For marketing reasons the part will be called WM8996. In order to avoid
user confusion rename the driver to reflect this.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Liam Girdwood <lrg@ti.com>
The generic library code already exports the generic function, this was
left-over from the ARM-specific version that just got removed.
Since commit 1eb19a12bd22 ("lib/sha1: use the git implementation of
SHA-1"), the ARM SHA1 routines no longer work. The reason? They
depended on the larger 320-byte workspace, and now the sha1 workspace is
just 16 words (64 bytes). So the assembly version would overwrite the
stack randomly.
The optimized asm version is also probably slower than the new improved
C version, so there's no reason to keep it around. At least that was
the case in git, where what appears to be the same assembly language
version was removed two years ago because the optimized C BLK_SHA1 code
was faster.
Reported-and-tested-by: Joachim Eastwood <manabian@gmail.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Nicolas Pitre <nico@fluxnic.net>
Commit a0bfa1373859e9d11dc92561a8667588803e42d8 mispells
cpuidle_idle_call() on ARM and SH code. Fix this to be consistent.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: x86@kernel.org
Cc: Len Brown <len.brown@intel.com>
Signed-off-by: David Brown <davidb@codeaurora.org>
[ Also done by Mark Brown - th ebug has been around forever, and was
noticed in -next, but the idle tree never picked it up. Bad bad bad ]
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
cpuidle: stop depending on pm_idle
x86 idle: move mwait_idle_with_hints() to where it is used
cpuidle: replace xen access to x86 pm_idle and default_idle
cpuidle: create bootparam "cpuidle.off=1"
mrst_pmu: driver for Intel Moorestown Power Management Unit
cpuidle users should call cpuidle_call_idle() directly
rather than via (pm_idle)() function pointer.
Architecture may choose to continue using (pm_idle)(),
but cpuidle need not depend on it:
my_arch_cpu_idle()
if(cpuidle_call_idle())
pm_idle();
cc: Kevin Hilman <khilman@deeprootsystems.com>
cc: Paul Mundt <lethal@linux-sh.org>
cc: x86@kernel.org
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio_msm: Move Qualcomm MSM v2 gpio driver into drivers
gpio_msm: Move Qualcomm v6 MSM driver into drivers
msm: gpio: Fold register defs into C file
msm: gpiomux: Move public API to public header
msm: gpio: Remove ifdefs on gpio chip registers
msm: gpio: Remove chip-specific register definitions
msm: Remove chip-ifdefs for GPIO io mappings
msm: gpio: Remove unsupported devices
gpio: ab8500: fix MODULE_ALIAS for ab8500
of/gpio: export of_gpio_simple_xlate
* 'for-3.1-rc1' of git://gitorious.org/linux-omap-dss2/linux: (31 commits)
OMAP: DSS2: HDMI: fix hdmi clock name
HACK: OMAP: DSS2: clk hack for OMAP2/3
OMAP: DSS2: DSS: Fix context save/restore
OMAP: DSS2: DISPC: Fix context save/restore
OMAP: DSS2: Remove ctx loss count from dss.c
OMAP: DSS2: Remove unused code from display.c
OMAP: DSS2: DISPC: remove finegrained clk enables/disables
OMAP: DSS2: Remove unused opt_clock_available
OMAP: DSS2: Use PM runtime & HWMOD support
OMAP: DSS2: Remove CONFIG_OMAP2_DSS_SLEEP_BEFORE_RESET
OMAP: DSS2: Remove core_dump_clocks
OMAP: DSS2: DPI: remove unneeded SYSCK enable/disable
OMAP: DSS2: Use omap_pm_get_dev_context_loss_count to get ctx loss count
OMAP: DSS2: rewrite use of context_loss_count
OMAP: DSS2: Remove clk optimization at dss init
OMAP: DSS2: Fix init and unit sequence
OMAP: DSS2: Clean up probe for DSS & DSI
OMAP: DSS2: Handle dpll4_m4_ck in dss_get/put_clocks
OMAP: DSS2: Fix FIFO threshold and burst size for OMAP4
OMAP: DSS2: DSI: sync when disabling a display
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: (39 commits)
SH: static should be at beginning of declaration
sh: move CLKDEV_xxx_ID macro to sh_clk.h
sh: clock-shx3: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7786: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7785: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7757: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7366: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7343: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7722: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7724: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7366: modify I2C clock settings
sh: clock-sh7343: modify I2C clock settings
sh: clock-sh7723: modify I2C clock settings
sh: clock-sh7722: modify I2C clock settings
sh: clock-sh7724: modify I2C clock settings
serial: sh-sci: Fix up pretty name printing for port IRQs.
