[ Upstream commit 1c363531dd814dc4fe10865722bf6b0f72ce4673 ]
The build robot is complaining on Blackfin:
drivers/pinctrl/pinctrl-adi2.c: In function 'port_setup':
>> drivers/pinctrl/pinctrl-adi2.c:221:21: error: dereferencing
pointer to incomplete type 'struct gpio_port_t'
writew(readw(®s->port_fer) & ~BIT(offset),
drivers/pinctrl/pinctrl-adi2.c: In function 'adi_gpio_ack_irq':
>> drivers/pinctrl/pinctrl-adi2.c:266:18: error: dereferencing
pointer to incomplete type 'struct bfin_pint_regs'
if (readl(®s->invert_set) & pintbit)
It seems the driver need to include <asm/gpio.h> and <asm/irq.h>
to compile.
The Blackfin architecture was re-defining the Kconfig
PINCTRL symbol which is not OK, so replaced this with
PINCTRL_BLACKFIN_ADI2 which selects PINCTRL and PINCTRL_ADI2
just like most arches do.
Further, the old GPIO driver symbol GPIO_ADI was possible to
select at the same time as selecting PINCTRL. This was not
working because the arch-local <asm/gpio.h> header contains
an explicit #ifndef PINCTRL clause making compilation break
if you combine them. The same is true for DEBUG_MMRS.
Make sure the ADI2 pinctrl driver is not selected at the same
time as the old GPIO implementation. (This should be converted
to use gpiolib or pincontrol and move to drivers/...) Also make
sure the old GPIO_ADI driver or DEBUG_MMRS is not selected at
the same time as the new PINCTRL implementation, and only make
PINCTRL_ADI2 selectable for the Blackfin families that actually
have it.
This way it is still possible to add e.g. I2C-based pin
control expanders on the Blackfin.
Cc: Steven Miao <realmz6@gmail.com>
Cc: Huanhuan Feng <huanhuan.feng@analog.com>
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
compliance tools to determine the correct license.
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
Pull MTD updates from Boris Brezillon:
"General updates:
- Constify pci_device_id in various drivers
- Constify device_type
- Remove pad control code from the Gemini driver
- Use %pOF to print OF node full_name
- Various fixes in the physmap_of driver
- Remove unused vars in mtdswap
- Check devm_kzalloc() return value in the spear_smi driver
- Check clk_prepare_enable() return code in the st_spi_fsm driver
- Create per MTD device debugfs enties
NAND updates, from Boris Brezillon:
- Fix memory leaks in the core
- Remove unused NAND locking support
- Rename nand.h into rawnand.h (preparing support for spi NANDs)
- Use NAND_MAX_ID_LEN where appropriate
- Fix support for 20nm Hynix chips
- Fix support for Samsung and Hynix SLC NANDs
- Various cleanup, improvements and fixes in the qcom driver
- Fixes for bugs detected by various static code analysis tools
- Fix mxc ooblayout definition
- Add a new part_parsers to tmio and sharpsl platform data in order
to define a custom list of partition parsers
- Request the reset line in exclusive mode in the sunxi driver
- Fix a build error in the orion-nand driver when compiled for ARMv4
- Allow 64-bit mvebu platforms to select the PXA3XX driver
SPI NOR updates, from Cyrille Pitchen and Marek Vasut:
- add support to the JEDEC JESD216B specification (SFDP tables).
- add support to the Intel Denverton SPI flash controller.
- fix error recovery for Spansion/Cypress SPI NOR memories.
- fix 4-byte address management for the Aspeed SPI controller.
