[ Upstream commit 627395a6f8091c0aa18f49dca7df59ba3ec147ef ]
Fixes the following warnings:
arch/arm/boot/dts/am437x-cm-t43.dtb: Warning (interrupts_property):
interrupts size is (8), expected multiple of 12 in
/ocp@44000000/mcasp@48038000
/ocp@44000000/mcasp@4803C000
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
[ Upstream commit cd7594ac3281722cb8f10d6f6c7e4287747c7a9d ]
The pin assignment for the wl127x interrupt was incorrect. I am
not sure how this every worked. This also eliminates a conflict with
the SMC911x ethernet driver and properly moves pinmuxes for the
related gpio to omap3_pmx_wkup from omap3_pmx_core.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD
DM3730 SOM-LV")
[ Upstream commit 3c18bbf3d11d2005da08b57ff26f44ff1c2b12d0 ]
This patch fixes and issue where the NAND and GPMC based ethernet
controller stopped working. This also updates the GPMC settings
to be consistent with the Logic PD Torpedo development from the
commit listed above.
Fixes: 44e4716499b8 ("ARM: dts: omap3: Fix NAND device nodes")
[ Upstream commit cf87634c8b24e24bf379b8c6807c8b0fb5f23567 ]
There's been a reproducable USB OHCI/EHCI cpuidle related hang on omap4
for a while that happens after about 20 - 40 minutes on an idle system
with some data feeding device being connected, like a USB GPS device or
a cellular modem.
This issue happens in cpuidle states C2 and C3 and does not happen if
cpuidle is limited to C1 state only. The symptoms are that the whole
system hangs and never wakes up from idle, and if a watchdog is
configured the system reboots after a while.
Turns out that OHCI/EHCI devices on omap4 are trying to use the GIC
interrupt controller directly as a parent instead of the WUGEN. We
need to pass the interrupts through WUGEN to GIC to provide the wakeup
events for the processor.
Let's fix the issue by removing the gic interrupt-parent and use the
default interrupt-parent wakeupgen instead. Note that omap5.dtsi had
this already fixes earlier by commit 7136d457f365 ("ARM: omap: convert
wakeupgen to stacked domains") but we somehow missed omap4 at that
point.
Fixes: 7136d457f365 ("ARM: omap: convert wakeupgen to stacked domains")
Cc: Dave Gerlach <d-gerlach@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Roger Quadros <rogerq@ti.com>
[ Upstream commit b6d6af7226465b6d11eac09d0be2ab78a4a9eb62 ]
Referring TRM Am335X series:
http://www.ti.com/lit/ug/spruh73p/spruh73p.pdf
The LastPowerStateEntered bitfield is present only for PM_CEFUSE
domain. This is not present in any of the other power domains. Hence
remove the generic am33xx_pwrdm_read_prev_pwrst hook which wrongly
reads the reserved bit fields for all the other power domains.
Reading the reserved bits leads to wrongly interpreting the low
power transitions for various power domains that do not have the
LastPowerStateEntered field. The pm debug counters values are wrong
currently as we are incrementing them based on the reserved bits.
Signed-off-by: Keerthy <j-keerthy@ti.com>
[ Upstream commit d09220a887f70368afa79e850c95e74890c0a32d ]
With the CMA changes from Joonsoo Kim <iamjoonsoo.kim@lge.com>, it
was noticed that n900 stopped booting. After investigating it turned
out that n900 save_secure_ram_context does some whacky virtual to
physical address translation for the SRAM data address.
As we now only have minimal parts of omap3 idle code copied to SRAM,
running save_secure_ram_context() in SRAM is not needed. It only gets
called on PM init. And it seems there's no need to ever call this from
SRAM idle code.
So let's just keep save_secure_ram_context() in DDR, and pass it the
physical address of the parameters. We can do everything else in
omap-secure.c like we already do for other secure code.
And since we don't have any documentation, I still have no clue what
the values for 0, 1 and 1 for the parameters might be. If somebody has
figured it out, please do send a patch to add some comments.
Debugged-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit a21b4c10c7bf5b58112afa20d6fa829e8d74e3e6 upstream.
