commit 9dcc87fec8947308e0111c65dcd881e6aa5b1673 upstream.
sam9x5 SoCs have the following errata:
"RTC: Interrupt Mask Register cannot be used
Interrupt Mask Register read always returns 0."
Hence we should not rely on what IMR claims about already masked IRQs
and just disable all IRQs.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Reported-by: Bryan Evenson <bevenson@melinkcorp.com>
Reviewed-by: Johan Hovold <johan@hovold.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Bryan Evenson <bevenson@melinkcorp.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Mark Roszko <mark.roszko@gmail.com>
commit 483a6c9d447f625b991fa04a1530493d893984db upstream.
According to the ARM ARM, the behaviour is UNPREDICTABLE if the PC read
from the exception return stack is not half word aligned. See the
pseudo code for ExceptionReturn() and PopStack().
The signal handler's address has the bit 0 set, and setup_return()
directly writes this to regs->ARM_pc. Current hardware happens to
discard this bit, but QEMU's emulation doesn't and this makes processes
crash. Mask out bit 0 before the exception return in order to get
predictable behaviour.
Fixes: 19c4d593f0b4 ("ARM: ARMv7-M: Add support for exception handling")
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit 537094b64b229bf3ad146042f83e74cf6abe59df upstream.
According to arm procedure call standart r2 register is call-cloberred.
So after the result of x expression was put into r2 any following
function call in p may overwrite r2. To fix this, the result of p
expression must be saved to the temporary variable before the
assigment x expression to __r2.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
all OMAP3 platforms
commit 98d7e1aee6dd534f468993f8c6a1bc730d4cfa81 upstream.
Commit 7b2e1277598e4187c9be3e61fd9b0f0423f97986 ("ARM: OMAP3: clock:
Back-propagate rate change from cam_mclk to dpll4_m5") enabled clock
rate back-propagation from cam_mclk do dpll4_m5 on OMAP3630 only.
Perform back-propagation on other OMAP3 platforms as well.
Reported-by: Jean-Philippe François <jp.francois@cynove.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit 0f9e19ad88eee820f517b85531b555a0fa73e7e4 upstream.
McPDM need to be configured to NO_IDLE mode when it is in used otherwise
vital clocks will be gated which results 'slow motion' audio playback.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit d1d70e5dc2cfa9047bb935c41ba808ebb8135696 upstream.
If we fail to allocate struct platform_device pdev we
dereference it after the goto label err.
This bug was found using coccinelle.
Fixes: afa77ef (ARM: mx3: dynamically allocate "ipu-core" devices)
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
commit 5f5092e72cc25a6a5785308270e0085b2b2772cc upstream.
Since we indirect all of our PMU IRQ handling through a dispatcher, it's
trivial to hook up perf_sample_event_took to prevent applications such
as oprofile from generating interrupt storms due to an unrealisticly
low sample period.
Reported-by: Robert Richter <rric@kernel.org>
commit 8fad87bca7ac9737e413ba5f1656f1114a8c314d upstream.
When we configure CONFIG_ARM_LPAE=y, pfn << PAGE_SHIFT will
overflow if pfn >= 0x100000 in copy_oldmem_page.
So use __pfn_to_phys for converting.
Signed-off-by: Liu Hua <sdu.liu@huawei.com>
commit bfaed5abad998bfc88a66e6e71c7b08dcf82f04e upstream.
The current .dts for ste-ccu8540 lacks a 'device_type = "memory"' for
its memory node, relying on an old ppc quirk in order to discover its
memory. Fix the data so that all parsing code can handle it correctly.
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Cc: devicetree@vger.kernel.org
Cc: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit 6e20bae8a39c40d4e03698e4160bad2d2629062b upstream.
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus
width declared in the Device Tree being considered as a 16 bits bus
width when configuring the hardware.
This bug in mvebu-devbus driver was compensated by a symetric mistake
in the Armada XP OpenBlocks AX3 Device Tree: a 8 bits bus width was
declared, even though the hardware actually has a 16 bits bus width
connection with the NOR flash.
Now that we have fixed the mvebu-devbus driver to behave according to
its Device Tree binding, this commit fixes the problematic Device Tree
files as well.