- add support to some Microchip SST26 memory parts
- remove unneeded pinctrl header Write a message for tag:"
* tag 'for-linus-20170904' of git://git.infradead.org/linux-mtd: (74 commits)
mtd: nand: complain loudly when chip->bits_per_cell is not correctly initialized
mtd: nand: make Samsung SLC NAND usable again
mtd: nand: tmio: Register partitions using the parsers
mfd: tmio: Add partition parsers platform data
mtd: nand: sharpsl: Register partitions using the parsers
mtd: nand: sharpsl: Add partition parsers platform data
mtd: nand: qcom: Support for IPQ8074 QPIC NAND controller
mtd: nand: qcom: support for IPQ4019 QPIC NAND controller
dt-bindings: qcom_nandc: IPQ8074 QPIC NAND documentation
dt-bindings: qcom_nandc: IPQ4019 QPIC NAND documentation
dt-bindings: qcom_nandc: fix the ipq806x device tree example
mtd: nand: qcom: support for different DEV_CMD register offsets
mtd: nand: qcom: QPIC data descriptors handling
mtd: nand: qcom: enable BAM or ADM mode
mtd: nand: qcom: erased codeword detection configuration
mtd: nand: qcom: support for read location registers
mtd: nand: qcom: support for passing flags in DMA helper functions
mtd: nand: qcom: add BAM DMA descriptor handling
mtd: nand: qcom: allocate BAM transaction
mtd: nand: qcom: DMA mapping support for register read buffer
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- new drivers for Spreadtrum I2C, Intel Cherry Trail Whiskey Cove SMBUS
- quite some driver updates
- cleanups for the i2c-mux subsystem
- some subsystem-wide constification
- further cleanup of include/linux/i2c
* 'i2c/for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (50 commits)
i2c: sprd: Fix undefined reference errors
i2c: nomadik: constify amba_id
i2c: versatile: Make i2c_algo_bit_data const
i2c: busses: make i2c_adapter_quirks const
i2c: busses: make i2c_adapter const
i2c: busses: make i2c_algorithm const
i2c: Add Spreadtrum I2C controller driver
dt-bindings: i2c: Add Spreadtrum I2C controller documentation
i2c-cht-wc: make cht_wc_i2c_adap_driver static
MAINTAINERS: Add entry for drivers/i2c/busses/i2c-cht-wc.c
i2c: aspeed: Retain delay/setup/hold values when configuring bus frequency
dt-bindings: i2c: eeprom: Document vendor to be used and deprecated ones
i2c: i801: Restore the presence state of P2SB PCI device after reading BAR
MAINTAINERS: drop entry for Blackfin I2C and Sonic's email
blackfin: merge the two TWI header files
i2c: davinci: Preserve return value of devm_clk_get
i2c: mediatek: Add i2c compatible for MediaTek MT7622
dt-bindings: i2c: Add MediaTek MT7622 i2c binding
dt-bindings: i2c: modify information formats
i2c: mux: i2c-arb-gpio-challenge: allow compiling w/o OF support
From Boris:
This pull request contains the following core changes:
* Fix memory leaks in the core
* Remove unused NAND locking support
* Rename nand.h into rawnand.h (preparing support for spi NANDs)
* Use NAND_MAX_ID_LEN where appropriate
* Fix support for 20nm Hynix chips
* Fix support for Samsung and Hynix SLC NANDs
and the following driver changes:
* Various cleanup, improvements and fixes in the qcom driver
* Fixes for bugs detected by various static code analysis tools
* Fix mxc ooblayout definition
* Add a new part_parsers to tmio and sharpsl platform data in order to
* Request the reset line in exclusive mode in the sunxi driver
* Fix a build error in the orion-nand driver when compiled for ARMv4
* Allow 64-bit mvebu platforms to select the PXA3XX driver
There seems to be no need for separate ones since all users include both
files anyhow. Merge them because include/linux/i2c is to be deprecated.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
'hotplug.2017.07.25b', 'misc.2017.08.17a', 'spin_unlock_wait_no.2017.08.17a', 'srcu.2017.07.27c' and 'torture.2017.07.24c' into HEAD
doc.2017.08.17a: Documentation updates.
fixes.2017.08.17a: RCU fixes.
hotplug.2017.07.25b: CPU-hotplug updates.
misc.2017.08.17a: Miscellaneous fixes outside of RCU (give or take conflicts).
spin_unlock_wait_no.2017.08.17a: Remove spin_unlock_wait().
srcu.2017.07.27c: SRCU updates.
torture.2017.07.24c: Torture-test updates.