Without this tag, we get a build warning:
WARNING: modpost: missing MODULE_LICENSE() in arch/arm/common/bL_switcher_dummy_if.o
For completeness, I'm also adding author and description fields.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 586b2a4befad88cd87b372a1cea01e58c6811ea9 upstream.
The EB MP board probably has a character LCD but the board manual does
not really state which IRQ it has assigned to this device. The invalid
assignment was a mistake by me during submission of the DTSI where I was
looking for the reference, didn't find it and didn't fill it in.
Delete this for now: it can probably be fixed but that requires access
to the actual board for some trial-and-error experiments.
commit ae72e95b5e4ded145bfc6926ad9457b74e3af41a upstream.
The hifsys and ethsys needs the definition of the reset-cells
property. Fix this.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
commit 5c1037196b9ee75897c211972de370ed1336ec8f upstream.
The ohci-hcd node has an interrupt number but no interrupt-parent,
leading to a warning with current dtc versions:
arch/arm/boot/dts/s5pv210-aquila.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-goni.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-smdkc110.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-smdkv210.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-torbreck.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
As seen from the related exynos dts files, the ohci and ehci controllers
always share one interrupt number, and the number is the same here as
well, so setting the same interrupt-parent is the reasonable solution
here.
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 3343647813fdf0f2409fbf5816ee3e0622168079 upstream.
WARNING: modpost: missing MODULE_LICENSE() in arch/arm/mach-pxa/tosa-bt.o
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 5628a8ca14149ba4226e3bdce3a04c3b688435ad upstream.
According to the comment added to exynos_dt_pmu_match[] in commit
8b283c025443 ("ARM: exynos4/5: convert pmu wakeup to stacked domains"),
the RTC is not able to wake up the system through the PMU on Exynos5410,
unlike Exynos5420.
However, when the RTC DT node got added, it was a straight copy of
the Exynos5420 node, which now causes a warning from dtc.
This removes the incorrect interrupt-parent, which should get the
interrupt working and avoid the warning.
Fixes: e1e146b1b062 ("ARM: dts: exynos: Add RTC and I2C to Exynos5410")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit f8975cb1b8a36d0839b6365235778dd9df1d04ca upstream.
This fixes the following warning by also sending the flags argument for
gpio controllers:
Property 'cs-gpios', cell 6 is not a phandle reference in
/ahb/apb/spi@e0100000
Fixes: 8113ba917dfa ("ARM: SPEAr: DT: Update device nodes")
Cc: stable@vger.kernel.org # v3.8+
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit cdd10409914184c7eee5ae3e11beb890c9c16c61 upstream.
The "dmas" cells for the designware DMA controller need to have only 3
properties apart from the phandle: request line, src master and
destination master. But the commit 6e8887f60f60 updated it incorrectly
while moving from platform code to DT. Fix it.
Cc: stable@vger.kernel.org # v3.10+
Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT")
commit 6ffb5b4f248fe53e0361b8cbc2a523b432566442 upstream.
The interrupt-parent of rtc was missing, add it.
commit e8bfa0422469cdfc86be3f525f621b1d44d2481b upstream.
The clcd device is lacking an interrupt-parent property, which makes
the interrupt unusable and shows up as a warning with the latest
dtc version:
arch/arm/boot/dts/ste-nomadik-s8815.dtb: Warning (interrupts_property): Missing interrupt-parent for /amba/clcd@10120000
arch/arm/boot/dts/ste-nomadik-nhk15.dtb: Warning (interrupts_property): Missing interrupt-parent for /amba/clcd@10120000
I looked up the old board files and found that this interrupt has
the same irqchip as all the other on-chip device, it just needs one
extra line.
Fixes: 17470b7da11c ("ARM: dts: add the CLCD LCD display to the NHK15")
commit 7ac1f59c09a61e6af6622df6809e003b0af07f3d upstream.