This bug was introduced in commit
a7d4f81821f7eec3175f8e23dd6949c71ab2da43 ('ARM: mvebu: Add support for
NOR flash device on Openblocks AX3 board') which was merged in v3.10.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1397489361-5833-5-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: a7d4f81821f7 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board')
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit f3aec8f3f05025e7b450102dae0759375346706e upstream.
in the Armada XP DB Device Tree: a 8 bits bus width was declared, even
though the hardware actually has a 16 bits bus width connection with
the NOR flash.
files as well.
b484ff42df475c5087d614c4d477273e1906bcb9 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-DB board') which was merged in v3.11.
Link: https://lkml.kernel.org/r/1397489361-5833-4-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: b484ff42df47 ('ARM: mvebu: Add support for NOR flash device on Armada XP-DB board')
commit 1a88f809ccb5db1509a7514b187c00b3a995fc82 upstream.
in the Armada XP GP Device Tree: a 8 bits bus width was declared, even
the NOR flash.
files as well.
da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-GP board') which was merged in v3.10.
Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board')
commit 6d66da89bf4422c0a0693627fb3e25f74af50f92 upstream.
The IPU register space is 128MB, not 2GB.
Fixes: abed9a6bf2bb 'ARM i.MX53: Add IPU support'
Acked-by: Shawn Guo <shawn.guo@freescale.com>
commit 788296b2d19d16ec33aba0a5ad1544d50bb58601 upstream.
Commit 54397d85349f
("ARM: kirkwood: Relocate PCIe device tree nodes")
moved the pcie-controller nodes for the Kirkwood SoCs to the mbus
bus node. For some reason, two boards were not properly converted
and have their pci-controller nodes still in the ocp bus node.
As the corresponding SoC pcie-controller does not exist anymore,
it is likely that pcie is broken on those boards since above commit.
Fix it by moving the pcie related nodes to the correct location.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Fixes: 54397d85349f ("ARM: kirkwood: Relocate PCIe device tree nodes")
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-2-git-send-email-sebastian.hesselbarth@gmail.com
commit 1cc9d48145b81e307fab94a5cf6ee66ec2f0de60 upstream.
In commit 4ca2c04085a1caa903e92a5fc0da25362150aac2 ('ARM: orion5x:
Move to ID based window creation'), the mach-orion5x code was changed
to use the new mvebu-mbus API. However, in the process, a mistake was
made on the crypto SRAM window target ID: it should have been 0x9
(verified in the datasheet) and not 0x0.
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Link: https://lkml.kernel.org/r/1397400006-4315-2-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: 4ca2c04085a1 ('ARM: orion5x: Move to ID based window creation')
commit 5d4e08c45a6cf8f1ab3c7fa375007635ac569165 upstream.
The kvm/mmu code shared by arm and arm64 uses kalloc() to allocate
a bounce page (if hypervisor init code crosses page boundary) and
hypervisor PGDs. The problem is that kalloc() does not guarantee
the proper alignment. In the case of the bounce page, the page sized
buffer allocated may also cross a page boundary negating the purpose
and leading to a hang during kvm initialization. Likewise the PGDs
allocated may not meet the minimum alignment requirements of the
underlying MMU. This patch uses __get_free_page() to guarantee the
worst case alignment needs of the bounce page and PGDs on both arm
and arm64.
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit a2f8d6b303213a98436455aece7e14cdd1240629 upstream.
In "ARM: dts: am33xx: correcting dt node unit address for usb", the
usb_ctrl_mod and cppi41dma nodes were updated with the correct register
addresses. However, the dts files that reference these nodes were not
updated, and those devices are no longer being enabled.
This patch corrects the references for the affected dts files.
Signed-off-by: Leigh Brown <leigh@solinno.co.uk>
Cc: Johan Hovold <jhovold@gmail.com>
commit a6e03dd451c724f785277d8ecca5d1a0b886d892 upstream.
The mvmdio driver accesses some register of the Ethernet unit. It
therefore takes a reference and enables a clock. However, on Armada
370/XP, no clock specification was given in the Device Tree, which
leads the mvmdio driver to fail when being used as a module and loaded
before the mvneta driver: it tries to access a register from a
hardware unit that isn't clocked.