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes the underlying arch-specific
arch_spin_unlock_wait() for all architectures providing them.
Cc: <linux-arch@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
This commit removes the pr_fmt() macro, replacing it with mod_err() and
mod_debug() macros to avoid errors when using printk() from header files.
struct siginfo is a union and the kernel since 2.4 has been hiding a union
tag in the high 16bits of si_code using the values:
__SI_KILL
__SI_TIMER
__SI_POLL
__SI_FAULT
__SI_CHLD
__SI_RT
__SI_MESGQ
__SI_SYS
While this looks plausible on the surface, in practice this situation has
not worked well.
- Injected positive signals are not copied to user space properly
unless they have these magic high bits set.
- Injected positive signals are not reported properly by signalfd
- These kernel internal values leaked to userspace via ptrace_peek_siginfo
- It was possible to inject these kernel internal values and cause the
the kernel to misbehave.
- Kernel developers got confused and expected these kernel internal values
in userspace in kernel self tests.
- Kernel developers got confused and set si_code to __SI_FAULT which
is SI_USER in userspace which causes userspace to think an ordinary user
sent the signal and that it was not kernel generated.
- The values make it impossible to reorganize the code to transform
siginfo_copy_to_user into a plain copy_to_user. As si_code must
be massaged before being passed to userspace.
So remove these kernel internal si codes and make the kernel code simpler
and more maintainable.
To replace these kernel internal magic si_codes introduce the helper
function siginfo_layout, that takes a signal number and an si_code and
computes which union member of siginfo is being used. Have
siginfo_layout return an enumeration so that gcc will have enough
information to warn if a switch statement does not handle all of union
members.
A couple of architectures have a messed up ABI that defines signal
specific duplications of SI_USER which causes more special cases in
siginfo_layout than I would like. The good news is only problem
architectures pay the cost.
Update all of the code that used the previous magic __SI_ values to
use the new SIL_ values and to call siginfo_layout to get those
values. Escept where not all of the cases are handled remove the
defaults in the switch statements so that if a new case is missed in
the future the lack will show up at compile time.
Modify the code that copies siginfo si_code to userspace to just copy
the value and not cast si_code to a short first. The high bits are no
longer used to hold a magic union member.
Fixup the siginfo header files to stop including the __SI_ values in
their constants and for the headers that were missing it to properly
update the number of si_codes for each signal type.
The fixes to copy_siginfo_from_user32 implementations has the
interesting property that several of them perviously should never have
worked as the __SI_ values they depended up where kernel internal.
With that dependency gone those implementations should work much
better.
The idea of not passing the __SI_ values out to userspace and then
not reinserting them has been tested with criu and criu worked without
changes.
Ref: 2.4.0-test1
Pull core fixes from Ingo Molnar:
"A fix to WARN_ON_ONCE() done by modules, plus a MAINTAINERS update"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
debug: Fix WARN_ON_ONCE() for modules
MAINTAINERS: Update the PTRACE entry
Mike Galbraith reported a situation where a WARN_ON_ONCE() call in DRM
code turned into an oops. As it turns out, WARN_ON_ONCE() seems to be
completely broken when called from a module.
The bug was introduced with the following commit:
19d436268dde ("debug: Add _ONCE() logic to report_bug()")
That commit changed WARN_ON_ONCE() to move its 'once' logic into the bug
trap handler. It requires a writable bug table so that the BUGFLAG_DONE
bit can be written to the flags to indicate the first warning has
occurred.
The bug table was made writable for vmlinux, which relies on
vmlinux.lds.S and vmlinux.lds.h for laying out the sections. However,
it wasn't made writable for modules, which rely on the ELF section
header flags.
