path: root/arch/avr32
2013-10-13avr32: fix clockevents kernel warningGabor Juhos
commit 1b0135b5e20c56b2edae29e92b91c0b12c983432 upstream. Since commit 01426478df3a8791ff5c8b6b82d409e699cfaf38 (avr32: Use generic idle loop) the kernel throws the following warning on avr32: WARNING: at 900322e4 [verbose debug info unavailable] Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 3.12.0-rc2 #117 task: 901c3ecc ti: 901c0000 task.ti: 901c0000 PC is at cpu_idle_poll_ctrl+0x1c/0x38 LR is at comparator_mode+0x3e/0x40 pc : [<900322e4>] lr : [<90014882>] Not tainted sp : 901c1f74 r12: 00000000 r11: 901c74a0 r10: 901d2510 r9 : 00000001 r8 : 901db4de r7 : 901c74a0 r6 : 00000001 r5 : 00410020 r4 : 901db574 r3 : 00410024 r2 : 90206fe0 r1 : 00000000 r0 : 007f0000 Flags: qvnzc Mode bits: hjmde....G CPU Mode: Supervisor Call trace: [<90039ede>] clockevents_set_mode+0x16/0x2e [<90039f00>] clockevents_shutdown+0xa/0x1e [<9003a078>] clockevents_exchange_device+0x58/0x70 [<9003a78c>] tick_check_new_device+0x38/0x54 [<9003a1a2>] clockevents_register_device+0x32/0x90 [<900035c4>] time_init+0xa8/0x108 [<90000520>] start_kernel+0x128/0x23c When the 'avr32_comparator' clockevent device is registered, the clockevent core sets the mode of that clockevent device to CLOCK_EVT_MODE_SHUTDOWN. Due to this, the 'comparator_mode' function calls the 'cpu_idle_poll_ctrl' to disables idle poll. This results in the aforementioned warning because the polling is not enabled yet. Change the code to only disable idle poll if it is enabled by the same function to avoid the warning. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32 Pull AVR32 update from Hans-Christian Egtvedt: "wow, it has gone 10 releases since my last request :(" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32: avr32: fix building warnings caused by redefinitions of HZ avr32: fix relocation check for signed 18-bit offset avr32: move NODES_SHIFT into Kconfig and delete numnodes.h
2013-05-22avr32: fix building warnings caused by redefinitions of HZJiang Liu
As suggested by David Howells <dhowells@redhat.com>, use asm-generic/param.h and uapi/asm-generic/param.h for AVR32. It also fixes building warnings caused by redefinitions of HZ: In file included from /ws/linux/kernel/linux.git/include/uapi/linux/param.h:4, from include/linux/timex.h:63, from include/linux/jiffies.h:8, from include/linux/ktime.h:25, from include/linux/timer.h:5, from include/linux/workqueue.h:8, from include/linux/srcu.h:34, from include/linux/notifier.h:15, from include/linux/memory_hotplug.h:6, from include/linux/mmzone.h:777, from include/linux/gfp.h:4, from arch/avr32/mm/init.c:10: /ws/linux/kernel/linux.git/arch/avr32/include/asm/param.h:6:1: warning: "HZ" redefined In file included from /ws/linux/kernel/linux.git/arch/avr32/include/asm/param.h:4, from /ws/linux/kernel/linux.git/include/uapi/linux/param.h:4, from include/linux/timex.h:63, from include/linux/jiffies.h:8, from include/linux/ktime.h:25, from include/linux/timer.h:5, from include/linux/workqueue.h:8, from include/linux/srcu.h:34, from include/linux/notifier.h:15, from include/linux/memory_hotplug.h:6, from include/linux/mmzone.h:777, from include/linux/gfp.h:4, from arch/avr32/mm/init.c:10: /ws/linux/kernel/linux.git/arch/avr32/include/uapi/asm/param.h:6:1: warning: this is the location of the previous definition Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2013-05-13avr32: fix relocation check for signed 18-bit offsetHans-Christian Egtvedt
Caught by static code analysis by David. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: stable@kernel.org
2013-05-13avr32: move NODES_SHIFT into Kconfig and delete numnodes.hHans-Christian Egtvedt
