Commit f014b5b3b3ab added an additional clock to ahci_imx.c used
on i.MX8. Add a dummy clock to imx6q.dtsi so that i.MX6 which doesn't
need the clock the driver keeps working.
Fixes:
[ 2.053942] ahci-imx 2200000.sata: can't get sata_ext clock.
[ 2.053962] ahci-imx: probe of 2200000.sata failed with error -2
commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[bwh: Backported to 4.14 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Fixes: commit: 5d2a26667010640e33ca0a52c73310f158179711
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
[ Upstream commit d64b212ea960db4276a1d8372bd98cb861dfcbb0 ]
When building a multiplatform kernel that includes armv4 support,
the default target CPU does not support the blx instruction,
which leads to a build failure:
arch/arm/mach-davinci/sleep.S: Assembler messages:
arch/arm/mach-davinci/sleep.S:56: Error: selected processor does not support `blx ip' in ARM mode
Add a .arch statement in the sources to make this file build.
Link: https://lore.kernel.org/r/20190722145211.1154785-1-arnd@arndb.de
Acked-by: Sekhar Nori <nsekhar@ti.com>
According to manual of I2C bus, both signals sda/scl are "open drain".
Fix flags for all affected Toradex boards.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
scl-gpios should be (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN) since
commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery GPIO")
Fix on-boot warning:
"enforced open drain please flag it properly in DT/ACPI DSDT/board file"
[ Upstream commit a135a392acbec7ecda782981788e8c03767a1571 ]
Since I2C1 and I2C4 have explicit pinmuxing set, let's be on the
safe side and set the pin muxing for I2C2 and I2C3.
[ Upstream commit 5fe3c0fa0d54877c65e7c9b4442aeeb25cdf469a ]
[ Upstream commit 8ef1ba39a9fa53d2205e633bc9b21840a275908e ]
This is similar to commit e6186820a745 ("arm64: dts: rockchip: Arch
counter doesn't tick in system suspend"). Specifically on the rk3288
it can be seen that the timer stops ticking in suspend if we end up
running through the "osc_disable" path in rk3288_slp_mode_set(). In
that path the 24 MHz clock will turn off and the timer stops.
To test this, I ran this on a Chrome OS filesystem:
before=$(date); \
suspend_stress_test -c1 --suspend_min=30 --suspend_max=31; \
echo ${before}; date
...and I found that unless I plug in a device that requests USB wakeup
to be active that the two calls to "date" would show that fewer than
30 seconds passed.
NOTE: deep suspend (where the 24 MHz clock gets disabled) isn't
supported yet on upstream Linux so this was tested on a downstream
kernel.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit 99fa066710f75f18f4d9a5bc5f6a711968a581d5 ]
When I try to boot rk3288-veyron-mickey I totally fail to make the
eMMC work. Specifically my logs (on Chrome OS 4.19):
mmc_host mmc1: card is non-removable.
mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
mmc1: switch to bus width 8 failed
mmc1: switch to bus width 4 failed
mmc1: new high speed MMC card at address 0001
mmcblk1: mmc1:0001 HAG2e 14.7 GiB
mmcblk1boot0: mmc1:0001 HAG2e partition 1 4.00 MiB
mmcblk1boot1: mmc1:0001 HAG2e partition 2 4.00 MiB
mmcblk1rpmb: mmc1:0001 HAG2e partition 3 4.00 MiB, chardev (243:0)
mmc1: tried to HW reset card, got error -110
mmcblk1: error -110 requesting status
mmcblk1: recovery failed!
print_req_error: I/O error, dev mmcblk1, sector 0
When I remove the '/delete-property/mmc-hs200-1_8v' then everything is
hunky dory.
That line comes from the original submission of the mickey dts
upstream, so presumably at the time the HS200 was failing and just
enumerating things as a high speed device was fine. ...or maybe it's
just that some mickey devices work when enumerating at "high speed",
just not mine?
