commit 58010fa6f71c9577922b22e46014b95a4ec80fa0 upstream.
The AES key schedule generation is mostly endian agnostic, with the
exception of the rotation and the incorporation of the round constant
at the start of each round. So implement a big endian specific version
of that part to make the whole routine big endian compatible.
Fixes: 86464859cc77 ("crypto: arm - AES in ECB/CBC/CTR/XTS modes using ARMv8 Crypto Extensions")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 0cff18cbab4f55581d9da86e4286655d9723d7d2 upstream.
The 2 USB host ports are directly tied to the 2 USB hosts in the SoC.
The 2 host pairs were already enabled, but the USB PHY wasn't.
VBUS on the 2 ports are always on.
Enable the USB PHY.
Fixes: 04c85ecad32a ("ARM: dts: sun7i: Add dts file for Bananapi M1 Plus
board")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit dc8ee9dbdba509fb58e23ba79f2e6059fe5d8b3b upstream.
The parent clock of the HSUSB clock is the HP clock, not the MP clock.
Fixes: c7bab9f929e51761 ("ARM: shmobile: r8a7794: Add USB clocks to device tree")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit ef37427ac5677331145ab27a17e6f5f1b43f0c11 upstream.
Similarly to the aemif clock - this screws up the linked list of clock
children. Create a separate clock for mdio inheriting the rate from
emac_clk.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
[nsekhar@ti.com: add a comment over mdio_clk to explaing its existence +
commit headline updates]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit 24d5373dda7c00a438d26016bce140299fae675e upstream.
The function xen_guest_init is using __alloc_percpu with an alignment
which are not power of two.
However, the percpu allocator never supported alignments which are not power
of two and has always behaved incorectly in thise case.
Commit 3ca45a4 "percpu: ensure requested alignment is power of two"
introduced a check which trigger a warning [1] when booting linux-next
on Xen. But in reality this bug was always present.
This can be fixed by replacing the call to __alloc_percpu with
alloc_percpu. The latter will use an alignment which are a power of two.
[1]
[ 0.023921] illegal size (48) or align (48) for percpu allocation
[ 0.024167] ------------[ cut here ]------------
[ 0.024344] WARNING: CPU: 0 PID: 1 at linux/mm/percpu.c:892 pcpu_alloc+0x88/0x6c0
[ 0.024584] Modules linked in:
[ 0.024708]
[ 0.024804] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
4.9.0-rc7-next-20161128 #473
[ 0.025012] Hardware name: Foundation-v8A (DT)
[ 0.025162] task: ffff80003d870000 task.stack: ffff80003d844000
[ 0.025351] PC is at pcpu_alloc+0x88/0x6c0
[ 0.025490] LR is at pcpu_alloc+0x88/0x6c0
[ 0.025624] pc : [<ffff00000818e678>] lr : [<ffff00000818e678>]
pstate: 60000045
[ 0.025830] sp : ffff80003d847cd0
[ 0.025946] x29: ffff80003d847cd0 x28: 0000000000000000
[ 0.026147] x27: 0000000000000000 x26: 0000000000000000
[ 0.026348] x25: 0000000000000000 x24: 0000000000000000
[ 0.026549] x23: 0000000000000000 x22: 00000000024000c0
[ 0.026752] x21: ffff000008e97000 x20: 0000000000000000
[ 0.026953] x19: 0000000000000030 x18: 0000000000000010
[ 0.027155] x17: 0000000000000a3f x16: 00000000deadbeef
[ 0.027357] x15: 0000000000000006 x14: ffff000088f79c3f
[ 0.027573] x13: ffff000008f79c4d x12: 0000000000000041
[ 0.027782] x11: 0000000000000006 x10: 0000000000000042