Link: https://lkml.kernel.org/r/1395790439-21332-2-git-send-email-thomas.petazzoni@free-electrons.com
commit 56b700fd6f1e49149880fb1b6ffee0dca5be45fb upstream.
For vmcore generated by LPAE enabled kernel, user space
utility such as crash needs additional infomation to
parse.
So this patch add arch_crash_save_vmcoreinfo as what PAE enabled
i386 linux does.
Reviewed-by: Will Deacon <will.deacon@arm.com>
commit 80bb3ef109ff40a7593d9481c17de9bbc4d7c0e2 upstream.
In big-endian systems, "%1" get the most significant part of the value, cause the instruction to get the wrong result.
When viewing ftrace record in big-endian ARM systems, we found that
the timestamp errors:
swapper-0 [001] 1325.970000: 0:120:R ==> [001] 16:120:R events/1
events/1-16 [001] 1325.970000: 16:120:S ==> [001] 0:120:R swapper
swapper-0 [000] 1325.1000000: 0:120:R + [000] 15:120:R events/0
swapper-0 [000] 1325.1000000: 0:120:R ==> [000] 15:120:R events/0
swapper-0 [000] 1326.030000: 0:120:R + [000] 1150:120:R sshd
swapper-0 [000] 1326.030000: 0:120:R ==> [000] 1150:120:R sshd
When viewed ftrace records, it will call the do_div(n, base) function, which achieved arch/arm/include/asm/div64.h in. When n = 10000000, base = 1000000, in do_div(n, base) will execute "umull %Q0, %R0, %1, %Q2".
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Alex Wu <wuquanming@huawei.com>
Signed-off-by: Xiangyu Lu <luxiangyu@huawei.com>
commit 95c52fe063351192e0f4ffb70ef9bac1aa26f5a4 upstream.
The kcmp system call was ported to ARM in
commit 3f7d1fe108dbaefd0c57a41753fc2c90b395f458
"ARM: 7665/1: Wire up kcmp syscall".
Fixes: 3f7d1fe108db ("ARM: 7665/1: Wire up kcmp syscall")
Signed-off-by: Christopher Covington <cov@codeaurora.org>
commit 12567bbdee7ea553237085a2bbc0ffa5240f5248 upstream.
CPU_ARM926T should be selected if no other CPU is. Put the ! in the
right place so this works.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Fixes: 24e860fbfdb1c ("ARM: multiplatform: always pick one CPU type")
commit b6ccb9803e90c16b212cf4ed62913a7591e79a39 upstream.
CPU_32v6 currently selects CPU_USE_DOMAINS if CPU_V6 and MMU. This is
because ARM 1136 r0pX CPUs lack the v6k extensions, and therefore do
not have hardware thread registers. The lack of these registers requires
the kernel to update the vectors page at each context switch in order to
write a new TLS pointer. This write must be done via the userspace
mapping, since aliasing caches can lead to expensive flushing when using
kmap. Finally, this requires the vectors page to be mapped r/w for
kernel and r/o for user, which has implications for things like put_user
which must trigger CoW appropriately when targetting user pages.
The upshot of all this is that a v6/v7 kernel makes use of domains to
segregate kernel and user memory accesses. This has the nasty
side-effect of making device mappings executable, which has been
observed to cause subtle bugs on recent cores (e.g. Cortex-A15
performing a speculative instruction fetch from the GIC and acking an
interrupt in the process).
This patch solves this problem by removing the remaining domain support
from ARMv6. A new memory type is added specifically for the vectors page
which allows that page (and only that page) to be mapped as user r/o,
kernel r/w. All other user r/o pages are mapped also as kernel r/o.
Patch co-developed with Russell King.
commit bfeda827278f09f4db35877e5f1ca9c149ca2890 upstream.
Apparently, if G3D regulator is powered off, the SoC cannot enter low
power modes and just hangs. This patch fixes this by keeping the
regulator always on when the system is running, as suggested by Exynos 4
User's Manual in case of Exynos4210/4x12 SoCs (Exynos5250 UM does not
have such note, but observed behavior seems to confirm that it is true
for this SoC as well).
