It will remove TEGRA_DC_FLAG_ENABLED flag in dc1
platform data, so display controller 1 enabling
in DC probe will be skipped.
Bug 1270114
Bug 1367030
Change-Id: I09489d18cfdb881b1b3a522339aab6afdd93489a
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/300386
GVS: Gerrit_Virtual_Submit
Reviewed-by: Gabby Lee <galee@nvidia.com>
display controller 1 probe is not required in charging
mode. Do not populate dc1, so its probe will be fail.
Bug 1367030
Change-Id: Ic31cd6d2291619f709e367b4d1be119737e15acb
Reviewed-on: http://git-master/r/299428
Set battery id check flag of max17048 and add ADC pdata of Batt_ID channel.
Bug 1368059
Change-Id: I918a6e063fc01132931aaf84c9cb09deaaa16b6b
Signed-off-by: Hyongbin Kim <hyongbink@nvidia.com>
Reviewed-on: http://git-master/r/299289
Tested-by: Gabby Lee <galee@nvidia.com>
Updated Micron 1GB MT41K128M16-125 dvfs table to v9.0.
Bug 1280381
Change-Id: Ibfc9fddc28c75785ff3df18193cb8d7c1751d473
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/281603
For fix USB Device Receiver Sensitivity fail, reduce hs_squelch level
from 112.5mV(2b'10) to 100mV(2b'01).
Bug 1349951
Change-Id: I3588fc3a9b4ee2486274872d55a30e575cf6d5e2
Reviewed-on: http://git-master/r/280707
Change VD_DDR_R(smps7) to 1.38V for DDR3 stability
Bug 1280381
Change-Id: I4735621fb53b490de2a58bc5218beb2d90ac38f6
Signed-off-by: Yong Goo Yi <yyi@nvidia.com>
Reviewed-on: http://git-master/r/279329
Updated Micron 1GB MT41K128M16-125 dvfs table to v8.0.
Bug 1280381
Change-Id: Ibcaceb15de6a4b1d9c95c3e7fa81e65afc1830ca
Reviewed-on: http://git-master/r/280320
To save charger boot mode boot time, skip hdmi init code.
Bug 1367030
Change-Id: I34ab00a1fa06c0d0819bb76e557860920f78892d
Reviewed-on: http://git-master/r/273601
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
In charger mode, sdhci2(External SD), sdhci0(Wifi) is not used.
Skip register to save boot time.
Bug 1367030
Change-Id: I297494976c8f0a50244638fc7c62916548c082e7
Reviewed-on: http://git-master/r/273600
Reviewed-by: Harry Hong <hhong@nvidia.com>
Change default brightness to 153, which is 60% compared
to max brightness
Bug 1353323
Change-Id: Ia2e35da24ff2a71c192b8436cc16b909b4d68aaa
Reviewed-on: http://git-master/r/278300
We don't support DVT1(non reversed panel) device. So we don't need to
support touch_fusion and touch_fusion_rd together. We will use
touch_fusion for reversed panel.
Change-Id: I576f926463c69e1a033b763e5e5c2207e373baa6
Signed-off-by: Bo Kim <bok@nvidia.com>
Reviewed-on: http://git-master/r/272926
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Added tegratab dvfs table in device tree.
This DT dvfs table is including a ram-code property to support multiple
devices of emc.
- ram-code = 0: Micron 1GB
- ram-code = 1: Hynix 1GB
Bug 1352073
Change-Id: I0353d9451043352c033cdcdee5b178d4c736f901
Reviewed-on: http://git-master/r/271985
Use ram code depending on each TegraTab H/W revisions.
Bug 1352073
Change-Id: I92d6267c6f352f3bb788a47db661b4b3499e4327
Reviewed-on: http://git-master/r/272929
The Undef abort handler in the kernel reads the undefined instruction
from user space. If the page table was modified from another CPU, the
user access could fail and do_page_fault() will be executed with
interrupts disabled. This can potentially deadlock on ARM11MPCore or on
Cortex-A15 with erratum 798181 workaround enabled (both implying IPI for
TLB maintenance with page table lock held).