[ 0.027995] x9 : ffff80003d847a40 x8 : 6f697461636f6c6c
[ 0.028208] x7 : 6120757063726570 x6 : ffff000008f79c84
[ 0.028419] x5 : 0000000000000005 x4 : 0000000000000000
[ 0.028628] x3 : 0000000000000000 x2 : 000000000000017f
[ 0.028840] x1 : ffff80003d870000 x0 : 0000000000000035
[ 0.029056]
[ 0.029152] ---[ end trace 0000000000000000 ]---
[ 0.029297] Call trace:
[ 0.029403] Exception stack(0xffff80003d847b00 to
0xffff80003d847c30)
[ 0.029621] 7b00: 0000000000000030 0001000000000000
ffff80003d847cd0 ffff00000818e678
[ 0.029901] 7b20: 0000000000000002 0000000000000004
ffff000008f7c060 0000000000000035
[ 0.030153] 7b40: ffff000008f79000 ffff000008c4cd88
ffff80003d847bf0 ffff000008101778
[ 0.030402] 7b60: 0000000000000030 0000000000000000
ffff000008e97000 00000000024000c0
[ 0.030647] 7b80: 0000000000000000 0000000000000000
[ 0.030895] 7ba0: 0000000000000035 ffff80003d870000
000000000000017f 0000000000000000
[ 0.031144] 7bc0: 0000000000000000 0000000000000005
ffff000008f79c84 6120757063726570
[ 0.031394] 7be0: 6f697461636f6c6c ffff80003d847a40
0000000000000042 0000000000000006
[ 0.031643] 7c00: 0000000000000041 ffff000008f79c4d
ffff000088f79c3f 0000000000000006
[ 0.031877] 7c20: 00000000deadbeef 0000000000000a3f
[ 0.032051] [<ffff00000818e678>] pcpu_alloc+0x88/0x6c0
[ 0.032229] [<ffff00000818ece8>] __alloc_percpu+0x18/0x20
[ 0.032409] [<ffff000008d9606c>] xen_guest_init+0x174/0x2f4
[ 0.032591] [<ffff0000080830f8>] do_one_initcall+0x38/0x130
[ 0.032783] [<ffff000008d90c34>] kernel_init_freeable+0xe0/0x248
[ 0.032995] [<ffff00000899a890>] kernel_init+0x10/0x100
[ 0.033172] [<ffff000008082ec0>] ret_from_fork+0x10/0x50
Reported-by: Wei Chen <wei.chen@arm.com>
Link: https://lkml.org/lkml/2016/11/28/669
Signed-off-by: Julien Grall <julien.grall@arm.com>
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Pull ARM SoC fixes from Olof Johansson:
"Final batch of SoC fixes
A few fixes that have trickled in over the last week, all fixing minor
errors in devicetrees -- UART pin assignment on Allwinner H3,
correcting number of SATA ports on a Marvell-based Linkstation
platform and a display clock fix for Freescale/NXP i.MX7D that fixes a
freeze when starting up X"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: orion5x: fix number of sata port for linkstation ls-gl
ARM: dts: imx7d: fix LCDIF clock assignment
dts: sun8i-h3: correct UART3 pin definitions
Bug report from Debian [0] shows there's minor changed model of
Linkstation LS-GL that uses the 2nd SATA port of the SoC.
So it's necessary to enable two SATA ports, though for that specific
model only the 2nd one is used.
[0] https://bugs.debian.org/845611
Fixes: b1742ffa9ddb ("ARM: dts: orion5x: add device tree for buffalo linkstation ls-gl")
Reported-by: Ryan Tandy <ryan@nardis.ca>
Tested-by: Ryan Tandy <ryan@nardis.ca>
Signed-off-by: Roger Shimizu <rogershimizu@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The eLCDIF IP of the i.MX 7 SoC knows multiple clocks and lists them
separately:
Clock Clock Root Description
apb_clk MAIN_AXI_CLK_ROOT AXI clock
pix_clk LCDIF_PIXEL_CLK_ROOT Pixel clock
ipg_clk_s MAIN_AXI_CLK_ROOT Peripheral access clock
All of them are switched by a single gate, which is part of the
IMX7D_LCDIF_PIXEL_ROOT_CLK clock. Hence using that clock also for
the AXI bus clock (clock-name "axi") makes sure the gate gets
enabled when accessing registers.
