The iMX7 is supporting UHS-I but as those pins are shared
a define is needed to let the user decide if he wants UHS-I.
Add atmel mxt multitouch controller driver which is interfaced over
I2C bus. Add TouchRevolution multitouch controller driver which is
connectable over I2C bus.
This patch adds spigpios group to pinmux. This is needed by Aster
devicetrees that will be added later on.
Add new gpio hog group for atmel mxt ts GPIOs.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit e747c0e955869e5cb6d9ea4da9477895901dbc92)
(cherry picked from commit 27e488ab4f471002a4549ea47551d08f62bbb698)
The SNVS subnodes reenable the power key which is not used on the
Colibri iMX7 modules. Disable the power key again.
Also make sure that the priority of the RTCs used is defined.
(cherry picked from commit 41ef3fad976e68175d9b087b1d072aac7183a906)
This reverts commit 511eacb77e74e9a23546b3afb0d2b2208eb4621c.
(cherry picked from commit ae8f31f4a7d78c8ff792cf2cf549b540f19488dc)
Merge changes from Toradex Linux 4.9 BSP.
Add pinmuxing and do not specify voltage restrictions in the
module level device tree.
(cherry picked from commit d4f875d9f8319ae9157702d5232f8b0b91444105)
Add wakeup GPIO key which is able to wake the system from sleep
modes (e.g. Suspend-to-Memory).
- add recovery mode for applicable i2c buses for
Colibri iMX7 module.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 01c0bda6912c37456b3df34a7cf30300100ffbad)
arch/arm/boot/dts/imx7-colibri.dtsi
Add sleep pinmux to the fec so it can properly sleep.
Prepare FlexCAN use on SODIMM 55/63 178/188. Those SODIMM pins are
compatible for CAN bus use with several modules from the Colibri
family.
Add Better drivestrength and also add flexcan2.
This is a squashed commit from:
(cherry picked from commit 5562bcc82fd50633199a6627c11ec9d41833ed4e
and commit 491a63f465e45eda40336d3e75538668a44e166e)
Force HS200 by masking bit 63 of the SDHCI capability register.
The i.MX ESDHC driver uses SDHCI_QUIRK2_CAPS_BIT63_FOR_HS400. With
that the stack checks bit 63 to descide whether HS400 is available.
Using sdhci-caps-mask allows to mask bit 63. The stack then selects
HS200 as operating mode.
This prevents rare communication errors with minimal effect on
performance:
sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status REF not lock!
(cherry picked from commit cf7097961efb6c93945b940065375ede1e03b254)
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
(cherry picked from commit c81fc92fa8852d4dcc607b6771463471607d0942)
Add the stmpe-adc DT node as found on Toradex iMX6 modules
Reviewed-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit a822029a0cc0b838bff043482629f5fb9c2deb32)
A valid WEIM range configuration must specify range entries for
all four chip selects. This fixes an error on boot:
imx-weim: probe of 21b8000.weim failed with error -22
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 063182a4c85673c735508dc01dd07fffbe7defb1)
Since commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery
GPIO") GPIO lib expects this GPIO to be configured as open drain.
Make sure we define this GPIO as open drain in the device tree.
This gets rid of the following warning:
gpio-81 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Note that currently the i.MX pinctrl driver does not support
enabling open drain directly, so this patch has no effect in
practice. Open drain is enabled by the fixed pinmux entry.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
(cherry picked from commit d2b91ab1480618885fe0a7f240b7e7710344a066)
Boards based on imx7 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx7s.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 29988e867cb17de7119e971f9acfad2c3fccdb47)
arch/arm/boot/dts/imx7d-cl-som-imx7.dts
arch/arm/boot/dts/imx7d-colibri-emmc.dtsi
arch/arm/boot/dts/imx7d-colibri.dtsi
arch/arm/boot/dts/imx7d-nitrogen7.dts
arch/arm/boot/dts/imx7d-pico.dtsi
arch/arm/boot/dts/imx7d-sdb.dts
arch/arm/boot/dts/imx7s-colibri.dtsi
arch/arm/boot/dts/imx7s-warp.dts
arch/arm/boot/dts/imx7s.dtsi
The pinctrl properties on the IOMUXC node get overwritten by the
carrier board level device tree, hence the pinctrl_reset_moci
pinctrl does not get applied.
