It compiles debug level messages into the kernel, which would not
otherwise be available at runtime.
Relates-to: ELB-4336
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Update UHS-I mode pinmux setting to 200 MHz speed grade,
e.g. pinmux bits 7-6: 11b SPEED_3_max_200MHz_
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Add disable-wp property to avoid the warning from
mmc/sd driver drivers/mmc/core/sd.c:
"mmc1: host does not support reading read-only switch,
assuming write-enable"
NAND devices do not use overlays. Keep lcdif, backlight and ad7879
resistive touch-screen enabled by default and explicitly specify
parent clock for lcdif to support clock source for RGB DAC output.
For eMMC devices keep lcdif, backlight, ad7879_ts
and atmel_mxt_ts disabled by default, just to enabled it in overlays
Keep +3.3V pull-ups interface by default in imx6ull-colibri.dtsi
SD card interface setting per board device tree:
imx6ull-colibri-aster.dtsi +3.3V pull-ups
imx6ull-colibri-eval-v3.dtsi +3.3V pull-ups
imx6ull-colibri-iris.dtsi +3.3V pull-ups
imx6ull-colibri-iris-v2.dtsi +1.8V signaling, UHS capable
SD card is not detected on Ixora revision v1.2 board.
Add card detect gpio to SOM DTSI, clean-up carrier boards
Keep +3.3V pull-ups interface by default in SOM DTSI imx7-colibri.dtsi
imx7-colibri-aster.dtsi +3.3V pull-ups
imx7-colibri-eval-3.dtsi +3.3V pull-ups
imx7-colibri-iris.dtsi +3.3V pull-ups
imx7-colibri-iris-v2.dtsi 1.8V signaling, no pull-ups, UHS capable
Keep +3.3V pull-ups interface by default in imx6qdl-colibri.dtsi.
Clean-up Iris V2.0 carrier board device tree.
UHS mode can be supported on Iris V2.0, where no SD pull-ups populated,
but not enabled to provide backward compatibility with
Colibri iMX6 rev1.0, without populated vgen3 LDO
Removed disable-wp as WP is not connected to GPIO.
toradex_5.4-2.3.x-imx-v5.4.161
drivers/net/phy/micrel.c
drivers/usb/chipidea/core.c
This is the 5.4.160 stable release
This is the 5.4.157 stable release
This is the 5.4.156 stable release
imx-cpufreq-dt driver needs speed_grade to be defined
for correct probe and registration. The speed grade
is defined by two speed grading bits present in OCOTP fuses.
It fixes the following error:
root@colibri-imx7-02951832:~# dmesg | grep cpufreq
[ 2.222317] imx-cpufreq-dt: probe of imx-cpufreq-dt failed with error -2
For all imx7s parts speed grade is fixed at 800mhz.
commit 418ace9992a7647c446ed3186df40cf165b67298 upstream.
Naresh and Antonio ran into a build failure with latest Debian
armhf compilers, with lots of output like
tmp/ccY3nOAs.s:2215: Error: selected processor does not support `cpsid i' in ARM mode
As it turns out, $(cc-option) fails early here when the FPU is not
selected before CPU architecture is selected, as the compiler
option check runs before enabling -msoft-float, which causes
a problem when testing a target architecture level without an FPU:
cc1: error: '-mfloat-abi=hard': selected architecture lacks an FPU
Passing e.g. -march=armv6k+fp in place of -march=armv6k would avoid this
issue, but the fallback logic is already broken because all supported
compilers (gcc-5 and higher) are much more recent than these options,
and building with -march=armv5t as a fallback no longer works.
The best way forward that I see is to just remove all the checks, which
also has the nice side-effect of slightly improving the startup time for
'make'.
The -mtune=marvell-f option was apparently never supported by any mainline
compiler, and the custom Codesourcery gcc build that did support is
now too old to build kernels, so just use -mtune=xscale unconditionally
for those.
This should be safe to apply on all stable kernels, and will be required
in order to keep building them with gcc-11 and higher.