There seem to be no separate AXI display clock, and the clock is
optional. Hence remove the dummy clock.
This fixes kernel freezes when starting the X-Server (which
disables/re-enables the display controller).
Fixes: e8ed73f691bd ("ARM: dts: imx7d: add lcdif support")
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
In a previous commit, I made a copy/paste error in the pinmux
definitions of UART3: PG{13,14} instead of PA{13,14}. This commit takes
care of that. I have tested this commit on Orange Pi PC and Orange Pi
Plus, and it works for these boards.
Fixes: e3d11d3c45c5 ("dts: sun8i-h3: add pinmux definitions for
UART2-3")
Signed-off-by: Jorik Jonker <jorik@kippendief.biz>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Pull ARM SoC fixes from Arnd Bergmann:
"This should be the last set of bugfixes for arm-soc in v4.9. None of
these are critical regressions, but it would be nice to still get them
merged.
- On the Juno platform, the idle latency was described wrong, leading
to suboptimal cpuidle tuning.
- Also on the same platform, PCI I/O space was set up incorrectly and
could not work.
- On the sti platform, a syntactically incorrect DT entry caused
warnings.
- The newly added 'gr8' platform has somewhat confusing file names,
which we rename for consistency"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dts: juno: fix cluster sleep state entry latency on all SoC versions
arm64: dts: juno: Correct PCI IO window
ARM: dts: STiH407-family: fix i2c nodes
ARM: gr8: Rename the DTSI and relevant DTS
Pull ARM fix from Russell King:
"This resolves the ksyms issues by reverting the commit which
introduced the breakage"
There was what I consider to be a better fix, but it's late in the rc
game, so I'll take the revert.
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
Revert "arm: move exports to definitions"
git://git.kernel.org/pub/scm/linux/kernel/git/pchotard/sti into fixes
Pull "STi DT fix" from Patrice Chotard:
The I2C nodes are missing #address-cells and #size-cells.
This is causing warning at device tree compilation when
some I2C device sub-nodes are defined.
* tag 'sti-dt-for-v4.9-rc-round2' of git://git.kernel.org/pub/scm/linux/kernel/git/pchotard/sti:
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes
Pull "Allwinner fixes for 4.9, second iteration" from Maxime Ripard:
A renaming of the GR8 DTSI and DTS to make it explicitly part of the sun5i
family.
* tag 'sunxi-fixes-for-4.9-2' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
This reverts commit 4dd1837d7589f468ed109556513f476e7a7f9121.
Moving the exports for assembly code into the assembly files breaks
KSYM trimming, but also breaks modversions.
While fixing the KSYM trimming is trivial, fixing modversions brings
us to a technically worse position that we had prior to the above
change:
- We end up with the prototype definitions divorsed from everything
else, which means that adding or removing assembly level ksyms
become more fragile:
* if adding a new assembly ksyms export, a missed prototype in
asm-prototypes.h results in a successful build if no module in
the selected configuration makes use of the symbol.
* when removing a ksyms export, asm-prototypes.h will get forgotten,
with armksyms.c, you'll get a build error if you forget to touch
the file.
- We end up with the same amount of include files and prototypes,
they're just in a header file instead of a .c file with their
exports.
As for lines of code, we don't get much of a size reduction:
(original commit)
47 files changed, 131 insertions(+), 208 deletions(-)
(fix for ksyms trimming)
7 files changed, 18 insertions(+), 5 deletions(-)
(two fixes for modversions)
1 file changed, 34 insertions(+)
3 files changed, 7 insertions(+), 2 deletions(-)
which results in a net total of only 25 lines deleted.