The GPIO polarity is missing in the hdmi,hpd-gpio property, this
fixes the following DT warnings:
arch/arm/boot/dts/stih410-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
size (8) too small for cell size 2 in /soc/sti-display-subsystem/sti-hdmi@8d04000
arch/arm/boot/dts/stih407-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
arch/arm/boot/dts/stih410-b2260.dtb: Warning (gpios_property): hdmi,hpd-gpio property
[arnd: marked Cc:stable since this warning shows up with the latest dtc
by default, and is more likely to actually cause problems than the
other patches from this series]
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
commit ca32e0c4bf9ca4b87089c5a5ce945e5f2ec890da upstream.
dtc warns about obviously incorrect GPIO numbers for the audio codec
on both lpc32xx boards:
arch/arm/boot/dts/lpc3250-phy3250.dtb: Warning (gpios_property): reset-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-phy3250.dtb: Warning (gpios_property): power-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-ea3250.dtb: Warning (gpios_property): reset-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-ea3250.dtb: Warning (gpios_property): power-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
It looks like the nodes are written for a different binding that combines
the GPIO number into a single number rather than a bank/number pair.
I found the right numbers on stackexchange.com, so this patch fixes
the warning and has a reasonable chance of getting things to actually
work.
Link: https://unix.stackexchange.com/questions/59497/alsa-asoc-how-to-correctly-load-devices-drivers/62217#62217
commit 58d6b15e9da5042a99c9c30ad725792e4569150e upstream.
cpu_pm_enter() calls the pm notifier chain with CPU_PM_ENTER, then if
there is a failure: CPU_PM_ENTER_FAILED.
When KVM receives CPU_PM_ENTER it calls cpu_hyp_reset() which will
return us to the hyp-stub. If we subsequently get a CPU_PM_ENTER_FAILED,
KVM does nothing, leaving the CPU running with the hyp-stub, at odds
with kvm_arm_hardware_enabled.
Add CPU_PM_ENTER_FAILED as a fallthrough for CPU_PM_EXIT, this reloads
KVM based on kvm_arm_hardware_enabled. This is safe even if CPU_PM_ENTER
never gets as far as KVM, as cpu_hyp_reinit() calls cpu_hyp_reset()
to make sure the hyp-stub is loaded before reloading KVM.
Fixes: 67f691976662 ("arm64: kvm: allows kvm cpu hotplug")
CC: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: James Morse <james.morse@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 20e8175d246e9f9deb377f2784b3e7dfb2ad3e86 upstream.
KVM doesn't follow the SMCCC when it comes to unimplemented calls,
and inject an UNDEF instead of returning an error. Since firmware
calls are now used for security mitigation, they are becoming more
common, and the undef is counter productive.
Instead, let's follow the SMCCC which states that -1 must be returned
to the caller when getting an unknown function number.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Upstream commit 5f1aa51c7a1eef1c5a60b8334e32c89904964245 ]
Booting a kernel results in the kernel warning us about the following
PPI interrupts configuration:
[ 0.105127] smp: Bringing up secondary CPUs ...
[ 0.110545] GIC: PPI11 is secure or misconfigured
[ 0.110551] GIC: PPI13 is secure or misconfigured
Fix this by using the appropriate edge configuration for PPI11 and
PPI13, this is similar to what was fixed for Northstar (BCM5301X) in
commit 0e34079cd1f6 ("ARM: dts: BCM5301X: Correct GIC_PPI interrupt
flags").
Fixes: 7b2e987de207 ("ARM: NSP: add minimal Northstar Plus device tree")
Fixes: 1a9d53cabaf4 ("ARM: dts: NSP: Add TWD Support to DT")
Acked-by: Jon Mason <jon.mason@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit c507babf10ead4d5c8cca704539b170752a8ac84 upstream.
KVM only supports PMD hugepages at stage 2 but doesn't actually check
that the provided hugepage memory pagesize is PMD_SIZE before populating
stage 2 entries.
In cases where the backing hugepage size is smaller than PMD_SIZE (such
as when using contiguous hugepages), KVM can end up creating stage 2
mappings that extend beyond the supplied memory.
Fix this by checking for the pagesize of userspace vma before creating
PMD hugepage at stage 2.
Fixes: 66b3923a1a0f77a ("arm64: hugetlb: add support for PTE contiguous bit")
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
commit 56aeb07c914a616ab84357d34f8414a69b140cdf upstream.