This patch moves the NODES_SHIFT symbol into Kconfig to synchronize AVR32 architecture with the current kernel. The global header files do longer use the value from numnodes.h. See commit c80d79d746cc48bd94b0ce4f6d4f3c90cd403aaf for details. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-04Merge tag 'mmc-updates-for-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC update from Chris Ball: "MMC highlights for 3.10: Core: - Introduce MMC_CAP2_NO_PRESCAN_POWERUP to allow skipping mmc_power_up() at boot/initialization time if it's already happened, for performance (faster boot time) reasons. - Fix a bit width test failure that resulted in old eMMC cards being put into 1-bit mode when 4-bit mode was available. - Expose fwrev/hwrev for MMCv4 parts. - Improve card removal logic in the case where the card's removed slowly; we were missing card removal events if the card retained contact with the slot pads for long enough to reply to a CMD13 while being removed. Drivers: - davinci_mmc: Support using PIO instead of DMA. - dw_mmc: Add support for Exynos4412. - mxcmmc: DT support, use slot-gpio API. - mxs-mmc: Add broken-cd/cd-inverted/non-removable DT property support. - sdhci-sirf: New sdhci-pltfm driver for CSR SiRF SoCs: SiRFprimaII: unicore ARM Cortex-A9 SiRFatlas6: unicore ARM Cortex-A9 SiRFmarco: dual core ARM Cortex-A9 SMP - sdhci-tegra: Add support for Tegra114 platforms, use mmc_of_parse()" * tag 'mmc-updates-for-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: sdhci-tegra: fix MODULE_DEVICE_TABLE mmc: core: fix init controller performance regression, updated patch mmc: mxcmmc: enable DMA support on mpc512x mmc: mxcmmc: constify mxcmci_devtype mmc: mxcmmc: use slot-gpio API for write-protect detection mmc: mxcmmc: add mpc512x SDHC support mmc: mxcmmc: fix race conditions for host->req and host->data access mmc: mxcmmc: DT support mmc: dw_mmc: let device core setup the default pin configuration mmc: mxs-mmc: add broken-cd property mmc: mxs-mmc: add non-removable property mmc: mxs-mmc: add cd-inverted property mmc: core: call pm_runtime_put_noidle in pm_runtime_get_sync failed case mmc: mxcmmc: Fix bug when card is present during boot mmc: core: fix performance regression initializing MMC host controllers Revert "mmc: core: wait while adding MMC host to ensure root mounts successfully" mmc: atmel-mci: pio hang on block errors mmc: core: Fix bit width test failing on old eMMC cards mmc: dw_mmc: Use pr_info instead of printk mmc: dw_mmc: Check return value of regulator_enable ...
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge third batch of fixes from Andrew Morton: "Most of the rest. I still have two large patchsets against AIO and IPC, but they're a bit stuck behind other trees and I'm about to vanish for six days. - random fixlets - inotify - more of the MM queue - show_stack() cleanups - DMI update - kthread/workqueue things - compat cleanups - epoll udpates - binfmt updates - nilfs2 - hfs - hfsplus - ptrace - kmod - coredump - kexec - rbtree - pids - pidns - pps - semaphore tweaks - some w1 patches - relay updates - core Kconfig changes - sysrq tweaks" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) Documentation/sysrq: fix inconstistent help message of sysrq key ethernet/emac/sysrq: fix inconstistent help message of sysrq key sparc/sysrq: fix inconstistent help message of sysrq key powerpc/xmon/sysrq: fix inconstistent help message of sysrq key ARM/etm/sysrq: fix inconstistent help message of sysrq key power/sysrq: fix inconstistent help message of sysrq key kgdb/sysrq: fix inconstistent help message of sysrq key lib/decompress.c: fix initconst notifier-error-inject: fix module names in Kconfig kernel/sys.c: make prctl(PR_SET_MM) generally available UAPI: remove empty Kbuild files menuconfig: print more info for symbol without prompts init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display kconfig menu: move Virtualization drivers near other virtualization options Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS relay: use macro PAGE_ALIGN instead of FIX_SIZE kernel/relay.c: move FIX_SIZE macro into relay.c kernel/relay.c: remove unused function argument actor drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave() drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave() ...
