This patch runs all the default configurations through make
silentoldconfig and make savedefconfig to rinse out outdated kconfig
entries.
for config in arch/avr32/configs/*defconfig; do
make ARCH=avr32 `basename $config`
make ARCH=avr32 silentoldconfig
make ARCH=avr32 savedefconfig
cp defconfig $config
done
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Now that all boards have switched to the generic PWM framework, update the
defconfigs to use it.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch removes CONFIG_MTD_PARTITIONS in config files for avr32.
Because CONFIG_MTD_PARTITIONS was removed by commit
6a8a98b22b10f1560d5f90aded4a54234b9b2724.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
Acked-by: Hans-Christian Egtvedt <hegtvedt@cisco.com>
This patch moves cpufreq driver of AVR32 based at32ap platform to
drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The File-backed Storage Gadget (g_file_storage) is being removed, since
it has been replaced by Mass Storage Gadget (g_mass_storage). This commit
changes defconfigs point to the new gadget.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> (AT91)
Acked-by: Tony Lindgren <tony@atomide.com> (OMAP1)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> (AVR32)
Signed-off-by: Felipe Balbi <balbi@ti.com>
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for
all default configuration files. This ensures the kernel is optimized for size,
and avoids potential relocation truncated to fit problems.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
This patch adjusts some values to make the default configuration for Atmel
boards more similar, and adds missing values to enable required functions. Also
remove defined symbols for functions not in use.
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Enable power management, DMA and MMC on all boards except ATSTK1004, and
add defconfig for the new ATSTK1006 board with NAND flash, UBI and UBIFS
enabled as well.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Just provide reasonable defaults for the new stuff. Tickless and
hrtimers are turned on for all boards except ATSTK1004.
ATSTK1003 and ATSTK1004 are CPU daughterboards for ATSTK1000 featuring
the AT32AP7001 and AT32AP7002 CPUs, respectively.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
