commit 5c02a4206538da12c040b51778d310df84c6bf6c upstream.
Since NULL is used as valid clock object on optional clocks we have to handle
this case in avr32 implementation as well.
Fixes: e1824dfe0d8e (net: macb: Adjust tx_clk when link speed changes)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
Almost all arches define ELF_ET_DYN_BASE as 2/3 of TASK_SIZE.
Though it seems that some architectures do this in a wrong way.
The problem is that 2*TASK_SIZE may overflow 32-bits so
the real ELF_ET_DYN_BASE becomes wrong.
Fix this overflow by dividing TASK_SIZE prior to multiplying:
(TASK_SIZE / 3 * 2)
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic uaccess.h cleanup from Arnd Bergmann:
"Like in 3.19, I once more have a multi-stage cleanup for one
asm-generic header file, this time the work was done by Michael
Tsirkin and cleans up the uaccess.h file in asm-generic, as well as
all architectures for which the respective maintainers did not pick up
his patches directly"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (37 commits)
sparc32: nocheck uaccess coding style tweaks
sparc64: nocheck uaccess coding style tweaks
xtensa: macro whitespace fixes
sh: macro whitespace fixes
parisc: macro whitespace fixes
m68k: macro whitespace fixes
m32r: macro whitespace fixes
frv: macro whitespace fixes
cris: macro whitespace fixes
avr32: macro whitespace fixes
arm64: macro whitespace fixes
arm: macro whitespace fixes
alpha: macro whitespace fixes
blackfin: macro whitespace fixes
sparc64: uaccess_64 macro whitespace fixes
sparc32: uaccess_32 macro whitespace fixes
avr32: whitespace fix
sh: fix put_user sparse errors
metag: fix put_user sparse errors
ia64: fix put_user sparse errors
Pull dmaengine updates from Vinod Koul:
"This update brings:
- the big cleanup up by Maxime for device control and slave
capabilities. This makes the API much cleaner.
- new IMG MDC driver by Andrew
- new Renesas R-Car Gen2 DMA Controller driver by Laurent along with
bunch of fixes on rcar drivers
- odd fixes and updates spread over driver"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (130 commits)
dmaengine: pl330: add DMA_PAUSE feature
dmaengine: pl330: improve pl330_tx_status() function
dmaengine: rcar-dmac: Disable channel 0 when using IOMMU
dmaengine: rcar-dmac: Work around descriptor mode IOMMU errata
dmaengine: rcar-dmac: Allocate hardware descriptors with DMAC device
dmaengine: rcar-dmac: Fix oops due to unintialized list in error ISR
dmaengine: rcar-dmac: Fix spinlock issues in interrupt
dmaenegine: edma: fix sparse warnings
dmaengine: rcar-dmac: Fix uninitialized variable usage
dmaengine: shdmac: extend PM methods
dmaengine: shdmac: use SET_RUNTIME_PM_OPS()
dmaengine: pl330: fix bug that cause start the same descs in cyclic
dmaengine: at_xdmac: allow muliple dwidths when doing slave transfers
dmaengine: at_xdmac: simplify channel configuration stuff
dmaengine: at_xdmac: introduce save_cc field
dmaengine: at_xdmac: wait for in-progress transaction to complete after pausing a channel
ioat: fail self-test if wait_for_completion times out
dmaengine: dw: define DW_DMA_MAX_NR_MASTERS
dmaengine: dw: amend description of dma_dev field
dmatest: move src_off, dst_off, len inside loop
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32
Pull AVR32 update from Hans-Christian Egtvedt.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32:
avr32: update all default configurations
avr32: remove fake at91 cpu identification
avr32: wire up missing syscalls
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
This patch runs all the default configurations through make
silentoldconfig and make savedefconfig to rinse out outdated kconfig
entries.
