path: root/arch/avr32
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20avr32: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32 Pull AVR32 updates from Hans-Christian Noren Egtvedt. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32: mmc: atmel: get rid of struct mci_dma_data mmc: atmel-mci: restore dma on AVR32 avr32: wire up missing syscalls avr32: wire up accept4 syscall
2016-01-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - more MM stuff: - Kirill's page-flags rework - Kirill's now-allegedly-fixed THP rework - MADV_FREE implementation - DAX feature work (msync/fsync). This isn't quite complete but DAX is new and it's good enough and the guys have a handle on what needs to be done - I expect this to be wrapped in the next week or two. - some vsprintf maintenance work - various other misc bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (145 commits) printk: change recursion_bug type to bool lib/vsprintf: factor out %pN[F] handler as netdev_bits() lib/vsprintf: refactor duplicate code to special_hex_number() printk-formats.txt: remove unimplemented %pT printk: help pr_debug and pr_devel to optimize out arguments lib/test_printf.c: test dentry printing lib/test_printf.c: add test for large bitmaps lib/test_printf.c: account for kvasprintf tests lib/test_printf.c: add a few number() tests lib/test_printf.c: test precision quirks lib/test_printf.c: check for out-of-bound writes lib/test_printf.c: don't BUG lib/kasprintf.c: add sanity check to kvasprintf lib/vsprintf.c: warn about too large precisions and field widths lib/vsprintf.c: help gcc make number() smaller lib/vsprintf.c: expand field_width to 24 bits lib/vsprintf.c: eliminate potential race in string() lib/vsprintf.c: move string() below widen_string() lib/vsprintf.c: pull out padding code from dentry_name() printk: do cond_resched() between lines while outputting to consoles ...
2016-01-17Merge tag 'gpio-v4.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "Here is the bulk of GPIO changes for v4.5. Notably there are big refactorings mostly by myself, aimed at getting the gpio_chip into a shape that makes me believe I can proceed to preserve state for a proper userspace ABI (character device) that has already been proposed once, but resulted in the feedback that I need to go back and restructure stuff. So I've been restructuring stuff. On the way I ran into brokenness (return code from the get_value() callback) and had to fix it. Also, refactored generic GPIO to be simpler. Some of that is still waiting to trickle down from the subsystems all over the kernel that provide random gpio_chips, I've touched every single GPIO driver in the kernel now, oh man I didn't know I was responsible for so much... Apart from that we're churning along as usual. I took some effort to test and retest so it should merge nicely and we shook out a couple of bugs in -next. Infrastructural changes: - In struct gpio_chip, rename the .dev node to .parent to better reflect the fact that this is not the GPIO struct device abstraction. We will add that soon so this would be totallt confusing. - It was noted that the driver .get_value() callbacks was sometimes reporting negative -ERR values to the gpiolib core, expecting them to be propagated to consumer gpiod_get_value() and gpio_get_value() calls. This was not happening, so as there was a mess of drivers returning negative errors and some returning "anything else than zero" to indicate that a line was active. As some would have bit 31 set to indicate "line active" it clashed with negative error codes. This is fixed by the largeish series clamping values in all drivers with !!value to [0,1] and then augmenting the code to propagate error codes to consumers. (Includes some ACKed patches in other subsystems.) - Add a void *data pointer to struct gpio_chip. The container_of() design pattern is indeed very nice, but we want to reform the struct gpio_chip to be a non-volative, stateless business, and keep states internal to the gpiolib to be able to hold on to the state when adding a proper userspace ABI (character device) further down the road. To achieve this, drivers need a handle at the internal state that is not dependent on their struct gpio_chip() so we add gpiochip_add_data() and gpiochip_get_data() following the pattern of many other subsystems. All the "use gpiochip data pointer" patches transforms drivers to this scheme. - The Generic GPIO chip header has been merged into the general <linux/gpio/driver.h> header, and the custom header for that removed. Instead of having a separate mm_gpio_chip struct for these generic drivers, merge that into struct gpio_chip, simplifying the code and removing the need for separate and confusing includes. Misc improvements: - Stabilize the way GPIOs are looked up from the ACPI legacy specification. - Incremental driver features for PXA, PCA953X, Lantiq (patches from the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48 New drivers: - Add a GPIO chip to the ALSA SoC AC97 driver. - Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir, but the branch is merged here too to account for infrastructural changes). - The sx150x driver now supports the sx1502" * tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits) gpio: generic: make bgpio_pdata always visible gpiolib: fix chip order in gpio list gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs() gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs() gpio: brcmstb: Allow building driver for BMIPS_GENERIC gpio: brcmstb: Set endian flags for big-endian MIPS gpio: moxart: fix build regression gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs() leds: pca9532: use gpiochip data pointer leds: tca6507: use gpiochip data pointer hid: cp2112: use gpiochip data pointer bcma: gpio: use gpiochip data pointer avr32: gpio: use gpiochip data pointer video: fbdev: via: use gpiochip data pointer gpio: pch: Optimize pch_gpio_get() Revert "pinctrl: lantiq: Implement gpio_chip.to_irq" pinctrl: nsp-gpio: use gpiochip data pointer pinctrl: vt8500-wmt: use gpiochip data pointer pinctrl: exynos5440: use gpiochip data pointer pinctrl: at91-pio4: use gpiochip data pointer ...
