path: root/arch/avr32/kernel
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29avr32: use kbuild.h macros instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: don't initialize a pre-allocated framebufferHaavard Skinnemoen
If the user specified a fixed framebuffer address on the command line, it may have been initialized already with a splash image or something, so we shouldn't clear it. Therefore, we should only initialize the framebuffer if we allocated it ourselves. This patch also updates the AVR32 setup code to clear the framebuffer if it allocated it itself, i.e. the user didn't provide a fixed address or the reservation failed. I've updated the at91 platform code as well so that it initializes the framebuffer if it is located in SRAM, but I haven't tested that it actually works. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19avr32: Add hardware power-down function callPeter Ma
This patch adds in the indirect call to pm_power_off(), as is done in other architectures (e.g. ARM). Tested on NGW100, with custom board with GPIO control over main DC power. Signed-off-by: Peter Ma <pma@mediamatech.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-04-19avr32: Generic clockevents supportDavid Brownell
This combines three patches from David Brownell: * avr32: tclib support * avr32: simplify clocksources * avr32: Turn count/compare into a oneshot clockevent device Register both TC blocks (instead of just the first one) so that the AT32/AT91 tclib code will pick them up (instead of just the avr32-only PIT-style clocksource). Rename the first one and its resources appropriately. More cleanups to the cycle counter clocksource code - Disable all the weak symbol magic; remove the AVR32-only TCB-based clocksource code (source and header). - Mark the __init code properly. - Don't forget to report IRQF_TIMER. - Make the system work properly with this clocksource, by preventing use of the CPU "idle" sleep state in the idle loop when it's used. Package the avr32 count/compare timekeeping support as a oneshot clockevent device, so it supports NO_HZ and high res timers. This means it also supports plugging in other clockevent devices and clocksources. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-04-19avr32: Move sleep code into mach-at32apHaavard Skinnemoen
Create a new file, pm-at32ap700x.S, in mach-at32ap and move the CPU idle sleep code there. Make it possible to disable the sleep code. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-04-19avr32: start clocksource cleanupDavid Brownell
Start cleaning up the AVR32 clocksource mess, starting with the cycle counter clocksource: remove unneeded pseudo-RTC (just inline that call to mktime) and associated build warning, and unused sysdev. Add comment about the problem using the cycle counter register, and adjust the clocksource rating accordingly. Later patches can make this usable again (by disabling use of the idle state and providing a proper clocksource without the weak binding hacks) and move towards TCB-based clockevent support (including high resolution timers) that's shared between AT91 and AVR32. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-03-27avr32: Fix bug in early resource allocation codeHaavard Skinnemoen
add_reserved_region() tries to keep the resource list sorted, so when looking for a place to insert the new resource, it may break out before the last entry. When this happens, the list is broken in two because the sibling field of the new entry doesn't point to the next resource. Fix it by updating the new resource's sibling field appropriately. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-03-13avr32: Build fix for CONFIG_BUG=nHaavard Skinnemoen
Don't include the BUG trap handling code when CONFIG_BUG is not set. This fixes allnoconfig. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-02-27avr32: Fix OCD refcounting bugHaavard Skinnemoen
Iff the parent has TIF_DEBUG set, _and_ clone_flags includes CLONE_PTRACE we should set the TIF_DEBUG flag for the child and increment the ocd refcount. Otherwise, the TIF_DEBUG flag must be unset. Currently, the child inherits TIF_DEBUG from the parent before copy_thread is called, so TIF_DEBUG may be already be set before we determine whether the child is supposed to inherit debugging capabilities from the parent or not. This means that ocd_enable() won't increment the refcount, because TIF_DEBUG is already set, and that TIF_DEBUG will be set for processes that aren't being debugged. This leads to a refcounting asymmetry, which may show up as ------------[ cut here ]------------ Badness at arch/avr32/kernel/ocd.c:73 PC is at ocd_disable+0x34/0x60 LR is at put_lock_stats+0xa/0x20 as reported by David Brownell. Happens when strace'ing a process that forks a new child process, e.g. "strace mount -tjffs2 mtd1 /mnt", and subsequently killing the child process (e.g. "umount /mnt".) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-15avr32: Call tick_nohz_{stop,restart}_sched_tick() in idle loopHaavard Skinnemoen
This fixes a hang on boot with nohz enabled. nohz is not actually supported in mainline yet, but patches that add support for it are currently under review. When nohz is compiled out, the functions are no-ops, so this patch results in no functional change, but it arguably makes the code more correct. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-08libfs: allow error return from simple attributesChristoph Hellwig
Sometimes simple attributes might need to return an error, e.g. for acquiring a mutex interruptibly. In fact we have that situation in spufs already which is the original user of the simple attributes. This patch merged the temporarily forked attributes in spufs back into the main ones and allows to return errors. [akpm@linux-foundation.org: build fix] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <stefano.brivio@polimi.it> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Fix timerfd breakage on avr32Haavard Skinnemoen
