path: root/arch/arm
2008-09-13[ARM] Fix PCI_DMA_BUS_IS_PHYS for ARMRussell King
PCI_DMA_BUS_IS_PHYS was defined to be zero, which meant we ignored the DMA mask for IDE and SCSI transfers. This is wrong - we have no DMA translation hardware. We want to obey DMA masks so that the block layer performs bouncing itself. Reported-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-13Merge branch 'for-rmk' of ↵Russell King
git://pasiphae.extern.pengutronix.de/git/imx/linux-2.6.git
2008-09-13[ARM] 5247/1: tosa: SW_EAR_IN supportDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-13[ARM] 5246/1: tosa: add proper clock alias for tc6393xb clockDmitry Baryshkov
Add clock alias for clock that is used by tc6393xb device on tosa. As that chip plays pretty major part in tosa life and is currently disabled, this is 2.4.27 material. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-11[ARM] OMAP: Fix MMC device dataRussell King
OMAPs MMC device data was passing the wrong structure via the platform device. Moreover, a missing function means that both sx1_defconfig and omap_h2_1610_defconfig builds failed with undefined reference to `omap_set_mmc_info' errors. Fix this by updating the MMC support from the omapzoom tree. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-08Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5241/1: provide ioremap_wc() [ARM] omap: fix virtual vs physical address space confusions [ARM] remove unused #include <version.h> [ARM] omap: fix build error in ohci-omap.c [ARM] omap: fix gpio.c build error
2008-09-06[ARM] 5241/1: provide ioremap_wc()Lennert Buytenhek
This patch provides an ARM implementation of ioremap_wc(). We use different page table attributes depending on which CPU we are running on: - Non-XScale ARMv5 and earlier systems: The ARMv5 ARM documents four possible mapping types (CB=00/01/10/11). We can't use any of the cached memory types (CB=10/11), since that breaks coherency with peripheral devices. Both CB=00 and CB=01 are suitable for _wc, and CB=01 (Uncached/Buffered) allows the hardware more freedom than CB=00, so we'll use that. (The ARMv5 ARM seems to suggest that CB=01 is allowed to delay stores but isn't allowed to merge them, but there is no other mapping type we can use that allows the hardware to delay and merge stores, so we'll go with CB=01.) - XScale v1/v2 (ARMv5): same as the ARMv5 case above, with the slight difference that on these platforms, CB=01 actually _does_ allow merging stores. (If you want noncoalescing bufferable behavior on Xscale v1/v2, you need to use XCB=101.) - Xscale v3 (ARMv5) and ARMv6+: on these systems, we use TEXCB=00100 mappings (Inner/Outer Uncacheable in xsc3 parlance, Uncached Normal in ARMv6 parlance). The ARMv6 ARM explicitly says that any accesses to Normal memory can be merged, which makes Normal memory more suitable for _wc mappings than Device or Strongly Ordered memory, as the latter two mapping types are guaranteed to maintain transaction number, size and order. We use the Uncached variety of Normal mappings for the same reason that we can't use C=1 mappings on ARMv5. The xsc3 Architecture Specification documents TEXCB=00100 as being Uncacheable and allowing coalescing of writes, which is also just what we need. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-05Revert "[ARM] use the new byteorder headers"David Woodhouse
This reverts commit ae82cbfc8beaa69007aa09966d3983ac938c3577. It needs the new byteorder headers to be exported to userspace, and they aren't yet -- and probably shouldn't be, at this point in the 2.6.27 release cycle (or ever, for that matter). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-04[ARM] omap: fix virtual vs physical address space confusionsRussell King
mcbsp is confused as to what takes a physical or virtual address. Fix the two instances where it gets it wrong. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-04[ARM] remove unused #include <version.h>Huang Weiyi
The driver(s) below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. arch/arm/plat-mxc/clock.c This patch removes the said #include <version.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-03[ARM] omap: fix gpio.c build errorRussell King
arch/arm/plat-omap/gpio.c: In function '_omap_gpio_init': arch/arm/plat-omap/gpio.c:1492: error: 'omap_mpuio_device' undeclared (first use in this function) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-02pcm037: add rts/cts support for serial portSascha Hauer
We have rts/cts pins on the first serial port on the pcm037. Enable it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-28[ARM] 5226/1: remove unmatched comment end.Jean-Christophe DUBOIS
remove unmatched comment end. Signed-off-by: Jean-Christophe DUBOIS <jcd@tribudubois.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27Merge branch 'omap-rmk'Russell King
2008-08-27[ARM] Skip memory holes in FLATMEM when reading /proc/pagetypeinfoMel Gorman