This patch enables the IRQs in __und_usr before attempting to read the
instruction from user space.
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Change-Id: Ie5164d8ada9646d723b2b6ef65797e9307718292
Reviewed-on: http://git-master/r/264300
(cherry picked from commit 099ae886a528059cdda926ce1701caaaeaa9e0e8)
Reviewed-on: http://git-master/r/267818
(cherry picked from commit 4b351ab2f929717d7e3c665828c6c9cff5fd4d33)
Reviewed-on: http://git-master/r/273633
Tested-by: Harry Hong <hhong@nvidia.com>
Update CMU calibration data. Normalized matrix is chosen
for CMU csc matrix.
Bug 1354492
Change-Id: I79dde8f33ff89bf261c70a65365eb5555a5e4cd5
Reviewed-on: http://git-master/r/272948
Bug 1356943
Change-Id: If34b39b849e350fd9312b9a73130db13c3571b4c
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/272840
Corrected a wrong device node pointer passing.
Bug 1352073
Change-Id: Ib4354e0b74d1babf671d141cea238e9a55299343
Reviewed-on: http://git-master/r/271984
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Add "CONFIG_PANIC_TIMEOUT=2" for reboot after 2sec,
when kernel panic occur.
Bug 1362640
Change-Id: I693573e1e6f2377866b609991c01f753d5e42f5b
Reviewed-on: http://git-master/r/270760
Reviewed-by: Simon Je <sje@nvidia.com>
Ensure unit is in reset when powering it back on.
Bug 1329416
Bug 1331777
Bug 1322046
Change-Id: I8ef6646a8fe2ae85fdb836f3222678e5f77a784c
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/256139
(cherry picked from commit 814f276c512cd49abbf15c64e14f8a9bbeb22d39)
Reviewed-on: http://git-master/r/271354
Set proper skin coeff to each P1640 board revision.
Bug 1362155
Change-Id: Ie3574f71961dec9441a7e8a6f0880385ae54a2b7
Reviewed-on: http://git-master/r/271337
Key code of SW_LID is 0 same with KEY_RESERVED used as default value
when checking wakeup key so even though waking up by RTC or wl18xx,
gpio key driver works for SW_LID. It increases LP0 standby power.
Use KEY_UNKNOWN as default wakeup_key.
Bug 1361016
Change-Id: Id44f78214060eb702e3a44997c1722095c734195
Reviewed-on: http://git-master/r/269908
Tegra CPU driver fixes CPU freq with a selected suspend freq between
pre-suspend and post-suspend. In this pre/post suspend period, the Tegra
CPU driver ignores CPU freq scaling requests from the CPU freq governor.
But the CPU freq governor keep working until the system suspended.
So the CPU freq governor updates its status even if the system is in
the pre/post suspend period.
This makes unexpected CPU freq setting issue on post-suspend.
To ensure CPU freq with the selected suspend freq in the pre/post
suspend period, set a policy max freq on CPU freq governor to the
selected suspend freq via PM QoS at pre-suspend and release the setting
via PM QoS at post-suspend.
Bug 1354391
Change-Id: I8efa6dd438a37adc7cadfb1d36eb7340a4e85c79
Reviewed-on: http://git-master/r/268955
To be aware of RAM strapping info,
print it at kernel init by default.
bug 1352073
Change-Id: Ia0462392d6a2ca06b68fcced1b39ec7d68110c74
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/267903
Bugi 1346871
Change-Id: I20e523a89d214f1265009abc10e183f4dcce67cf
Signed-off-by: Woojung Min <wmin@nvidia.com>
Reviewed-on: http://git-master/r/265928
Reviewed-by: Joshua Cha <joshuac@nvidia.com>
Don't register touch driver if charger boot mode to reduce power
consumption.
Change-Id: I7dcd120ecf2b7f6156aa40551c59aba88f815035
Reviewed-on: http://git-master/r/268203
At this moment, bootloader framebuffer memory is freed
in arch_initcall, whereas, kernel framebuffer is used
in dc device register with device_initcall. bootloader
framebuffer memory should be freed after dc device
register, so move it to late_initcall frame.