MPP7 is currently muxed as "gpio", but this function doesn't exist for
MPP7, only "gpo" is available. This causes the following error:
kirkwood-pinctrl f1010000.pin-controller: unsupported function gpio on pin mpp7
pinctrl core: failed to register map default (6): invalid type given
kirkwood-pinctrl f1010000.pin-controller: error claiming hogs: -22
kirkwood-pinctrl f1010000.pin-controller: could not claim hogs: -22
kirkwood-pinctrl f1010000.pin-controller: unable to register pinctrl driver
kirkwood-pinctrl: probe of f1010000.pin-controller failed with error -22
So the pinctrl driver is not probed, all device drivers (including the
UART driver) do a -EPROBE_DEFER, and therefore the system doesn't
really boot (well, it boots, but with no UART, and no devices that
require pin-muxing).
Back when the Device Tree file for this board was introduced, the
definition was already wrong. The pinctrl driver also always described
as "gpo" this function for MPP7. However, between Linux 4.10 and 4.11,
a hog pin failing to be muxed was turned from a simple warning to a
hard error that caused the entire pinctrl driver probe to bail
out. This is probably the result of commit 6118714275f0a ("pinctrl:
core: Fix pinctrl_register_and_init() with pinctrl_enable()").
This commit fixes the Device Tree to use the proper "gpo" function for
MPP7, which fixes the boot of OpenBlocks A7, which was broken since
Linux 4.11.
Fixes: f24b56cbcd9d ("ARM: kirkwood: add support for OpenBlocks A7 platform")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit c13e7f313da33d1488355440f1a10feb1897480a upstream.
The DRM driver most notably, but also out of tree drivers (for now) like
the VPU or GPU drivers, are quite big consumers of large, contiguous memory
buffers. However, the sunxi_defconfig doesn't enable CMA in order to
mitigate that, which makes them almost unusable.
Enable it to make sure it somewhat works.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
Reported by syzkaller:
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
[ Upstream commit 916a008b4b8ecc02fbd035cfb133773dba1ff3d7 ]
dma_get_sgtable() tries to create a scatterlist table containing valid
struct page pointers for the coherent memory allocation passed in to it.
However, memory can be declared via dma_declare_coherent_memory(), or
via other reservation schemes which means that coherent memory is not
guaranteed to be backed by struct pages. In such cases, the resulting
scatterlist table contains pointers to invalid pages, which causes
kernel oops later.
This patch adds detection of such memory, and refuses to create a
scatterlist table for such memory.
Reported-by: Shuah Khan <shuahkhan@gmail.com>
[ Upstream commit 9bcf53f34a2c1cebc45cc12e273dcd5f51fbc099 ]
mmc2 used for wl12xx was missing the keep-power-in suspend
parameter. As a result the board couldn't reach suspend state.
Signed-off-by: Eyal Reizer <eyalr@ti.com>
[ Upstream commit 7d79f6098d82f8c09914d7799bc96891ad9c3baf ]
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
[ Upstream commit 974310d047f3c7788a51d10c8d255eebdb1fa857 ]
kprobes test cases need to have a stack that is aligned to an 8-byte
boundary because they call other functions (and the ARM ABI mandates
that alignment) and because test cases include 64-bit accesses to the
stack. Unfortunately, GCC doesn't ensure this alignment for inline
assembler and for the code in question seems to always misalign it by
pushing just the LR register onto the stack. We therefore need to
explicitly perform stack alignment at the start of each test case.
Without this fix, some test cases will generate alignment faults on
systems where alignment is enforced. Even if the kernel is configured to
handle these faults in software, triggering them is ugly. It also
exposes limitations in the fault handling code which doesn't cope with
writes to the stack. E.g. when handling this instruction
strd r6, [sp, #-64]!
the fault handling code will write to a stack location below the SP
value at the point the fault occurred, which coincides with where the
exception handler has pushed the saved register context. This results in
corruption of those registers.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
[ Upstream commit 06553175f585b52509c7df37d6f4a50aacb7b211 ]
This is arm port of commit 737480a0d525 ("kprobes/x86:
Fix the return address of multiple kretprobes").
Fix the return address of subsequent kretprobes when multiple
kretprobes are set on the same function.
