Commit b70661c70830 ("net: smc91x: use run-time configuration on all ARM
machines") broke some ARM platforms through several mistakes. Firstly,
the access size must correspond to the following rule:
(a) at least one of 16-bit or 8-bit access size must be supported
(b) 32-bit accesses are optional, and may be enabled in addition to
the above.
Secondly, it provides no emulation of 16-bit accesses, instead blindly
making 16-bit accesses even when the platform specifies that only 8-bit
is supported.
Reorganise smc91x.h so we can make use of the existing 16-bit access
emulation already provided - if 16-bit accesses are supported, use
16-bit accesses directly, otherwise if 8-bit accesses are supported,
use the provided 16-bit access emulation. If neither, BUG(). This
exactly reflects the driver behaviour prior to the commit being fixed.
Since the conversion incorrectly cut down the available access sizes on
several platforms, we also need to go through every platform and fix up
the overly-restrictive access size: Arnd assumed that if a platform can
perform 32-bit, 16-bit and 8-bit accesses, then only a 32-bit access
size needed to be specified - not so, all available access sizes must
be specified.
This likely fixes some performance regressions in doing this: if a
platform does not support 8-bit accesses, 8-bit accesses have been
emulated by performing a 16-bit read-modify-write access.
Tested on the Intel Assabet/Neponset platform, which supports only 8-bit
accesses, which was broken by the original commit.
Fixes: b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Currently, include/media is messy, as it contains both the V4L2 core
headers and some driver-specific headers on the same place. That makes
harder to identify what core headers should be documented and what
headers belong to I2C drivers that are included only by bridge/main
drivers that would require the functions provided by them.
Let's move those i2c specific files to its own subdirectory.
The files to move were produced via the following script:
mkdir include/media/i2c
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/*/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
for i in include/media/*.h; do n=`basename $i`; (for j in $(git grep -l $n); do dirname $j; done)|sort|uniq|grep -ve '^.$' > list; num=$(wc -l list|cut -d' ' -f1); if [ $num == 1 ]; then if [ "`grep i2c list`" != "" ]; then git mv $i include/media/i2c; fi; fi; done
And the references corrected via this script:
MAIN_DIR="media/"
PREV_DIR="media/"
DIRS="i2c/"
echo "Checking affected files" >&2
for i in $DIRS; do
for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do
n=`basename $j`
git grep -l $n
done
done|sort|uniq >files && (
echo "Handling files..." >&2;
echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\";
cd include/$MAIN_DIR;
for j in $DIRS; do
for i in $(ls $j); do
echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\";
done;
done;
echo "cat > a && mv a \$i; done";
echo "Handling documentation..." >&2;
echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\";
for j in $DIRS; do
echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\";
done;
done;
) >script && . ./script
Merged Sakari Ailus patch that moves smiapp.h to include/media/i2c.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Signed-off-by: Steven Miao <realmz6@gmail.com>
using IS_ENABLED() macro instead of defined(CONFIG_XXX) || defined(CONFIG_XXX_MODULE)
The bf5x_tdm driver has been removed. Remove all references to it from board
code.
The bf5xx-i2s driver now has support for TDM mode and the bf5xx-tdm driver is
going to be removed soon, so switch the driver over to bf5xx-i2s.
Add capabilities in adv7183_inputs to indicate that S_STD is supported.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Change default clock rate of GPIO based I2C operation for BF533
and BF561 to bring up the I2C interface LCD display
Signed-off-by: Aaron Wu <Aaron.Wu@analog.com>
Macro name for spi controller driver has been modified, so update default
board file accordingly.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
The serial TX IRQ is not simply (RX IRQ + 1) on some Blackfin chips,
so move the values to the platform resources.
The default for the Blackfin SPI driver is 8 bits and dma disabled,
so many of the bfin5xx_spi_chip resources are redundant. So punt
those parts.
Further, drivers should themselves be declaring 16 bit transfers,
so for those that do, and for the ones which no longer do 16 bit
transfers, drop the bfin5xx_spi_chip resources.
Both the BF548-EZKIT and the BF561-EZKIT use top boot flashes, so now
that Das U-Boot uses the last small sector for its environment, update
their nor layout in the kernel accordingly.
Rather than use raw numbers for the GPIO pins, use proper GPIO defines.
This board has an AD1836 codec, so make sure we have the right resources
declared for it.
Signed-off-by: Barry Song <barry.song@analog.com>
With the recent kernel update the isp1362-hcd driver evaluates the
IORESOURCE_IRQ resource flags and requests the irq with the given
polarity/edge settings. However the ISP1362 config requires low
level/edge interrupts. Most of the Blackfin boards use some random
flag or no flag at all. Make all boards use a know good flag
IORESOURCE_IRQ_LOWEDGE.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Make sure we use the right Kconfig names and platform strings.
The ASoC codec driver was generalized and renamed, so update the board
resources accordingly.
This lets people easily select the UART/SPORT consoles for early printk
while leveraging the pins declared in the boards file.
Rather than keeping the pins in the actual driver and worrying about a
mess of Kconfig options, declare all the desired pin resources in the
boards file. This lets people easily select the specific pins/ports for
the normal UART as well as GPIOs for CTS/RTS.
The ax88180 driver was never merged, so drop the corresponding resources.
The driver changed from "isp1760-hcd" to "isp1760", so update resources
to match.
The simple-gpio has been replaced by the gpio sysfs interface, so drop the
unused simple-gpio resources from all Blackfin boards.
Bill Gatliff & David Brownell pointed out we were missing some
copyrights, and licensing terms in some of the files in
./arch/blackfin, so this fixes things, and cleans them up.
It also removes:
- verbose GPL text(refer to the top level ./COPYING file)
- file names (you are looking at the file)
- bug url (it's in the ./MAINTAINERS file)
- "or later" on GPL-2, when we did not have that right
It also allows some Blackfin-specific assembly files to be under a BSD
like license (for people to use them outside of Linux).
Signed-off-by: Robin Getz <robin.getz@analog.com>
The ASoC drivers have dropped the redundant "-spi" suffix in the driver
name, so update the board resources accordingly.
Latest smc91x driver allows you to specify settings in board resources
rather than needing CONFIG_BLACKFIN in the drivers/net/smc91x.h header.
The port1 disable stuff was dropped from the USB ISP1760, so update the
Blackfin boards accordingly.
The Blackfin SPI driver can be driven by an IRQ now, so declare it in
the board resources.
Signed-off-by: Yi Li <yi.li@analog.com>
Signed-off-by: Graf Yang <graf.yang@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Cc: Graf Yang <graf.yang@analog.com>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
initialization code.
these are highly board specific, so putting into generic doesnt make much sense
identified
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
voltage scaling support
- add platform device resources in board files
- add new bfin_sir.h to each machines
device.
Signed-off-by: Grace Pan <grace.pan@analog.com>
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
async memory bank
- set default u-boot partition size to 256k
- modify the offset with the size change
- use mtd defines (append for offset and full for size)
where applicable rather than churning constants when we dont have to
platform support
- Enable kernel generic spidev driver for blackfin SPI ADC
- spi_adc driver, document and test sample not synced
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
bf5xx-flash driver
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com>
EZKIT-BF533 and EZKIT-BF561 boards