Bug 1346172
Change-Id: Ibd6dc72deea82069aaa2ab6d2cd52d4810b1cb53
Reviewed-on: http://git-master/r/267790
Specified PMU undershoot gaurd-band 100mV for tegratab, macallan, and
pluto boards.
Bug 1285525
Change-Id: I950630c1d3208657fde0a8dda7a538c60cfc706d
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/227756
(cherry picked from commit 31a740326f55b922edc0b3c89839dc2332b4ed35)
Reviewed-on: http://git-master/r/267385
- add IORESOURCE_IRQ_OPTIONAL in st host wakeup irq resource.
if it's set, don't request irq.
INT_UARTC need to be requested in hsuard driver.
So, don't request it in st host wake drvier. only doing
enable/disable irq in that driver.
- set INT_UARTC as st_host_wakeup irq
bug 1347948
Change-Id: Id6ee39b7307dcbbdc812e531ae743a9e14be03b1
Reviewed-on: http://git-master/r/265923
Support EMC frequency min/max constraints by PM QoS
Bug 1346293
Change-Id: I6987235c72921fdf8229a2411eb212dd7ffa66f0
Reviewed-on: http://git-master/r/263784
At low SOC, set current threshold with INA230 is not enough.
Need to use sysedp capping in low soc.
set 10000mW under 4%, 10500mW under 8%.
Bug 1329495
Change-Id: I15b845f7669729692bfa3e32729512af0a20e555
Reviewed-on: http://git-master/r/264168
Set ina230 current threshold in low SOC.
1.8A under 4% SOC and 2.5A under 8% SOC.
This change has trade off against performence drop at low SOC.
Bug 1316595
Bug 1304204
Change-Id: I6e397277729f2570e29ee3f36170e9c6dfe08467
Reviewed-on: http://git-master/r/260356
This reverts commit a285db7ae223699c8d31cce51c32c443cc3d4571.
Bug 1316595
Bug 1333630
Change-Id: Ib382f49dfdab8b72ca7f40618d6eaa43e274450c
Reviewed-on: http://git-master/r/260355
bug 1351377
Change-Id: I73fb063219907e11c07166516731cc19d4145fbf
Reviewed-on: http://git-master/r/264098
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Enable Tegra profiler for Tegra platforms
Bug 1312406
Change-Id: I5d2051549b9a144a885e71939cf49a0648b6b4ba
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/250844
Reviewed-by: Daniel Horowitz <dhorowitz@nvidia.com>
Tested-by: Daniel Horowitz <dhorowitz@nvidia.com>
Charging complete soc can be set by sysfs.
Don't need to change charger pdata in factory mode.
Bug 1342684
Change-Id: Ia514a0e0b92906c46660ef92edbb39831e747037
Reviewed-on: http://git-master/r/261487
Disabled/Enabled auto-refresh during EMC clock change using CCFIFO
mechanism.
Bug 1339693
Change-Id: I00fc1cc4fe4668ed84c1e7a4e105ebbb684b0ca5
Reviewed-on: http://git-master/r/261318
Reviewed-by: David Yu (Engrg-SW) <davyu@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
avdd_lcd(palmas smps6) need to be set to < 3.185V = 3.24V(Vsys min) - 0.055V
to prevent the dropout of smps6 output.
Bug 1343471
Change-Id: I8308abded2af4c5600302eaea959202f7086015b
Reviewed-on: http://git-master/r/259014
bug 1328470
Change-Id: I4290bf99942efc2e78a494e25a123de01c73ca91
Reviewed-on: http://git-master/r/257236
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Update tmds setting according to hw input.
bug 1299040
Change-Id: I7d9934e9e7e0d1add5e574b957cfdda45aeea9f4
Reviewed-on: http://git-master/r/259399
Reviewed-by: Naly Guo <nguo@nvidia.com>
Tested-by: Naly Guo <nguo@nvidia.com>
For temperature compensation, apply TempCo values.
