New helper - sys_mmap_pgoff(); switch syscalls to using it.
Replace handcoded rcall instructions with the call pseudo-instruction.
For kernels too far over 1MB the rcall instruction can't reach and
linking will fail. We already call the final linker with --relax which
converts call pseudo-instructions to the right things anyway.
This fixes
arch/avr32/kernel/built-in.o: In function `syscall_exit_work':
(.ex.text+0x198): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `schedule' defined in .sched.text section in kernel/built-in.o
arch/avr32/kernel/built-in.o: In function `fault_exit_work':
(.ex.text+0x3b6): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `schedule' defined in .sched.text section in kernel/built-in.o
But I'm still left with
arch/avr32/kernel/built-in.o:(.fixup+0x2): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+45a
arch/avr32/kernel/built-in.o:(.fixup+0x8): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+8ea
arch/avr32/kernel/built-in.o:(.fixup+0xe): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+abe
arch/avr32/kernel/built-in.o:(.fixup+0x14): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ac8
arch/avr32/kernel/built-in.o:(.fixup+0x1a): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ad2
arch/avr32/kernel/built-in.o:(.fixup+0x20): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+adc
arch/avr32/kernel/built-in.o:(.fixup+0x26): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ae6
arch/avr32/kernel/built-in.o:(.fixup+0x2c): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+af0
arch/avr32/kernel/built-in.o:(.fixup+0x32): additional relocation overflows omitted from the output
These are caused by a similar problem with 'rjmp' instructions.
Unfortunately, there's no easy fix for these at the moment since we
don't have a arbitrary-range 'jmp' instruction similar to 'call'.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
On AVR32, all parameters beyond the 5th are passed on the stack. System
calls don't use the stack -- they borrow a callee-saved register
instead. This means that syscalls that take 6 parameters must be called
through a stub that pushes the last parameter on the stack.
This patch adds a stub for sync_file_range syscall on AVR32
architecture. Tested with uClibc snapshot.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000
CPU and the AT32STK1000 development board.
AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for
cost-sensitive embedded applications, with particular emphasis on low power
consumption and high code density. The AVR32 architecture is not binary
compatible with earlier 8-bit AVR architectures.
The AVR32 architecture, including the instruction set, is described by the
AVR32 Architecture Manual, available from
http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf
The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It
features a 7-stage pipeline, 16KB instruction and data caches and a full
Memory Management Unit. It also comes with a large set of integrated
peripherals, many of which are shared with the AT91 ARM-based controllers from
Atmel.
Full data sheet is available from
http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf
while the CPU core implementation including caches and MMU is documented by
the AVR32 AP Technical Reference, available from
http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf
Information about the AT32STK1000 development board can be found at
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918
including a BSP CD image with an earlier version of this patch, development
tools (binaries and source/patches) and a root filesystem image suitable for
booting from SD card.
Alternatively, there's a preliminary "getting started" guide available at
http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links
to the sources and patches you will need in order to set up a cross-compiling
environment for avr32-linux.
This patch, as well as the other patches included with the BSP and the
toolchain patches, is actively supported by Atmel Corporation.
[dmccr@us.ibm.com: Fix more pxx_page macro locations]
[bunk@stusta.de: fix `make defconfig']
Signed-off-by: Dave McCracken <dmccr@us.ibm.com>
