System register accesses also use zero register for Rt == 31, and
therefore using it will also result in getting SP value instead. This
patch makes them also using new accessors, introduced by the previous
patch. Since register value is no longer directly associated with storage
inside vCPU context structure, we introduce a dedicated storage for it in
struct sys_reg_params.
This refactor also gets rid of "massive hack" in kvm_handle_cp_64().
Signed-off-by: Pavel Fedin <p.fedin@samsung.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Further rework is going to introduce a dedicated storage for transfer
register value in struct sys_reg_params. Before doing this we have to
remove 'const' modifiers from it in all accessor functions and their
callers.
This patch adds a generic ARM v8 KVM target cpu type for use
by the new CPUs which eventualy ends up using the common sys_reg
table. For backward compatibility the existing targets have been
preserved. Any new target CPU that can be covered by generic v8
sys_reg tables should make use of the new generic target.
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Acked-by: Marc Zyngier <Marc.Zyngier@arm.com>
In order to allow KVM to run on Cortex-A53 implementations, wire the
minimal support required.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
This patch allows us to have X-Gene guest VCPU when using KVM arm64
on APM X-Gene host.
We add KVM_ARM_TARGET_XGENE_POTENZA for X-Gene Potenza compatible
guest VCPU and we return KVM_ARM_TARGET_XGENE_POTENZA in kvm_target_cpu()
when running on X-Gene host with Potenza core.
[maz: sanitized the commit log]
Signed-off-by: Anup Patel <anup.patel@linaro.org>
Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org>
Enable handling of CPU specific 32bit coprocessor access. Not much
here either.
Reviewed-by: Christopher Covington <cov@codeaurora.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Add the support code for CPU specific system registers. Not much
here yet.