serial: sh-sci: Kill off per-port enable/disable callbacks.
serial: sh-sci: Add missing module description/author bits.
serial: sh-sci: Regtype probing doesn't need to be fatal.
sh: Tidy up pre-clkdev clk_get() error handling.
git://codeaurora.org/quic/kernel/davidb/linux-msm into gpio/next
drivers/gpio/Kconfig
drivers/gpio/Makefile
Migrate the driver for the v7-based MSM chips into drivers/gpio. The
driver is unchanged, only moved.
Change-Id: I810db5b50b71cdca4e869aa0d0310f7f48781a55
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Migrate the driver for the v6-based MSM chips into drivers/gpio. The
Change-Id: I03ba597b95b4d62b42da112a8efac88d67aa40f9
No need to have a separate header file containing only register
definitions that are used by a single driver. Fold these into the
gpio driver.
The gpiomux.h header contains some SOC ifdefs. However, the API that
is actually used by the GPIO driver only uses two functions that are
general. Move these general definitions into a public header file.
Change-Id: Ia5df8af87dba268225598d56908e523bcfc24ef6
Select the GPIO register configuration at runtime rather than through
idefs.
Change-Id: I02ea0a3d61bc81669f32097c32420f0688552231
Put an SOC prefix on each GPIO register definition, eliminating the
need to have SOC ifdefs around the definitions.
Change-Id: I5a01fd328a89ce1be610847934d6e118f5465e42
The two GPIO controllers are always mapped to the same virtual address
across all MSM devices. Instead of selecting this at compile time,
determine the physical address at runtime, eliminating yet something
else preventing multiple MSM targets from being compiled into the same
kernel.
Change-Id: I1672219d978ab6243526adeda6badf49472baa27
The MSM7x25 and MSM7x27 devices are not yet supported in the kernel.
Remove #ifdef-based tables supporting these chips for now.
Change-Id: I4d9f5abc4cc0942ce75a067097b072489493c1b8
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: remove printks about disabled bridge windows
PCI: fold pci_calc_resource_flags() into decode_bar()
PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR
PCI: correct pcie_set_readrq write size
PCI: pciehp: change wait time for valid configuration access
x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems
PCI: ARI is a PCIe v2 feature
x86/PCI: quirks: Use pci_dev->revision
PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.
PCI hotplug: cpqphp: use pci_dev->vendor
PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device}
x86/PCI: config space accessor functions should not ignore the segment argument
PCI: Assign values to 'pci_obff_signal_type' enumeration constants
x86/PCI: reduce severity of host bridge window conflict warnings
PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI
PCI: PCIe AER: add aer_recover_queue
x86/PCI: select direct access mode for mmconfig option
PCI hotplug: Rename is_ejectable which also exists in dock.c
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'at91/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
at91: add arch specific ioremap support
at91: factorize sram init
at91: move register clocks to soc generic init
at91: move clock subsystem init to soc generic init
at91: use structure to store the current soc
at91: remove AT91_DBGU offset from dbgu register macro
at91: factorize at91 interrupts init to soc
at91: introduce commom AT91_BASE_SYS
* 'next/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (21 commits)
arm/dt: tegra devicetree support
arm/versatile: Add device tree support
dt/irq: add irq_domain_generate_simple() helper
irq: add irq_domain translation infrastructure
dmaengine: imx-sdma: add device tree probe support
dmaengine: imx-sdma: sdma_get_firmware does not need to copy fw_name
dmaengine: imx-sdma: use platform_device_id to identify sdma version
mmc: sdhci-esdhc-imx: add device tree probe support
mmc: sdhci-pltfm: dt device does not pass parent to sdhci_alloc_host
mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx()
mmc: sdhci-esdhc-imx: do not reference platform data after probe
mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5
net/fec: add device tree probe support
net: ibm_newemac: convert it to use of_get_phy_mode
dt/net: add helper function of_get_phy_mode
net/fec: gasket needs to be enabled for some i.mx
serial/imx: add device tree probe support
serial/imx: get rid of the uses of cpu_is_mx1()
arm/dt: Add dtb make rule
arm/dt: Add skeleton dtsi file
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: zynq: remove incorrectly deleted file
ARM: tegra: only select MACH_HAS_SND_SOC_TEGRA_WM8903 if SND_SOC
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits)
watchdog: WatchDog Timer Driver Core - Add minimum and max timeout
watchdog: WatchDog Timer Driver Core - Add ioctl call
watchdog: WatchDog Timer Driver Core - Add nowayout feature
watchdog: WatchDog Timer Driver Core - Add Magic Close feature
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl
watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality
watchdog: WatchDog Timer Driver Core - Add basic framework
watchdog: hpwdt: add next gen HP servers
watchdog: it8712f_wdt.c: improve includes
watchdog: at91sam9/wdt: move register header to drivers
watchdog: Add Xilinx watchdog timer driver
watchdog: remove empty pm-functions
watchdog: sp805: Flush posted writes in enable/disable.