2016-01-15avr32: convert to asm-generic/memory_model.hDan Williams
Switch avr32/include/asm/page.h to use the common defintions for pfn_to_page(), page_to_pfn(), and ARCH_PFN_OFFSET. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching Pull livepatching updates from Jiri Kosina: - RO/NX attribute fixes for patch module relocations from Josh Poimboeuf. As part of this effort, module.c has been cleaned up as well and livepatching is piggy-backing on this cleanup. Rusty is OK with this whole lot going through livepatching tree. - symbol disambiguation support from Chris J Arges. That series is also Reviewed-by: Miroslav Benes <mbenes@suse.cz> but this came in only after I've alredy pushed out. Didn't want to rebase because of that, hence I am mentioning it here. - symbol lookup fix from Miroslav Benes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching: livepatch: Cleanup module page permission changes module: keep percpu symbols in module's symtab module: clean up RO/NX handling. module: use a structure to encapsulate layout. gcov: use within_module() helper. module: Use the same logic for setting and unsetting RO/NX livepatch: function,sympos scheme in livepatch sysfs directory livepatch: add sympos as disambiguator field to klp_reloc livepatch: add old_sympos as disambiguator field to klp_func
2016-01-14mmc: atmel: get rid of struct mci_dma_dataMans Rullgard
As struct mci_dma_data is now only used by AVR32, it is nothing but pointless indirection. Replace it with struct dw_dma_slave in the AVR32 platform code and with a void pointer elsewhere. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-01-14mmc: atmel-mci: restore dma on AVR32Mans Rullgard
Commit ecb89f2f5f3e7 ("mmc: atmel-mci: remove compat for non DT board when requesting dma chan") broke dma on AVR32 and any other boards not using DT. This restores a fallback mechanism for such cases. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-01-11avr32: wire up missing syscallsHans-Christian Egtvedt
This patch adds three missing syscalls to AVR32: __NR_userfaultfd __NR_membarrier __NR_mlock2 Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2016-01-11avr32: wire up accept4 syscallMans Rullgard
The accept4 syscall is missing on AVR32. Fix this. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
2016-01-07avr32: gpio: use gpiochip data pointerLinus Walleij
This makes the driver use the data pointer added to the gpio_chip to store a pointer to the state container instead of relying on container_of(). Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-04soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPFCraig Gallek
Expose socket options for setting a classic or extended BPF program for use when selecting sockets in an SO_REUSEPORT group. These options can be used on the first socket to belong to a group before bind or on any socket in the group after bind. This change includes refactoring of the existing sk_filter code to allow reuse of the existing BPF filter validation checks. Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-04module: use a structure to encapsulate layout.Rusty Russell
Makes it easier to handle init vs core cleanly, though the change is fairly invasive across random architectures. It simplifies the rbtree code immediately, however, while keeping the core data together in the same cachline (now iff the rbtree code is enabled). Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-11-19gpio: change member .dev to .parentLinus Walleij
The name .dev in a struct is normally reserved for a struct device that is let us say a superclass to the thing described by the struct. struct gpio_chip stands out by confusingly using a struct device *dev to point to the parent device (such as a platform_device) that represents the hardware. As we want to give gpio_chip:s real devices, this is not working. We need to rename this member to parent. This was done by two coccinelle scripts, I guess it is possible to combine them into one, but I don't know such stuff. They look like this: @@ struct gpio_chip *var; @@ -var->dev +var->parent and: @@ struct gpio_chip var; @@ -var.dev +var.parent and: @@ struct bgpio_chip *var; @@ -var->gc.dev +var->gc.parent Plus a few instances of bgpio that I couldn't figure out how to teach Coccinelle to rewrite. This patch hits all over the place, but I *strongly* prefer this solution to any piecemal approaches that just exercise patch mechanics all over the place. It mainly hits drivers/gpio and drivers/pinctrl which is my own backyard anyway. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Alek Du <alek.du@intel.