Re-architect how we save/restore the gpio/port logic that only pertains
to bf538/bf539 parts by pulling it out of the core code paths and pushing
it out to bf538-specific locations.
Have the logic that uses peripheral interrupt blocks key off of pint
defines rather than CPU names so that things are generalized across
families.
These defines don't accomplish much as GPIO_# is the same thing as #.
Each CPU already provides helpful symbolic defines like GPIO_<PIN>
which everyone uses, so just punt these # ones.
The GPIO API was extended recently to include debounce functions, but
since the on-chip Blackfin GPIO modules don't support this stuff, make
a stub in the non-GPIOLIB case so drivers build properly.
Random tabs instead of spaces, mixes of the two, and unicode spaces
instead of ascii spaces.
This patch removes a custom GPIO wakeup API which allowed GPIOs to act
as wakeup sources, which are not configured as Interrupts.
This API is a leftover from the time before irq_wake was established.
From now on people must use enable_irq_wake(GPIO_IRQx) and the GPIO in
question needs to be configured as Interrupt.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
This makes it possible to support IRQs coming from off-chip GPIO
controllers.
Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com>
The GPIOs on ports C/D/E on the BF538/BF539 do not behave the same way as
the other ports on the part and the same way as all other Blackfin parts.
The MMRs are programmed slightly different and they cannot be used to
generate interrupts or wakeup a sleeping system. Since these guys don't
fit into the existing code, create a simple gpiolib driver for them.
Bill Gatliff & David Brownell pointed out we were missing some
copyrights, and licensing terms in some of the files in
./arch/blackfin, so this fixes things, and cleans them up.
It also removes:
- verbose GPL text(refer to the top level ./COPYING file)
- file names (you are looking at the file)
- bug url (it's in the ./MAINTAINERS file)
- "or later" on GPL-2, when we did not have that right
It also allows some Blackfin-specific assembly files to be under a BSD
like license (for people to use them outside of Linux).
Signed-off-by: Robin Getz <robin.getz@analog.com>
convert BF5{18,27,48}_FAMILY to CONFIG_BF{51,52,54}x as the defines
are redundant in these cases
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
merge more of the bf54x and !bf54x gpio code together to
cut down on #ifdef mess
[Mike Frysinger <vapier.adi@gmail.com>:
- use KERN_NOTICE when using gpios as both irq and non
rather than KERN_ERR
- embedded newlines in printk() does not fly]
Signed-off-by: Graf Yang <graf.yang@analog.com>
GPIO_BANK_NUM macro caculating
infrastructure
- This patch adds support for ARCH_WANT_OPTIONAL_GPIOLIB.
- It may be changed in future to ARCH_REQUIRE_GPIOLIB.
- Change GPIO_BANK_NUM use DIV_ROUND_UP( , ) macro
with positioning a gpio
The whole story:
Before BF51x merged, all the MAX_BLACKFIN_GPIOS are integral multiple of GPIO_BANKSIZE (= 16).
But BF51x provides MAX_BLACKFIN_GPIOS = 40 which includes 3 banks and the 3rd bank has only 8
GPIO pins.
Therefore, gpio_bank() macros is correct when you try to find a GPIO in which bank (GPIO_35 is
in bank 2). But on BF51x gpio_bank(MAX_BLACKFIN_GPIOS) only gives out 2 banks instead of 3
banks for some static array initialization.
This patch add a new macros gpio_bank_n() and GPIO_BANK_NUM to do bank number caculating and
remain the gpio_bank() macros for positioning a gpio in which bank.
Add supporing for Blackfin BF538 and BF539 processors.
