Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
The apalis has a 8 and 4 bit SD/MMC interface.
Switch on a 100k pull up on the card detect pins for carrier boards
which leave the pin floating.
Switch on hysteresis in case the signal has slow rise or fall times.
On imx6 the SGTL5000 audio codec supply voltage is 3.3V and
not 2.5V as might have been copied over from other modules.
Output is slightly overamplified if the value is not corrected,
which may lead to signal clipping.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
The i.MX6 ULL's watchdog is used to reset the SoC on reboot. The watchdog is
configured to use the SoC's internal reset signal which does not generate a
reset pulse on nRESET_OUT. Change the watchdog configuration to use a SoC
external HW signal.
This will additionally change the 'Reset cause' message from U-Boot
from WDOG to POR.
Use a pinmux configuration for SD/MMC card detect and SPI chip
select instead of relying on reset/boot settings. There have
been no adverse effects observed, but it seems sensible to mux
the pads explicitly.
The device tree got changed to use the simple card driver, so enable it
in the defconfig.
While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver.
While at it remove the unused ESAI driver.
While at it remove the unused CS42XX8_I2C codec driver.
This reverts commit 5f60d82d38a8af8529d1493463e301e548595ccb.
Several modules have issues with HS400 at 100MHz at room temperature
but they seem to work fine at HS400 at 200MHz. Do not restrict
frequency for now.
The Capacitive Touch Adapter is an interface board designed to easily
connect the Capacitive Touch Display 7" Parallel to the Colibri Carrier
boards which do not have PCAP connector yet available on board.
Change the pins for interrupt and reset to those defined in the
Capacitive Touch Adapter's datasheet.
While at it remove the '#ifdef PCAP' in favour of disabled nodes.
That way one can fixup the device tree in U-Boot to disable the
pwm nodes and enable the connected touch controller.
e.g. for a Colibri iMX6S/DL:
Colibri iMX6 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt resize && fdt set /soc/aips-bus@02100000/i2c@021a8000/atmel_mxt_ts@4a status okay; fdt set /soc/aips-bus@02000000/pwm@02080000 status disabled; fdt set /soc/aips-bus@02000000/pwm@0208c000 status disabled'
Colibri iMX6 # saveenv
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC
is almost the same, but the M41T0 needs some special handling in
case the oscillator fails. Now that support for this difference is
available, using the new compatible string to make use of it.
Sync with commit 10e718b1c60c4e490e6972cfa58e97fcf5260685
Synced with 558d378d522189ad68fcb00aff05fd134bf20924
Add mxt nodes to dts and gpio-reset functionality.
Synchronize with commit fcfdb9c32075501e64751cc6a79fd91d15933692
A9, A12 and A17
In order to prevent aliasing attacks on the branch predictor,
invalidate the BTB on CPUs that are known to be affected when taking
a prefetch abort on a address that is outside of a user task limit.
(cherry picked from commit a07373c8c365746583f25f49fee41b1bc0ff94b2)
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
In order to avoid aliasing attacks against the branch predictor,
some implementations require to invalidate the BTB when switching
from one user context to another.
For this, we reuse the existing implementation for Cortex-A8, and
apply it to A9, A12 and A17.
(cherry picked commit from efcd0e857a656bbd1c1da15ff984ad6402332c61)
[jason: adapted to 4.9]
Prepare FlexCAN use on SODIMM 55/63. Those SODIMM pins are compatible
for CAN bus use with several modules from the Colibri family.
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5.
MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference
Manual. Tested playback and record on pulseaudio with 44.1kHz samples.
The Colibri iMX6ULL 256MB crashes in resume if the M/F mix domain is
powered down when suspending.
With this workaround this does not happen.
Crash looks as follows:
root@colibri-imx6ull:~# echo +3 > /sys/class/rtc/rtc1/wakealarm; echo mem > /sys/power/state
[ 52.800741] PM: Syncing filesystems ... done.
[ 52.856715] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 52.865669] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 52.875024] Suspending console(s) (use no_console_suspend to debug)
[ 52.950638] PM: suspend of devices complete after 68.211 msecs
[ 52.952506] PM: late suspend of devices complete after 1.835 msecs
[ 52.954292] PM: noirq suspend of devices complete after 1.757 msecs
[ 52.954300] Disabling non-boot CPUs ...