for config in arch/avr32/configs/*defconfig; do
make ARCH=avr32 `basename $config`
make ARCH=avr32 silentoldconfig
make ARCH=avr32 savedefconfig
cp defconfig $config
done
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
cpu_is_at91* are not used in any driver outside mach-at91. Remove those
useless definitions.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch adds a bunch of missing syscalls to AVR32:
__NR_pread64
__NR_pwrite64
__NR_timerfd_create
__NR_fallocate
__NR_timerfd_settime
__NR_timerfd_gettime
__NR_signalfd4
__NR_eventfd2
__NR_epoll_create1
__NR_dup3
__NR_pipe2
__NR_inotify_init1
__NR_preadv
__NR_pwritev
__NR_rt_tgsigqueueinfo
__NR_perf_event_open
__NR_recvmmsg
__NR_fanotify_init
__NR_fanotify_mark
__NR_prlimit64
__NR_name_to_handle_at
__NR_open_by_handle_at
__NR_clock_adjtime
__NR_syncfs
__NR_sendmmsg
__NR_process_vm_readv
__NR_process_vm_writev
__NR_kcmp
__NR_finit_module
__NR_sched_setattr
__NR_sched_getattr
__NR_renameat2
__NR_seccomp
__NR_getrandom
__NR_memfd_create
__NR_bpf
__NR_execveat
On AVR32, all parameters beyond the 5th are passed on the stack. System
calls don't use the stack -- they borrow a callee-saved register
instead. This means that syscalls that take 6 parameters must be called
through a stub that pushes the last parameter on the stack.
This relates to syscall fallocate, fanotify_mark, process_vm_readv, and
process_vm_writev.
Instead of using magic number in the code the patch provides
DW_DMA_MAX_NR_MASTERS constant.
While here, restrict the reading of data width array by amount of the actual
number of AHB masters.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
Archs have been abusing module_free() to clean up their arch-specific
allocations. Since module_free() is also (ab)used by BPF and trace code,
let's keep it to simple allocations, and provide a hook called before
that.
This means that avr32, ia64, parisc and s390 no longer need to implement
their own module_free() at all. avr32 doesn't need module_finalize()
either.
Cc: linux-ia64@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-s390@vger.kernel.org
While working on arch/avr32/include/asm/uaccess.h, I noticed
that some macros within this header are made harder to read because they
violate a coding style rule: space is missing after comma.
Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Align using tabs to make code prettier.
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
Fix that up using __force.
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
introduce new setsockopt() command:
setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd))
where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...)
and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER
setsockopt() calls bpf_prog_get() which increments refcnt of the program,
so it doesn't get unloaded while socket is using the program.
The same eBPF program can be attached to multiple sockets.
User task exit automatically closes socket which calls sk_filter_uncharge()
which decrements refcnt of eBPF program
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
Use the generic platform_data header file instead of mach/atmel-mci.h
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
Use the much more reader friendly ACCESS_ONCE() instead of the cast to volatile.
This is purely a stylistic change.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Link: http://lkml.kernel.org/r/1411482607-20948-1-git-send-email-bobby.prani@gmail.com
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Instead of exposing the possibility to set DMA registers CFG_HI and CFG_LO
strict user to provide handshake interfaces explicitly.
In future we are going to remove the defaults of AHB masters from dw_dmac
driver. It means each user have to supply proper source and destination masters
by itself explicitly.
There is a common storage for platform data related structures and definitions
inside kernel source tree. The patch moves file from include/linux to
include/linux/platform_data and renames it acoordingly. The users are also
updated.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
[For the arch/avr32/.* and .*sound/atmel.*]
Replace the single use of __get_cpu_var in avr32 with
__this_cpu_write.
Signed-off-by: Christoph Lameter <cl@linux.com>
Many of the atomic op implementations are the same except for one
instruction; fold the lot into a few CPP macros and reduce LoC.
This also prepares for easy addition of new ops.
Requires the asm_op because of eor.
AVR32 is a bit special in that its ADD/SUB instructions are not
symmetric. Its SUB instruction allows for an 21bit immediate.
Link: http://lkml.kernel.org/r/20140531141445.GD16155@laptop.programming.kicks-ass.net
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
Pull ARM SoC driver changes from Olof Johansson:
"A handful of driver-related changes. We've had a bunch of them going
in through other branches as well, so it's only a part of what we
really have this release.