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Fixes: 19d436268dde ("debug: Add _ONCE() logic to report_bug()")
Link: http://lkml.kernel.org/r/a53b04235a65478dd9afc51f5b329fdc65c84364.1500095401.git.jpoimboe@redhat.com
Several variables had their types changed from unsigned long to u32,
but the printk()-style format to print them wasn't updated, leading to:
arch/blackfin/kernel/flat.c: In function 'bfin_get_addr_from_rp':
arch/blackfin/kernel/flat.c:35:3: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'u32' [-Wformat]
arch/blackfin/kernel/flat.c: In function 'bfin_put_addr_at_rp':
arch/blackfin/kernel/flat.c:80:3: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'u32' [-Wformat]
Fixes: 468138d78510688f ("binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail")
Several variables had their types changed from unsigned long to u32, but
the arch-specific implementations of flat_set_persistent() weren't
updated, leading to compiler warnings on blackfin and m68k:
fs/binfmt_flat.c: In function ‘load_flat_file’:
fs/binfmt_flat.c:799: warning: passing argument 2 of ‘flat_set_persistent’ from incompatible pointer type
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- Move generic-y of exported headers to uapi/asm/Kbuild for complete
de-coupling of UAPI
- Clean up scripts/Makefile.headersinst
- Fix host programs for 32 bit machine with XFS file system
* tag 'kbuild-v4.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (29 commits)
kbuild: Enable Large File Support for hostprogs
kbuild: remove wrapper files handling from Makefile.headersinst
kbuild: split exported generic header creation into uapi-asm-generic
kbuild: do not include old-kbuild-file from Makefile.headersinst
xtensa: move generic-y of exported headers to uapi/asm/Kbuild
unicore32: move generic-y of exported headers to uapi/asm/Kbuild
tile: move generic-y of exported headers to uapi/asm/Kbuild
sparc: move generic-y of exported headers to uapi/asm/Kbuild
sh: move generic-y of exported headers to uapi/asm/Kbuild
parisc: move generic-y of exported headers to uapi/asm/Kbuild
openrisc: move generic-y of exported headers to uapi/asm/Kbuild
nios2: move generic-y of exported headers to uapi/asm/Kbuild
nios2: remove unneeded arch/nios2/include/(generated/)asm/signal.h
microblaze: move generic-y of exported headers to uapi/asm/Kbuild
metag: move generic-y of exported headers to uapi/asm/Kbuild
m68k: move generic-y of exported headers to uapi/asm/Kbuild
m32r: move generic-y of exported headers to uapi/asm/Kbuild
ia64: remove redundant generic-y += kvm_para.h from asm/Kbuild
hexagon: move generic-y of exported headers to uapi/asm/Kbuild
h8300: move generic-y of exported headers to uapi/asm/Kbuild
For architectures that define HAVE_NMI_WATCHDOG, instead of having them
provide the complete touch_nmi_watchdog() function, just have them
provide arch_touch_nmi_watchdog().
This gives the generic code more flexibility in implementing this
function, and arch implementations don't miss out on touching the
softlockup watchdog or other generic details.
Link: http://lkml.kernel.org/r/20170616065715.18390-3-npiggin@gmail.com
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Don Zickus <dzickus@redhat.com>
Reviewed-by: Babu Moger <babu.moger@oracle.com>
Tested-by: Babu Moger <babu.moger@oracle.com> [sparc]
Cc: Michael Ellerman <mpe@ellerman.id.au>
Since commit fcc8487d477a ("uapi: export all headers under uapi
directories"), all (and only) headers under uapi directories are
exported, but asm-generic wrappers are still exceptions.
To complete de-coupling the uapi from kernel headers, move generic-y
of exported headers to uapi/asm/Kbuild.
With this change, "make headers_install" will just need to parse
uapi/asm/Kbuild to build up exported headers.
Also, move "generic-y += kprobes.h" up in order to keep the entries
sorted.