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-10Merge tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have a very typical update which is mostly fixes and updates to drivers and no new drivers. - the biggest change is coming from Peter for edma cleanup which even caused some last minute regression, things seem settled now - idma64 and dw updates - iotdma updates - module autoload fixes for various drivers - scatter gather support for hdmac" * tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits) dmaengine: edma: Add dummy driver skeleton for edma3-tptc Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3" Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3" dmaengine: dw: some Intel devices has no memcpy support dmaengine: dw: platform: provide platform data for Intel dmaengine: dw: don't override platform data with autocfg dmaengine: hdmac: Add scatter-gathered memset support dmaengine: hdmac: factorise memset descriptor allocation dmaengine: virt-dma: Fix kernel-doc annotations ARM: DTS: am437x: Use the new DT bindings for the eDMA3 ARM: DTS: am33xx: Use the new DT bindings for the eDMA3 dmaengine: edma: New device tree binding dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx dmaengine: edma: Merge the of parsing functions dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot dmaengine: edma: Refactor the dma device and channel struct initialization dmaengine: edma: Get qDMA channel information from HW also dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_) ...
2015-11-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking changes from Ingo Molnar: "The main changes in this cycle were: - More gradual enhancements to atomic ops: new atomic*_read_ctrl() ops, synchronize atomic_{read,set}() ordering requirements between architectures, add atomic_long_t bitops. (Peter Zijlstra) - Add _{relaxed|acquire|release}() variants for inc/dec atomics and use them in various locking primitives: mutex, rtmutex, mcs, rwsem. This enables weakly ordered architectures (such as arm64) to make use of more locking related optimizations. (Davidlohr Bueso) - Implement atomic[64]_{inc,dec}_relaxed() on ARM. (Will Deacon) - Futex kernel data cache footprint micro-optimization. (Rasmus Villemoes) - pvqspinlock runtime overhead micro-optimization. (Waiman Long) - misc smaller fixlets" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ARM, locking/atomics: Implement _relaxed variants of atomic[64]_{inc,dec} locking/rwsem: Use acquire/release semantics locking/mcs: Use acquire/release semantics locking/rtmutex: Use acquire/release semantics locking/mutex: Use acquire/release semantics locking/asm-generic: Add _{relaxed|acquire|release}() variants for inc/dec atomics atomic: Implement atomic_read_ctrl() atomic, arch: Audit atomic_{read,set}() atomic: Add atomic_long_t bitops futex: Force hot variables into a single cache line locking/pvqspinlock: Kick the PV CPU unconditionally when _Q_SLOW_VAL locking/osq: Relax atomic semantics locking/qrwlock: Rename ->lock to ->wait_lock locking/Documentation/lockstat: Fix typo - lokcing -> locking locking/atomics, cmpxchg: Privatize the inclusion of asm/cmpxchg.h
2015-11-03avr32: atngw100: remove useless includeAlexandre Belloni
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2015-10-06Merge tag 'v4.3-rc4' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-09-30avr32: use dw_dmac autoconfigurationAndy Shevchenko
Instead of hardcoding a platform data for dw_dmac let's use it's own autoconfiguration feature. Thus, remove hardcoded values. Tested on ATNGW100. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
2015-09-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This updated pull request does not contain the last few GIC related patches which were reported to cause a regression. There is a fix available, but I let it breed for a couple of days first. The irq departement provides: - new infrastructure to support non PCI based MSI interrupts - a couple of new irq chip drivers - the usual pile of fixlets and updates to irq chip drivers - preparatory changes for removal of the irq argument from interrupt flow handlers - preparatory changes to remove IRQF_VALID" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2 irqchip: Add documentation for the bcm2836 interrupt controller irqchip/bcm2835: Add support for being used as a second level controller irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ PCI: xilinx: Fix typo in function name irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance irqchip/gic: Only allow the primary GIC to set the CPU map PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove unicore32/irq: Prepare puv3_gpio_handler for irq argument removal tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal m68k/irq: Prepare irq handlers for irq argument removal C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal blackfin: Prepare irq handlers for irq argument removal arc/irq: Prepare idu_cascade_isr for irq argument removal sparc/irq: Use access helper irq_data_get_affinity_mask() sparc/irq: Use helper irq_data_get_irq_handler_data() parisc/irq: Use access helper irq_data_get_affinity_mask() mn10300/irq: Use access helper irq_data_get_affinity_mask() irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal ...
