This is the 4.4.291 stable release
commit 091bb549f7722723b284f63ac665e2aedcf9dec9 upstream.
This option is not supported by lld:
ld.lld: error: unknown argument: -p
This has been a no-op in binutils since 2004 (see commit dea514f51da1 in
that tree). Given that the lowest officially supported of binutils for
the kernel is 2.20, which was released in 2009, nobody needs this flag
around so just remove it. Commit 1a381d4a0a9a ("arm64: remove no-op -p
linker flag") did the same for arm64.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 1f323127cab086e4fd618981b1e5edc396eaf0f4 upstream.
With extra warnings enabled, gcc complains about this function
definition:
arch/arm/probes/kprobes/core.c: In function 'arch_init_kprobes':
arch/arm/probes/kprobes/core.c:465:12: warning: old-style function definition [-Wold-style-definition]
465 | int __init arch_init_kprobes()
Link: https://lore.kernel.org/all/20201027093057.c685a14b386acacb3c449e3d@kernel.org/
Fixes: 24ba613c9d6c ("ARM kprobes: core code")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk>
commit eaf6cc7165c9c5aa3c2f9faa03a98598123d0afb upstream.
Both the decompressor code and the kasan logic try to override
the memcpy() and memmove() definitions, which leading to a clash
in a KASAN-enabled kernel with XZ decompression:
arch/arm/boot/compressed/decompress.c:50:9: error: 'memmove' macro redefined [-Werror,-Wmacro-redefined]
#define memmove memmove
arch/arm/include/asm/string.h:59:9: note: previous definition is here
#define memmove(dst, src, len) __memmove(dst, src, len)
arch/arm/boot/compressed/decompress.c:51:9: error: 'memcpy' macro redefined [-Werror,-Wmacro-redefined]
#define memcpy memcpy
arch/arm/include/asm/string.h:58:9: note: previous definition is here
#define memcpy(dst, src, len) __memcpy(dst, src, len)
Here we want the set of functions from the decompressor, so undefine
the other macros before the override.
Link: https://lore.kernel.org/linux-arm-kernel/CACRpkdZYJogU_SN3H9oeVq=zJkRgRT1gDz3xp59gdqWXxw-B=w@mail.gmail.com/
Link: https://lore.kernel.org/lkml/202105091112.F5rmd4By-lkp@intel.com/
Fixes: d6d51a96c7d6 ("ARM: 9014/2: Replace string mem* functions for KASan")
Fixes: a7f464f3db93 ("ARM: 7001/2: Wire up support for the XZ decompressor")
Reported-by: kernel test robot <lkp@intel.com>
commit e6a0c958bdf9b2e1b57501fc9433a461f0a6aadd upstream.
A kernel built with CONFIG_THUMB2_KERNEL=y and using clang as the
assembler could generate non-naturally-aligned v7wbi_tlb_fns which
results in a boot failure. The original commit adding the macro missed
the .align directive on this data.
Link: https://github.com/ClangBuiltLinux/linux/issues/1447
Link: https://lore.kernel.org/all/0699da7b-354f-aecc-a62f-e25693209af4@linaro.org/
Debugged-by: Ard Biesheuvel <ardb@kernel.org>
Debugged-by: Nathan Chancellor <nathan@kernel.org>
Debugged-by: Richard Henderson <richard.henderson@linaro.org>
Fixes: 66a625a88174 ("ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macros")
Suggested-by: Ard Biesheuvel <ardb@kernel.org>
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Tested-by: Nathan Chancellor <nathan@kernel.org>
commit 9d417cbe36eee7afdd85c2e871685f8dab7c2dba upstream.
tglx notes:
This function [futex_detect_cmpxchg] is only needed when an
architecture has to runtime discover whether the CPU supports it or
not. ARM has unconditional support for this, so the obvious thing to
do is the below.
Fixes linkage failure from Clang randconfigs:
kernel/futex.o:(.text.fixup+0x5c): relocation truncated to fit: R_ARM_JUMP24 against `.init.text'
and boot failures for CONFIG_THUMB2_KERNEL.
