path: root/arch/blackfin/mach-bf548/boards/cm_bf548.c
2009-01-07Blackfin arch: fix bug: kernel crash when enable SDIO host driverMike Frysinger
update bfin-sdh platform data to fix this issue. Pointed-out-by: Dominik Herwald <d.herwald@dsh-elektronik.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: Fix bug - wrong endpoint number and dma channels of USBBryan Wu
Blackfin MUSB has 8 endpoints including ep0 and 8 dma channels not 7 Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: Modify bfin_sir device configuration to board fileGraf Yang
Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: add simple-gpio resources to all adi/tinyboardsMike Frysinger
2008-11-18Blackfin arch: use physmap in board resources rather than legacy config methodMike Frysinger
2008-11-18Blackfin arch: enable i2c_bfin_twi0_device in cm_bf548 boardMike Frysinger
2008-10-09Blackfin arch: flags of UART3 mem resource is missingSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-13Blackfin arch: only include asm/cplb.h when it is truly usedMike Frysinger
2008-10-08Blackfin arch: use new platform data interface of musb to replace old oneBryan Wu
2008-08-27Blackfin arch: move include/asm-blackfin header files to arch/blackfinBryan Wu
2008-08-05Blackfin arch: be consistant with parition names, and ensure the bus is ↵Robin Getz
identified Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-20Blackfin arch: Cleanup no functional changesMichael Hennerich
Singed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-10[Blackfin] arch: protect linux/usb/musb.h include until the driver gets ↵Mike Frysinger
mainlined Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-07[Blackfin] arch: Functional power management support: Add CPU and platform ↵Michael Hennerich
voltage scaling support Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-04-25[Blackfin] arch: add Blackfin on-chip SIR IrDA driver supportGraf Yang
- add platform device resources in board files - add new bfin_sir.h to each machines Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-04-24[Blackfin] arch: Apply Bluetechnix vendor patchMichael Hennerich