Ordinarily, memory holes in flatmem still have a valid memmap and is safe to use. However, an architecture (ARM) frees up the memmap backing memory holes on the assumption it is never used. /proc/pagetypeinfo reads the whole range of pages in a zone believing that the memmap is valid and that pfn_valid will return false if it is not. On ARM, freeing the memmap breaks the page->zone linkages even though pfn_valid() returns true and the kernel can oops shortly afterwards due to accessing a bogus struct zone *. This patch lets architectures say when FLATMEM can have holes in the memmap. Rather than an expensive check for valid memory, /proc/pagetypeinfo will confirm that the page linkages are still valid by checking page->zone is still the expected zone. The lookup of page_zone is safe as there is a limited range of memory that is accessed when calling page_zone. Even if page_zone happens to return the correct zone, the impact is that the counters in /proc/pagetypeinfo are slightly off but fragmentation monitoring is unlikely to be relevant on an embedded system. Reported-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27[ARM] use bcd2bin/bin2bcdAdrian Bunk
This patch changes arm to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27[ARM] use the new byteorder headersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
2008-08-27[ARM] OMAP: Fix 2430 SMC91x ethernet IRQRussell King
Taken from omap 97b705ad835f1481270c4b67b402d6e37fa8ad15: ARM: OMAP: Misc compile fixes after syncing with mainline Also fix 2430 smc91x to use IRQ_LOWLEVEL. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-27[ARM] OMAP: Add and update OMAP default configuration filesRussell King
Update omap_h2_1610 and omap_osk_5912 default configurations. Add ams delta, n770, omap 2430sdp, apollon_2420, generic 1510, 1610, 1710, 2420, h4 2420, innovator 1510 and 1610, perseus2 730, palte, palmtt, palmz71 and sx1 default configurations. Pulled out of the omap zoom tree. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-26Merge branch 's3c2410' of git://aeryn.fluff.org.uk/bjdooks/linux.gitRussell King
2008-08-26[ARM] S3C2443: Fix the S3C2443 clock register definitionsWei Shuai
Fix the S3C2443 clock register definitions for selecting the EPLL reference clock described by S3C2443_CLKSRC_EPLLREF. Signed-off-by: Wei Shuai <cpuwolf@gmail.com> [ben-linux@fluff.org: minor description fixes] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] JIVE: Fix the spi bus numberingBen Dooks
The first spi bus is registered with number 0, but the board data says that the device on it is registered on bus 1. Move the spi bus to bus 1 to keep the compatibility with the original board-support patches. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] S3C24XX: pwm.c: stop debugging outputBen Dooks
Move debugging output to dev_dbg() instead of dev_info(). Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] S3C24XX: Fix sparse warnings in pwm.cBen Dooks
Fix the following sparse warnings in arch/arm/plat-s3c24xx/pwm.c: warning: symbol 's3c_device_timer' was not declared. Should it be static? warning: symbol 'pwm_calc_tin' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] S3C24XX: Fix spare errors in pwm-clock driverBen Dooks
Fix the following sparse warnings in arch/arm/plat-s3c24xx/pwm-clock.c: warning: symbol 'clk_timer_scaler' was not declared. Should it be static? warning: symbol 'clk_timer_tclk' was not declared. Should it be static? warning: symbol 'clk_timer_tdiv' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] S3C24XX: Fix sparse warnings in arch/arm/plat-s3c24xx/gpiolib.cBen Dooks
Fix the following problems spotted by sparse: warning: symbol 's3c24xx_gpiolib_input' was not declared. Should it be static? warning: symbol 's3c24xx_gpiolib_output' was not declared. Should it be static? warning: symbol 's3c24xx_gpiolib_set' was not declared. Should it be static? warning: symbol 's3c24xx_gpiolib_get' was not declared. Should it be static? warning: symbol 'gpios' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] S3C24XX: Fix nor-simtec driver sparse errorsBen Dooks
Fix the following sparse errors in arch/arm/mach-s3c2410/nor-simtec.c: 53:27: warning: symbol 'simtec_nor_pdata' was not declared. Should it be static? 77:13: warning: symbol 'nor_simtec_init' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-26[ARM] 5225/1: zaurus: Register I2C controller for audio codecsMark Brown
corgi, spitz and poodle have audio codecs on their primary I2C bus so need to call pxa_set_i2c_info() to set it up during init. Tested on spitz by Stanislav. Reported-by: Stanislav Brabec <utx@penguin.cz> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-22[ARM] orion5x: update defconfig to v2.6.27-rc4Nicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-08-21[ARM] Orion: register UART1 on QNAP TS-209 and TS-409Martin Michlmayr
Register UART1 on QNAP TS-209 and TS-409 because the PIC controller is connected to it. This fixes a regression from 2.6.26. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-21[ARM] Orion: activate lm75 driver on DNS-323Martin Michlmayr
The lm75 driver was recently converted to the new-style binding, so now it can be loaded from the DNS-323 support code. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Tested-by: Tobias Poschwatta <tp@fonz.de> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-21[ARM] Orion: fix MAC detection on QNAP TS-209 and TS-409Martin Michlmayr
Flash needs to be set up before we can try to read the MAC address from there. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-21[ARM] Orion: Fix boot crash on Kurobox ProPer Andersson