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge tag 'pm+acpi-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael J Wysocki: - ARM big.LITTLE cpufreq driver from Viresh Kumar. - exynos5440 cpufreq driver from Amit Daniel Kachhap. - cpufreq core cleanup and code consolidation from Viresh Kumar and Stratos Karafotis. - cpufreq scalability improvement from Nathan Zimmer. - AMD "frequency sensitivity feedback" powersave bias for the ondemand cpufreq governor from Jacob Shin. - cpuidle code consolidation and cleanups from Daniel Lezcano. - ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano. - ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto. - ACPI core updates related to hotplug from Toshi Kani, Paul Bolle, Yasuaki Ishimatsu, and Rafael J Wysocki. - Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from Rafael J Wysocki and Andy Shevchenko. * tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits) cpufreq: Revert incorrect commit 5800043 cpufreq: MAINTAINERS: Add co-maintainer cpuidle: add maintainer entry ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points ARM: s3c64xx: cpuidle: use init/exit common routine cpufreq: pxa2xx: initialize variables ACPI: video: correct acpi_video_bus_add error processing SH: cpuidle: use init/exit common routine ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y ACPI: Fix wrong parameter passed to memblock_reserve cpuidle: fix comment format pnp: use %*phC to dump small buffers isapnp: remove debug leftovers ARM: imx: cpuidle: use init/exit common routine ARM: davinci: cpuidle: use init/exit common routine ARM: kirkwood: cpuidle: use init/exit common routine ARM: calxeda: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine for tegra3 ARM: tegra: cpuidle: use init/exit common routine for tegra2 ARM: OMAP4: cpuidle: use init/exit common routine ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29mm/avr32: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-28Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (57 commits) cpufreq: MAINTAINERS: Add co-maintainer cpufreq: pxa2xx: initialize variables ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y cpufreq: cpu0: Put cpu parent node after using it cpufreq: ARM big LITTLE: Adapt to latest cpufreq updates cpufreq: ARM big LITTLE: put DT nodes after using them cpufreq: Don't call __cpufreq_governor() for drivers without target() cpufreq: exynos5440: Protect OPP search calls with RCU lock cpufreq: dbx500: Round to closest available freq cpufreq: Call __cpufreq_governor() with correct policy->cpus mask cpufreq / intel_pstate: Optimize intel_pstate_set_policy cpufreq: OMAP: instantiate omap-cpufreq as a platform_driver arm: exynos: Enable OPP library support for exynos5440 cpufreq: exynos: Remove error return even if no soc is found cpufreq: exynos: Add cpufreq driver for exynos5440 cpufreq: AMD "frequency sensitivity feedback" powersave bias for ondemand governor cpufreq: ondemand: allow custom powersave_bias_target handler to be registered cpufreq: convert cpufreq_driver to using RCU cpufreq: powerpc/platforms/cell: move cpufreq driver to drivers/cpufreq cpufreq: sparc: move cpufreq driver to drivers/cpufreq ... Conflicts: MAINTAINERS (with commit a8e39c3 from pm-cpuidle) drivers/cpufreq/cpufreq_governor.h (with commit beb0ff3)
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17avr32: fix build error in atstk1006_defconfigJosh Wu
fixed the following compile error when use avr32 atstk1006_defconfig: drivers/mtd/nand/atmel_nand.c: In function 'pmecc_err_location': drivers/mtd/nand/atmel_nand.c:639: error: implicit declaration of function 'writel_relaxed' which was introduced by commit 1c7b874d33b4 ("mtd: at91: atmel_nand: add Programmable Multibit ECC controller support"). The PMECC for nand flash code uses writel_relaxed(). But in avr32, there is no macro "writel_relaxed" defined. This patch add writex_relaxed macro definitions. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Havard Skinnemoen <havard@skinnemoen.net> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17idle: Remove GENERIC_IDLE_LOOP config switchThomas Gleixner
All archs are converted over. Remove the config switch and the fallback code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-16Remove GENERIC_GPIO config optionAlexandre Courbot