For example:
# cd /sys/kernel/debug/tracing
# echo "r:event1 sys_symlink" > kprobe_events
# echo "r:event2 sys_symlink" >> kprobe_events
# echo 1 > events/kprobes/enable
# ln -s /tmp/foo /tmp/bar
(without this patch)
# cat trace | grep -v ^#
ln-82 [000] dn.2 68.446525: event1: (kretprobe_trampoline+0x0/0x18 <- SyS_symlink)
ln-82 [000] dn.2 68.447831: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
(with this patch)
ln-81 [000] dn.1 39.463469: event1: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
ln-81 [000] dn.1 39.464701: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink)
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: KUMANO Syuhei <kumano.prog@gmail.com>
[ Upstream commit f050fe7a9164945dd1c28be05bf00e8cfb082ccf ]
Currently we BUG() if we see a HSR.EC value we don't recognise. As
configurable disables/enables are added to the architecture (controlled
by RES1/RES0 bits respectively), with associated synchronous exceptions,
it may be possible for a guest to trigger exceptions with classes that
we don't recognise.
While we can't service these exceptions in a manner useful to the guest,
we can avoid bringing down the host. Per ARM DDI 0406C.c, all currently
unallocated HSR EC encodings are reserved, and per ARM DDI
0487A.k_iss10775, page G6-4395, EC values within the range 0x00 - 0x2c
are reserved for future use with synchronous exceptions, and EC values
within the range 0x2d - 0x3f may be used for either synchronous or
asynchronous exceptions.
The patch makes KVM handle any unknown EC by injecting an UNDEFINED
exception into the guest, with a corresponding (ratelimited) warning in
the host dmesg. We could later improve on this with with a new (opt-in)
exit to the host userspace.
Cc: Dave Martin <dave.martin@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit b92675d998a9fa37fe9e0e35053a95b4a23c158b ]
The device node returned by of_find_node_by_name() needs to be released
after it is no longer needed to avoid a device node leak.
[ Upstream commit 10e5778f54765c96fe0c8f104b7a030e5b35bc72 ]
After commit 0549bde0fcb1 ("of: fix of_node leak caused in
of_find_node_opts_by_path"), the following error may be
reported when running omap images.
OF: ERROR: Bad of_node_put() on /ocp@68000000
CPU: 0 PID: 0 Comm: swapper Not tainted 4.10.0-rc7-next-20170210 #1
Hardware name: Generic OMAP3-GP (Flattened Device Tree)
[<c0310604>] (unwind_backtrace) from [<c030bbf4>] (show_stack+0x10/0x14)
[<c030bbf4>] (show_stack) from [<c05add8c>] (dump_stack+0x98/0xac)
[<c05add8c>] (dump_stack) from [<c05af1b0>] (kobject_release+0x48/0x7c)
[<c05af1b0>] (kobject_release)
from [<c0ad1aa4>] (of_find_node_by_name+0x74/0x94)
[<c0ad1aa4>] (of_find_node_by_name)
from [<c1215bd4>] (omap3xxx_hwmod_is_hs_ip_block_usable+0x24/0x2c)
[<c1215bd4>] (omap3xxx_hwmod_is_hs_ip_block_usable) from
[<c1215d5c>] (omap3xxx_hwmod_init+0x180/0x274)
[<c1215d5c>] (omap3xxx_hwmod_init)
from [<c120faa8>] (omap3_init_early+0xa0/0x11c)
[<c120faa8>] (omap3_init_early)
from [<c120fb2c>] (omap3430_init_early+0x8/0x30)
[<c120fb2c>] (omap3430_init_early)
from [<c1204710>] (setup_arch+0xc04/0xc34)
[<c1204710>] (setup_arch) from [<c1200948>] (start_kernel+0x68/0x38c)
[<c1200948>] (start_kernel) from [<8020807c>] (0x8020807c)
of_find_node_by_name() drops the reference to the passed device node.
The commit referenced above exposes this problem.
To fix the problem, use of_get_child_by_name() instead of
of_find_node_by_name(); of_get_child_by_name() does not drop
the reference count of passed device nodes. While semantically
different, we only look for immediate children of the passed
device node, so of_get_child_by_name() is a more appropriate
function to use anyway.
