This patch enables both RXC and TXC 2ns dll delay lines on the
KSZ9131 PHY. Both are neede because the i.MX8MM SoC is RGMII v1.3
compliant. This means we need the TXC delay of the PHY.
Related-to: ELB-1299
The RXC delay is provided in both PHYs used (KSZ9031 and KSZ9131)
on the PHY itself so it is not needed on the MAC.
Add CTRL_SLEEP_MOCI required for e.g. the Dahlia carrier board.
Related-to: ELB-2520
The hardware of verdin has some bypass caps after the switch that
switches power to the sd-card. These caps are resulting in a slow
discharge.
Add off-on-delay to set a minimum off-time of the regulator so it
can fully discharge until it turns on again.
This commit basically deletes the devicetree for V1.0 Apalis iMX8
modules. It includes V1.1 devicetree then and only puts in the
differences and deletes the nodes that are not used in V1.0.
This is done to prevent code duplication and have better overview of
what has changed.
Related-to: ELB-1254
This commit does no code changes it just copies fsl-imx8qm-apalis.dtsi
to fsl-imx8qm-apalis-v1.1.dtsi.
This is done to be able to track changes made between those versions.
Related-to: ELB-2289
Related-to: ELB-2359
Note: there is still backfeeding present at this moment from those pads:
SC_P_ENET0_RGMII_TXD0
SC_P_ENET0_RGMII_TXD1
SC_P_ENET0_RGMII_RXD0
SC_P_ENET0_RGMII_RXD1
Add a 'sleep' pinmuxing which prevents driving RGMII pins and backfeed the
unpowered Ethernet PHY.
When switching the Ethernet PHY supply off, it takes about 400 ms for
the PHY power to go down. So wait a minimum of 500 ms before reenabling
the PHY supply.
Related-to: HAR-2339
After the Ethernet PHY supply is enabled an RC holds the reset asserted
for about 120 ms. Reduce the time waited from 1000 ms to 200 ms which
should account for any possible tolerance.
U-Boot enables the PHY supply, switching it off in Linux with the RGMII
pins allready muxed creates backfeeding, thus set regulator-boot-on.
The driver now checks the fuses for a disabled DSP. Thus enable the DSP
device in the device tree and let the driver decide at run-time if the
DSP can be used or not.
This reverts commit 862886b0c48296d34b0e63d7497fa671e6fe25d7.
Related-to: ELB-1380
toradex_4.14-2.0.x-imx-next
sound/soc/codecs/sgtl5000.c
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit 5b78012636f537344bd551934387f5772c38ba80 ]
The gpio line names were set in the pinctrl node instead of the gpio node,
at the time it was merged, it worked, but was obviously wrong.
This patch moves the properties to the gpio nodes.
Fixes: 60795933b709 ("ARM64: dts: meson-gxl-khadas-vim: Add GPIO lines names")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
[ Upstream commit 2165b006b65d609140dafafcb14cce5a4aaacbab ]
Fixes: b03c7d6438bb ("ARM64: dts: meson-gxbb-odroidc2: Add GPIO lines names")
[ Upstream commit f0783f5edb52af14ecaae6c5ce4f38e0a358f5d8 ]
Fixes: 12ada0513d7a ("ARM64: dts: meson-gxbb-nanopi-k2: Add GPIO lines names")
[ Upstream commit 11fa9774612decea87144d7f950a9c53a4fe3050 ]
Fixes: 47884c5c746e ("ARM64: dts: meson-gxl-libretech-cc: Add GPIO lines names")
commit 1e5e929c009559bd7e898ac8e17a5d01037cb057 upstream.
Commit 34993594181d ("arm64: tegra: Enable HDMI on Jetson TX1")
added a regulator for HDMI on the Jetson TX1 platform. This regulator
has an active high enable, but the GPIO specifier for enabling the
regulator incorrectly defines it as active-low. This causes the
following warning to occur on boot ...
WARNING KERN regulator@10 GPIO handle specifies active low - ignored
The fixed-regulator binding does not use the active-low flag from the
gpio specifier and purely relies of the presence of the
'enable-active-high' property to determine if it is active high or low
(if this property is omitted). Fix this warning by setting the GPIO
to active-high in the GPIO specifier which aligns with the presense of
the 'enable-active-high' property.
Fixes: 34993594181d ("arm64: tegra: Enable HDMI on Jetson TX1")
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Use a OV5640 camera driver which works with the i.MX8 MM camera stack.
gst-launch-1.0 v4l2src device='/dev/video0' ! video/x-raw,format=YUY2,width=1920,height=1080,framerate=30/1 ! waylandsink
This reverts commit d9003e67cdd76aa83324159838b2725411d45c15.
On Verdin iMX8M Mini the OV5640_MIPI_NV driver does not work while it does
with the original NXP driver OV5640_MIPI_V2.
The Apalis iMX8QM still works.
[ Upstream commit f357b3a7e17af7736d67d8267edc1ed3d1dd9391 ]
The __cpu_up() routine ignores the errors reported by the firmware
for a CPU bringup operation and looks for the error status set by the
booting CPU. If the CPU never entered the kernel, we could end up
in assuming stale error status, which otherwise would have been
set/cleared appropriately by the booting CPU.
Reported-by: Steve Capper <steve.capper@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit a96a33b1ca57dbea4285893dedf290aeb8eb090b ]
For cases where there is a mismatch in ARMv8.2-LVA support between CPUs
we have to be careful in allowing secondary CPUs to boot if 52-bit
virtual addresses have already been enabled on the boot CPU.