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code and all driver code has been switch to depend on GPIOLIB. It is thus safe to have GENERIC_GPIO removed. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2013-04-10cpufreq: AVR32: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of AVR32 based at32ap platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-08Merge tag 'vt8500/pinctrl' of git://server.prisktech.co.nz/git/linuxwmt into ↵Arnd Bergmann
next/drivers From Tony Prisk <linux@prisktech.co.nz>: arm: vt8500: Add pinctrl driver for arch-vt8500 This series adds support for the pinctrl/gpio module on all arch-vt8500 supported SoCs. As part of the review process, some tidy up is also done to drivers/of/base.c to remove some code that is being constantly duplicated. Also, a patch for the bcm2835 pinctrl driver is included to take advantage of the new of/base.c code. * tag 'vt8500/pinctrl' of git://server.prisktech.co.nz/git/linuxwmt: (606 commits) pinctrl: bcm2835: make use of of_property_read_u32_index() gpio: vt8500: Remove arch-vt8500 gpio driver arm: vt8500: Remove gpio devicetree nodes arm: dts: vt8500: Update Wondermedia SoC dtsi files for pinctrl driver pinctrl: gpio: vt8500: Add pincontrol driver for arch-vt8500 arm: vt8500: Increase available GPIOs on arch-vt8500 of: Remove duplicated code for validating property and value of: Add support for reading a u32 from a multi-value property. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-08avr32: Use generic idle loopThomas Gleixner
Also replace the idle poll enforcement by the generic functionality. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Link: http://lkml.kernel.org/r/20130321215233.950290809@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-02cpufreq: Notify all policy->cpus in cpufreq_notify_transition()Viresh Kumar
policy->cpus contains all online cpus that have single shared clock line. And their frequencies are always updated together. Many SMP system's cpufreq drivers take care of this in individual drivers but the best place for this code is in cpufreq core. This patch modifies cpufreq_notify_transition() to notify frequency change for all cpus in policy->cpus and hence updates all users of this API. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-31net: add option to enable error queue packets waking selectKeller, Jacob E
Currently, when a socket receives something on the error queue it only wakes up the socket on select if it is in the "read" list, that is the socket has something to read. It is useful also to wake the socket if it is in the error list, which would enable software to wait on error queue packets without waking up for regular data on the socket. The main use case is for receiving timestamped transmit packets which return the timestamp to the socket via the error queue. This enables an application to select on the socket for the error queue only instead of for the regular traffic. -v2- * Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file * Modified every socket poll function that checks error queue Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Matthew Vick <matthew.vick@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-22mmc: at91/avr32/atmel-mci: fix DMA-channel leak on module unloadJohan Hovold
Fix regression introduced by commit 796211b7953 ("mmc: atmel-mci: add pdc support and runtime capabilities detection") which removed the need for CONFIG_MMC_ATMELMCI_DMA but kept the Kconfig-entry as well as the compile guards around dma_release_channel() in remove(). Consequently, DMA is always enabled (if supported), but the DMA-channel is not released on module unload unless the DMA-config option is selected. Remove the no longer used CONFIG_MMC_ATMELMCI_DMA option completely. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-20avr32: default GENERIC_GPIO to falseAlexandre Courbot
This will help removing the GENERIC_GPIO option. GPIO access is done through gpiolib, which selects GENERIC_GPIO anyway. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-13ARM: at91/avr32/atmel_lcdfb: add platform device-id tableJohan Hovold
Add platform device-id table in order to identify the controller and determine its configuration. The currently used configuration parameters are: have_alt_pixclock - SOC uses an alternate pixel-clock calculation formula (at91sam9g45 non-ES) have_hozval - SOC has a HOZVAL field in LCDFRMCFG which is used to determine the linesize for STN displays (at91sam9261, at921sam9g10 and at32ap) have_intensity_bit - SOC uses IBGR:555 rather than BGR:565 16-bit pixel layout (at91sam9261, at91sam9263 and at91sam9rl) This allows us to remove all the remaining uses of cpu_is macros from the driver. Tested on at91sam9263 and at91sam9g45, compile-tested for other AT91-SOCs, and untested for AVR32. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-13ARM: at91/avr32/atmel_lcdfb: add bus-clock entryJohan Hovold