This fixes an issue preventing Arndale board from entering sleep mode
observed since commit
346f372f7b72a0 clk: exynos5250: Add CLK_IGNORE_UNUSED flag for pmu clock
that landed in kernel 3.10, which has fixed the clock driver to make the
SoC actually try to enter the sleep mode.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Tested-by: Tushar Behera <tushar.behera@linaro.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit 8abcdd680d543fb582371e146e62ba9f2af8a816 upstream.
DT node's unit address should be its own register offset address to make it a
unique across the system. This patch corrects the incorrect USB entries with
correct register offset for unit address.
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
commit c6c56697ae4bf1226263c19e8353343d7083f40e upstream.
OMAP3 doesn't contain "l3_init_clkdm" clock domain. Use the
proper clock domains for USB Host and USB TLL modules.
Gets rid of the following warnings during boot
omap_hwmod: usb_host_hs: could not associate to clkdm l3_init_clkdm
omap_hwmod: usb_tll_hs: could not associate to clkdm l3_init_clkdm
Reported-by: Nishanth Menon <nm@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Fixes: de231388cb80a8ef3e779bbfa0564ba0157b7377 ("ARM: OMAP: USB: EHCI and OHCI hwmod structures for OMAP3")
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Cc: Partha Basak <parthab@india.ti.com>
commit 07484ca33ef83900f5cfbde075c1a19e5a237aa1 upstream.
Just like IS_PM34XX_ERRATUM, IS_PM44XX_ERRATUM is valid only if
CONFIG_PM is enabled, else, disabling CONFIG_PM results in build
failure complaining about the following:
arch/arm/mach-omap2/built-in.o: In function `omap4_boot_secondary':
:(.text+0x8a70): undefined reference to `pm44xx_errata'
Fixes: c962184 (ARM: OMAP4: PM: add errata support)
Reported-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.ocm>
Acked-by: Kevin Hilman <khilman@linaro.org>
commit 698b48532539484b012fb7c4176b959d32a17d00 upstream.
When an interrupt has become active on the INTC it will stay active
until it is acked, even if masked or de-asserted. The
INTC_PENDING_IRQn registers are however updated and since these are
used by omap_intc_handle_irq to determine which interrupt to handle,
it will never see the active interrupt. This will result in a storm of
useless interrupts that is only stopped when another higher priority
interrupt is asserted.
Fix by sending the INTC an acknowledge if we find no interrupts to
handle.
Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com>
commit 3159f372354e8e1f5dee714663d705dd2c7e0759 upstream.
With LPAE enabled, physical address space is larger than 4GB. Allow mapping any
part of it via /dev/mem by using PHYS_MASK to determine valid range.
PHYS_MASK covers 40 bits with LPAE enabled and 32 bits otherwise.
Reported-by: Vassili Karpov <av1474@comtv.ru>
Signed-off-by: Sergey Dyasly <dserrg@gmail.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 8859685785bfafadf9bc922dd3a2278e59886947 upstream.
Fix tegra_init_cache() to check whether the system has a PL310 cache
before touching the PL310 registers. This prevents access to non-existent
registers on Tegra114 and later.
Note for stable kernels:
In <= v3.12, the file to patch is arch/arm/mach-tegra/common.c.
commit 571b14375019c3a66ef70d4d4a7083f4238aca30 upstream.
If the kernel is loaded higher in physical memory than normal, and we
calculate PHYS_OFFSET higher than the start of RAM, this leads to
boot problems as we attempt to map part of this RAM into userspace.
Rather than struggle with this, just truncate the mapping.
commit 6d7d5da7d75c6df676c8b72d32b02ff024438f0c upstream.
Use CONFIG_ARCH_PHYS_ADDR_T_64BIT to determine
if ignoring or truncating of memory banks is
neccessary. This may be needed in the case of
64-bit memory bank addresses but when phys_addr_t
is kept 32-bit.
Signed-off-by: Magnus Damm <damm@opensource.se>
commit 4d9c5b89cf3605bbc39c6e274351ff25f0d83e6a upstream.
The stage-2 memory attributes are distinct from the Hyp memory
attributes and the Stage-1 memory attributes. We were using the stage-1
memory attributes for stage-2 mappings causing device mappings to be
mapped as normal memory. Add the S2 equivalent defines for memory
attributes and fix the comments explaining the defines while at it.
Add a prot_pte_s2 field to the mem_type struct and fill out the field
for device mappings accordingly.