Link: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=996419
Reported-by: Antonio Terceiro <antonio.terceiro@linaro.org>
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Tested-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Tested-by: Klaus Kudielka <klaus.kudielka@gmail.com>
Cc: Matthias Klose <doko@debian.org>
Cc: stable@vger.kernel.org
Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk>
commit 0d08e7bf0d0d1a29aff7b16ef516f7415eb1aa05 upstream.
Currently __set_fixmap() bails out with a warning when called in early boot
from early_iounmap(). Fix it, and while at it, make the comment a bit easier
to understand.
Cc: <stable@vger.kernel.org>
Fixes: b089c31c519c ("ARM: 8667/3: Fix memory attribute inconsistencies when using fixmap")
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
[ Upstream commit 6f87a74d31277f0896dcf8c0850ec14bde03c423 ]
The STM32 SAI subblocks registers offsets are in the range
0x0004 (SAIx_CR1) to 0x0020 (SAIx_DR).
The corresponding range length is 0x20 instead of 0x1c.
Change reg property accordingly.
Fixes: 5afd65c3a060 ("ARM: dts: stm32: add sai support on stm32mp157c")
Signed-off-by: Olivier Moysan <olivier.moysan@foss.st.com>
Signed-off-by: Alexandre Torgue <alexandre.torgue@foss.st.com>
[ Upstream commit 884ea75d79a36faf3731ad9d6b9c29f58697638d ]
Fix typo in pinctrl. It did only work because the bootloader
seems to have initialized it.
Fixes: ee327111953b ("ARM: dts: omap3-gta04: Define and use bma180 irq pin")
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
[ Upstream commit dcdbc335a91a26e022a803e1a6b837266989c032 ]
This went unnoticed until commit 7897b071ac3b ("net: macb: convert
to phylink") which tickled the problem. The sama5d3 emac has never
been capable of rgmii, and it all just happened to work before that
commit.
Fixes: 21dd0ece34c2 ("ARM: dts: at91: add devicetree for the Axentia TSE-850")
Signed-off-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Link: https://lore.kernel.org/r/ea781f5e-422f-6cbf-3cf4-d5a7bac9392d@axentia.se
[ Upstream commit 8ccecf6c710b8c048eecc65709640642e5357d6e ]
According to YAML validation, and for a future patchset putting this
xo_board reference clock to use as VCO reference parent, add the missing
clock to dsi_phy0.
Fixes: 5a9fc531f6ec ("ARM: dts: msm8974: add display support")
Signed-off-by: Marijn Suijten <marijn.suijten@somainline.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Link: https://lore.kernel.org/r/20210830175739.143401-1-marijn.suijten@somainline.org
[ Upstream commit 345dac33f58894a56d17b92a41be10e16585ceff ]
When configuring the kernel for big-endian, we set either BE-8 or BE-32
based on the CPU architecture level. Until linux-4.4, we did not have
any ARMv7-M platform allowing big-endian builds, but now i.MX/Vybrid
is in that category, adn we get a build error because of this:
arch/arm/kernel/module-plts.c: In function 'get_module_plt':
arch/arm/kernel/module-plts.c:60:46: error: implicit declaration of function '__opcode_to_mem_thumb32' [-Werror=implicit-function-declaration]
This comes down to picking the wrong default, ARMv7-M uses BE8
like ARMv7-A does. Changing the default gets the kernel to compile
and presumably works.
https://lore.kernel.org/all/1455804123-2526139-2-git-send-email-arnd@arndb.de/
Tested-by: Vladimir Murzin <vladimir.murzin@arm.com>
[ Upstream commit b3ea5d56f212ad81328c82454829a736197ebccc ]
Currently the stacktrace on clang compiled arm kernel uses the 'lr'
register to find the first frame address from pt_regs. However, that
is wrong after calling another function, because the 'lr' register
is used by 'bl' instruction and never be recovered.
As same as gcc arm kernel, directly use the frame pointer (r11) of
the pt_regs to find the first frame address.