Add hclk entry for the atmel_lcdfb bus clock. On at91sam9261, at91sam9g10 and at32ap the bus clock has to be enabled as well as the peripheral clock. Add the appropriate lookup entries to these SOCs and fake clocks to the SOCs that do not use it. This allows us to get rid of the conditional enabling of the clocks in the driver which relied on the cpu_is macros. Tested on at91sam9263 and at91sam9g45, compile-tested for other AT91-SOCs, and untested for AVR32. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03consolidate cond_syscall and SYSCALL_ALIAS declarationsAl Viro
take them to asm/linkage.h, with default in linux/linkage.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26default SET_PERSONALITY() in linux/elf.hAl Viro
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Synchronize with 'net' in order to sort out some l2tp, wireless, and ipv6 GRE fixes that will be built on top of in 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-03avr32: switch to generic sigaltstackAl Viro
2013-02-03consolidate kernel-side struct sigaction declarationsAl Viro
2013-02-03consolidate declarations of k_sigactionAl Viro
Only alpha and sparc are unusual - they have ka_restorer in it. And nobody needs that exposed to userland. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-29avr32: Provide dma_mmap_coherent() and dma_get_sgtable()Geert Uytterhoeven
avr32/allmodconfig: drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_mmap’: drivers/media/v4l2-core/videobuf2-dma-contig.c:204: error: implicit declaration of function ‘dma_mmap_coherent’ drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_get_base_sgt’: drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function ‘dma_get_sgtable’ For architectures using dma_map_ops, dma_mmap_coherent() and dma_get_sgtable() are provided in <asm-generic/dma-mapping-common.h>. Avr32 does not use dma_map_ops, hence it should implement them as inline stubs using dma_common_mmap() and dma_common_get_sgtable(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-01-23soreuseport: infrastructureTom Herbert
Definitions and macros for implementing soreusport. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21taint: add explicit flag to show whether lock dep is still OK.Rusty Russell
Fix up all callers as they were before, with make one change: an unsigned module taints the kernel, but doesn't turn off lockdep. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-17sk-filter: Add ability to lock a socket filter programVincent Bernat
While a privileged program can open a raw socket, attach some restrictive filter and drop its privileges (or send the socket to an unprivileged program through some Unix socket), the filter can still be removed or modified by the unprivileged program. This commit adds a socket option to lock the filter (SO_LOCK_FILTER) preventing any modification of a socket filter program. This is similar to OpenBSD BIOCLOCK ioctl on bpf sockets, except even root is not allowed change/drop the filter. The state of the lock can be read with getsockopt(). No error is triggered if the state is not changed. -EPERM is returned when a user tries to remove the lock or to change/remove the filter while the lock is active. The check is done directly in sk_attach_filter() and sk_detach_filter() and does not affect only setsockopt() syscall. Signed-off-by: Vincent Bernat <bernat@luffy.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-03ARCH: drivers remove __dev* attributes.Greg Kroah-Hartman
This fixes up all of the smaller arches that had __dev* markings for their platform-specific drivers. CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Bob Liu <lliubbo@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Myron Stowe <myron.stowe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19unify SS_ONSTACK/SS_DISABLE definitionsAl Viro
2012-12-19missing user_stack_pointer() instancesAl Viro
for the architectures that have usp in pt_regs and do not have user_stack_pointer() already defined. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