2015-09-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "The dominant change in this cycle was the continued work to isolate kernel drivers from MTRR legacies: this tree gets rid of all kernel internal driver interfaces to MTRRs (mostly by rewriting it to proper PAT interfaces), the only access left is the /proc/mtrr ABI. This work was done by Luis R Rodriguez. There's also some related PCI interface additions for which I've Cc:-ed Bjorn" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del() s390/io: Add pci_iomap_wc() and pci_iomap_wc_range() drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc() PCI: Add pci_iomap_wc() variants drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() PCI: Add pci_ioremap_wc_bar() x86/mm: Make kernel/check.c explicitly non-modular x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular x86/mm/pat: Add comments to cachemode translation tables arch/*/io.h: Add ioremap_uc() to all architectures drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc() drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC drivers/video/fbdev/atyfb: Clarify ioremap() base and length used drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default ...
2015-08-31Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The biggest change in this cycle is the rewrite of the main SMP load balancing metric: the CPU load/utilization. The main goal was to make the metric more precise and more representative - see the changelog of this commit for the gory details: 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") It is done in a way that significantly reduces complexity of the code: 5 files changed, 249 insertions(+), 494 deletions(-) and the performance testing results are encouraging. Nevertheless we need to keep an eye on potential regressions, since this potentially affects every SMP workload in existence. This work comes from Yuyang Du. Other changes: - SCHED_DL updates. (Andrea Parri) - Simplify architecture callbacks by removing finish_arch_switch(). (Peter Zijlstra et al) - cputime accounting: guarantee stime + utime == rtime. (Peter Zijlstra) - optimize idle CPU wakeups some more - inspired by Facebook server loads. (Mike Galbraith) - stop_machine fixes and updates. (Oleg Nesterov) - Introduce the 'trace_sched_waking' tracepoint. (Peter Zijlstra) - sched/numa tweaks. (Srikar Dronamraju) - misc fixes and small cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) sched/deadline: Fix comment in enqueue_task_dl() sched/deadline: Fix comment in push_dl_tasks() sched: Change the sched_class::set_cpus_allowed() calling context sched: Make sched_class::set_cpus_allowed() unconditional sched: Fix a race between __kthread_bind() and sched_setaffinity() sched: Ensure a task has a non-normalized vruntime when returning back to CFS sched/numa: Fix NUMA_DIRECT topology identification tile: Reorganize _switch_to() sched, sparc32: Update scheduler comments in copy_thread() sched: Remove finish_arch_switch() sched, tile: Remove finish_arch_switch sched, sh: Fold finish_arch_switch() into switch_to() sched, score: Remove finish_arch_switch() sched, avr32: Remove finish_arch_switch() sched, MIPS: Get rid of finish_arch_switch() sched, arm: Remove finish_arch_switch() sched/fair: Clean up load average references sched/fair: Provide runnable_load_avg back to cfs_rq sched/fair: Remove task and group entity load when they are dead sched/fair: Init cfs_rq's sched_entity load average ...