Note that this fixes kretprobe stacktrace issue only with
CONFIG_UNWINDER_FRAME_POINTER=y. For the CONFIG_UNWINDER_ARM,
we need another fix.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 55dd7e059098ce4bd0a55c251cb78e74604abb57 ]
Commit bbc4d71d6354 ("net: phy: realtek: fix rtl8211e rx/tx delay
config") sets the RX/TX delay according to the phy-mode property in the
device tree. For the A20-olinuxino-lime2 board this is "rgmii", which is the
wrong setting.
Following the example of a900cac3750b ("ARM: dts: sun7i: a20: bananapro:
Fix ethernet phy-mode") the phy-mode is changed to "rgmii-id" which gets
the Ethernet working again on this board.
Signed-off-by: Bastien Roucariès <rouca@debian.org>
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
Link: https://lore.kernel.org/r/20210916081721.237137-1-rouca@debian.org
Some DT node path are changed, correct them to support i.MX7D 12x12 LPDDR3
validation board.
Related-to: ELB-4064
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
(cherry picked from commit eb0b5039ea485a6fd86d51884d95c26e3eddbd02)
This is the 5.4.153 stable release
commit 48ccc8edf5b90622cdc4f8878e0042ab5883e2ca upstream.
In randconfig builds, we sometimes come across this warning:
arm-linux-gnueabi-ld: XIP start address may cause MPU programming issues
While this is helpful for actual systems to figure out why it
fails, the warning does not provide any benefit for build testing,
so guard it in a check for CONFIG_COMPILE_TEST, which is usually
set on randconfig builds.
Fixes: 216218308cfb ("ARM: 8713/1: NOMMU: Support MPU in XIP configuration")
commit 1f323127cab086e4fd618981b1e5edc396eaf0f4 upstream.
With extra warnings enabled, gcc complains about this function
definition:
arch/arm/probes/kprobes/core.c: In function 'arch_init_kprobes':
arch/arm/probes/kprobes/core.c:465:12: warning: old-style function definition [-Wold-style-definition]
465 | int __init arch_init_kprobes()
Link: https://lore.kernel.org/all/20201027093057.c685a14b386acacb3c449e3d@kernel.org/
Fixes: 24ba613c9d6c ("ARM kprobes: core code")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
commit eaf6cc7165c9c5aa3c2f9faa03a98598123d0afb upstream.
Both the decompressor code and the kasan logic try to override
the memcpy() and memmove() definitions, which leading to a clash
in a KASAN-enabled kernel with XZ decompression:
arch/arm/boot/compressed/decompress.c:50:9: error: 'memmove' macro redefined [-Werror,-Wmacro-redefined]
#define memmove memmove
arch/arm/include/asm/string.h:59:9: note: previous definition is here
#define memmove(dst, src, len) __memmove(dst, src, len)
arch/arm/boot/compressed/decompress.c:51:9: error: 'memcpy' macro redefined [-Werror,-Wmacro-redefined]
#define memcpy memcpy
arch/arm/include/asm/string.h:58:9: note: previous definition is here
#define memcpy(dst, src, len) __memcpy(dst, src, len)
Here we want the set of functions from the decompressor, so undefine
the other macros before the override.
Link: https://lore.kernel.org/linux-arm-kernel/CACRpkdZYJogU_SN3H9oeVq=zJkRgRT1gDz3xp59gdqWXxw-B=w@mail.gmail.com/
Link: https://lore.kernel.org/lkml/202105091112.F5rmd4By-lkp@intel.com/
Fixes: d6d51a96c7d6 ("ARM: 9014/2: Replace string mem* functions for KASan")
Fixes: a7f464f3db93 ("ARM: 7001/2: Wire up support for the XZ decompressor")
Reported-by: kernel test robot <lkp@intel.com>
commit e6a0c958bdf9b2e1b57501fc9433a461f0a6aadd upstream.
A kernel built with CONFIG_THUMB2_KERNEL=y and using clang as the
assembler could generate non-naturally-aligned v7wbi_tlb_fns which
results in a boot failure. The original commit adding the macro missed
the .align directive on this data.