As there does not seem to be much benefit from this change of approach,
revert the change.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
The I2C nodes are missing #address-cells and #size-cells. This is
causing warning at device tree compilation when some I2C device
Signed-off-by: Loic Pallardy <loic.pallardy@st.com>
Reviews have found that sun5i was a better prefix after all for the GR8.
Rename the relevant device trees before it's too late.
Pull ARM fixes from Russell King:
"A few more ARM fixes:
- the assembly backtrace code suffers problems with the new printk()
implementation which assumes that kernel messages without KERN_CONT
should have newlines inserted between them. Fix this.
- fix a section naming error - ".init.text" rather than ".text.init"
- preallocate DMA debug memory at core_initcall() time rather than
fs_initcall(), as we have some core drivers that need to use DMA
mapping - and that triggers a kernel warning from the DMA debug
code.
- fix XIP kernels after the ro_after_init changes made this data
permanently read-only"
ARM: Fix XIP kernels
ARM: 8628/1: dma-mapping: preallocate DMA-debug hash tables in core_initcall
ARM: 8624/1: proc-v7m.S: fix init section name
ARM: fix backtrace
A fix to reintroduce missing pinmux options that turned out not to be
optional.
* tag 'sunxi-fixes-for-4.9' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
ARM: dts: sun8i: fix the pinmux for UART1
STi DT fix:
Fix typo cs-gpio to cs-gpios
* tag 'sti-dt-for-v4.9-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/pchotard/sti:
ARM: dts: STiH410-b2260: Fix typo in spi0 chipselect definition
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes
i.MX fixes for 4.9, 2nd round:
It fixes a boot failure on imx53-qsb board with a DA9053 PMIC, which is
caused by the regulator core change, commit fa93fd4ecc9c ("regulator:
core: Ensure we are at least in bounds for our constraints").
* tag 'imx-fixes-4.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
ARM: dts: imx53-qsb: Fix regulator constraints
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Fixes for omaps for v4.9-rc cycle. Except for the omap3 fix for the SoC
features printed, all these are quite trivial and tiny. The omap5 jack
detection and gpadc patches are not strictly fixes, but I wanted to get
binding document typo fixed before it pops up on other boards. The
gpadc one liner was in the same series and I applied and pushed it out
already before noticing it could have waited. The list of changes is:
- Fix omap3 SoC features printed
- Make sure OMAP_INTERCONNECT is selected for am43xx only configurations
- Add missing memory node for torpedo
- Initialize uart4_mask properly to avoid writing garbage to PRM registers
- Fix NULL pointer dereference for omap4 volt_data
- Add alias for omap5 gpadc needed by iio drivers
- Enable omap5 jack headset jack detection and fix it's binding typo
- Add missing memory node for logicpd-som-lv
- Fix wrong SMPS6 voltage for VDD-DDR3 for omap5
* tag 'omap-for-v4.9/fixes-for-rc-cycle' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: omap5: board-common: fix wrong SMPS6 (VDD-DDR3) voltage
ARM: omap3: Add missing memory node in SOM-LV
ASoC: omap-abe-twl6040: fix typo in bindings documentation
dts: omap5: board-common: enable twl6040 headset jack detection
dts: omap5: board-common: add phandle to reference Palmas gpadc
ARM: OMAP2+: avoid NULL pointer dereference
ARM: OMAP2+: PRM: initialize en_uart4_mask and grpsel_uart4_mask
ARM: dts: omap3: Fix memory node in Torpedo board
ARM: AM43XX: Select OMAP_INTERCONNECT in Kconfig
ARM: OMAP3: Fix formatting of features printed
Commit 7619751f8c90 ("ARM: 8595/2: apply more __ro_after_init") caused
a regression with XIP kernels by moving the __ro_after_init data into
the read-only section. With XIP kernels, the read-only section is
located in read-only memory from the very beginning.