Link: https://github.com/ClangBuiltLinux/linux/issues/325
Comments from Nick Desaulniers:
See-also: 03b8c7b623c8 ("futex: Allow architectures to skip
futex_atomic_cmpxchg_inatomic() test")
Reported-by: Nathan Chancellor <nathan@kernel.org>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: stable@vger.kernel.org # v3.14+
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[ Upstream commit 6636fec29cdf6665bd219564609e8651f6ddc142 ]
On SPEAr3xx, ethernet driver is not compatible with the SPEAr600
one.
Indeed, SPEAr3xx uses an earlier version of this IP (v3.40) and
needs some driver tuning compare to SPEAr600.
The v3.40 IP support was added to stmmac driver and this patch
fixes this issue and use the correct compatible string for
SPEAr3xx
Signed-off-by: Herve Codina <herve.codina@bootlin.com>
[ Upstream commit 783f3db030563f7bcdfe2d26428af98ea1699a8e ]
Any pending interrupt can prevent entering standby based power off state.
To avoid it, disable the GIC CPU interface.
Fixes: 8148d2136002 ("ARM: imx6: register pm_power_off handler if "fsl,pmic-stby-poweroff" is set")
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
This is the 4.4.288 stable release
[ Upstream commit 2270ad2f4e123336af685ecedd1618701cb4ca1e ]
This patch fixes the tristate and pullup configuration for UART 1 to 3
on the Tamonten SOM.
Signed-off-by: Andreas Obergschwandtner <andreas.obergschwandtner@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit b30d0289de72c62516df03fdad8d53f552c69839 upstream.
The merge_fdt_bootargs() function by definition consumes more than 1024
bytes of stack because it has a 1024 byte command line on the stack,
meaning that we always get a warning when building this file:
arch/arm/boot/compressed/atags_to_fdt.c: In function 'merge_fdt_bootargs':
arch/arm/boot/compressed/atags_to_fdt.c:98:1: warning: the frame size of 1032 bytes is larger than 1024 bytes [-Wframe-larger-than=]
However, as this is the decompressor and we know that it has a very shallow
call chain, and we do not actually risk overflowing the kernel stack
at runtime here.
This just shuts up the warning by disabling the warning flag for this
file.
Tested on Nexus 7 2012 builds.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Signed-off-by: David Heidelberg <david@ixit.cz>
Cc: <stable@vger.kernel.org>
commit fb033c95c94ca1ee3d16e04ebdb85d65fb55fff8 upstream.
The system currently warns if the config conditions for
building return_address in arch/arm/kernel/return_address.c
are not met, leaving just an EXPORT_SYMBOL_GPL(return_address)
of a function defined to be 'static linline'.
This is a result of aeea3592a13b ("ARM: 8158/1: LLVMLinux: use static inline in ARM ftrace.h").
Since we're not going to build anything other than an exported
symbol for something that is already being defined to be an
inline-able return of NULL, just avoid building the code to
remove the following warning:
Fixes: aeea3592a13b ("ARM: 8158/1: LLVMLinux: use static inline in ARM ftrace.h")
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
[ Upstream commit 20a6b3fd8e2e2c063b25fbf2ee74d86b898e5087 ]
Based on the latest timing specifications for the TPS65218 from the data
sheet, http://www.ti.com/lit/ds/symlink/tps65218.pdf, document SLDS206
from November 2014, we must change the i2c bus speed to better fit within
the minimum high SCL time required for proper i2c transfer.
When running at 400khz, measurements show that SCL spends
0.8125 uS/1.666 uS high/low which violates the requirement for minimum
high period of SCL provided in datasheet Table 7.6 which is 1 uS.
Switching to 100khz gives us 5 uS/5 uS high/low which both fall above
the minimum given values for 100 khz, 4.0 uS/4.7 uS high/low.
Without this patch occasionally a voltage set operation from the kernel
will appear to have worked but the actual voltage reflected on the PMIC
will not have updated, causing problems especially with cpufreq that may
update to a higher OPP without actually raising the voltage on DCDC2,
leading to a hang.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit 9c698bff66ab4914bb3d71da7dc6112519bde23e upstream.
Ensure that the signal page contains our poison instruction to increase
the protection against ROP attacks and also contains well defined
contents.
