Now that all boards have switched to the generic PWM framework, update the
defconfigs to use it.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch removes CONFIG_MTD_PARTITIONS in config files for avr32.
Because CONFIG_MTD_PARTITIONS was removed by commit
6a8a98b22b10f1560d5f90aded4a54234b9b2724.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
Acked-by: Hans-Christian Egtvedt <hegtvedt@cisco.com>
This patch moves cpufreq driver of AVR32 based at32ap platform to
drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The File-backed Storage Gadget (g_file_storage) is being removed, since
it has been replaced by Mass Storage Gadget (g_mass_storage). This commit
changes defconfigs point to the new gadget.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> (AT91)
Acked-by: Tony Lindgren <tony@atomide.com> (OMAP1)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> (AVR32)
Signed-off-by: Felipe Balbi <balbi@ti.com>
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for
all default configuration files. This ensures the kernel is optimized for size,
and avoids potential relocation truncated to fit problems.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
This patch adjusts some values to make the default configuration for Atmel
boards more similar, and adds missing values to enable required functions. Also
remove defined symbols for functions not in use.
This patch will disable kprobes for all the default AVR32 board configurations.
This works around a regression in kprobes which seems to be related to AVR32 is
now lacking the struct kprobe_ctlblk.
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This patch updates the default configuration for ATNGW100 (also for the
EVKLCD10X configs), ATSTK1002 and ATSTK1006.
By default all kernels will now have support for EXT2/3/4 out of the box, this
is handy if the user wants to boot from SD-Card.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
In the defconfigs for ATNGW100 and ATSTK100[236] the DMA Test driver is
compiled as a module. This means systems built with *_defconfig +
CONFIG_MODULES=n are unusable as the 3 dma test channels monopolise the
CPU.
I 'spose Haavard uses this module a lot but IMO it isn't really
something needed on all eval boards by default.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Enable power management, DMA and MMC on all boards except ATSTK1004, and
add defconfig for the new ATSTK1006 board with NAND flash, UBI and UBIFS
enabled as well.
Just provide reasonable defaults for the new stuff. Tickless and
hrtimers are turned on for all boards except ATSTK1004.
Turn off a few useless options, enable a few useful ones and enable
quite a few new drivers.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
These are derivatives of the AT32AP7000 chip, which means that most of
the code stays the same. Rename a few files, functions, definitions
and config symbols to reflect that they apply to all AP700x chips, and
exclude some platform devices from chips where they aren't present.
Update defconfigs for ATNGW100 and ATSTK1002. This will enable the
SLUB allocator by default on both, and will enable NFS root on
ATSTK1002 (ATNGW100 had it enabled before.)
Enable the Atmel MACB ethernet driver by default on ATSTK1000.
Sync atstk1002_defconfig with latest git, turn off non-existent
drivers and enable a few more userspace-visible options like
SysV IPC and inotify support.
Rename the following Kconfig symbols:
* CONFIG_SERIAL_AT91 -> CONFIG_SERIAL_ATMEL
* CONFIG_SERIAL_AT91_CONSOLE -> CONFIG_SERIAL_ATMEL_CONSOLE
* CONFIG_SERIAL_AT91_TTYAT -> CONFIG_SERIAL_ATMEL_TTYAT
Acked-by: Andrew Victor <andrew@sanpeople.com>
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000
CPU and the AT32STK1000 development board.
AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for
cost-sensitive embedded applications, with particular emphasis on low power
consumption and high code density. The AVR32 architecture is not binary
compatible with earlier 8-bit AVR architectures.
The AVR32 architecture, including the instruction set, is described by the
AVR32 Architecture Manual, available from
http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf
The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It
features a 7-stage pipeline, 16KB instruction and data caches and a full
Memory Management Unit. It also comes with a large set of integrated
peripherals, many of which are shared with the AT91 ARM-based controllers from
Atmel.
Full data sheet is available from
http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf
while the CPU core implementation including caches and MMU is documented by
the AVR32 AP Technical Reference, available from
http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf
Information about the AT32STK1000 development board can be found at
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918
including a BSP CD image with an earlier version of this patch, development
tools (binaries and source/patches) and a root filesystem image suitable for
booting from SD card.
Alternatively, there's a preliminary "getting started" guide available at
http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links
to the sources and patches you will need in order to set up a cross-compiling
environment for avr32-linux.
This patch, as well as the other patches included with the BSP and the
toolchain patches, is actively supported by Atmel Corporation.
[dmccr@us.ibm.com: Fix more pxx_page macro locations]
[bunk@stusta.de: fix `make defconfig']
Signed-off-by: Dave McCracken <dmccr@us.ibm.com>