Set TempCoHot to -1.125
Set TempCoCold to -7.625
Bug 1304204
Bug 1317331
Change-Id: If48d934b02d85c0aeb58364ae82e214e7faaf91c
Reviewed-on: http://git-master/r/258674
Reviewed-by: Bo Kim <bok@nvidia.com>
Store_add_ports function in tegra wakeup monitor can add new pro-
gram to improve accuracy of nSaver apk wow statistics.
Bug 1230562
Change-Id: I522b77466128c94610859f061dce08444eab2d9a
Signed-off-by: Chun Xu <chunx@nvidia.com>
Reviewed-on: http://git-master/r/258629
Tested-by: Jiukai Ma <jiukaim@nvidia.com>
Turn off vddio_sdmmc(Palmas LDO9) for sd card when
system reset and system shutdown.
If it is turned on during system reset, Palmas smps9(supply of LDO9)
is turned on during LP0 after reset then abnormally consume additional 22mA.
Bug 1341915
Change-Id: Idd0ca32482c9f8fcb67970d4d914810c35560fda
Reviewed-on: http://git-master/r/258623
Added Tskin coefficients for P1640 A02.
Bug 1341945
Change-Id: I6c48db541d19a63b07a8d3c1fedb995df4263ee7
Reviewed-on: http://git-master/r/257983
Reviewed-on: http://git-master/r/250928
(cherry picked from commit dff57ab9fba624e009ddc4763dd371c8835561ab)
Change-Id: Id1df835e0b60da703b67fc289b2ed21087f2c0c3
Reviewed-on: http://git-master/r/255338
Reviewed-on: http://git-master/r/250417
(cherry picked from commit 03dc8a991ab22e4cd0e048b3157b6f63a0ddc27f)
Change-Id: Ib00775ecbded79cb865cdeaed8e05ba2e06e486a
Reviewed-on: http://git-master/r/255337
Enabled throttling and shutdown on GPU zone for TegraTab platform.
Bug 1169070
Bug 1200077
Change-Id: I072af5aae0d23af93e3f8dcffdc25b476a723f1f
Reviewed-on: http://git-master/r/255341
This reverts commit 8f4db94f105ca9d2c367db02cb2bd27835c2e3f3
Change-Id: Ia2da37e41971b9c86c6211e34f95a88c340aa7dd
Reviewed-on: http://git-master/r/254951
Added mechanism to install sysfs objects for tegra shared bus floors.
Currently no floor objects are installed.
Reviewed-on: http://git-master/r/250416
(cherry picked from commit ec8651cf8f8822253dc6a6221a390ea79568a638)
Change-Id: I4940b096fe7013f09213813b18b1cfe71fce9336
Reviewed-on: http://git-master/r/255336
- Allowed per-SoC code to select emc monitor preset rate.
For now, rounded down boot rate is used as monitor preset rate
(round down to not over-clock on boot).
- Skipped emc clock update when monitor preset rate is set, but not
yet enabled (to avoid temporary dip in EMC rate). EMC rate is updated
only when monitor preset is enabled.
- Preset EMC monitor rate after iso usage table is initialized.
Reviewed-on: http://git-master/r/219504
(cherry picked from commit 9279fd450cba7c8012a405755d483dfc9b502941)
Reviewed-on: http://git-master/r/241242
(cherry picked from commit 16e29c11104e053f219ebafd6259cebf367f40f7)
Change-Id: I3a1407b8523596a7823a7c5398f5c1a03b4c3206
Reviewed-on: http://git-master/r/255335
Fixed initialization of GPU throttling in level2 thermal control regs.
Bug 1169070
Reviewed-on: http://git-master/r/232300
(cherry picked from commit 51383ec7f26659c758a2f0ddf119c491e47737ff)
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/246230
(cherry picked from commit dd538b8877a75e27ed41e0afd29ba9d3850102a3)
Change-Id: I121449b20fb987f61c6142e3783cd924f19a5bd6
Reviewed-on: http://git-master/r/255334
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