Acked-by: Will Deacon <will@kernel.org>
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
[ Upstream commit 82a1c67554dff610d6be4e1982c425717b3c6a23 ]
Once the new schema interrupt-controller/arm,vic.yaml is added, we get
the below warnings:
arch/arm/boot/dts/versatile-ab.dt.yaml:
intc@10140000: $nodename:0: 'intc@10140000' does not match
'^interrupt-controller(@[0-9a-f,]+)*$'
intc@10140000: 'clear-mask' does not match any of the regexes
Fix the node names for the interrupt controller to conform
to the standard node name interrupt-controller@.. Also drop invalid
clear-mask property.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Link: https://lore.kernel.org/r/20210701132118.759454-1-sudeep.holla@arm.com'
[ Upstream commit 89b759469d525f4d5f9c29cd3b1f490311c67f85 ]
The name of the struct, as defined in arch/arm/mach-imx/pm-imx5.c,
is imx5_cpu_suspend_info.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit 14cdc1f243d79e0b46be150502b7dba9c5a6bdfd ]
Serial interface uart3 on phyFLEX board is capable of 5-wire connection
including signals RTS and CTS for hardware flow control.
Fix signals UART3_CTS_B and UART3_RTS_B padmux assignments and add
missing property "uart-has-rtscts" to allow serial interface to be
configured and used with the hardware flow control.
Signed-off-by: Primoz Fiser <primoz.fiser@norik.com>
[ Upstream commit 75e2f012f6e34b93124d1d86eaa8f27df48e9ea0 ]
This matches nand-controller.yaml requirements.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 9a800ce1aada6e0f56b78e4713f4858c8990c1f7 ]
[ Upstream commit fd2f1717966535b7d0b6fe45cf0d79e94330da5f ]
There is no "max_brightness" property as pointed out by dtschema:
arch/arm/boot/dts/exynos5422-odroidxu4.dt.yaml: led-controller: led-1: 'max-brightness' is a required property
Fixes: 6658356014cb ("ARM: dts: Add support Odroid XU4 board for exynos5422-odroidxu4")
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
Link: https://lore.kernel.org/r/20210505135941.59898-5-krzysztof.kozlowski@canonical.com
[ Upstream commit 8b95a7d90ce8160ac5cffd5bace6e2eba01a871e ]
There's a few instructions that GAS infers operands but Clang doesn't;
from what I can tell the Arm ARM doesn't say these are optional.
F5.1.257 TBB, TBH T1 Halfword variant
F5.1.238 STREXD T1 variant
F5.1.84 LDREXD T1 variant
Link: https://github.com/ClangBuiltLinux/linux/issues/1309
Reviewed-by: Jian Cai <jiancai@google.com>
commit 253adffb0e98eaf6da2e7cf73ae68695e21f2f3c upstream.
Fix pinctrl muxing, PD28, PD29 and PD31 can be muxed to peripheral A. It
allows to use SCK0, SCK1 and SPI0_NPCS2 signals.
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Fixes: 679f8d92bb01 ("ARM: at91/dt: sama5d4: add pioD pin mux mask and enable pioD")
Cc: stable@vger.kernel.org # v4.4+
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Link: https://lore.kernel.org/r/20191025084210.14726-1-ludovic.desroches@microchip.com
commit f3fbd7ec62dec1528fb8044034e2885f2b257941 upstream.
This is arm port of commit 6a5022a56ac3 ("kprobes/x86: Allow to
handle reentered kprobe on single-stepping")
Since the FIQ handlers can interrupt in the single stepping
(or preparing the single stepping, do_debug etc.), we should
consider a kprobe is hit in the NMI handler. Even in that
case, the kprobe is allowed to be reentered as same as the
kprobes hit in kprobe handlers
(KPROBE_HIT_ACTIVE or KPROBE_HIT_SSDONE).
The real issue will happen when a kprobe hit while another
reentered kprobe is processing (KPROBE_REENTER), because
we already consumed a saved-area for the previous kprobe.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Jon Medhurst <tixy@linaro.org>
Cc: stable@vger.kernel.org #v2.6.25~v4.11
Signed-off-by: huangshaobo <huangshaobo6@huawei.com>
Linux 4.4.274
commit dad7b9896a5dbac5da8275d5a6147c65c81fb5f2 upstream.