This patch adds code to the secondary startup path. If the boot CPU has
enabled 52-bit VAs then ID_AA64MMFR2_EL1 is checked to see if the
secondary can also enable 52-bit support. If not, the secondary is
prevented from booting and an error message is displayed indicating why.
Technically this patch could be implemented using the cpufeature code
when considering 52-bit userspace support. However, we employ low level
checks here as the cpufeature code won't be able to run if we have
mismatched 52-bit kernel va support.
Signed-off-by: Steve Capper <steve.capper@arm.com>
Toradex USB WiFi module LM816 uses RTL8188EUS wi-fi chip.
There is staging working driver in kernel for this chip.
Enabling it makes one able to use LM816 wifi usb dongle
"from the box" w/o installing additional software.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Ixora board has several differences from the Apalis Evaluation one.
Some important differences are reflected in personalized device-tree files.
This patch adds the device tree to support Toradex Verdin iMX8M Mini a
computer on module which can be used on different carrier boards.
The module consists of an NXP i.MX 8M Mini family SoC, a Rohm BD71847
PMIC, a Gigabit Ethernet PHY, 2 GB of LPDDR4 RAM, an eMMC, an ADC, a
Secure Element, an EEPROM, an RTC, USB host and OTG ports, PCIe and
MIPI-CSI2/DSI interfaces plus optional Bluetooth/Wi-Fi module and CAN
controllers.
Anything that is not self-contained on the module is disabled by
default.
The device tree for the Verdin Development Board includes the module's
device tree and enables the supported peripherals of the carrier board
(the Verdin Development Board supports almost all of them).
Not yet tested:
- all UARTs other than console/debug Verdin UART_3
- push button controller on carrier board
- JTAG
- I2S to Wi-Fi
- I2S to DSI Mezzanine
Not yet working:
- carrier board audio
- MIPI-CSI2
- carrier board power gating
- FTDI control signals and JTAG
On Verdin iMX8MM ADC is provided by a MAX11607.
On Verdin iMX8MM Development board the CAN-FD controller Microchip
MCP2518FD is used.
Enable the driver which got backported from linux-can-next.git,
branch mcp25xxfd-rpi.
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
On Verdin iMX8MM the Wi-Fi module is connected through SDIO.
Add this driver variant.
On Verdin iMX8MM Development board this codec is used.
commit e4ba15debcfd27f60d43da940a58108783bff2a6 upstream.
The bad_mode() handler is called if we encounter an uunknown exception,
with the expectation that the subsequent call to panic() will halt the
system. Unfortunately, if the exception calling bad_mode() is taken from
EL0, then the call to die() can end up killing the current user task and
calling schedule() instead of falling through to panic().
Remove the die() call altogether, since we really want to bring down the
machine in this "impossible" case.
Signed-off-by: Hari Vyas <hari.vyas@broadcom.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit 98356eb0ae499c63e78073ccedd9a5fc5c563288 ]
After 'a66649dab350 arm64: fix vdso-offsets.h dependency' if
one will try to build .i file in case of external kernel module,
build fails complaining that prepare0 target is missing. This
issue came up with SystemTap when it tries to build variety
of .i files for its own generated kernel modules trying to
figure given kernel features/capabilities.
The issue is that prepare0 is defined in top level Makefile
only if KBUILD_EXTMOD is not defined. .i file rule depends
on prepare and in case KBUILD_EXTMOD defined top level Makefile
contains empty rule for prepare. But after mentioned commit
arch/arm64/Makefile would introduce dependency on prepare0
through its own prepare target.
Fix it to put proper ifdef KBUILD_EXTMOD around code introduced
by mentioned commit. It matches what top level Makefile does.
Acked-by: Kevin Brodsky <kevin.brodsky@arm.com>
Signed-off-by: Victor Kamensky <kamensky@cisco.com>
[ Upstream commit 19a2ca0fb560fd7be7b5293c6b652c6d6078dcde ]
ARM64 has asm implementation of memchr(), memcmp(), str[r]chr(),
str[n]cmp(), str[n]len(). KASAN don't see memory accesses in asm code,
thus it can potentially miss many bugs.
Ifdef out __HAVE_ARCH_* defines of these functions when KASAN is enabled,
so the generic implementations from lib/string.c will be used.
We can't just remove the asm functions because efistub uses them. And we
can't have two non-weak functions either, so declare the asm functions as
weak.
Link: http://lkml.kernel.org/r/20180920135631.23833-2-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reported-by: Kyeongdon Kim <kyeongdon.kim@lge.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Mark Rutland <mark.rutland@arm.com>
This fixes the following device tree compilation issue as introduced by
the previous commit 621db2fdb2e1 ("arm64: dts: apalis-imx8x: add adv7280
to devicetree"):
DTC arch/arm64/boot/dts/freescale/fsl-imx8qxp-apalis-eval.dtb
arch/arm64/boot/dts/freescale/fsl-imx8qxp-apalis-eval.dtb: ERROR
(phandle_references): Reference to non-existent node or label
"adv7280_ep"
This patch adds the adv7280 to the devicetree and makes changes that
are necessary for parallel-CSI.
This reverts commit c1e7d4fc8c1b9bd599eed9cf848eff3ed9a34637.
Adding pcie_per leads to eventual kernel panics on boot for Apalis
iMX8QM modules.
Related-To: #58016