The Kurobox Pro crashes when any of the PCI controller registers are accessed. This patch adds a function to the Orion PCI handling code that board support code can call to disable enumerating the PCI bus entirely, and makes the Kurobox Pro PCI-related init code call this function. Signed-off-by: Per Andersson <avtobiff@gmail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-20[ARM] 5212/1: pxa: fix build error when CPU_PXA310 is not definedMike Rapoport
Fix arch/arm/mach-pxa/pxa300.c:94: error: 'CKEN_MMC3' undeclared here (not in a function) when building for PXA300. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-19[ARM] 5208/1: fsg-setup.c fixesTomasz Chmielewski
This patch against 2.6.27-rc3 does the following changes to FSG-3 setup code: 1) Enable RTC on FSG-3 (proper name is needed). This change is needed due to a recent change in i2c. 2) i variable is only used when compiling for big endian. So move its declaration to ARMEB ifdef to silence the warning when compiling for LE. Mailing list link: http://lists.arm.linux.org.uk/lurker/message/20080813.091556.cae2917e.en.html Signed-off-by: Tomasz Chmielewski <mangoo@wpkg.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-18Merge branch 'for_rmk_17' of git://git.mnementh.co.uk/linux-2.6-imRussell King
2008-08-18[ARM] fix impd1.c build warningRussell King
CC arch/arm/mach-integrator/impd1.o arch/arm/mach-integrator/impd1.c: In function `impd1_probe': arch/arm/mach-integrator/impd1.c:408: warning: too few arguments for format Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (38 commits) [ARM] 5191/1: ARM: remove CVS keywords [ARM] pxafb: fix the warning of incorrect lccr when lcd_conn is specified [ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16 [ARM] pxafb: fix the incorrect configuration of GPIO77 as ACBIAS for TFT LCD [ARM] 5198/1: PalmTX: PCMCIA fixes [ARM] Fix a pile of broken watchdog drivers [ARM] update mach-types [ARM] 5196/1: fix inline asm constraints for preload [ARM] 5194/1: update .gitignore [ARM] add proc-macros.S include to proc-arm940 and proc-arm946 [ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to {possible,always}_tlb_flags [ARM] 5193/1: Wire up missing syscalls [ARM] traps: don't call undef hook functions with spinlock held [ARM] 5183/2: Provide Poodle LoCoMo GPIO names [ARM] dma-mapping: provide sync_range APIs [ARM] dma-mapping: improve type-safeness of DMA translations [ARM] Kirkwood: instantiate the orion_spi driver in the platform code [ARM] prevent crashing when too much RAM installed [ARM] Kirkwood: Instantiate mv_xor driver [ARM] Orion: Instantiate mv_xor driver for 5182 ...
2008-08-16[ARM] 5191/1: ARM: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16[ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16Eric Miao
Another fix of inconsistent shift of the LCD_BIAS_ACTIVE_* and LCD_PCLK_EDGE_* is also included. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16[ARM] update mach-typesRussell King
2008-08-16[ARM] 5196/1: fix inline asm constraints for preloadNicolas Pitre
With gcc 4.3 and later, a pointer that has already been dereferenced is assumed not to be null since it should have caused a segmentation fault otherwise, hence any subsequent test against NULL is optimized away. Current inline asm constraint used in the implementation of prefetch() makes gcc believe that the pointer is dereferenced even though the PLD instruction does not load any data and does not cause a segmentation fault on null pointers, which causes all sorts of interesting results when reaching the end of a linked lists for example. Let's use a better constraint to properly represent the actual usage of the pointer value. Problem reported by Chris Steel. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-15kexec jump: rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZEHuang Ying
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control page is used for not only code on some platform. For example in kexec jump, it is used for data and stack too. [akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion] Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-13usb: musb: pass configuration specifics via pdataFelipe Balbi
Use platform_data to pass musb configuration-specific details to musb driver. This patch will prevent that other platforms selecting HAVE_CLK and enabling musb won't break tree building. The other parts of it will come when linux-omap merge up more omap2/3 board-files. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-12[ARM] 5194/1: update .gitignoreNicolas Pitre
2008-08-12[ARM] add proc-macros.S include to proc-arm940 and proc-arm946Russell King
... otherwise these fail to build. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to ↵Paul Walmsley
{possible,always}_tlb_flags Commit 2ccdd1e77da52ad494e9af46bf272d816830cb28 doesn't add v7wbi_possible_flags and v7wbi_always_flags to possible_tlb_flags and always_tlb_flags. This causes the L2 cache flush in clean_pmd_entry() (intended for Feroceon only) to execute on ARMv7, and the CPU hangs. This patch is required for OMAP3 boards to boot. Signed-off-by: Paul Walmsley <paul@pwsan.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] 5193/1: Wire up missing syscallsStefan Schmidt
Setup some missing syscall pointed out by the checksyscalls.sh script. Fix two small whitespace issues while being there. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