When building the kernel wtih gcc-10 or higher using the
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y flag, the compiler picks a slightly
different set of registers for the inline assembly in cpu_init() that
subsequently results in a corrupt kernel stack as well as remaining in
FIQ mode. If a banked register is used for the last argument, the wrong
version of that register gets loaded into CPSR_c. When building in Arm
mode, the arguments are passed as immediate values and the bug cannot
happen.
This got introduced when Daniel reworked the FIQ handling and was
technically always broken, but happened to work with both clang and gcc
before gcc-10 as long as they picked one of the lower registers.
This is probably an indication that still very few people build the
kernel in Thumb2 mode.
Marek pointed out the problem on IRC, Arnd narrowed it down to this
inline assembly and Russell pinpointed the exact bug.
Change the constraints to force the final mode switch to use a non-banked
register for the argument to ensure that the correct constant gets loaded.
Another alternative would be to always use registers for the constant
arguments to avoid the #ifdef that has now become more complex.
Cc: <stable@vger.kernel.org> # v3.18+
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Reported-by: Marek Vasut <marek.vasut@gmail.com>
Fixes: c0e7f7ee717e ("ARM: 8150/3: fiq: Replace default FIQ handler")
[ Upstream commit 040ab72ee10ea88e1883ad143b3e2b77596abc31 ]
GCC reports the following warning with W=1:
arch/arm/mach-omap2/board-n8x0.c:325:19: warning:
variable 'index' set but not used [-Wunused-but-set-variable]
325 | int bit, *openp, index;
Fix this by moving CONFIG_MMC_OMAP to cover the rest codes
in the n8x0_mmc_callback().
Signed-off-by: Yongqiang Liu <liuyongqiang13@huawei.com>
[ Upstream commit 8987efbb17c2522be8615085df9a14da2ab53d34 ]
The Maxim PMIC datasheets describe the interrupt line as active low
with a requirement of acknowledge from the CPU. Without specifying the
interrupt type in Devicetree, kernel might apply some fixed
configuration, not necessarily working for this hardware.
Additionally, the interrupt line is shared so using level sensitive
interrupt is here especially important to avoid races.
Fixes: c61248afa819 ("ARM: dts: Add max77686 RTC interrupt to cros5250-common")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Link: https://lore.kernel.org/r/20201210212534.216197-9-krzk@kernel.org
[ Upstream commit f6368c60561370e4a92fac22982a3bd656172170 ]
Fixes: 47580e8d94c2 ("ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250")
Link: https://lore.kernel.org/r/20201210212534.216197-8-krzk@kernel.org
[ Upstream commit a1ebdb3741993f853865d1bd8f77881916ad53a7 ]
Also some omap3 devices like n900 seem to have eMMC and micro-sd swapped
around with commit 21b2cec61c04 ("mmc: Set PROBE_PREFER_ASYNCHRONOUS for
drivers that existed in v4.4").
Let's fix the issue with aliases as discussed on the mailing lists. While
the mmc aliases should be board specific, let's first fix the issue with
minimal changes.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Peter Ujfalusi <peter.ujfalusi@gmail.com>
commit d2f7eca60b29006285d57c7035539e33300e89e5 upstream.
Since uprobes is not supported for thumb, check that the thumb bit is
not set when matching the uprobes instruction hooks.
The Arm UDF instructions used for uprobes triggering
(UPROBE_SWBP_ARM_INSN and UPROBE_SS_ARM_INSN) coincidentally share the
same encoding as a pair of unallocated 32-bit thumb instructions (not
UDF) when the condition code is 0b1111 (0xf). This in effect makes it
possible to trigger the uprobes functionality from thumb, and at that
using two unallocated instructions which are not permanently undefined.