In any case, hs200 seems good now. Let's turn it on.
[ Upstream commit 1c0479023412ab7834f2e98b796eb0d8c627cd62 ]
As some point hs200 was failing on rk3288-veyron-minnie. See commit
984926781122 ("ARM: dts: rockchip: temporarily remove emmc hs200 speed
from rk3288 minnie"). Although I didn't track down exactly when it
started working, it seems to work OK now, so let's turn it back on.
To test this, I booted from SD card and then used this script to
stress the enumeration process after fixing a memory leak [1]:
cd /sys/bus/platform/drivers/dwmmc_rockchip
for i in $(seq 1 3000); do
echo "========================" $i
echo ff0f0000.dwmmc > unbind
sleep .5
echo ff0f0000.dwmmc > bind
while true; do
if [ -e /dev/mmcblk2 ]; then
break;
fi
sleep .1
done
done
It worked fine.
[1] https://lkml.kernel.org/r/20190503233526.226272-1-dianders@chromium.org
[ Upstream commit ffd9a1ba9fdb7f2bd1d1ad9b9243d34e96756ba2 ]
DMA got broken a while back in two different ways:
1) a change in the behaviour of disable_irq() to wait for the interrupt
to finish executing causes us to deadlock at the end of DMA.
2) a change to avoid modifying the scatterlist left the first transfer
uninitialised.
DMA is only used with expansion cards, so has gone unnoticed.
Fixes: fa4e99899932 ("[ARM] dma: RiscPC: don't modify DMA SG entries")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit 3cf10132ac8d536565f2c02f60a3aeb315863a52 ]
According to the i.MX6UL/L RM, table 3.1 "ARM Cortex A7 domain interrupt
summary", the interrupts for the PWM[1-4] go from 83 to 86.
Fixes: b9901fe84f02 ("ARM: dts: imx6ul: add pwm[1-4] nodes")
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit 27e23d8975270df6999f8b5b3156fc0c04927451 ]
omap3xxx_prm_enable_io_wakeup() is marked __init, but its caller is not, so
we get a warning with clang-8:
WARNING: vmlinux.o(.text+0x343c8): Section mismatch in reference from the function omap3xxx_prm_late_init() to the function .init.text:omap3xxx_prm_enable_io_wakeup()
The function omap3xxx_prm_late_init() references
the function __init omap3xxx_prm_enable_io_wakeup().
This is often because omap3xxx_prm_late_init lacks a __init
annotation or the annotation of omap3xxx_prm_enable_io_wakeup is wrong.
When building with gcc, omap3xxx_prm_enable_io_wakeup() is always
inlined, so we never noticed in the past.
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Andrew Murray <andrew.murray@arm.com>
[ Upstream commit 68f2515bb31a664ba3e2bc1eb78dd9f529b10067 ]
The lcdc device is missing the dma_coherent_mask definition causing the
following warning on da850-evm:
da8xx_lcdc da8xx_lcdc.0: found Sharp_LK043T1DG01 panel
WARNING: CPU: 0 PID: 1 at kernel/dma/mapping.c:247 dma_alloc_attrs+0xc8/0x110
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 5.2.0-rc3-00077-g16d72dd4891f #18
Hardware name: DaVinci DA850/OMAP-L138/AM18x EVM
[<c000fce8>] (unwind_backtrace) from [<c000d900>] (show_stack+0x10/0x14)
[<c000d900>] (show_stack) from [<c001a4f8>] (__warn+0xec/0x114)
[<c001a4f8>] (__warn) from [<c001a634>] (warn_slowpath_null+0x3c/0x48)
[<c001a634>] (warn_slowpath_null) from [<c0065860>] (dma_alloc_attrs+0xc8/0x110)
[<c0065860>] (dma_alloc_attrs) from [<c02820f8>] (fb_probe+0x228/0x5a8)
[<c02820f8>] (fb_probe) from [<c02d3e9c>] (platform_drv_probe+0x48/0x9c)
[<c02d3e9c>] (platform_drv_probe) from [<c02d221c>] (really_probe+0x1d8/0x2d4)