2015-08-25Merge tag 'v4.2-rc8' into x86/mm, before applying new changesIngo Molnar
2015-08-12Merge branch 'locking/arch-atomic' into locking/core, because it's ready for ↵Ingo Molnar
upstream Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-04sched, avr32: Remove finish_arch_switch()Peter Zijlstra
Fold the tracing hook into switch_to() in order to remove finish_arch_switch(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-30Merge branch 'linus' into irq/coreThomas Gleixner
Pull in upstream fixes before applying conflicting changes
2015-07-29arch/*/io.h: Add ioremap_uc() to all architecturesLuis R. Rodriguez
This adds ioremap_uc() only for architectures that do not include asm-generic.h/io.h as that already provides a default definition for them for both cases where you have CONFIG_MMU and you do not, and because of this, the number of architectures this patch address is less than the architectures that the ioremap_wt() patch addressed, "arch/*/io.h: Add ioremap_wt() to all architectures"). In order to reduce the number of architectures we have to modify by adding new architecture IO APIs we'll have to review the architectures in this patch, see why they can't add asm-generic.h/io.h or issues that would be created by doing so and then spread a consistent inclusion of this header towards the end of their own header. For instance arch/metag includes the asm-generic/io.h *before* the ioremap*() definitions, this should be the other way around but only once we have guard wrappers for the non-MMU case also for asm-generic/io.h. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Cc: Abhilash Kesavan <a.kesavan@samsung.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@suse.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Kyle McMartin <kyle@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-am33-list@redhat.com Cc: linux-arch@vger.kernel.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-sh@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20150728181713.GB30479@wotan.suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-27atomic: Provide atomic_{or,xor,and}Peter Zijlstra
Implement atomic logic ops -- atomic_{or,xor,and}. These will replace the atomic_{set,clear}_mask functions that are available on some archs. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-27avr32: Provide atomic_{or,xor,and}Peter Zijlstra
2015-07-27avr32: handle NULL as a valid clock objectAndy Shevchenko
Since NULL is used as valid clock object on optional clocks we have to handle this case in avr32 implementation as well. Fixes: e1824dfe0d8e (net: macb: Adjust tx_clk when link speed changes) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2015-07-26avr32/irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Link: http://lkml.kernel.org/r/20150713100606.527106283@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-26avr32/at32ap: Use irq_set_handler_locked()Thomas Gleixner
Use irq_set_handler_locked() as it avoids a redundant lookup of the irq descriptor. Search and replacement was done with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Link: http://lkml.kernel.org/r/20150713100606.448031045@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-26avr32/at32ap: Consolidate chained IRQ handler install/removeThomas Gleixner
Chained irq handlers usually set up handler data as well. We now have a function to set both under irq_desc->lock. Replace the two calls with one. Search and conversion was done with coccinelle. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Link: http://lkml.kernel.org/r/20150713100606.351640193@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-20AVR32/time: Migrate to new 'set-state' interfaceViresh Kumar
Migrate avr32 driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. We want to call cpu_idle_poll_ctrl() in shutdown only if we were in oneshot or resume state earlier. Create another variable to save this information and check that in shutdown callback. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-08Make asm/word-at-a-time.h available on all architecturesChris Metcalf
Added the x86 implementation of word-at-a-time to the generic version, which previously only supported big-endian. Omitted the x86-specific load_unaligned_zeropad(), which in any case is also not present for the existing BE-only implementation of a word-at-a-time, and is only used under CONFIG_DCACHE_WORD_ACCESS. Added as a "generic-y" to the Kbuilds of all architectures that didn't previously have it. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-07-01Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This contains: - a series of fixes for interrupt drivers to prevent a potential race when installing a chained interrupt handler - a fix for cpumask pointer misuse - a fix for using the wrong interrupt number from struct irq_data - removal of unused code and outdated comments - a few new helper functions which allow us to cleanup the interrupt handling code further in 4.3 I decided against doing the cleanup at the end of this merge window and rather do the preparatory steps for 4.3, so we can run the final ABI change at the end of the 4.3 merge window with less risk" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked() genirq: Implement irq_set_handler_locked()/irq_set_chip_handler_name_locked() genirq: Introduce helper irq_desc_get_irq() genirq: Remove irq_node() genirq: Clean up outdated comments related to include/linux/irqdesc.h mn10300: Fix incorrect use of irq_data->affinity MIPS/ralink: Fix race in installing chained IRQ handler MIPS/pci: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler m68k/psc: Fix race in installing chained IRQ handler avr32/at32ap: Fix race in installing chained IRQ handler sh/intc: Fix race in installing chained IRQ handler sh/intc: Fix potential race in installing chained IRQ handler pinctrl/sun4i: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/exynos: Fix race in installing chained IRQ handler pinctrl/st: Fix race in installing chained IRQ handler pinctrl/adi2: Fix race in installing chained IRQ handler ...