Signed-off-by: Fredrik Strupe <fredrik@strupe.net>
Fixes: c7edc9e326d5 ("ARM: add uprobes support")
[ Upstream commit 844b85dda2f569943e1e018fdd63b6f7d1d6f08e ]
clang warns about an impossible condition when building with 32-bit
phys_addr_t:
arch/arm/mach-keystone/keystone.c:79:16: error: result of comparison of constant 51539607551 with expression of type 'phys_addr_t' (aka 'unsigned int') is always false [-Werror,-Wtautological-constant-out-of-range-compare]
mem_end > KEYSTONE_HIGH_PHYS_END) {
arch/arm/mach-keystone/keystone.c:78:16: error: result of comparison of constant 34359738368 with expression of type 'phys_addr_t' (aka 'unsigned int') is always true [-Werror,-Wtautological-constant-out-of-range-compare]
if (mem_start < KEYSTONE_HIGH_PHYS_START ||
Change the temporary variable to a fixed-size u64 to avoid the warning.
Reviewed-by: Nathan Chancellor <nathan@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Link: https://lore.kernel.org/r/20210323131814.2751750-1-arnd@kernel.org'
[ Upstream commit 77335a040178a0456d4eabc8bf17a7ca3ee4a327 ]
Fix moving mmc devices with dts aliases as discussed on the lists.
Without this we now have internal eMMC mmc1 show up as mmc2 compared
to the earlier order of devices.
Commit 262b003d059c6671601a19057e9fe1a5e7f23722 upstream.
When registering a memslot, we check the size and location of that
memslot against the IPA size to ensure that we can provide guest
access to the whole of the memory.
Unfortunately, this check rejects memslot that end-up at the exact
limit of the addressing capability for a given IPA size. For example,
it refuses the creation of a 2GB memslot at 0x8000000 with a 32bit
IPA space.
Fix it by relaxing the check to accept a memslot reaching the
limit of the IPA space.
Fixes: c3058d5da222 ("arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE")
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Signed-off-by: Marc Zyngier <maz@kernel.org>
Cc: stable@vger.kernel.org # 4.4, 4.9
Reviewed-by: Andrew Jones <drjones@redhat.com>
Link: https://lore.kernel.org/r/20210311100016.3830038-3-maz@kernel.org
commit 8310b77b48c5558c140e7a57a702e7819e62f04e upstream.
Bailing immediately from set_foreign_p2m_mapping() upon a p2m updating
error leaves the full batch in an ambiguous state as far as the caller
is concerned. Instead flags respective slots as bad, unmapping what
was mapped there right away.
HYPERVISOR_grant_table_op()'s return value and the individual unmap
slots' status fields get used only for a one-time - there's not much we
can do in case of a failure.
Note that there's no GNTST_enomem or alike, so GNTST_general_error gets
used.
The map ops' handle fields get overwritten just to be on the safe side.
This is part of XSA-367.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Link: https://lore.kernel.org/r/96cccf5d-e756-5f53-b91a-ea269bfb9be0@suse.com
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit 2acb909750431030b65a0a2a17fd8afcbd813a84 ]
It was observed that decompressor running on hardware implementing ARM v8.2
Load/Store Multiple Atomicity and Ordering Control (LSMAOC), say, as guest,
would stuck just after:
Uncompressing Linux... done, booting the kernel.
The reason is that it clears nTLSMD bit when disabling caches:
nTLSMD, bit [3]
When ARMv8.2-LSMAOC is implemented:
No Trap Load Multiple and Store Multiple to
Device-nGRE/Device-nGnRE/Device-nGnRnE memory.
0b0 All memory accesses by A32 and T32 Load Multiple and Store
Multiple at EL1 or EL0 that are marked at stage 1 as
Device-nGRE/Device-nGnRE/Device-nGnRnE memory are trapped and
generate a stage 1 Alignment fault.
0b1 All memory accesses by A32 and T32 Load Multiple and Store
Device-nGRE/Device-nGnRE/Device-nGnRnE memory are not trapped.
This bit is permitted to be cached in a TLB.
This field resets to 1.
Otherwise:
Reserved, RES1
So as effect we start getting traps we are not quite ready for.
Looking into history it seems that mask used for SCTLR clear came from
the similar code for ARMv4, where bit[3] is the enable/disable bit for
the write buffer. That not applicable to ARMv7 and onwards, so retire
that bit from the masks.