Hmm. Someone removed the timerfd() syscall... Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: [AVR32] extint: Set initial irq type to low level [AVR32] extint: change set_irq_type() handling [AVR32] NMI debugging [AVR32] constify function pointer tables [AVR32] ATNGW100: Update defconfig [AVR32] ATSTK1002: Update defconfig [AVR32] Kconfig: Choose daughterboard instead of CPU [AVR32] Add support for ATSTK1003 and ATSTK1004 [AVR32] Clean up external DAC setup code [AVR32] ATSTK1000: Move gpio-leds setup to setup.c [AVR32] Add support for AT32AP7001 and AT32AP7002 [AVR32] Provide more CPU information in /proc/cpuinfo and dmesg [AVR32] Oprofile support [AVR32] Include instrumentation menu Disable VGA text console for AVR32 architecture [AVR32] Enable debugging only when needed ptrace: Call arch_ptrace_attach() when request=PTRACE_TRACEME [AVR32] Remove redundant try_to_freeze() call from do_signal() [AVR32] Drop GFP_COMP for DMA memory allocations
2008-01-25[AVR32] NMI debuggingHaavard Skinnemoen
Change the NMI handler to use the die notifier chain to signal anyone who cares. Add a simple "nmi debugger" which hooks into this chain and that may dump registers, task state, etc. when it happens. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Provide more CPU information in /proc/cpuinfo and dmesgHaavard Skinnemoen
Add the following fields to /proc/cpuinfo: * chip type and revision (from the JTAG chip id) * cpu MHz (from clk_get_rate()) * features (from the CONFIG0 register) Also rename "cpu family" to "cpu arch" and "cpu type" to "cpu core" to remove some ambiguity. Show chip type and revision at bootup, and clarify that the other kinds of IDs that we're already printing are for the cpu core and architecture. Rename "AP7000" to "AP7" since that's the name of the core. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Enable debugging only when neededHaavard Skinnemoen
Keep track of processes being debugged (including the kernel itself) and turn the OCD system on and off as appropriate. Since enabling debugging turns off some optimizations in the CPU core, this fixes the issue that enabling KProbes support or simply running a program under gdbserver will reduce system performance significantly until the next reboot. The CPU performance will still be reduced for all processes while a process is being debugged, but this is a lot better than reducing the performance forever. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Remove redundant try_to_freeze() call from do_signal()Haavard Skinnemoen
get_signal_to_deliver() will call try_to_freeze(), so there's no point in do_signal() doing it as well. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-07[AVR32] Fix wrong pt_regs in critical exception handlerHaavard Skinnemoen
It's not like it really matters at this point since the system is dying anyway, but handle_critical pushes too few registers on the stack so the register dump, which makes the register dump look a bit strange. This patch fixes it. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-07[AVR32] Follow the rules when dealing with the OCD systemHaavard Skinnemoen
The current debug trap handling code does a number of things that are illegal according to the AVR32 Architecture manual. Most importantly, it may try to schedule from Debug Mode, thus clearing the D bit, which can lead to "undefined behaviour". It seems like this works in most cases, but several people have observed somewhat unstable behaviour when debugging programs, including soft lockups. So there's definitely something which is not right with the existing code. The new code will never schedule from Debug mode, it will always exit Debug mode with a "retd" instruction, and if something not running in Debug mode needs to do something debug-related (like doing a single step), it will enter debug mode through a "breakpoint" instruction. The monitor code will then return directly to user space, bypassing its own saved registers if necessary (since we don't actually care about the trapped context, only the one that came before.) This adds three instructions to the common exception handling code, including one branch. It does not touch super-hot paths like the TLB miss handler. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-07[AVR32] Clean up OCD register usageHaavard Skinnemoen
Generate a new set of OCD register definitions in asm/ocd.h and rename __mfdr() and __mtdr() to ocd_read() and ocd_write() respectively. The bitfield definitions are a lot more complete now, and they are entirely based on bit numbers, not masks. This is because OCD registers are frequently accessed from assembly code, where bit numbers are a lot more useful (can be fed directly to sbr, bfins, etc.) Bitfields that consist of more than one bit have two definitions: _START, which indicates the number of the first bit, and _SIZE, which indicates the number of bits. These directly correspond to the parameters taken by the bfextu, bfexts and bfins instructions. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-07[AVR32] Implement irqflags trace and lockdep supportHaavard Skinnemoen
2007-12-07[AVR32] Implement stacktrace supportHaavard Skinnemoen
2007-12-07[AVR32] Fix invalid status register bit definitions in asm/ptrace.hHaavard Skinnemoen
The 'H' bit is bit 29, while the 'R' bit doesn't exist. Luckily, we don't actually use any of the bits in question. Also update show_regs() to show the Debug Mask and Debug state bits. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16kprobes: support kretprobe blacklistMasami Hiramatsu
Introduce architecture dependent kretprobe blacklists to prohibit users from inserting return probes on the function in which kprobes can be inserted but kretprobes can not. This patch also removes "__kprobes" mark from "__switch_to" on x86_64 and registers "__switch_to" to the blacklist on x86-64, because that mark is to prohibit user from inserting only kretprobe. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Consolidate PTRACE_DETACHAlexey Dobriyan