Release the reference to the device node obtained with
of_get_child_by_name() after it is no longer needed to avoid
another device node leak.
While at it, clean up the code and change the return type of
omap3xxx_hwmod_is_hs_ip_block_usable() to bool to match its use
and the return type of of_device_is_available().
Cc: Qi Hou <qi.hou@windriver.com>
Cc: Peter Rosin <peda@axentia.se>
Cc: Rob Herring <robh@kernel.org>
[ Upstream commit 7807e086a2d1f69cc1a57958cac04fea79fc2112 ]
gpmc_probe_onenand_child returns success even on gpmc_onenand_init
failure. Fix that.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Acked-by: Roger Quadros <rogerq@ti.com>
[ Upstream commit 32b143637e8180f5d5cea54320c769210dea4f19 ]
In commit 76624175dcae ("arm64: uaccess: consistently check object sizes"),
the object size checks are moved outside the access_ok() so that bad
destinations are detected before hitting the "memset(dest, 0, size)" in the
copy_from_user() failure path.
This makes the same change for arm, with attention given to possibly
extracting the uaccess routines into a common header file for all
architectures in the future.
Suggested-by: Mark Rutland <mark.rutland@arm.com>
commit 3aaf33bebda8d4ffcc0fc8ef39e6c1ac68823b11 upstream.
When qemu starts a kernel in a bare environment, the default SCR has
the AW and FW bits clear, which means that the kernel can't modify
the PSR A or PSR F bits, and means that FIQs and imprecise aborts are
always masked.
When running uboot under qemu, the AW and FW SCR bits are set, and the
kernel functions normally - and this is how real hardware behaves.
Fix this for qemu by ignoring the FIQ bit.
Fixes: 8bafae202c82 ("ARM: BUG if jumping to usermode address in kernel mode")
Cc: Alex Shi <alex.shi@linaro.org>
commit 8bafae202c82dc257f649ea3c275a0f35ee15113 upstream.
Detect if we are returning to usermode via the normal kernel exit paths
but the saved PSR value indicates that we are in kernel mode. This
could occur due to corrupted stack state, which has been observed with
"ftracetest".
This ensures that we catch the problem case before we get to user code.
commit 5553b142be11e794ebc0805950b2e8313f93d718 upstream.
VTTBR_BADDR_MASK is used to sanity check the size and alignment of the
VTTBR address. It seems to currently be off by one, thereby only
allowing up to 39-bit addresses (instead of 40-bit) and also
insufficiently checking the alignment. This patch fixes it.
This patch is the 32bit pendent of Kristina's arm64 fix, and
she deserves the actual kudos for pinpointing that one.
Fixes: f7ed45be3ba52 ("KVM: ARM: World-switch implementation")
Reported-by: Kristina Martsenko <kristina.martsenko@arm.com>
[ Upstream commit 657279778af54f35e54b07b6687918f254a2992c ]
OMAP1510, OMAP5910 and OMAP310 have only 9 logical channels.
OMAP1610, OMAP5912, OMAP1710, OMAP730, and OMAP850 have 16 logical channels
available.
The wired 17 for the lch_count must have been used to cover the 16 + 1
dedicated LCD channel, in reality we can only use 9 or 16 channels.
The d->chan_count is not used by the omap-dma stack, so we can skip the
setup. chan_count was configured to the number of logical channels and not
the actual number of physical channels anyways.
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit a3ac350793d90d1da631c8beeee9352387974ed5 ]
Commit 485fa1261f78 ("ARM: OMAP2+: LogicPD Torpedo + Wireless: Add Bluetooth")
set the wrong baud rate for the UART. The Baud rate was 300,000 and it should
be 3,000,000 for WL1283.
commit a3ac350793d90d1da631c8beeee9352387974ed5 upstream.
commit b7ace5ed8867ca54503727988adec6b20af54eeb upstream.
Fixes commit 687c27676151 ("ARM: dts: Add minimal support for LogicPD
Torpedo DM3730 devkit")
This patch corrects an issue where the cd-gpios was improperly setup
using IRQ_TYPE_LEVEL_LOW instead of GPIO_ACTIVE_LOW.
commit 56322e123235370f1449c7444e311cce857d12f5 upstream.