Fixes: 7d09e85448dfa78e3e58186c934449aaf6d49b50 ("[ARM] 4393/2: ARMv7: Add uncompressing code for the new CPU Id format")
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
[ Upstream commit 1ac8893c4fa3d4a34915dc5cdab568a39db5086c ]
The Samsung PMIC datasheets describe the interrupt line as active low
with a requirement of acknowledge from the CPU. The falling edge
interrupt will mostly work but it's not correct.
Fixes: 1fed2252713e ("ARM: dts: fix pinctrl for s2mps11-irq on exynos5420-arndale-octa")
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Link: https://lore.kernel.org/r/20201210212903.216728-5-krzk@kernel.org
[ Upstream commit 77e6a5467cb8657cf8b5e610a30a4c502085e4f9 ]
Fixes: 53dd4138bb0a ("ARM: dts: Add exynos5250-spring device tree")
Link: https://lore.kernel.org/r/20201210212903.216728-4-krzk@kernel.org
commit 36bf1dfb8b266e089afa9b7b984217f17027bf35 upstream.
set_phys_to_machine can fail due to lack of memory, see the kzalloc call
in arch/arm/xen/p2m.c:__set_phys_to_machine_multi.
Don't ignore the potential return error in set_foreign_p2m_mapping,
returning it to the caller instead.
This is part of XSA-361.
Signed-off-by: Stefano Stabellini <stefano.stabellini@xilinx.com>
Reviewed-by: Julien Grall <jgrall@amazon.com>
commit 39d3454c3513840eb123b3913fda6903e45ce671 upstream.
Building with gcc 4.9.2 reveals a latent bug in the PCI accessors
for Footbridge platforms, which causes a fatal alignment fault
while accessing IO memory. Fix this by making the assembly volatile.
commit a88afa46b86ff461c89cc33fc3a45267fff053e8 upstream.
When the kernel is configured to use the Thumb-2 instruction set
"suspend-to-memory" fails to resume. Observed on a Colibri iMX6ULL
(i.MX 6ULL) and Apalis iMX6 (i.MX 6Q).
It looks like the CPU resumes unconditionally in ARM instruction mode
and then chokes on the presented Thumb-2 code it should execute.
Fix this by using the arm instruction set for all code in
suspend-imx6.S.
Fixes: df595746fa69 ("ARM: imx: add suspend in ocram support for i.mx6q")
Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
[ Upstream commit bac717171971176b78c72d15a8b6961764ab197f ]
dtc points out that the interrupts for some devices are not parsable:
picoxcell-pc3x2.dtsi:45.19-49.5: Warning (interrupts_property): /paxi/gem@30000: Missing interrupt-parent
picoxcell-pc3x2.dtsi:51.21-55.5: Warning (interrupts_property): /paxi/dmac@40000: Missing interrupt-parent
picoxcell-pc3x2.dtsi:57.21-61.5: Warning (interrupts_property): /paxi/dmac@50000: Missing interrupt-parent
picoxcell-pc3x2.dtsi:233.21-237.5: Warning (interrupts_property): /rwid-axi/axi2pico@c0000000: Missing interrupt-parent
There are two VIC instances, so it's not clear which one needs to be
used. I found the BSP sources that reference VIC0, so use that:
https://github.com/r1mikey/meta-picoxcell/blob/master/recipes-kernel/linux/linux-picochip-3.0/0001-picoxcell-support-for-Picochip-picoXcell-SoC.patch
Acked-by: Jamie Iles <jamie@jamieiles.com>
Link: https://lore.kernel.org/r/20201230152010.3914962-1-arnd@kernel.org'
[ Upstream commit e1062fa7292f1e3744db0a487c4ac0109e09b03d ]
The pincontrol node is needed for USB Host since Linux v5.7-rc1. Without
it the driver probes but VBus is not powered because of wrong pincontrol
configuration.
Fixes: b7c2b61570798 ("ARM: at91: add Atmel's SAMA5D3 Xplained board")
Signed-off-by: Cristian Birsan <cristian.birsan@microchip.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Link: https://lore.kernel.org/r/20201118120019.1257580-4-cristian.birsan@microchip.com
[ Upstream commit be4dd2d448816a27c1446f8f37fce375daf64148 ]
configuration.