watchdog: sp805: Don't write 0 to the load value register.
watchdog: imx2_wdt: add device tree probe support
watchdog: s3c2410: Add support for device tree based probe
watchdog: mpcore_wdt: Add suspend/resume support.
watchdog: mtx1-wdt: use dev_{err,info} instead of printk()
My previous commit left the file empty and present in the
Makefile, which is a bit dirty and caused problems with
'make distclean', as pointed out by David Howells.
This hopefully cleans it up the right way.
Acked-by: John Linn <john.linn@xilinx.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
instead of reading the registers everytime
the current implementation respect the following constrain:
- allow 1 to n soc to be enabled
- allow to have a virtual cpu type and subtype
- always detect the cpu type and subtype and report it
- detect if the soc support is enabled
- prepare for sysfs export support
- drop soc specific code via compiler when the soc not enabled
(via cpu_is_xxx)
Today if we read the exid we will have the same value for 9g35 and 9m11
and we will need to check the cidr too
with the new implementation we just need to check the soc subtype
this will also allow to have specific virtual subtype for rm9200 which the
board will have to specify via at91rm9200_set_type(int) as we have no way to
detect it.
this implementation is inspired by the SH cpu detection support
to make the soc base specified at runtime instead of compiled time
they are the same except the default priority
On all at91 except rm9200 and x40 have the System Controller starts
at address 0xffffc000 and has a size of 16KiB.
On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting
at 0xfffff000
This patch removes the individual definitions of AT91_BASE_SYS and
replaces them with a common version at base 0xfffffc000 and size 16KiB
and map the same memory space
Everything required to populate NVIDIA Tegra devices from the device
tree. This patch adds a new DT_MACHINE_DESC() which matches against
a tegra20 device tree. So far it only registers the on-chip devices,
but it will be refined in follow on patches to configure clocks and
pin IO from the device tree also.
For testing the dt work, define a dt-enabled versatile platform.
This patch adds a new versatile platform for when using the device
tree. Add platform and amba devices are discovered and registered by
parsing the device tree. Clocks and initial io mappings are still
configured statically.
This patch still depends on some static platform_data for a few devices
which is passed via the auxdata structure to of_platform_populate(),
but it is a viable starting point until the drivers can get all
configuration data out of the device tree.
This patch adds irq_domain infrastructure for translating from
hardware irq numbers to linux irqs. This is particularly important
for architectures adding device tree support because the current
implementation (excluding PowerPC and SPARC) cannot handle
translation for more than a single interrupt controller. irq_domain
supports device tree translation for any number of interrupt
controllers.
This patch converts x86, Microblaze, ARM and MIPS to use irq_domain
for device tree irq translation. x86 is untested beyond compiling it,
irq_domain is enabled for MIPS and Microblaze, but the old behaviour is
preserved until the core code is modified to actually register an
irq_domain yet. On ARM it works and is required for much of the new
ARM device tree board support.
PowerPC has /not/ been converted to use this new infrastructure. It
is still missing some features before it can replace the virq
infrastructure already in powerpc (see documentation on
irq_domain_map/unmap for details). Followup patches will add the
missing pieces and migrate PowerPC to use irq_domain.
SPARC has its own method of managing interrupts from the device tree
and is unaffected by this change.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Now that v4l2 subdevices have got their own device objects, having
one more device in soc-camera clients became redundant and confusing.