[ 52.954307] Turn off M/F mix!
[ 52.955663] PM: noirq resume of devices complete after 1.222 msecs
[ 52.956767] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 52.957669] PM: early resume of devices complete after 1.411 msecs
[ 52.959140] gpmi-nand 1806000.gpmi-nand: use legacy bch geometry
[ 53.005653] Suspended for 2.907 seconds
[ 53.012207] PM: resume of devices complete after 54.507 msecs
[ 53.073751] Restarting tasks ... done.
root@colibri-imx6ull:~# [ 55.049753] gpmi-nand 1806000.gpmi-nand: DMA timeout, last DMA :2
[ 55.056377] gpmi-nand 1806000.gpmi-nand: Show GPMI registers :
[ 55.062835] gpmi-nand 1806000.gpmi-nand: offset 0x000 : 0x00000000
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit 3e1b857786f0d46a92b3a4d7878767883ed90bdc)
To operate RS-485 on Toradex Carrier Boards a low active RTS signal
is required. Furthermore, a low active RTS signal requires the
receiver to be active (this seems to be a hardware limitation of the
i.MX UART).
Remove duplicate nodes introduced with the move to L4.9.11
release.
The new Apalis iMX6 Mezzanine board allows access to the MIPI-CSI2
interface from the evaluation board. The current device tree has
different GPIO pin assignments for the camera reset and power pins.
Change the pin assignment to use Apalis GPIO1 for reset and Apalis
GPIO2 for power down.
Add timings for LTTD1280800101-L4WH-CT1 panel used in the new
Capacitive Touch 10.1" LVDS display.
Note that the color mapping is to be set as follows:
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
The Atmel maXTouch multitouch controller driver does not control the
reset line connected to the chip. Use a GPIO reset controller node to
release the reset line and make the controller work.
Note that both the reset controller's and the mxt mutitouch controller's
node are set to disabled. Either change this in the dtsi source or fix
this from U-Boot if you use an Atmel maXTouch multitouch controller.
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay && fdt set /mxt-reset status okay'
Configure Ethernet clock source for each FEC instance individually.
This allows to use different clock source setting for the two FEC
controllers.
Exit early in case General-Purpose Registers are missing. This makes
sure that clock is always freed properly (clk_put).
Add alias for Ethernet controllers. This allows code to determine
id of controllers using of_alias_get_id.
Commit 95c163471135 ("usb: chipidea: use of extcon framework to
work for non OTG case") requires both pins to be specified (ID and
VBUS pin) to work correctly.
Fix the remaining dts.
toradex_4.9-1.0.x-imx-next
This is the 4.9.87 stable release
drivers/dma/fsl-edma.c
commit 74402055a2d3ec998a1ded599e86185a27d9bbf4 upstream.
The pinmuxing was missing for I2C1 which was causing intermittent issues
with the PMIC which is connected to I2C1. The bootloader did not quite
configure the I2C1 either, so when running at 2.6MHz, it was generating
errors at time.
This correctly sets the I2C1 pinmuxing so it can operate at 2.6MHz
Fixes: 687c27676151 ("ARM: dts: Add minimal support for LogicPD Torpedo
DM3730 devkit")
commit 84c7efd607e7fb6933920322086db64654f669b2 upstream.
errors at times.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730
SOM-LV")
commit 67870eb1204223598ea6d8a4467b482e9f5875b5 upstream.
In banked-sr.c, we use a top-level '__asm__(".arch_extension virt")'
statement to allow compilation of a multi-CPU kernel for ARMv6
and older ARMv7-A that don't normally support access to the banked
registers.
This is considered to be a programming error by the gcc developers
and will no longer work in gcc-8, where we now get a build error:
/tmp/cc4Qy7GR.s:34: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_usr'
/tmp/cc4Qy7GR.s:41: Error: Banked registers are not available with this architecture. -- `mrs r3,ELR_hyp'
/tmp/cc4Qy7GR.s:55: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_svc'
/tmp/cc4Qy7GR.s:62: Error: Banked registers are not available with this architecture. -- `mrs r3,LR_svc'
/tmp/cc4Qy7GR.s:69: Error: Banked registers are not available with this architecture. -- `mrs r3,SPSR_svc'
/tmp/cc4Qy7GR.s:76: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_abt'
Passign the '-march-armv7ve' flag to gcc works, and is ok here, because
we know the functions won't ever be called on pre-ARMv7VE machines.