Cc: <stable@vger.kernel.org> [3.12]
commit 052450fdc55894a39fbae93d9bbe43947956f663 upstream.
Due to a problem in the MFD Kconfig it was not possible to
compile the UCB battery driver for the Collie SA1100 system,
in turn making it impossible to compile in the battery driver.
(See patch "mfd: include all drivers in subsystem menu".)
After fixing the MFD Kconfig (separate patch) a compile error
appears in the Collie battery driver due to the <mach/collie.h>
implicitly requiring <mach/hardware.h> through <linux/gpio.h>
via <mach/gpio.h> prior to commit
40ca061b "ARM: 7841/1: sa1100: remove complex GPIO interface".
Fix this up by including the required header into
<mach/collie.h>.
Cc: Andrea Adami <andrea.adami@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
is built as module
commit 980386d2d6d49e0b42f48550853ef1ad6aa5d79a upstream.
Fixes: commit 75d3625e0e86b2d8d77b4e9c6f685fd7ea0d5a96
ARM: OMAP2+: gpmc: add DT bindings for OneNAND
OMAP SoC(s) depend on GPMC controller driver to parse GPMC DT child nodes and
register them platform_device for ONENAND driver to probe later. However this does
not happen if generic MTD_ONENAND framework is built as module (CONFIG_MTD_ONENAND=m).
Therefore, when MTD/ONENAND and MTD/ONENAND/OMAP2 modules are loaded, they are unable
to find any matching platform_device and remain un-binded. This causes on board
ONENAND flash to remain un-detected.
This patch causes GPMC controller to parse DT nodes when
CONFIG_MTD_ONENAND=y || CONFIG_MTD_ONENAND=m
Signed-off-by: Pekon Gupta <pekon@ti.com>
built as module
commit 6b187b21c92b6e2c7e8ef0b450181c37a3f31681 upstream.
Fixes: commit bc6b1e7b86f5d8e4a6fc1c0189e64bba4077efe0
ARM: OMAP: gpmc: add DT bindings for GPMC timings and NAND
register them platform_device for NAND driver to probe later. However this does
not happen if generic MTD_NAND framework is built as module (CONFIG_MTD_NAND=m).
Therefore, when MTD/NAND and MTD/NAND/OMAP2 modules are loaded, they are unable
CONFIG_MTD_NAND=y || CONFIG_MTD_NAND=m
commit 39544ac9df20f73e49fc6b9ac19ff533388c82c0 upstream.
Add DSB after icache flush to complete the cache maintenance operation.
Signed-off-by: Vinayak Kale <vkale@apm.com>
commit 7c8746a9eb287642deaad0e7c2cdf482dce5e4be upstream.
When unlocking a spinlock, we require the following, strictly ordered
sequence of events:
<barrier> /* dmb */
<unlock>
<barrier> /* dsb */
<sev>
Whilst the code does indeed reflect this in terms of the architecture,
the final <barrier> + <sev> have been contracted into a single inline
asm without a "memory" clobber, therefore the compiler is at liberty to
reorder the unlock to the end of the above sequence. In such a case,
a waiting CPU may be woken up before the lock has been unlocked, leading
to extremely poor performance.
This patch reworks the dsb_sev() function to make use of the dsb()
macro and ensure ordering against the unlock.
Reported-by: Mark Rutland <mark.rutland@arm.com>
commit bae0ca2bc550d1ec6a118fb8f2696f18c4da3d8e upstream.
During __v{6,7}_setup, we invalidate the TLBs since we are about to
enable the MMU on return to head.S. Unfortunately, without a subsequent
dsb instruction, the invalidation is not guaranteed to have completed by
the time we write to the sctlr, potentially exposing us to junk/stale
translations cached in the TLB.
This patch reworks the init functions so that the dsb used to ensure
completion of cache/predictor maintenance is also used to ensure
completion of the TLB invalidation.
Reported-by: Albin Tonnerre <Albin.Tonnerre@arm.com>
commit 10c8562f932d89c030083e15f9279971ed637136 upstream.
GFP_ATOMIC is not a single gfp flag, but a macro which expands to the other
flags and LACK of __GFP_WAIT flag. To check if caller wanted to perform an
atomic allocation, the code must test __GFP_WAIT flag presence. This patch
fixes the issue introduced in v3.6-rc5
commit dc4910d9e93f8cc56b190dd8fc9e789135978216 upstream.
