmem net.
The IVSHMEM net are from http://git.kiszka.org/?p=linux.git;a=shortlog;h=refs/heads/queues/jailhouse
This feature is not in Linux Upstream.
This is to support ivshmem net between cells on Jailhouse hypervisor.
(cherry picked from commit c8b1103870eebfed45b51f441265d6331dc0e084)
Select CONFIG_GPIO_SYSFS by default for i.MX arm64
platforms.
Enable synaptics touchscreen, and default build-in this touch
driver.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
enable the i.MX8MM thermal driver by default.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Enable UIO for jailhouse ivshmem.
(cherry picked from commit 2628c334868258c7b27256dacc0a295ee74d9c48)
Enable the 'IMX_SEC_DSIM' config by default in ARM64
defconfig.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
Enable the 'IMX_LCDIF_CORE' config by default in ARM64
defconfig.
When adding a new config option one should always run:
$ make savedefconfig
Tested-by: Raluca Oncioiu <raluca.oncioiu@nxp.com>
Add CONFIG_ION, CONFIG_ION_CMA_HEAP and CONFIG_ION_SYSTEM_HEAP.
Change-Id: I67825353e44fe33d79dfa4c6f3be5b92aea8f9bc
Signed-off-by: ivan.liu <xiaowen.liu@nxp.com>
Add IMX_MICFIL in arm64 defconfig.
Signed-off-by: Cosmin-Gabriel Samoila <cosmin.samoila@nxp.com>
Select the CONFIG_PWM_FSL_FTM option and build the driver
by default.
Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com>
Allow the CONFIG_SPI_IMX option to be built by default.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Enable imx8qxp adc in default
Add some necessary configs for qualcomm wifi QCA6174/QCA9377 qcacld-2.0
CLD driver and remove the ath10k configs.
(Run "make savedefconfig" to change the defconfig)
Reviewed-by: Robin Gong <yibin.gong@nxp.com>
Enable regulatory rules database config:
CONFIG_CFG80211_INTERNAL_REGDB
Reviewed-by: Haibo Chen <haibo.chen@nxp.com>
Enable i.MX8MM SoC by default.
Enable BD71837 PMIC by default.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
In order to avoid the name problem going forward with
integration with Qcom, Qcom has their own dsp and hifi
is competitor, so the hifi name should not be used in
our code.
So use the name of dsp instead of hifi to fix this
problem.
Signed-off-by: Weiguang Kong <weiguang.kong@nxp.com>
Built XEN_NETDEV_BACKEND as module, with this,
frontent side network could have network
capability with bridge set properly in Dom0.
Reviewed-by: Leonard Crestez <leonard.crestez@nxp.com>
Built-in xen block back driver to avoid insmod
xen-blkback.ko when use xvda from DomU.
Remove FB_MX8_HDMI.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
Enable CCI400 PMU config
Signed-off-by: Frank Li <Frank.Li@nxp.com>
These two configurations are needed for USB EH certification test.
Acked-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Add Kconfig and DTS support for i.MX8QP with a simplified structure
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Squashed into a single commit during 4.14 rebase.
Add usb video support by build it as module.
Acked-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Enable CONFIG_NXP_TJA110X_PHY config to support NXP TJA1100 net card
for i.MX8QM/QXP platforms.
Reviewed-by: Pandy Gao <pandy.gao@nxp.com>
This patch:
- Adds compilation of the secvio driver for all arm64 targets
- Adds the secvio driver to fsl-imx8mq.dtsi
Add max732x config enable.
Acked-by: Gao Pan <pandy.gao@nxp.com>
build in AK4458, AK5558, AK4497
enable EMVSIM in defconfig
Signed-off-by: Gao Pan <pandy.gao@nxp.com>
Reviewed-by: Andy Duan <fugang.duan@nxp.com>
