The header file is used by the SPI and I2C variant of the driver.
Therefore, move it to a more generic place under platform_data.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Instead of using arch-specific accessors remap rotary register physical
address into kernel space in probe and use standard readw and writew to
access rotary MMRs.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Newer Blackfin boards use pinctrl API to manage pins and the legacy
peripherial lists are not useful on them. Let's move pin lists into
platform data so older boards can still use them and newer boards can use
the modern API.
The platform data definition of the rotary driver should be generic for all
architectures.
using IS_ENABLED() macro instead of defined(CONFIG_XXX) || defined(CONFIG_XXX_MODULE)
Signed-off-by: Steven Miao <realmz6@gmail.com>
The bf5x_tdm driver has been removed. Remove all references to it from board
code.
The bf5xx-i2s driver now has support for TDM mode and the bf5xx-tdm driver is
going to be removed soon, so switch the driver over to bf5xx-i2s.
Musb can't work since the marco name has been changed.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Rotary can't be used as a wakeup source in all platform.
Changed bfin_get_ether_addr() to return a state and to
set no random mac address if the board don't provide one.
Let the caller of bfin_get_ether_addr() set a random mac
address if the return value is not 0.
v2: don't set random mac in bfin_get_ether_addr()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Macro name for spi controller driver has been modified, so update default
board file accordingly.
The serial TX IRQ is not simply (RX IRQ + 1) on some Blackfin chips,
so move the values to the platform resources.
These particular files were just assuming that module.h was
somehow in the include paths. Give them the more minimalist
header file explicitly.
The pcm driver name has been changed, but the device name has not.
Signed-off-by: Scott Jiang <scott.jiang@analog.com>
The default for the Blackfin SPI driver is 8 bits and dma disabled,
so many of the bfin5xx_spi_chip resources are redundant. So punt
those parts.
Further, drivers should themselves be declaring 16 bit transfers,
so for those that do, and for the ones which no longer do 16 bit
transfers, drop the bfin5xx_spi_chip resources.
Now that the Blackfin machine drivers have been updated to the
multicomponent support, update the resources to match. The pin
settings are now a board issue and removed from the driver.
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
In order to not touch the driver file for different xtal usage,
push the clkin value to board file and calculate the register
value instead of hardcoding it.
Just adding its own platform_driver, not really
using it yet.
Later patches will come to split power management
code from musb_core and move it completely to HW
glue layer.
Signed-off-by: Felipe Balbi <balbi@ti.com>
change all ocurrences of musb_hdrc to musb-hdrc.
We will call glue layer drivers musb-<glue layer>,
so in order to keep things somewhat standard, let's
change the underscore into a dash.
Soon resource data will get automatically
populated from a set of autogenerated data
from TI's hardware database for the OMAP
platform.
Such database, might not have resources at
the expected order by the current drivers.
While we could hack in some exceptions to
that tool to generate resources in a specific
order, it seems less fragile to use the
resource name instead. That way, no matter
what order the resources are generated, the
driver still work.
Modified the OMAP, Blackfin and Davinci
architecture files to add the name of the IRQs
in the resource structures and musb driver to
use the platform_get_irq_byname() api to get
the device and dma irq numbers instead of using
the index.
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Signed-off-by: Hema HK <hemahk@ti.com>
Move all the pin settings out of the Kconfig and into the platform
resources (MII vs RMII). This clean up also lets us push out the
phy settings so that board porters may control the layout.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Since these boards can boot out of NAND, make sure we give u-boot its
own partition by default to avoid clobbering it.
Signed-off-by: steven miao <realmz6@gmail.com>
Make sure we use the right Kconfig names and platform strings.
Signed-off-by: Barry Song <barry.song@analog.com>
Now that the driver for the Blackfin on-chip NFC no longer uses/respects
the page_size from the platform resources (figures out the needs on the
fly), drop it from the platform resources. This fixes some build errors
since the defines no longer exists.
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
These boards all have the GPIO VRSEL hooked up as an active high.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
The ASoC codec driver was generalized and renamed, so update the board
resources accordingly.
Rather than declaring pin resources in the drivers, do it in the board.
These platforms don't hook up to this USB controller, so no point in
declaring resources for it.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
This lets us support the new BF527-EZKIT V2.1 via platform resources
tweaks only.
This lets people easily select the UART/SPORT consoles for early printk
while leveraging the pins declared in the boards file.
Rather than keeping the pins in the actual driver and worrying about a
mess of Kconfig options, declare all the desired pin resources in the
boards file. This lets people easily select the specific pins/ports for
the normal emulated UART as well as GPIOs for CTS/RTS.
the normal UART as well as GPIOs for CTS/RTS.
The driver changed from "isp1760-hcd" to "isp1760", so update resources
to match.
The driver was moved during the merge process, so update the defines to
match the new location.
Drop the CONFIG_USB_ISP1362_BFIN_GPIO_IRQ Kconfig as it never made it into
mainline and it was a bad interface into the board resources. For boards
that actually used this, replace it with an actual IRQ define. For boards
that didn't, simply drop the resources.
Now that the driver has been updated, convert the board resources to the
new i2c framework for managing slaves.
For boards that don't actually hook up to this hardware, simply drop the
resources altogether.
The simple-gpio has been replaced by the gpio sysfs interface, so drop the
unused simple-gpio resources from all Blackfin boards.
