path: root/arch/avr32/configs/atngw100mkii_evklcd101_defconfig
2011-06-14avr32: set CONFIG_CC_OPTIMIZE_FOR_SIZE=y for all defconfigsHans-Christian Egtvedt
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for all default configuration files. This ensures the kernel is optimized for size, and avoids potential relocation truncated to fit problems. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: update default configuration files for Atmel boardsHans-Christian Egtvedt
This patch adjusts some values to make the default configuration for Atmel boards more similar, and adds missing values to enable required functions. Also remove defined symbols for functions not in use. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: disable kprobes for all default configurationsHans-Christian Egtvedt
This patch will disable kprobes for all the default AVR32 board configurations. This works around a regression in kprobes which seems to be related to AVR32 is now lacking the struct kprobe_ctlblk. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-12-14avr32: add default configurations for ATNGW100 mkII and EVKLCD10XHans-Christian Egtvedt
This patch adds three default configurations for ATNGW100 mkII and ATNGW100 mkII with either EVKLCD100 or EVKLCD101 addon board. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