Work around this by moving the __ro_after_init data back into the .data
section, which will be in RAM, and hence will be writable.
It should be noted that in doing so, this remains writable after init.
Fixes: 7619751f8c90 ("ARM: 8595/2: apply more __ro_after_init")
Reported-by: Andrea Merello <andrea.merello@gmail.com>
Tested-by: Andrea Merello <andrea.merello@gmail.com> [ XIP stm32 ]
Tested-by: Alexandre Torgue <alexandre.torgue@st.com>
fs_initcall is definitely too late to initialize DMA-debug hash tables,
because some drivers might get probed and use DMA mapping framework
already in core_initcall. Late initialization of DMA-debug results in
false warning about accessing memory, that was not allocated, like this
one:
WARNING: CPU: 5 PID: 1 at lib/dma-debug.c:1104 check_unmap+0xa1c/0xe50
exynos-sysmmu 10a60000.sysmmu: DMA-API: device driver tries to free DMA memory it has not allocated [device
address=0x000000006ebd0000] [size=16384 bytes]
Modules linked in:
CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.9.0-rc5-00028-g39dde3d-dirty #44
Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[<c0119dd4>] (unwind_backtrace) from [<c01122bc>] (show_stack+0x20/0x24)
[<c01122bc>] (show_stack) from [<c062714c>] (dump_stack+0x84/0xa0)
[<c062714c>] (dump_stack) from [<c0132560>] (__warn+0x14c/0x180)
[<c0132560>] (__warn) from [<c01325dc>] (warn_slowpath_fmt+0x48/0x50)
[<c01325dc>] (warn_slowpath_fmt) from [<c06814f8>] (check_unmap+0xa1c/0xe50)
[<c06814f8>] (check_unmap) from [<c06819c4>] (debug_dma_unmap_page+0x98/0xc8)
[<c06819c4>] (debug_dma_unmap_page) from [<c076c3e8>] (exynos_iommu_domain_free+0x158/0x380)
[<c076c3e8>] (exynos_iommu_domain_free) from [<c0764a30>] (iommu_domain_free+0x34/0x60)
[<c0764a30>] (iommu_domain_free) from [<c011f168>] (release_iommu_mapping+0x30/0xb8)
[<c011f168>] (release_iommu_mapping) from [<c011f23c>] (arm_iommu_release_mapping+0x4c/0x50)
[<c011f23c>] (arm_iommu_release_mapping) from [<c0b061ac>] (s5p_mfc_probe+0x640/0x80c)
[<c0b061ac>] (s5p_mfc_probe) from [<c07e6750>] (platform_drv_probe+0x70/0x148)
[<c07e6750>] (platform_drv_probe) from [<c07e25c0>] (driver_probe_device+0x12c/0x6b0)
[<c07e25c0>] (driver_probe_device) from [<c07e2c6c>] (__driver_attach+0x128/0x17c)
[<c07e2c6c>] (__driver_attach) from [<c07df74c>] (bus_for_each_dev+0x88/0xc8)
[<c07df74c>] (bus_for_each_dev) from [<c07e1b6c>] (driver_attach+0x34/0x58)
[<c07e1b6c>] (driver_attach) from [<c07e1350>] (bus_add_driver+0x18c/0x32c)
[<c07e1350>] (bus_add_driver) from [<c07e4198>] (driver_register+0x98/0x148)
[<c07e4198>] (driver_register) from [<c07e5cb0>] (__platform_driver_register+0x58/0x74)
[<c07e5cb0>] (__platform_driver_register) from [<c174cb30>] (s5p_mfc_driver_init+0x1c/0x20)
[<c174cb30>] (s5p_mfc_driver_init) from [<c0102690>] (do_one_initcall+0x64/0x258)
[<c0102690>] (do_one_initcall) from [<c17014c0>] (kernel_init_freeable+0x3d0/0x4d0)
[<c17014c0>] (kernel_init_freeable) from [<c116eeb4>] (kernel_init+0x18/0x134)
[<c116eeb4>] (kernel_init) from [<c010bbd8>] (ret_from_fork+0x14/0x3c)
---[ end trace dc54c54bd3581296 ]---
This patch moves initialization of DMA-debug to core_initcall. This is
safe from the initialization perspective. dma_debug_do_init() internally calls
debugfs functions and debugfs also gets initialised at core_initcall(), and
that is earlier than arch code in the link order, so it will get initialized
just before the DMA-debug.