[<c02d221c>] (really_probe) from [<c02d2474>] (driver_probe_device+0x5c/0x168)
[<c02d2474>] (driver_probe_device) from [<c02d2728>] (device_driver_attach+0x58/0x60)
[<c02d2728>] (device_driver_attach) from [<c02d27b0>] (__driver_attach+0x80/0xbc)
[<c02d27b0>] (__driver_attach) from [<c02d047c>] (bus_for_each_dev+0x64/0xb4)
[<c02d047c>] (bus_for_each_dev) from [<c02d1590>] (bus_add_driver+0xe4/0x1d8)
[<c02d1590>] (bus_add_driver) from [<c02d301c>] (driver_register+0x78/0x10c)
[<c02d301c>] (driver_register) from [<c000a5c0>] (do_one_initcall+0x48/0x1bc)
[<c000a5c0>] (do_one_initcall) from [<c05cae6c>] (kernel_init_freeable+0x10c/0x1d8)
[<c05cae6c>] (kernel_init_freeable) from [<c048a000>] (kernel_init+0x8/0xf4)
[<c048a000>] (kernel_init) from [<c00090e0>] (ret_from_fork+0x14/0x34)
Exception stack(0xc6837fb0 to 0xc6837ff8)
7fa0: 00000000 00000000 00000000 00000000
7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
---[ end trace 8a8073511be81dd2 ]---
Add a 32-bit mask to the platform device's definition.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit 0c0c9b5753cd04601b17de09da1ed2885a3b42fe ]
The BB expander at 0x21 i2c bus 1 fails to probe on da850-evm because
the board doesn't set has_full_constraints to true in the regulator
API.
Call regulator_has_full_constraints() at the end of board registration
just like we do in da850-lcdk and da830-evm.
[ Upstream commit 8a0098c05a272c9a68f6885e09755755b612459c ]
Active level of the mmc1 cd gpio needs to be low instead of high.
Fix PCM-953 and phyBOARD-WEGA.
Signed-off-by: Teresa Remmet <t.remmet@phytec.de>
Fix commit '46a30aca7f5c MLK-20052 L2 Cache TEE/Linux shared mutex' when
CONFIG_OPTEE is not defined. Compiler warning:
| arch/arm/mm/cache-l2x0.c:151:12: warning: ‘l2c_set_mutex’ defined but not used [-Wunused-function]
fns.set_mutex and l2c_set_mutex() are guarded by CONFIG_OPTEE.
On top of that the function pointer is tested for NULL before calling.
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
Usdhc1 had wrong stuff in it due to the merge request. Fix that
In order for the otg ports, that these modules support, it is needed
that dr_mode is on otg. Switch to use that feature.
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
There where some defconfigs missed in the commit with the same name
before, correct that.
commit 88a748419b84187fd1da05637b8e5928b04a1e06 upstream.
If UHS speed modes are enabled, a compatible SD card switches down to
1.8V during enumeration. If after this a software reboot/crash takes
place and on-chip ROM tries to enumerate the SD card, the difference in
IO voltages (host @ 3.3V and card @ 1.8V) may end up damaging the card.
The fix for this is to have support for power cycling the card in
hardware (with a PORz/soft-reset line causing a power cycle of the
card). Since am571x-, am572x- and am574x-idk don't have this
capability, disable voltage switching for these boards.
The major effect of this is that the maximum supported speed
mode is now high speed(50 MHz) down from SDR104(200 MHz).
Cc: <stable@vger.kernel.org>
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
commit b25af2ff7c07bd19af74e3f64ff82e2880d13d81 upstream.
Since commit 1e434b703248 ("ARM: imx: update the cpu power up timing
setting on i.mx6sx") some characters loss is noticed on i.MX6ULL UART
as reported by Christoph Niedermaier.