Link: https://github.com/ClangBuiltLinux/linux/issues/1447
Link: https://lore.kernel.org/all/0699da7b-354f-aecc-a62f-e25693209af4@linaro.org/
Debugged-by: Ard Biesheuvel <ardb@kernel.org>
Debugged-by: Nathan Chancellor <nathan@kernel.org>
Debugged-by: Richard Henderson <richard.henderson@linaro.org>
Fixes: 66a625a88174 ("ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macros")
Suggested-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Tested-by: Nathan Chancellor <nathan@kernel.org>
commit 9d417cbe36eee7afdd85c2e871685f8dab7c2dba upstream.
tglx notes:
This function [futex_detect_cmpxchg] is only needed when an
architecture has to runtime discover whether the CPU supports it or
not. ARM has unconditional support for this, so the obvious thing to
do is the below.
Fixes linkage failure from Clang randconfigs:
kernel/futex.o:(.text.fixup+0x5c): relocation truncated to fit: R_ARM_JUMP24 against `.init.text'
and boot failures for CONFIG_THUMB2_KERNEL.
Link: https://github.com/ClangBuiltLinux/linux/issues/325
Comments from Nick Desaulniers:
See-also: 03b8c7b623c8 ("futex: Allow architectures to skip
futex_atomic_cmpxchg_inatomic() test")
Reported-by: Nathan Chancellor <nathan@kernel.org>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: stable@vger.kernel.org # v3.14+
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[ Upstream commit 6636fec29cdf6665bd219564609e8651f6ddc142 ]
On SPEAr3xx, ethernet driver is not compatible with the SPEAr600
one.
Indeed, SPEAr3xx uses an earlier version of this IP (v3.40) and
needs some driver tuning compare to SPEAr600.
The v3.40 IP support was added to stmmac driver and this patch
fixes this issue and use the correct compatible string for
SPEAr3xx
Signed-off-by: Herve Codina <herve.codina@bootlin.com>
[ Upstream commit 4348cc10da6377a86940beb20ad357933b8f91bb ]
Without a sensor node, the ISC will simply fail to probe, as the
corresponding port node is missing.
It is then logical to disable the node in the devicetree.
If we add a port with a connection to a sensor endpoint, ISC can be enabled.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Link: https://lore.kernel.org/r/20210902121358.503589-1-eugen.hristev@microchip.com
[ Upstream commit b13a270ace2e4c70653aa1d1d0394c553905802f ]
Commit 94f6345712b3 ("bus: ti-sysc: Implement quirk handling for
CLKDM_NOAUTO") should have also added the quirk for dra7 dcan1 in
addition to dcan2 for errata i893 handling.
Let's also pass the quirk flag for legacy mode booting for if "ti,hwmods"
dts property is used with related dcan hwmod data. This should be only
needed if anybody needs to git bisect earlier stable trees though.
Fixes: 94f6345712b3 ("bus: ti-sysc: Implement quirk handling for CLKDM_NOAUTO")
[ Upstream commit 783f3db030563f7bcdfe2d26428af98ea1699a8e ]
Any pending interrupt can prevent entering standby based power off state.
To avoid it, disable the GIC CPU interface.
Fixes: 8148d2136002 ("ARM: imx6: register pm_power_off handler if "fsl,pmic-stby-poweroff" is set")
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
[ Upstream commit 79e3445b38e0cab94264a3894c0c3d57c930b97e ]
On ARM CPUs that lack div/mod instructions, ALU32 BPF_DIV and BPF_MOD are
implemented using a call to a helper function. Before, the emitted code
for those function calls failed to preserve caller-saved ARM registers.
Since some of those registers happen to be mapped to BPF registers, it
resulted in eBPF register values being overwritten.
This patch emits code to push and pop the remaining caller-saved ARM
registers r2-r3 into the stack during the div/mod function call. ARM
registers r0-r1 are used as arguments and return value, and those were
already saved and restored correctly.