Associate the pinctrl_reset_moci pinctrl with the PCIe node where
we also make use of the pin as a reset GPIO.
Since the pin is muxed as a GPIO by default not muxing it explicitly
worked fine in practise.
(cherry picked from commit 78f10734f95873c22255f536e894c704bb5e8fa2)
100/200MHz states for USDHC3 are not required since the SoC
does not support modes faster than DDR52 for the on board eMMC.
(cherry picked from commit b074f057ac60d32f604e0ca3120064e688e9a622)
VDDD is connected to VGEN4 of the PF0100. This rail should only
run at 1.8V since there are multiple consumer and they all
expect the rail to be at 1.8V.
(cherry picked from commit 330f85598e87497974431c0f6f736e413ccf2d27)
Remove the 2.5V regulator, it does not exist. There is 3.3V and
3.3V_AUDIO provided to the module through the edge connector,
model those as fixed regulators like we use to do in other
Colibri device trees. The SGTL5000 uses 3.3V_AUDIO as VDDA. Note
that the driver derives the analog ground voltage (VAG) from this
supply. The new value should allow higher output swings before
clipping occurs. Refer to the SGTL5000 datasheet for details.
(cherry picked from commit 7060066d3e9920a4d96e106243e544c14ba0fd79)
The fixed 1.8V regulator is not used, and there is in fact no
fixed 1.8V regulator on the module. Remove it.
(cherry picked from commit 7034de41186f3b49fe987b4626ae1a151760a609)
Use the disable-wp to indicate that Apalis and Colibri iMX6 do not
make use of the native write-protect signal available on the i.MX 6
SoCs. This prevents warnings:
mmc0: host does not support reading read-only switch, assuming write-enable
(cherry picked from commit 147299a8fc3a70f02984a6d6a042d0cbf53c46f9)
Use no-1-8-v device tree property to indicate that the board does
not support 1.8V signaling. The property voltage-ranges seems not
appropriate in our case since we do not have level shifters in
place.
(cherry picked from commit 3b1147a952cf9efb36144c1f7fd847d5a99adb7a)
Add the 3.3V main supply on the carrier board. Currently as a fixed
supply since not all consumer are modeled yet. This gets also rid of
some missing supply warnings.
(cherry picked from commit 5780acda81d3f5378b71d8dead95b8d052dc22ae)
Add Apalis UART1 as default serial console.
(cherry picked from commit 6c74366b8db6fc70b65266bf52c58a89ebc946f1)
The wake-up pin is pulled low with 100kOhm on the carrier board.
The current configuration of 100kOhm pull-up caused lots of
interrupts, especially during boot up. Make sure the pin is at a
reasonable level at startup by pulling it low on SoC side too.
(cherry picked from commit c4288946d43ed2d76247ab757581ce428c90d9ef)
Muxing the card detect only in the carrier board device tree
overwrites the USDHC muxing in the module level device tree.
Move card detect to the module level device tree since this
is also a default pinout of the Colibri standard. If a carrier
board requires a different setting it still can overwrite the
nodes in the carrier board specific device tree.
(cherry picked from commit c768224360094b3e3b11c81a4163a9e1c7bd3336)
Do not rely on reset/boot defaults and use a default GPIO setting
with pull-up enabled.
(cherry picked from commit 10d11dad4a4e343652fca86bda3b10684be30d4e)
For soc level of clocks which are input to Clock Control Module, clock
driver expects them to be under 'clocks' container node. But for board
level clocks, this container is not really necessary. Let's drop it and
use an unique name for fixed rate clock, so that 'reg' property can be
saved as well.