Larger pieces are:
- Removal of a now unused PWM driver for atmel
[ This includes AVR32 changes that have been appropriately acked ]
- Performance counter support for the arm CCN interconnect
- OMAP mailbox driver cleanups and consolidation
- PCI and SATA PHY drivers for SPEAr 13xx platforms
- Redefinition (with backwards compatibility!) of PCI DT bindings for
Tegra to better model regulators/power"
Note: this merge also fixes up the semantic conflict with the new
calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy:
core: Let node ptr of PHY point to PHY and not of PHY provider") that
came in through Greg's USB tree.
Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through
the next tree.
* tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
bus: arm-ccn: Fix error handling at event allocation
mailbox/omap: add a parent structure for every IP instance
mailbox/omap: remove the private mailbox structure
mailbox/omap: consolidate OMAP mailbox driver
mailbox/omap: simplify the fifo assignment by using macros
mailbox/omap: remove omap_mbox_type_t from mailbox ops
mailbox/omap: remove OMAP1 mailbox driver
mailbox/omap: use devm_* interfaces
bus: ARM CCN: add PERF_EVENTS dependency
bus: ARM CCN PMU driver
PCI: spear: Remove spear13xx_pcie_remove()
PCI: spear: Fix Section mismatch compilation warning for probe()
ARM: tegra: Remove legacy PCIe power supply properties
PCI: tegra: Remove deprecated power supply properties
PCI: tegra: Implement accurate power supply scheme
ARM: SPEAr13xx: Update defconfigs
ARM: SPEAr13xx: Add pcie and miphy DT nodes
ARM: SPEAr13xx: Add bindings and dt node for misc block
ARM: SPEAr13xx: Fix static mapping table
phy: Add drivers for PCIe and SATA phy on SPEAr13xx
Pull avr32 fix from Hans-Christian Egtvedt.
avr32: fix error return code
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use sigsp() instead of the open coded variant.
Use the more generic functions get_signal() signal_setup_done()
for signal delivery.
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-am33-list@redhat.com
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-sh@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
Now that all boards have switched to the generic PWM framework, update the
defconfigs to use it.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Switch to the generic pwm_bl driver instead of atmel-pwm-bl.
Switch to the generic leds_pwm driver instead of leds-atmel-pwm.
Switch to the pwm/pwm-atmel driver instead of misc/atmel_pwm
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
It no longer occurs in Kconfig.
USB: remove CONFIG_USB_DEVICEFS(fb28d58b) leaked remove defconfig.
Signed-off-by: Naoki MATSUMOTO <nekomatu+linux@gmail.com>
AVR32's mb() implementation is a compiler barrier(), therefore it all
doesn't matter, fully rely on whatever asm-generic/barrier.h
generates.
Link: http://lkml.kernel.org/n/tip-8gow97a7mapmnec0pvf729pj@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver updates for 3.15-rc1.
Lots of various things here, including the new mcb driver subsystem.
All of these have been in linux-next for a while"
* tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits)
extcon: Move OF helper function to extcon core and change function name
extcon: of: Remove unnecessary function call by using the name of device_node
extcon: gpio: Use SIMPLE_DEV_PM_OPS macro
extcon: palmas: Use SIMPLE_DEV_PM_OPS macro
mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro
mei: amthif: fix checkpatch error
mei: client.h fix checkpatch errors
mei: use cl_dbg where appropriate
mei: fix Unnecessary space after function pointer name
mei: report consistently copy_from/to_user failures
mei: drop pr_fmt macros
mei: make me hw headers private to me hw.
mei: fix memory leak of pending write cb objects
mei: me: do not reset when less than expected data is received
drivers: mcb: Fix build error discovered by 0-day bot
cs5535-mfgpt: Simplify dependencies
spmi: pm: drop bus-level PM suspend/resume routines
spmi: pmic_arb: make selectable on ARCH_QCOM
Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle
pch_phub: Report error writing MAC back to user