Identical handlers of PTRACE_DETACH go into ptrace_request(). Not touching compat code. Not touching archs that don't call ptrace_request. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[AVR32] Fix random segfault with preemptionPhilippe Rétornaz
As explained on: http://www.avrfreaks.net/index.php?nameÿphpBB2&fileÿewtopic&tS307 If the current process is preempted before it can copy RAR_SUP and RSR_SUP both register are lost and the process will segfault as soon as it return from the syscall since the return adress will be corrupted. This patch disable IRQ as soon as we enter the syscall path and reenable them when the copy is done. In the interrupt handlers, check if we are interrupting the srrf instruction, if so disable interrupts and return. The interrupt handler will be re-called immediatly when the interrupts are reenabled. After some stressing workload: - find / > /dev/null in loop - top (in ssh) - ping -f avr32 The segfaults are not seen anymore. Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] Remove unneeded 8K alignment of .text sectionHaavard Skinnemoen
__init_end, which comes immediately before .text, is already page aligned, and that should be more than enough for the .text section. The reason why we need to align the .text section is because the interrupt handler offset is ORed with EVBA, so we need to provide enough alignment of EVBA that this OR operation works as an ADD. Currently, the last interrupt handler is not nearly a full page away from EVBA, so it won't be a problem. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] Kill a few hardcoded constants in vmlinux.ldsHaavard Skinnemoen
Use PAGE_SIZE, THREAD_SIZE and L1_CACHE_BYTES instead of harcoded constants in places where that's what we really mean. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] rename vmlinux.ldsSam Ravnborg
Rename vmlinux.lds to a .S file to match other architectures. Simplify Makefile to match the rename and deleted the unused USE_STANDARD_AS_RULE Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] fix command line parsing in early_parse_fbmemMatteo Vit
Signed-off-by: Matteo Vit - Dave S.r.l. <matteo.vit@dave.eu> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-18[AVR32] Correct misspelled CONFIG_BLK_DEV_INITRD variable.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-18[AVR32] Fix build error in parse_tag_rdimg()Haavard Skinnemoen
This code is inside an #ifdef with a misspelled config symbol, so it hasn't been used for a long time. Fix it before fixing the config symbol to keep bisection working. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Report that kernel is tainted if there was an OOPSPavel Emelianov
If the kernel OOPSed or BUGed then it probably should be considered as tainted. Thus, all subsequent OOPSes and SysRq dumps will report the tainted kernel. This saves a lot of time explaining oddities in the calltraces. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Added parisc patch from Matthew Wilson -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16generic bug: use show_regs() instead of dump_stack()Heiko Carstens
The current generic bug implementation has a call to dump_stack() in case a WARN_ON(whatever) gets hit. Since report_bug(), which calls dump_stack(), gets called from an exception handler we can do better: just pass the pt_regs structure to report_bug() and pass it to show_regs() in case of a warning. This will give more debug informations like register contents, etc... In addition this avoids some pointless lines that dump_stack() emits, since it includes a stack backtrace of the exception handler which is of no interest in case of a warning. E.g. on s390 the following lines are currently always present in a stack backtrace if dump_stack() gets called from report_bug(): [<000000000001517a>] show_trace+0x92/0xe8) [<0000000000015270>] show_stack+0xa0/0xd0 [<00000000000152ce>] dump_stack+0x2e/0x3c [<0000000000195450>] report_bug+0x98/0xf8 [<0000000000016cc8>] illegal_op+0x1fc/0x21c [<00000000000227d6>] sysc_return+0x0/0x10 Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andi Kleen <ak@suse.de> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19all-archs: consolidate .data section definition in asm-genericSam Ravnborg
With this consolidation we can now modify the .data section definition in one spot for all archs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19all-archs: consolidate .text section definition in asm-genericSam Ravnborg
Move definition of .text section to asm-generic. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-13[AVR32] Wire up signalfd, timerfd and eventfdHaavard Skinnemoen
2007-05-13[AVR32] optimize pagefault pathChristoph Hellwig
Avoid the costly notifier list in the pagefault path and call the kprobes code directly. The same change went into the 2.6.22 cycle for powerpc, 2s390 and sparc64 already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-13[AVR32] Remove bogus comment in arch/avr32/kernel/irq.cHaavard Skinnemoen
The comment at the top of arch/avr32/kernel/irq.c doesn't really make sense anymore since most of the actual interrupt handling code is elsewhere. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-09Merge branch 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32Linus Torvalds
* 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32: [AVR32] Wire up sys_utimensat [AVR32] Fix section mismatch .taglist -> .init.text [AVR32] Implement dma_{alloc,free}_writecombine() AVR32: Spinlock initializer cleanup [AVR32] Use correct config symbol when setting cpuflags
2007-05-09wrap access to thread_infoRoman Zippel
Recently a few direct accesses to the thread_info in the task structure snuck back, so this wraps them with the appropriate wrapper. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