Fix commit 05c4ffc3a266 ("ARM: dts: LogicPD Torpedo: Add MT9P031 Support")
In the previous commit, I indicated that the only testing was done by
showing the camera showed up when probing. This patch fixes an incorrect
pin muxing on cam_d0, cam_d1 and cam_d2.
commit 3b0c0c922ff4be275a8beb87ce5657d16f355b54 upstream.
When CONFIG_ARM_LPAE is set, the PMD dump relies on the software
read-only bit to determine whether a page is writable. This
concealed a bug which left the kernel text section writable
(AP2=0) while marked read-only in the software bit.
In a kernel with the AP2 bug, the dump looks like this:
---[ Kernel Mapping ]---
0xc0000000-0xc0200000 2M RW NX SHD
0xc0200000-0xc0600000 4M ro x SHD
0xc0600000-0xc0800000 2M ro NX SHD
0xc0800000-0xc4800000 64M RW NX SHD
The fix is to check that the software and hardware bits are both
set before displaying "ro". The dump then shows the true perms:
0xc0200000-0xc0600000 4M RW x SHD
0xc0600000-0xc0800000 2M RW NX SHD
Fixes: ded947798469 ("ARM: 8109/1: mm: Modify pte_write and pmd_write logic for LPAE")
Signed-off-by: Philip Derrin <philip@cog.systems>
Tested-by: Neil Dick <neil@cog.systems>
commit 400eeffaffc7232c0ae1134fe04e14ae4fb48d8c upstream.
Currently, for ARM kernels with CONFIG_ARM_LPAE and
CONFIG_STRICT_KERNEL_RWX enabled, the 2MiB pages mapping the
kernel code and rodata are writable. They are marked read-only in
a software bit (L_PMD_SECT_RDONLY) but the hardware read-only bit
is not set (PMD_SECT_AP2).
For user mappings, the logic that propagates the software bit
to the hardware bit is in set_pmd_at(); but for the kernel,
section_update() writes the PMDs directly, skipping this logic.
The fix is to set PMD_SECT_AP2 for read-only sections in
section_update(), at the same time as L_PMD_SECT_RDONLY.
Fixes: 1e3479225acb ("ARM: 8275/1: mm: fix PMD_SECT_RDONLY undeclared compile error")
Reported-by: Neil Dick <neil@cog.systems>
Tested-by: Laura Abbott <labbott@redhat.com>
[ Upstream commit e13a22a406f20322651b8c0847f4210bdef246d1 ]
Note that with 9730 the wiring is different compared to 9514 found on
beagleboard xm for example.
On beagleboard xm we have:
/sys/bus/usb/devices/1-2 hub
/sys/bus/usb/devices/1-2.1 9514
While on omap5-uevm we have:
/sys/bus/usb/devices/1-3 9730
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 6e613ebf4405fc09e2a8c16ed193b47f80a3cbed ]
It's possible that there are multiple quirks that need to be initialized
for the same SoC. Fix the issue by not returning on the first match.
[ Upstream commit 1aa09df0854efe16b7a80358a18f0a0bebafd246 ]
Without these changes children of the scn syscon
won't probe.
[ Upstream commit f62280efe8934a1275fd148ef302d1afec8cd3df ]
When using 8250_omap driver, we need to specify the right
compatible value for the UART to work on dm814x and dm816x.
[ Not upstream because this is a minimal fix for a bug where arm32
kernels can use a much slower implementation of AES than is actually
available, potentially forcing vendors to disable encryption on their
devices.]
All the aes-bs (bit-sliced) and aes-ce (cryptographic extensions)
algorithms had a priority of 300. This is undesirable because it means
an aes-bs algorithm may be used when an aes-ce algorithm is available.
The aes-ce algorithms have much better performance (up to 10x faster).
Fix it by decreasing the priority of the aes-bs algorithms to 250.
This was fixed upstream by commit cc477bf64573 ("crypto: arm/aes -
replace bit-sliced OpenSSL NEON code"), but it was just a small part of
a complete rewrite. This patch just fixes the priority bug for older
kernels.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