Reported-by: Seung-Woo Kim <sw0312.kim@samsung.com>
There is no .text.init sections.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Recent kernels have changed their behaviour to be more inconsistent
when handling printk continuations. With todays kernels, the output
looks sane on the console, but dmesg splits individual printk()s which
do not have the KERN_CONT prefix into separate lines.
Since the assembly code is not trivial to add the KERN_CONT, and we
ideally want to avoid using KERN_CONT (as multiple printk()s can race
between different threads), convert the assembly dumping the register
values to C code, and have the C code build the output a line at a
time before dumping to the console.
This avoids the KERN_CONT issue, and also avoids situations where the
output is intermixed with other console activity.
Change cs-gpio to cs-gpios.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
DDR3L is usually specified as
JEDEC standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V)
Therefore setting smps6 regulator to 1.2V is definitively below
minimum. It appears that real world chips are more forgiving than
data sheets indicate, but let's set the regulator right.
Note: a board that uses other voltages (DDR with 1.5V) can
overwrite by referencing &smps6_reg.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/ARM updates for v4.9-rc4
- Kick the vcpu when a pending interrupt becomes pending again
- Prevent access to invalid interrupt registers
- Invalid TLBs when two vcpus from the same VM share a CPU
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
commit ("766a1fe78fc3 ARM: omap3: Add missing memory node") had
fixes for Torpedo and Overo boards, but this SOM-LV was missed.
This should help prevent the DTC warning:
"Node /memory has a reg or ranges property, but no unit name"
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Will be needed for iio based drivers.
For OMAP4, volt_data is set in omap44xx_voltagedomains_init.
If the SoC is neither OMAP443X or OMAP446X, we end up with a
NULL in volt_data which causes a kernel oops.
This is the case when booting OMAP4470.
Signed-off-by: Nicolae Rosia <Nicolae_Rosia@mentor.com>
In the case where has_uart4 is false, en_uart4_mask and grpsel_uart4_mask
are not initialized and so any garbage value is being logically or'd into
the write of PM_WKEN and OMAP3430_PM_MPUGRPSEL. Fix this by initializing
these masks to zero.
Commit ("766a1fe78fc3 ARM: omap3: Add missing memory node") added
the memory node, but the patch didn't have the correct starting address.
This patch fixes the correct starting address.
AM437x makes use of the omap_l3_noc driver so explicitly select
OMAP_INTERCONNECT in the Kconfig for SOC_AM43XX to ensure it gets enabled
for AM43XX only builds.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
With the printk cleanups merged into v4.9-rc1, we now get the omap
revision printed on multiple lines. Let's fix that and also remove the
extra empty space at the end of the features. And let's update things
to use scnprintf as suggested by Ivaylo Dimitrov
<ivo.g.dimitrov.75@gmail.com>.
Reported-by: Adam Ford <aford173@gmail.com>
Cc: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com>
Reviewed-by: Sebastian Reichel <sre@kernel.org>
Since commit fa93fd4ecc9c ("regulator: core: Ensure we are at least in
bounds for our constraints") the imx53-qsb board populated with a Dialog
DA9053 PMIC fails to boot:
LDO3: Bringing 3300000uV into 1800000-1800000uV
The LDO3 voltage constraints passed in the device tree do not match
the valid range according to the datasheet, so fix this accordingly to
allow the board booting again.
While at it, fix the other voltage constraints as well.