Fixes: 38153a017896f ("ARM: at91/dt: sama5d4: add dts for sama5d4 xplained board")
Link: https://lore.kernel.org/r/20201118120019.1257580-3-cristian.birsan@microchip.com
[ Upstream commit 4e79f0211b473f8e1eab8211a9fd50cc41a3a061 ]
When running in BE mode on LPAE hardware with a PA-to-VA translation
that exceeds 4 GB, we patch bits 39:32 of the offset into the wrong
byte of the opcode. So fix that, by rotating the offset in r0 to the
right by 8 bits, which will put the 8-bit immediate in bits 31:24.
Note that this will also move bit #22 in its correct place when
applying the rotation to the constant #0x400000.
Fixes: d9a790df8e984 ("ARM: 7883/1: fix mov to mvn conversion in case of 64 bit phys_addr_t and BE")
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
[ Upstream commit 33d0d843872c5ddbe28457a92fc6f2487315fb9f ]
The SPI chip selects are represented as:
cs-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>, <&gpio4 13 GPIO_ACTIVE_LOW>;
, which means that they are used in GPIO function instead of native
SPI mode.
Fix the IOMUX for the chip select 1 to use GPIO4_13 instead of
the native CSPI_SSI function.
Fixes: c605cbf5e135 ("ARM: dts: imx: add device tree support for Freescale imx50evk board")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit 7dd8f0ba88fce98e2953267a66af74c6f4792a56 ]
Commit bcf3440c6dd7 ("net: phy: micrel: add phy-mode support for the
KSZ9031 PHY") fixed micrel phy driver adding proper support for phy
modes. Adapt imx6q-udoo board phy settings : explicitly set required
delay configuration using "rgmii-id".
Fixes: cbd54fe0b2bc ("ARM: dts: imx6dl-udoo: Add board support based off imx6q-udoo")
Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com>
[ Upstream commit dea252fa41cd8ce332d148444e4799235a8a03ec ]
When running dtbs_check thermal_zone warn about the
temperature declared.
thermal-zones: cpu-thermal:trips:cpu-alert0:temperature:0:0: 850000 is greater than the maximum of 200000
It's indeed wrong the real value is 85°C and not 850°C.
Signed-off-by: Clément Péron <peron.clem@gmail.com>
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
Link: https://lore.kernel.org/r/20201003100332.431178-1-peron.clem@gmail.com
commit f6d7cde84f6c5551586c8b9b68d70f8e6dc9a000 upstream.
Commit f6361c6b3880 ("ARM: S3C24XX: remove separate restart code")
removed usage of the watchdog reset platform code in favor of the
Samsung SoC watchdog driver. However the latter was not selected thus
S3C24xx platforms lost reset abilities.
Fixes: f6361c6b3880 ("ARM: S3C24XX: remove separate restart code")
commit 7be0d19c751b02db778ca95e3274d5ea7f31891c upstream.
Selecting CONFIG_SAMSUNG_PM_DEBUG (depending on CONFIG_DEBUG_LL) but
without CONFIG_MMU leads to build errors:
arch/arm/plat-samsung/pm-debug.c: In function ‘s3c_pm_uart_base’:
arch/arm/plat-samsung/pm-debug.c:57:2: error:
implicit declaration of function ‘debug_ll_addr’ [-Werror=implicit-function-declaration]
Fixes: 99b2fc2b8b40 ("ARM: SAMSUNG: Use debug_ll_addr() to get UART base address")
Link: https://lore.kernel.org/r/20200910154150.3318-1-krzk@kernel.org
[ Upstream commit 6c17a2974abf68a58517f75741b15c4aba42b4b8 ]
The 'audio-subsystem' node is an artificial creation, not representing
real hardware. The hardware is described by its nodes - AUDSS clock
controller and I2S0.
Remove the 'audio-subsystem' node along with its undocumented compatible
to fix dtbs_check warnings like:
audio-subsystem: $nodename:0: 'audio-subsystem' does not match '^([a-z][a-z0-9\\-]+-bus|bus|soc|axi|ahb|apb)(@[0-9a-f]+)?$'
Tested-by: Jonathan Bakker <xc-racer2@live.ca>
Link: https://lore.kernel.org/r/20200907161141.31034-9-krzk@kernel.org