Unfortunately, older compiler versions (4.8 and earlier) do not understand
that flag, so we still need to keep the asm around.
Backporting to stable kernels (4.6+) is needed to allow those to be built
with future compilers as well.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84129
Fixes: 33280b4cd1dc ("ARM: KVM: Add banked registers save/restore")
Cc: stable@vger.kernel.org
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 8aa36a8dcde3183d84db7b0d622ffddcebb61077 upstream.
The MACH_ARMADA_375 and MACH_ARMADA_38X boards select ARM_ERRATA_753970,
but it was renamed to PL310_ERRATA_753970 by commit fa0ce4035d48 ("ARM:
7162/1: errata: tidy up Kconfig options for PL310 errata workarounds").
Fix the selects to use the new name.
Discovered with the
https://github.com/ulfalizer/Kconfiglib/blob/master/examples/list_undefined.py
script.
Fixes: fa0ce4035d48 ("ARM: 7162/1: errata: tidy up Kconfig options for
cc: stable@vger.kernel.org
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
The SNVS RTC does not use an address in its node name anymore.
Instead of using the full path, simply use the SNVS RTC label.
The SNVS subnodes reenable the power key which is not used on the
Colibri iMX7 modules. Disable the power key again.
Also make sure that the priority of the RTCs used is defined.
Add SNVS subnodes such as internal SNVS RTC.
Fixes: b66e57551f4e ("ARM: dts: imx7d: move nodes to i.MX 7Solo device tree")
The operating points are already present in imx7d.dtsi, there is
no need to dupplicate the operating points in the module level
device tree.
The i.MX Thermal driver requires a cpufreq device to be present.
Create a single operating point to make sure cpufreq device can
successfully probe.
Commit 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a
hugepage at Stage 2") lost the check for PMD_SIZE during the backport
to 4.9.
Fix this by correcting the condition to detect hugepages during stage
2 allocation.
Fixes: 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a hugepage at Stage 2")
Reported-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
[ Upstream commit 506e8a912661c97b41adc8a286b875d01323ec45 ]
dtc warns about two 'clocks' properties that have an extraneous '1'
at the end:
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a:clocks[1])
Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2190000/sgtl5000@a
arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2190000/sgtl5000@a:clocks[1])
The clocks that get referenced here are fixed-rate, so they do not
take any argument, and dtc interprets the next cell as a phandle, which
is invalid.
[ Upstream commit 36b0cb84ee858f02c256d26f0cb4229c78e3399e ]
An additional 'ip' will be pushed to the stack, for restoring the
DACR later, if CONFIG_CPU_SW_DOMAIN_PAN defined.
However, the fixup still get the err_ptr by add #8*4 to sp, which
results in the fact that the code area pointed by the LR will be
overwritten, or the kernel will crash if CONFIG_DEBUG_RODATA is enabled.
This patch fixes the stack mismatch.
Fixes: a5e090acbf54 ("ARM: software-based priviledged-no-access support")
Signed-off-by: Lvqiang Huang <Lvqiang.Huang@spreadtrum.com>
Signed-off-by: Chunyan Zhang <zhang.lyra@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
This is the 4.9.84 stable release
[ Upstream commit d364b038bc962f494cffb8f6cb6cddbe41bcb5b6 ]
Looks like the interrupt property is missing the controller and level
information causing:
Warning (interrupts_property): interrupts size is (4), expected multiple
of 12 in /ocp/elm@48078000
[ Upstream commit ca41e244517d6d3f1600c229ff7ca615049c1e9c ]
The DMA binding for eDMA needs 2 parameters, not 1.
The second, missing parameter is the tptc to be used for the channel.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
[ Upstream commit 627395a6f8091c0aa18f49dca7df59ba3ec147ef ]
Fixes the following warnings:
arch/arm/boot/dts/am437x-cm-t43.dtb: Warning (interrupts_property):
interrupts size is (8), expected multiple of 12 in
/ocp@44000000/mcasp@48038000
/ocp@44000000/mcasp@4803C000