Cc: <stable@vger.kernel.org> # 4.7.x
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
single CPU
Architecturally, TLBs are private to the (physical) CPU they're
associated with. But when multiple vcpus from the same VM are
being multiplexed on the same CPU, the TLBs are not private
to the vcpus (and are actually shared across the VMID).
Let's consider the following scenario:
- vcpu-0 maps PA to VA
- vcpu-1 maps PA' to VA
If run on the same physical CPU, vcpu-1 can hit TLB entries generated
by vcpu-0 accesses, and access the wrong physical page.
The solution to this is to keep a per-VM map of which vcpu ran last
on each given physical CPU, and invalidate local TLBs when switching
to a different vcpu from the same VM.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
"A fix for a regression on ARMv4T CPUs, and wiring up the new pkey
syscalls for ARM"
ARM: wire up new pkey syscalls
ARM: fix oops when using older ARMv4T CPUs
"We haven't seen a whole lot of fixes for the first two weeks since the
merge window, but here is the batch that we have at the moment.
Nothing sticks out as particularly bad or scary, it's mostly a handful
of smaller fixes to several platforms. The Uniphier reset controller
changes could probably have been delayed to 4.10, but they're not
scary and just plumbing up driver changes that went in during the
merge window.
We're also adding another maintainer to Marvell Berlin platforms, to
help out when Sebastian is too busy. Yay teamwork!"
ARM: imx: mach-imx6q: Fix the PHY ID mask for AR8031
ARM: dts: vf610: fix IRQ flag of global timer
ARM: imx: gpc: Fix the imx_gpc_genpd_init() error path
ARM: imx: gpc: Initialize all power domains
arm64: dts: Updated NAND DT properties for NS2 SVK
arm64: dts: uniphier: change MIO node to SD control node
ARM: dts: uniphier: change MIO node to SD control node
reset: uniphier: rename MIO reset to SD reset for Pro5, PXs2, LD20 SoCs
arm64: uniphier: select ARCH_HAS_RESET_CONTROLLER
ARM: uniphier: select ARCH_HAS_RESET_CONTROLLER
arm64: dts: Add timer erratum property for LS2080A and LS1043A
arm64: dts: rockchip: remove the abuse of keep-power-in-suspend
ARM: multi_v7_defconfig: Enable Intel e1000e driver
MAINTAINERS: add myself as Marvell berlin SoC maintainer
bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TEST
ARM: dts: fix the SD card on the Snowball
arm64: dts: rockchip: remove always-on and boot-on from vcc_sd
arm64: dts: marvell: fix clocksource for CP110 master SPI0
ARM: mvebu: Select corediv clk for all mvebu v7 SoC
The i.MX fixes for 4.9:
- A couple of patches from Fabio to fix the GPC power domain regression
which is caused by PM Domain core change 0159ec670763dd
("PM / Domains: Verify the PM domain is present when adding a
provider"), and a related kernel crash seen with multi_v7_defconfig
build.
- Correct the PHY ID mask for AR8031 to match phy driver code.
- Apply new added timer erratum A008585 for LS1043A and LS2080A SoC.
- Correct vf610 global timer IRQ flag to avoid warning from gic driver
after commit 992345a58e0c ("irqchip/gic: WARN if setting the
interrupt type for a PPI fails").
* tag 'imx-fixes-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier into fixes
UniPhier ARM SoC fixes for v4.9
- Add "select ARCH_HAS_RESET_CONTROLLER" in Kconfig
- Rename wrongly-named mioctrl to sdctrl
* tag 'uniphier-fixes-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier:
When the patch is applied, the allwinner,driver and allwinner,pull
properties are removed.
Although they're described to be optional in the devicetree binding,
without them, the pinmux cannot be initialized, and the uart cannot
be used.
Add them back to fix the problem, and makes the bluetooth on iNet D978
Rev2 board work.