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25avr32: use for_each_sg()Akinobu Mita
This replaces the plain loop over the sglist array with for_each_sg() macro which consists of sg_next() function calls. Since avr32 doesn't select ARCH_HAS_SG_CHAIN, it is not necessary to use for_each_sg() in order to loop over each sg element. But this can help find problems with drivers that do not properly initialize their sg tables when CONFIG_DEBUG_SG is enabled. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-25avr32/at32ap: Fix race in installing chained IRQ handlerThomas Gleixner
Fix a race where a pending interrupt could be received and the handler called before the handler's data has been setup, by converting to irq_set_chained_handler_and_data(). Search and conversion was done with coccinelle: @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); | -irq_set_chained_handler(E1, E3); ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); ... | -irq_set_chained_handler(E1, E3); ... ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-22Merge branch 'x86-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 core updates from Ingo Molnar: "There were so many changes in the x86/asm, x86/apic and x86/mm topics in this cycle that the topical separation of -tip broke down somewhat - so the result is a more traditional architecture pull request, collected into the 'x86/core' topic. The topics were still maintained separately as far as possible, so bisectability and conceptual separation should still be pretty good - but there were a handful of merge points to avoid excessive dependencies (and conflicts) that would have been poorly tested in the end. The next cycle will hopefully be much more quiet (or at least will have fewer dependencies). The main changes in this cycle were: * x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas Gleixner) - This is the second and most intrusive part of changes to the x86 interrupt handling - full conversion to hierarchical interrupt domains: [IOAPIC domain] ----- | [MSI domain] --------[Remapping domain] ----- [ Vector domain ] | (optional) | [HPET MSI domain] ----- | | [DMAR domain] ----------------------------- | [Legacy domain] ----------------------------- This now reflects the actual hardware and allowed us to distangle the domain specific code from the underlying parent domain, which can be optional in the case of interrupt remapping. It's a clear separation of functionality and removes quite some duct tape constructs which plugged the remap code between ioapic/msi/hpet and the vector management. - Intel IOMMU IRQ remapping enhancements, to allow direct interrupt injection into guests (Feng Wu) * x86/asm changes: - Tons of cleanups and small speedups, micro-optimizations. This is in preparation to move a good chunk of the low level entry code from assembly to C code (Denys Vlasenko, Andy Lutomirski, Brian Gerst) - Moved all system entry related code to a new home under arch/x86/entry/ (Ingo Molnar) - Removal of the fragile and ugly CFI dwarf debuginfo annotations. Conversion to C will reintroduce many of them - but meanwhile they are only getting in the way, and the upstream kernel does not rely on them (Ingo Molnar) - NOP handling refinements. (Borislav Petkov) * x86/mm changes: - Big PAT and MTRR rework: making the code more robust and preparing to phase out exposing direct MTRR interfaces to drivers - in favor of using PAT driven interfaces (Toshi Kani, Luis R Rodriguez, Borislav Petkov) - New ioremap_wt()/set_memory_wt() interfaces to support Write-Through cached memory mappings. This is especially important for good performance on NVDIMM hardware (Toshi Kani) * x86/ras changes: - Add support for deferred errors on AMD (Aravind Gopalakrishnan) This is an important RAS feature which adds hardware support for poisoned data. That means roughly that the hardware marks data which it has detected as corrupted but wasn't able to correct, as poisoned data and raises an APIC interrupt to signal that in the form of a deferred error. It is the OS's responsibility then to take proper recovery action and thus prolonge system lifetime as far as possible. - Add support for Intel "Local MCE"s: upcoming CPUs will support CPU-local MCE interrupts, as opposed to the traditional system- wide broadcasted MCE interrupts (Ashok Raj) - Misc cleanups (Borislav Petkov) * x86/platform changes: - Intel Atom SoC updates ... and lots of other cleanups, fixlets and other changes - see the shortlog and the Git log for details" * 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits) x86/hpet: Use proper hpet device number for MSI allocation x86/hpet: Check for irq==0 when allocating hpet MSI interrupts x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail genirq: Prevent crash in irq_move_irq() genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain iommu, x86: Properly handle posted interrupts for IOMMU hotplug iommu, x86: Provide irq_remapping_cap() interface iommu, x86: Setup Posted-Interrupts capability for Intel iommu iommu, x86: Add cap_pi_support() to detect VT-d PI capability iommu, x86: Avoid migrating VT-d posted interrupts iommu, x86: Save the mode (posted or remapped) of an IRTE iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip iommu: dmar: Provide helper to copy shared irte fields iommu: dmar: Extend struct irte for VT-d Posted-Interrupts iommu: Add new member capability to struct irq_remap_ops x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry() ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-06-22Merge branches 'x86/apic', 'x86/asm', 'x86/mm' and 'x86/platform' into ↵Ingo Molnar
x86/core, to merge last updates Signed-off-by: Ingo Molnar <mingo@kernel.org>
