Signed-off-by: Aaron Wu <aaronwu06@gmail.com>
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
In order to not touch the driver file for different xtal usage,
push the clkin value to board file and calculate the register
value instead of hardcoding it.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Just adding its own platform_driver, not really
using it yet.
Later patches will come to split power management
code from musb_core and move it completely to HW
glue layer.
Signed-off-by: Felipe Balbi <balbi@ti.com>
change all ocurrences of musb_hdrc to musb-hdrc.
We will call glue layer drivers musb-<glue layer>,
so in order to keep things somewhat standard, let's
change the underscore into a dash.
Soon resource data will get automatically
populated from a set of autogenerated data
from TI's hardware database for the OMAP
platform.
Such database, might not have resources at
the expected order by the current drivers.
While we could hack in some exceptions to
that tool to generate resources in a specific
order, it seems less fragile to use the
resource name instead. That way, no matter
what order the resources are generated, the
driver still work.
Modified the OMAP, Blackfin and Davinci
architecture files to add the name of the IRQs
in the resource structures and musb driver to
use the platform_get_irq_byname() api to get
the device and dma irq numbers instead of using
the index.
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Signed-off-by: Hema HK <hemahk@ti.com>
The BF54x processor has a ton of on-chip peripherals and in order to
support them all, the u-boot image is quite large. So give it 512KiB
in all bootable flashes to make our lives easier.
Signed-off-by: steven miao <realmz6@gmail.com>
The num_chipselect field for on-chip Blackfin SPI buses is supposed to
be 1 larger than the number of actual CSs available. This is because
the hardware starts counting at 1 and not 0. There is a field for "CS0",
but it is marked as "reserved" everywhere.
Make sure we use the right Kconfig names and platform strings.
Signed-off-by: Barry Song <barry.song@analog.com>
Now that the driver for the Blackfin on-chip NFC no longer uses/respects
the page_size from the platform resources (figures out the needs on the
fly), drop it from the platform resources. This fixes some build errors
since the defines no longer exists.
These boards all have the GPIO VRSEL hooked up as an active high.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
The ASoC codec driver was generalized and renamed, so update the board
resources accordingly.
This lets people easily select the UART/SPORT consoles for early printk
while leveraging the pins declared in the boards file.
Rather than keeping the pins in the actual driver and worrying about a
mess of Kconfig options, declare all the desired pin resources in the
boards file. This lets people easily select the specific pins/ports for
the normal emulated UART as well as GPIOs for CTS/RTS.
the normal UART as well as GPIOs for CTS/RTS.
The ADXL34x driver was updated to include orientation sensing, so have the
bf537-stamp use it by default.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
The driver changed from "isp1760-hcd" to "isp1760", so update resources
to match.
The driver was moved during the merge process, so update the defines to
match the new location.
The simple-gpio has been replaced by the gpio sysfs interface, so drop the
unused simple-gpio resources from all Blackfin boards.
Fix the following 'make includecheck' warning:
arch/blackfin/mach-bf548/boards/ezkit.c: linux/input.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Structs get initialized to 0 already, and we want to punt this field, so
scrub it from all of our boards.
Reported-by: David Brownell <dbrownell@users.sourceforge.net>
Bill Gatliff & David Brownell pointed out we were missing some
copyrights, and licensing terms in some of the files in
./arch/blackfin, so this fixes things, and cleans them up.
It also removes:
- verbose GPL text(refer to the top level ./COPYING file)
- file names (you are looking at the file)
- bug url (it's in the ./MAINTAINERS file)
- "or later" on GPL-2, when we did not have that right
It also allows some Blackfin-specific assembly files to be under a BSD
like license (for people to use them outside of Linux).
Signed-off-by: Robin Getz <robin.getz@analog.com>
The BF54x has three slave select signals for SPI0/SPI1, not eight.
Signed-off-by: Yi Li <yi.li@analog.com>
The ASoC drivers have dropped the redundant "-spi" suffix in the driver
name, so update the board resources accordingly.
I think we have to use the physical dimensions [mm] of the display for
.width and .heigth in struct bfin_bf54xfb_mach_info bf54x_lq043_data which
are copied to fbinfo->var.height/.width in bf54x-lq043fb.c.
linux/fb.h describes this values as 'height/weight of picture in mm'
Otherwise QT calcs the wrong dpi value and the displayed fonts are very
small.
Signed-off-by: Stefan Pledl <stefan.pledl@mesutronic.de>
The "TWI_KEYPAD" driver was renamed to "INPUT_PCF8574", so update the
defines in the board resources accordingly.
The sed used to rename the bfin-twi-lcd only replaced the first instance
rather than all which led to the resources not being enabled when the
driver was built as a module.
The port1 disable stuff was dropped from the USB ISP1760, so update the
Blackfin boards accordingly.
The older smsc911x driver made platform data optional, but the newer one
always requires it, so add proper settings to the BF548-EZKIT.
The Blackfin SPI driver can be driven by an IRQ now, so declare it in
the board resources.
Try to keep the naming conventions consistent, so:
SPI_ADC_BF533 -> BFIN_SPI_ADC
TWI_LCD -> BFIN_TWI_LCD
Drop CONFIG_I2C_BOARDINFO ifdefs as the common i2c header handles this
already by stubbing things out
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Blackfin MUSB has 8 endpoints including ep0 and 8 dma channels not 7
Signed-off-by: Graf Yang <graf.yang@analog.com>
Cc: Graf Yang <graf.yang@analog.com>
initialization code.
partition size to 4meg
resource to board file