Fixes: 82eec384249f (ARM: dts: sun8i: add pinmux for UART1 at PG)
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
AR8031 and AR8035 have the same PHY ID mask of 0xffffffef.
So fix it and make it match with the PHY ID mask definition
at drivers/net/phy/at803x.c.
The global timer IRQ (PPI[0], PPI 11 in device tree terms) is a
rising edge interrupt. The ARM Cortex-A5 MPCore TRM in Chapter
10.1.2. Interrupt types and sources says:
"Interrupt is rising-edge sensitive."
The bits seem to be read-only, hence this missconfiguration had
no negative effect. However, with commit 992345a58e0c
("irqchip/gic: WARN if setting the interrupt type for a PPI fails")
warnings such as this get printed:
GIC: PPI11 is secure or misconfigured
With this change the new configuration matches the default
configuration and no warning is printed anymore.
If of_genpd_add_provider_onecell() fails the following kernel crash is
observed on a kernel built with multi_v7_defconfig:
[ 1.739301] [00000040] *pgd=00000000
[ 1.739310] Internal error: Oops: 5 [#1] SMP ARM
[ 1.739319] Modules linked in:
[ 1.739328] CPU: 1 PID: 95 Comm: kworker/1:4 Not tainted 4.8.0-11897-g6b5e09a #1
[ 1.739331] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 1.739352] Workqueue: pm genpd_power_off_work_fn
[ 1.739356] task: ee63d400 task.stack: ee70a000
[ 1.739365] PC is at mutex_lock+0xc/0x4c
[ 1.739374] LR is at regulator_disable+0x2c/0x60
[ 1.739379] pc : [<c0bc0da0>] lr : [<c06e4b10>] psr: 60000013
[ 1.739379] sp : ee70beb0 ip : 10624dd3 fp : ee6e6280
[ 1.739382] r10: eefb0900 r9 : 00000000 r8 : c1309918
[ 1.739385] r7 : 00000000 r6 : 00000040 r5 : 00000000 r4 : 00000040
[ 1.739390] r3 : 0000004c r2 : 7fffd540 r1 : 000001e4 r0 : 00000040
Instead of returning of_genpd_add_provider_onecell() directly,
we should check its return value and in the case of error we
should unwind the previously taken actions, which in these case are:
- Call imx6q_pm_pu_power_off()
- Set imx6q_pu_domain.reg back to NULL
Setting imx6q_pu_domain.reg to NULL in the error case is important
as it will prevent further operations in the pu_reg regulator.
This kernel crash is not observed with imx_v6_v7_defconfig because
it selects GPU and VPU drivers, which are consumers of the GPC block
and thus change the refcount of the pu_reg regulator.
Since commit 0159ec670763dd ("PM / Domains: Verify the PM domain is present
when adding a provider") the following regression is observed on imx6:
imx-gpc: probe of 20dc000.gpc failed with error -22
The gpc probe fails because of_genpd_add_provider_onecell() now checks
if all the domains are initialized via pm_genpd_present() function
and it fails because not all the power domains are initialized.
In order to fix this error, initialize all the power domains from
imx_gpc_domains[], not only the imx6q_pu_domain.base one.
Reported-by: Olof's autobooter <build@lixom.net>
I made a mistake bacuse the Media I/O block is not implemented in
these SoCs.
The UniPhier reset driver (drivers/reset/reset-uniphier.c) has been
merged. Select ARCH_HAS_RESET_CONTROLLER from the SoC Kconfig.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
When used with a compiler that doesn't implement "asm goto"
(such as the AArch64 port of GCC 4.8), jump labels generate a
memory access to find out about the value of the key (instead
of just patching the code). The key itself is likely to be
stored in the BSS.
This is perfectly fine, except that we don't map the BSS at HYP,
leading to an exploding kernel at the first access. The obvious
fix is simply to map the BSS there (which should have been done
a long while ago, but hey...).
Reported-by: Eric Auger <eric.auger@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