Fixes: 39c13c204bb1 ("arm: eBPF JIT compiler")
Signed-off-by: Johan Almbladh <johan.almbladh@anyfinetworks.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 5c187e2eb3f92daa38cb3d4ab45e1107ea34108e ]
The MIC2025 switch input signal nEN is active low, describe it as such
in the DT. The previous change to this regulator polarity was incorrectly
influenced by broken quirks in gpiolib-of.c, which is now long fixed. So
fix this regulator polarity setting here once and for all.
Fixes: 3c3601cd6a6d3 ("ARM: dts: imx53: Update USB configuration on M53Menlo")
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP Linux Team <linux-imx@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit c8c1efe14a4aadcfe93a158b1272e48298d2de15 ]
The panel already contains pinctrl-0 phandle, but it is missing
the default pinctrl-names property, so the pin configuration is
ignored. Fill in the missing pinctrl-names property, so the pin
configuration is applied.
Fixes: d81765d693db6 ("ARM: dts: imx53: Update LCD panel node on M53Menlo")
[ Upstream commit f1db21c315f4b4f8c3fbea56aac500673132d317 ]
The 28NM DSI PLL driver for msm8960 calculates with a 27MHz reference
clock and should hence use PXO, not CXO which runs at 19.2MHz.
Note that none of the DSI PHY/PLL drivers currently use this "ref"
clock; they all rely on (sometimes inexistant) global clock names and
usually function normally without a parent clock. This discrepancy will
be corrected in a future patch, for which this change needs to be in
place first.
Fixes: 6969d1d9c615 ("ARM: dts: qcom-apq8064: Set 'cxo_board' as ref clock of the DSI PHY")
Reviewed-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
Link: https://lore.kernel.org/r/20210829203027.276143-2-marijn.suijten@somainline.org
commit f5c03f131dae3f06d08464e6157dd461200f78d9 upstream.
Also resolves these kernel warnings for APQ8064:
adreno 4300000.adreno-3xx: Using legacy qcom,chipid binding!
adreno 4300000.adreno-3xx: Use compatible qcom,adreno-320.2 instead.
Tested on Nexus 7 2013, no functional changes.
Signed-off-by: David Heidelberg <david@ixit.cz>
Link: https://lore.kernel.org/r/20210818065317.19822-1-david@ixit.cz
commit 80d680fdccba214e8106dc1aa33de5207ad75394 upstream.
Nand is on CS1 so reg properties first field should be 1 not 0.
Fixes: 44e4716499b8 ("ARM: dts: omap3: Fix NAND device nodes")
Cc: stable@vger.kernel.org # v4.6+
Signed-off-by: Roger Quadros <rogerq@kernel.org>
This is the 5.4.149 stable release
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit 6fa630bf473827aee48cbf0efbbdf6f03134e890 upstream
FTRACE_ADDR is only defined when CONFIG_DYNAMIC_FTRACE is defined, the
latter is even stronger requirement than CONFIG_FUNCTION_TRACER (which is
enough for MCOUNT_ADDR).
Link: https://lists.01.org/hyperkitty/list/kbuild-all@lists.01.org/thread/ZUVCQBHDMFVR7CCB7JPESLJEWERZDJ3T/
Fixes: 1f12fb25c5c5d22f ("ARM: 9079/1: ftrace: Add MODULE_PLTS support")
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 79f32b221b18c15a98507b101ef4beb52444cc6f upstream
Teach ftrace_make_call() and ftrace_make_nop() about PLTs.
Teach PLT code about FTRACE and all its callbacks.
