path: root/arch/avr32/Makefile
2014-02-17avr32: Makefile: add '-D__linux__' flag for gcc-4.4.7 useChen Gang
For avr32 cross compiler, do not define '__linux__' internally, so it will cause issue with allmodconfig. The related error: CC [M] fs/coda/psdev.o In file included from include/linux/coda.h:64, from fs/coda/psdev.c:45: include/uapi/linux/coda.h:221: error: expected specifier-qualifier-list before 'u_quad_t' The related toolchain version (which only download, not re-compile): [root@gchen linux-next]# /upstream/toolchain/download/avr32-gnu-toolchain-linux_x86/bin/avr32-gcc -v Using built-in specs. Target: avr32 Configured with: /data2/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/src/gcc/configure --target=avr32 --host=i686-pc-linux-gnu --build=x86_64-pc-linux-gnu --prefix=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libstdcxx-pch --with-dwarf2 --enable-version-specific-runtime-libs --disable-shared --enable-doc --with-mpfr-lib=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86/lib --with-mpfr-include=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86/include --with-gmp=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --with-mpc=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --enable-__cxa_atexit --disable-shared --with-newlib --with-pkgversion=AVR_32_bit_GNU_Toolchain_3.4.2_435 --with-bugurl=http://www .atmel.com/avr Thread model: single gcc version 4.4.7 (AVR_32_bit_GNU_Toolchain_3.4.2_435) Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Acked-by: Hans-Christian Egtvedt <hegtvedt@cisco.com> Cc: stable@vger.kernel.org
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-14avr32: add support for ATNGW100 mkII boardHans-Christian Egtvedt
This patch adds board support for ATNGW100 mkII. This board is an upgrade of the ATNGW100 where the difference is an additional 256 MB NAND flash device and 128 MB 32-bit SDRAM instead of the 32 MB 16-bit SDRAM on ATNGW100. Tested on ATNGW100 mkII, duh (-: Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-05-01avr32: drop unused CLEAN_FILESSam Ravnborg
Left over from before we used arch/avr32/include Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com>
2009-03-27Add Merisc board supportJonas Larsson
Merisc is the family name for a range of AVR32-based boards. The boards are designed to be used in a man-machine interfacing environment, utilizing a touch-based graphical user interface. They host a vast range of I/O peripherals as well as a large SDRAM & Flash memory bank. For more information see: http://www.martinsson.se/merisc Signed-off-by: Jonas Larsson <jonas.larsson@martinsson.se> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-01-05avr32: Hammerhead board supportAlex Raimondi
The Hammerhead platform is built around a AVR32 32-bit microcontroller from Atmel. It offers versatile peripherals, such as ethernet, usb device, usb host etc. The board also incooperates a power supply and is a Power over Ethernet (PoE) Powered Device (PD). Additonally, a Cyclone III FPGA from Altera is integrated on the board. The FPGA is mapped into the 32-bit AVR memory bus. The FPGA offers two DDR2 SDRAM interfaces, which will cover even the most exceptional need of memory bandwidth. Together with the onboard video decoder the board is ready for video processing. This patch does include the basic support for the fpga device driver, but not the device driver itself. Signed-off-by: Alex Raimondi <mailinglist@miromico.ch> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-10-13avr32: Add MIMC200 board supportMark Jackson
Please consider the following patch which adds support for a new AVR32 based board. The board is closely based on Atmel's NGW100 reference board, but has an extra 8MByte FLASH and 128KByte FRAM. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-10-13avr32: add support for EarthLCD Favr-32 boardHans-Christian Egtvedt
This patch adds support for the Favr-32 board made by EarthLCD. This kit, which is also called ezLCD-101, has a 10.4" touch screen LCD panel, 16 MB 32-bit SDRAM, 8 MB parallel flash, Ethernet, audio out, USB device, SD-card slot, USART and various other connectors for cennecting stuff to SPI, I2C, GPIO, etc. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-08avr32: Remove include/asm-avr32/arch-at32apHaavard Skinnemoen
Since all users have been converted over to use <mach/foo.h>, there's no need for the arch-at32ap directory and associated symlink anymore. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-05avr32: Introduce arch/avr32/mach-*/include/machHaavard Skinnemoen
Add arch/avr32/mach-*/include to include search path and copy all the files from include/asm/arch there. The old files will be removed once ARM does the same change and all common drivers are converted. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-01-25[AVR32] Add support for AT32AP7001 and AT32AP7002Haavard Skinnemoen
These are derivatives of the AT32AP7000 chip, which means that most of the code stays the same. Rename a few files, functions, definitions and config symbols to reflect that they apply to all AP700x chips, and exclude some platform devices from chips where they aren't present. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Oprofile supportHaavard Skinnemoen
This adds the necessary architecture code to run oprofile on AVR32 using the performance counters documented by the AVR32 Architecture Manual. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Philippe Elie <phil.el@wanadoo.fr>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-09[AVR32] Use correct config symbol when setting cpuflagsHaavard Skinnemoen
As Robert P. J. Day pointed out, the CONFIG_CPU_AT32AP7000 symbol wasn't used for anything. It should have been used to select the correct -mcpu= options for CFLAGS. -mcpu=ap7000 is the default anyway, so this patch shouldn't really make any difference, but it's always nice to do things correctly. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27[AVR32] Board code for ATNGW100Haavard Skinnemoen
Add board code and defconfig for the ATNGW100 Network Gateway kit. For more information about this board, see http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4102 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-25[PATCH] AVR32: Minor Makefile cleanupHaavard Skinnemoen
Don't generate listing by default, remove unused LIBGCC variable and rename generated disassembly and listing files to vmlinux.{s,lst}. Also make sure that files generated during the build are actually removed with make clean. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
