This ensures all stub component are freed when the kernel proper is
done booting, by prefixing the names of all ELF sections that have
the SHF_ALLOC attribute with ".init". This approach ensures that even
implicitly emitted allocated data (like initializer values and string
literals) are covered.
At the same time, remove some __init annotations in the stub that have
now become redundant, and add the __init annotation to handle_kernel_image
which will now trigger a section mismatch warning without it.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
If we cannot relocate the kernel Image to its preferred offset of base of DRAM
plus TEXT_OFFSET, instead relocate it to the lowest available 2 MB boundary plus
TEXT_OFFSET. We may lose a bit of memory at the low end, but we can still
proceed normally otherwise.
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Leif Lindholm <leif.lindholm@linaro.org>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
This patch changes both x86 and arm64 efistub implementations
from #including shared .c files under drivers/firmware/efi to
building shared code as a static library.
The x86 code uses a stub built into the boot executable which
uncompresses the kernel at boot time. In this case, the library is
linked into the decompressor.
In the arm64 case, the stub is part of the kernel proper so the library
is linked into the kernel proper as well.
In order to move from the #include "../../../xxxxx.c" anti-pattern used
by both the x86 and arm64 versions of the stub to a static library
linked into either the kernel proper (arm64) or a separate boot
executable (x86), there is some prepatory work required.
This patch does the following:
- move forward declarations of functions shared between the arch
specific and the generic parts of the stub to include/linux/efi.h
- move forward declarations of functions shared between various .c files
of the generic stub code to a new local header file called "efistub.h"
- add #includes to all .c files which were formerly relying on the
#includor to include the correct header files
- remove all static modifiers from functions which will need to be
externally visible once we move to a static library
This moves definitions depended upon both by code under arch/arm64/boot
and under drivers/firmware/efi to <asm/efi.h>. This is in preparation of
turning the stub code under drivers/firmware/efi into a static library.
As EFI_ERROR is not a UEFI result code but a local invention only
intended to allow get_dram_base() to signal failure, we should not use
it elsewhere.
Replace with EFI_LOAD_ERROR.
The shared efistub code for ARM and arm64 contains a local copy of
linux_banner, allowing it to be referenced from separate executables
such as the ARM decompressor. However, this introduces a dependency on
generated header files, causing unnecessary rebuilds of the stub itself
and, in case of arm64, vmlinux which contains it.
On arm64, the copy is not actually needed since we can reference the
original symbol directly, and as it turns out, there may be better ways
to deal with this for ARM as well, so let's remove it from the shared
code. If it still needs to be reintroduced for ARM later, it should live
under arch/arm anyway and not in shared code.
Acked-by: Will Deacon <will.deacon@arm.com>
This patch adds PE/COFF header fields to the start of the kernel
Image so that it appears as an EFI application to UEFI firmware.
An EFI stub is included to allow direct booting of the kernel
Image.
Signed-off-by: Mark Salter <msalter@redhat.com>
[Add support in PE/COFF header for signed images]
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