When pci_base is accessed whereas it has not been properly mapped by
of_iomap() the kernel hang. The check of this pointer made an improper
use of IS_ERR() instead of comparing to NULL. This patch fix this
issue.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reported-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Fixes: 930ab3d403ae (i2c: mv64xxx: Add I2C Transaction Generator support)
commit f28d7de6bd4d41774744e011141945affa127da4 upstream.
DT-enabled Marvell Kirkwood and Dove SoCs make use of an irqchip
driver. As expected for irqchip drivers, it uses a C-style
interrupt handler and therefore selects MULTI_IRQ_HANDLER.
Now, compiling a kernel with both non-DT and DT support enabled,
selecting MULTI_IRQ_HANDLER will break ASM irq handler used by
non-DT boards.
Therefore, we provide a C-style irq handler even for non-DT boards,
if MULTI_IRQ_HANDLER is set. By installing the C-style irq handler
in orion_irq_init this is transparent to all non-DT board files.
While the regression report was filed on Marvell Kirkwood, also
Marvell Dove non-DT boards are affected and fixed by this patch.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Reported-by: Ian Campbell <ijc@hellion.org.uk>
Fixes: 2326f04321a9 ("ARM: kirkwood: convert to DT irqchip and clocksource")
Fixes: f07d73e33d0e ("ARM: dove: convert to DT irqchip and clocksource")
[ Upstream commit aee636c4809fa54848ff07a899b326eb1f9987a2 ]
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
commit 85e618a1be2b2092318178d1d66bdad49cbbeeeb upstream.
The first variants of Armada XP SoCs (A0 stepping) have issues related
to the i2c controller which prevent to use the offload mechanism and
lead to a kernel hang during boot.
This commit add quirk in the mvebu platform code to check the SoC
version and then update the compatible string for the i2c controller
according to the revision of the SoC. Currently only some OpenBlocks
AX3-4 boards are known to use an A0 revision so the check is done only
for these boards.
commit af8d1c63afcbf36eea06789c92e22d4af118d2fb upstream.
All the mvebu SoCs have information related to their variant and
revision that can be read from the PCI control register.
This patch adds support for Armada XP and Armada 370. This reading of
the revision and the ID are done before the PCI initialization to
avoid any conflicts. Once these data are retrieved, the resources are
freed to let the PCI subsystem use it.
commit a96cc303e42ad7830dde929aad0046e448a05505 upstream.
This patch updates the Armada 370/XP SATA node with the new compatible
string "marvell,armada-370-sata".
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Lior Amsalem <alior@marvell.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
commit 1588c51cf6d782e63a8719681d905ef0ac22ee62 upstream.
There was a copy/paste error when reading the nwe_pulse value.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
Acked-by: Boris BREZILLON <b.brezillon@overkiz.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit 0645b93f6c223b594c0dca348e2ae0a23bccf6e3 upstream.
pinctrl-names property was missing from mmc nodes.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit b25f3e1c358434bf850220e04f28eebfc45eb634 upstream.
Kexec disables outer cache before jumping to reboot code, but it doesn't
flush it explicitly. Flush is done implicitly inside of l2x0_disable().
But some SoC's override default .disable handler and don't flush cache.
This may lead to a corrupted memory during Kexec reboot on these
platforms.
This patch adds cache flush inside of OMAP4 and Highbank outer_cache.disable()
handlers to make it consistent with default l2x0_disable().
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Cc: Wang Nan <wangnan0@huawei.com>
commit e44ef891e9e68b6ce7d3fd3bac73b7d5433050ae upstream.
The MPIDR contains specific bitfields(MPIDR.Aff{2..0}) which uniquely
identify a CPU, in addition to some non-identifying information and
reserved bits. The ARM cpu binding defines the 'reg' property to only
contain the affinity bits, and any cpu nodes with other bits set in
their 'reg' entry are skipped.
As such it is not necessary to mask the phys_id with MPIDR_HWID_BITMASK,
and doing so could lead to matching erroneous CPU nodes in the device
tree. This patch removes the masking of the physical identifier.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