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit 8799b5d5c76c5fc53a83cc86f16fb7f74bad923d)
Remove unnecessary #address-cells/#size-cells to fix the following
DTC warnings:
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/aips-bus@2100000/i2c@21a0000/stmpe811@44: unnecessary #address-cells/#size-cells without "ranges" or child "reg"
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit c099a5e5750bfad6b48f5216580813014779628a)
Add Colibri UART_A as default serial console.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit f10acffc550ddf651968330b2b4d08b9c1aa75a9)
Add support for the Computer on Module Colibri iMX6ULL and its
Bluetooth/Wifi variant along with the development/evaluation carrier
board device trees. Follow the usual hierarchic include model,
maintaining shared configuration in imx6ull-colibri.dtsi and
imx6ull-colibri-eval-v3.dtsi respectively.
(cherry picked from commit c2e4987e0e02095ed3d19e958b3891954ef38243)
Add support for the Computer on Module Colibri iMX7D 1GB along
with the Colibri Evaluation Board device trees. Follow the usual
hierarchic include model, maintaining shared configuration in
imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively.
(cherry picked from commit f928a4a377e476525298a552185dfd92d2780319)
The Colibri Evaluation Carrier Board provides a MCP2515 CAN
controller connected via SPI. Note that the i.MX 7 provides
an internal CAN controller which is much better suited for CAN
operations. Using the MCP2515 with a Colibri iMX7 module is
mainly useful to test the SPI interface.
(cherry picked from commit 66d59b678a87152f85dd327ba6aa024df2896b37)
The Colibri standard defines SODIMM 71 as backlight enable
GPIO. Assign the GPIO to the backlight node in the module
level device tree.
(cherry picked from commit 6deb2260b2138154ab25922ffb0e1a67a9aa3ea4)
The usdhc1 controller instance is used to provide the default
SD/MMC capabilities of the Colibri standard. The IO pins are
supplied to the SoC on the module whereas the SD-card is powered
by the Carrier Board supply.
(cherry picked from commit 49e6ce614b456a4456f9ef8770797f9bc885a247)
Specify CPU supply using the "cpu-supply" property instead of
the invalid "arm-supply" property.
(cherry picked from commit 5dc2dcf58a87ba74f06a9aba5c7248991aa65ece)
All Colibri iMX7 SKUs use either single-die NAND or eMMC, hence
NAND_CE1 is not used on the module and can be used as a GPIO by
carrier boards.
(cherry picked from commit c2e70bbb616d8605b86b3344ccc03d122b5d8494)
Use pull-ups instead of pull-downs for the pins which are already
pulled-up externally.
(cherry picked from commit ffb2e259c462b38f4cccf742d6d9856429725ed0)
The Colibri pins PWM<A> and <D> are multiplexed on the module, make
sure the secondary SoC pin is not active.
(cherry picked from commit e95723b5ecaa21b30de3c786d3e8a34e15632beb)
The Colibri default which enables USB Host power is not necessarily
tied to the OTG2 controller, some carrier board use the pin to
control USB power for both controllers. Hence name the pinctrl
group more generic.
Also move the regulator to the generic eval-v3 device tree since
the regulator is always on the carrier board. In the Colibri iMX7S
case the regulator is just not used. This allows to reuse the
regulator in a upcoming SKU Colibri iMX7D 1GB with eMMC.
(cherry picked from commit 7e81cb3d9cf5a7cc56606a63ca6f100bb3f1f5de)
All Toradex Carrier Boards use a st,m41t0 compatible RTC. Compared
to a st,m41t00 this RTC has also an oscillator fail bit which allows
to detect when the RTC lost track of time.
Cc: Sanchayan Maity <maitysanchayan@gmail.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
(cherry picked from commit c53bec16b150a84f6b5395af1bc45335293d3c64)
As described in
Documentation/devicetree/bindings/input/touchscreen/stmpe.txt
there is no 'reg' property under stmpe_touchscreen, so remove it
to fix the following build warning with W=1:
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb: Warning (unit_address_vs_reg): Node /soc/aips-bus@2100000/i2c@21a4000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name
(cherry picked from commit 0fe9c347c138dc8f2c7bd3d90875d1e72b039fd8)
As described in
arch/arm/boot/dts/imx6q-apalis-eval.dtb: Warning (unit_address_vs_reg): Node /soc/aips-bus@2100000/i2c@21a4000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name
(cherry picked from commit 89277e8e2679932e34b5f85674c12de4b6352da0)
For iptables filtering to work we need the NF_FILTER kernel module.