This patch removes those devices and the soc-camera bus, they used to
reside on.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Paul Mundt <lethal@linux-sh.org>
This moves us one more step closer to eliminating the soc-camera bus
and devices on it. Besides, as a side effect, CSI-2 runtime PM on
sh-mobile secomes finer grained now: we only have to power on the
interface, when the device nodes are open.
The RX-51 uses the CSIb IO complex for camera operation. The
board file is missing definition for the regulator supplying
the CSIb complex, so this is added for better power
management.
Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@nokia.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
This fixes:
warning: (MACH_HARMONY && MACH_KAEN && MACH_SEABOARD) selects MACH_HAS_SND_SOC_TEGRA_WM8903 which has unmet direct dependencies (SOUND && !M68K && SND && SND_SOC)
Acked-By: Colin Cross <ccross@android.com>
It might be not good to use software defined version to identify sdma
device type, when hardware does not define such version. Instead,
soc name is stable enough to define the device type.
The patch uses platform_device_id rather than version number passed
by platform data to identify sdma device type/version.
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Vinod Koul <vinod.koul@intel.com>
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes
platform_device_id to distinguish the esdhc differences among SoCs.
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: Chris Ball <cjb@laptop.org>
Acked-by: Chris Ball <cjb@laptop.org>
The patch extends card_detect and write_protect support to get mx5
family and more scenarios supported. The changes include:
* Turn platform_data from optional to mandatory
* Add cd_types and wp_types into platform_data to cover more use
cases
* Remove the use of flag ESDHC_FLAG_GPIO_FOR_CD
* Adjust some machine codes to adopt the platform_data changes
* Work around the issue that software reset will get card detection
circuit stop working
With this patch, card_detect and write_protect gets supported on
mx5 based platforms.
Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org>
On the recent i.mx (mx25/50/53), there is a gasket inside fec
controller which needs to be enabled no matter phy works in MII
or RMII mode.
The current code enables the gasket only when phy interface is RMII.
It's broken when the driver works with a MII phy. The patch uses
platform_device_id to distinguish the SoCs that have the gasket and
enables it on these SoCs for both MII and RMII mode.
Reported-by: Troy Kisky <troy.kisky@boundarydevices.com>
The patch removes all the uses of cpu_is_mx1(). Instead, it uses
the .id_table of platform_driver to distinguish the uart device type,
IMX1_UART and IMX21_UART. The IMX21_UART type runs on all i.mx
except i.mx1.
A couple of !cpu_is_mx1 logic gets turned into is_imx21_uart,
as the codes wrapped there are really IMX21 type uart specific.
It also removes macro MX1_UCR3_REF25 and MX1_UCR3_REF30 which are
not used anywhere.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
* 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits)
OMAP: Add debugfs node to show the summary of all clocks
OMAP2+: hwmod: Follow the recommended PRCM module enable sequence
OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code
OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming
OMAP2+: PM: idle clkdms only if already in idle
OMAP2+: clockdomain: add clkdm_in_hwsup()
OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework
OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition()
OMAP4: hwmod: Introduce the module control in hwmod control
OMAP4: cm: Add two new APIs for modulemode control
OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure
OMAP4: hwmod data: Add PRM context register offset
OMAP4: prm: Remove deprecated functions
OMAP4: prm: Replace warm reset API with the offset based version
OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros
OMAP: hwmod: Wait the idle status to be disabled
OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros
OMAP2+: hwmod: Init clkdm field at boot time
OMAP4: hwmod data: Add clock domain attribute
OMAP4: clock data: Add missing divider selection for auxclks
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
* 'next/board' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: S3C64XX: Configure backup battery charger on Cragganmore
ARM: S3C64XX: Fix WM8915 IRQ polarity on Cragganmore
ARM: S3C64XX: Configure supplies for all Cragganmore regulators
ARM: S3C64XX: Refresh Cragganmore support
ARM: S3C64XX: Initial support for Wolfson/Simtec Cragganmore/Banff
OMAP4: Keyboard: Mux changes in the board file
omap: blaze: add mmc5/wl1283 device support
omap: 4430SDP: Register the card detect GPIO properly
arm: omap3: cm-t35: add support for cm-t3730
OMAP3: beagle: add support for beagleboard xM revision C
OMAP3: rx-51: Add full regulator definitions
omap: rx51: Platform support for lp5523 led chip
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