The intention of such commit was to increase the SW2ISO field for i.MX6SX
only, but since cpuidle-imx6sx is also used on i.MX6UL/i.MX6ULL this caused
unintended side effects on other SoCs.
Fix this problem by keeping the original SW2ISO value for i.MX6UL/i.MX6ULL
and only increase SW2ISO in the i.MX6SX case.
Cc: stable@vger.kernel.org
Fixes: 1e434b703248 ("ARM: imx: update the cpu power up timing setting on i.mx6sx")
Reported-by: Christoph Niedermaier <cniedermaier@dh-electronics.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Tested-by: Christoph Niedermaier <cniedermaier@dh-electronics.com>
Avoid the following spew:
[ 2.083946] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin MX7D_PAD_GPIO1_IO01
already requested by 302c0000.iomuxc-lpsr; cannot claim for gpio-keys
[ 2.099682] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin-1 (gpio-keys) status -22
[ 2.108272] imx7d-pinctrl 302c0000.iomuxc-lpsr: could not request pin 1
(MX7D_PAD_GPIO1_IO01) from group gpiokeysgrp on device 302c0000.iomuxc-lpsr
[ 2.124626] gpio-keys gpio-keys: Error applying setting, reverse things back
[ 2.133420] gpio-keys: probe of gpio-keys failed with error -22
While at it also fix some missing new lines.
Further clean-up Apalis iMX6 device trees.
No options where added or removed in this commit. A simple
make (apalis|colibri)*_defconfig
make savedefconfig
cp defconfig arch/arm/boot/(apalis|colibri)*_defconfig
While at it, add the dtbs for Aster Carrier Board to the Makefile.
In 4.14 devicetress are based on the mainline DT's and only necessary
stuff for downstream is put into those devicetrees.
This commit holds the changes for imx6ull*colibri* from 4.9.
This commit holds the changes for imx6*(colibri|apalis)* from 4.9.
This commit adds the mipi_csi node to Toradex's evalboard as found
on the mezzanine connector
Those devices are used in conjunction with Toradex's carrier boards.
This commit adds the touchscreens from Toradex so one can enable it.
- fix the name of pinctrl set for i2c2 recovery mode;
- add recovery mode for applicable i2c buses for
Apalis/Colibri iMX6Q/D/DL modules.
Related to: #49059
(cherry picked from commit 1501883b4682178e38afc3f08b221f9477fcd7ae)
This patch prepares the devicetree for the new Ixora V1.2 where we are
able to turn off the supply of the can transceiver. This implies to use
a sleep state on transmission pins in order to prevent backfeeding.
(cherry picked from commit c1016f5da0dbb8291575949e7f4a417c6306d70a)
Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry-picked from 7ffa92d64cc7a6331faaae3e2507458461ab90f3)
Add the phy-node and mdio bus to the fec-node, represented as is on
hardware.
This commit includes micrel,led-mode that is set to the default
value, prepared for someone who wants to change this.
(cherry-picked from 03ff3610434d89fc8e20b280e1219ce0ebb08935)
This adds the muxing for the optional pins usb-oc (overcurrent) and
usb-id.
Commit 41ec065fc5841 fixes ecspi sdma script type for spi1-4 only.
Commit df07101e1c4a2 sets wrong type of sdma script for SPI5.
The workaroud sdma script NOT work in SPBA bus, so return back
the correct sdma script type for spi5.
Related to: #48675
(cherry picked from commit bbe2052f145e8afbebc46d47a439f72250998539)
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5.
MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference
Manual. Tested playback and record on pulseaudio with 44.1kHz samples.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
(cherry picked from commit 58e5313d36b969029d76b1ef45d3224c8557af75)
(cherry picked from commit d1c393ddcb6937b58fa3a9314c8b6f2382b346dc)
(cherry picked from commit a9dc775e6796488a3de676e1736d88560d181138)