Otherwise the following might happen:
WARNING: CPU: 14 PID: 2265 at .../arch/arm/kernel/insn.c:14 __arm_gen_branch+0x83/0x8c()
Hardware name: LSI Axxia AXM55XX
[<c0314a49>] (unwind_backtrace) from [<c03115e9>] (show_stack+0x11/0x14)
[<c03115e9>] (show_stack) from [<c0519f51>] (dump_stack+0x81/0xa8)
[<c0519f51>] (dump_stack) from [<c032185d>] (warn_slowpath_common+0x69/0x90)
[<c032185d>] (warn_slowpath_common) from [<c03218f3>] (warn_slowpath_null+0x17/0x1c)
[<c03218f3>] (warn_slowpath_null) from [<c03143cf>] (__arm_gen_branch+0x83/0x8c)
[<c03143cf>] (__arm_gen_branch) from [<c0314337>] (ftrace_make_nop+0xf/0x24)
[<c0314337>] (ftrace_make_nop) from [<c038ebcb>] (ftrace_process_locs+0x27b/0x3e8)
[<c038ebcb>] (ftrace_process_locs) from [<c0378d79>] (load_module+0x11e9/0x1a44)
[<c0378d79>] (load_module) from [<c037974d>] (SyS_finit_module+0x59/0x84)
[<c037974d>] (SyS_finit_module) from [<c030e981>] (ret_fast_syscall+0x1/0x18)
---[ end trace e1b64ced7a89adcc ]---
WARNING: CPU: 14 PID: 2265 at .../kernel/trace/ftrace.c:1979 ftrace_bug+0x1b1/0x234()
[<c03218f3>] (warn_slowpath_null) from [<c038e87d>] (ftrace_bug+0x1b1/0x234)
[<c038e87d>] (ftrace_bug) from [<c038ebd5>] (ftrace_process_locs+0x285/0x3e8)
[<c038ebd5>] (ftrace_process_locs) from [<c0378d79>] (load_module+0x11e9/0x1a44)
---[ end trace e1b64ced7a89adcd ]---
ftrace failed to modify [<e9ef7006>] 0xe9ef7006
actual: 02:f0:3b:fa
ftrace record flags: 0
(0) expected tramp: c0314265
commit 890cb057a46d323fd8c77ebecb6485476614cd21 upstream
Will be used in the following patch. No functional change.
commit 4e271701c17dee70c6e1351c4d7d42e70405c6a9 upstream
No functional change, later it will be re-used in several files.
commit fcf044891c84e38fc90eb736b818781bccf94e38 upstream.
We do not need a SWIOTLB unless we have DRAM that is addressable beyond
the arm_dma_limit. Compare max_pfn with arm_dma_pfn_limit to determine
whether we do need a SWIOTLB to be initialized.
Fixes: ad3c7b18c5b3 ("arm: use swiotlb for bounce buffering on LPAE configs")
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This is the 5.4.148 stable release
- drivers/dma/imx-sdma.c:
Following upstream patches are already applied to NXP tree:
7cfbf391e870 ("dmaengine: imx-sdma: remove duplicated sdma_load_context")
788122c99d85 ("Revert "dmaengine: imx-sdma: refine to load context only
once"")
- drivers/usb/chipidea/host.c:
Merge upstream commit a18cfd715e91 ("usb: chipidea: host: fix port index
underflow and UBSAN complains") to NXP version.
[ Upstream commit 2270ad2f4e123336af685ecedd1618701cb4ca1e ]
This patch fixes the tristate and pullup configuration for UART 1 to 3
on the Tamonten SOM.
Signed-off-by: Andreas Obergschwandtner <andreas.obergschwandtner@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit cd7cd5b716d594e27a933c12f026d4f2426d7bf4 ]
PPD has only one ACHC device, which effectively is a Kinetis
microcontroller. It has one SPI interface used for normal
communication. Additionally it's possible to flash the device
firmware using NXP's EzPort protocol by correctly driving a
second chip select pin and the device reset pin.
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Link: https://lore.kernel.org/r/20210802172309.164365-3-sebastian.reichel@collabora.com
[ Upstream commit 0dc6c59892ead17a9febd11202c9f6794aac1895 ]
Since new code doesn't take old clk names in account, it does fixes
error:
msm_dsi 4700000.mdss_dsi: dev_pm_opp_set_clkname: Couldn't find clock: -2
and following kernel oops introduced by
b0530eb1191 ("drm/msm/dpu: Use OPP API to set clk/perf state").
Also removes warning about deprecated clock names.
Tested against linux-5.10.y LTS on Nexus 7 2013.
Reviewed-by: Brian Masney <masneyb@onstation.org>
Link: https://lore.kernel.org/r/20210707131453.24041-1-david@ixit.cz