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight
Pull backlight updates from Lee Jones:
"Core Framework:
- Report correct error status to user
Fix-ups:
- Move Backlight headers out of I2C (adp8860, adp8870)"
* tag 'backlight-next-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight:
video: adp8870: move header file out of I2C realm
backlight: adp8860: Move header file out of I2C realm
backlight: Report error on failure
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.13 series.
Some administrativa:
I have a slew of 8250 serial patches and the new IOT2040 serial+GPIO
driver coming in through this tree, along with a whole bunch of Exar
8250 fixes. These are ACKed by Greg and also hit drivers/platform/*
where they are ACKed by Andy Shevchenko.
Speaking about drivers/platform/* there is also a bunch of ACPI stuff
coming through that route, again ACKed by Andy.
The MCP23S08 changes are coming in here as well. You already have the
commits in your tree, so this is just a result of sharing an immutable
branch between pin control and GPIO.
Core:
- Export add/remove for lookup tables so that modules can export GPIO
descriptor tables.
- Handle GPIO sleep states: it is now possible to flag that a GPIO
line may loose its state during suspend/resume of the system to
save power. This is used in the Wolfson Micro Arizona driver.
- ACPI-based GPIO was tightened up a lot around the edges.
- Use bitmap_fill() to speed up a loop.
New drivers:
- Exar XRA1403 SPI-based GPIO.
- MVEBU driver now supports Armada 7K and 8K.
- LP87565 PMIC GPIO.
- Renesas R-CAR R8A7743 (RZ/G1M).
- The new IOT2040 8250 serial/GPIO also comes in through this
changeset.
Substantial driver changes:
- Seriously fix the Exar 8250 GPIO portions to work.
- The MCP23S08 was moved out to a pin control driver.
- Convert MEVEBU to use regmap for register access.
- Drop Vulcan support from the Broadcom driver.
- Serious cleanup and improvement of the mockup driver, giving us a
better test coverage.
Misc:
- Lots of janitorial clean up.
- A bunch of documentation fixes"
* tag 'gpio-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (70 commits)
serial: exar: Add support for IOT2040 device
gpio-exar/8250-exar: Make set of exported GPIOs configurable
platform: Accept const properties
serial: exar: Factor out platform hooks
gpio-exar/8250-exar: Rearrange gpiochip parenthood
gpio: exar: Fix iomap request
gpio-exar/8250-exar: Do not even instantiate a GPIO device for Commtech cards
serial: uapi: Add support for bus termination
gpio: rcar: Add R8A7743 (RZ/G1M) support
gpio: gpio-wcove: Fix GPIO control register offset calculation
gpio: lp87565: Add support for GPIO
gpio: dwapb: fix missing first irq for edgeboth irq type
MAINTAINERS: Take maintainership for GPIO ACPI support
gpio: exar: Fix reading of directions and values
gpio: exar: Allocate resources on behalf of the platform device
gpio-exar/8250-exar: Fix passing in of parent PCI device
gpio: mockup: use devm_kcalloc() where applicable
gpio: mockup: add myself as author
gpio: mockup: improve the error message
gpio: mockup: don't return magic numbers from probe()
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"This is the big bulk of pin control changes for the v4.13 series:
Core:
- The documentation is moved over to RST.
- We now have agreed bindings for enabling input and output buffers
without actually enabling input and/or output on a pin. We are
chiseling out some details of pin control electronics.
New drivers:
- ZTE ZX
- Renesas RZA1
- MIPS Ingenic JZ47xx: also switch over existing drivers in the tree
to use this pin controller and consolidate earlier spread out code.
- Microschip MCP23S08: this driver is migrated from the GPIO
subsystem and totally rewritten to use proper pin control. All
users are switched over.
New subdrivers:
- Renesas R8A7743 and R8A7745.
- Allwinner Sunxi A83T R_PIO.
- Marvell MVEBU Armada CP110 and AP806.
- Intel Cannon Lake PCH.
- Qualcomm IPQ8074.
Notable improvements:
- IRQ support on the Marvell MVEBU Armada 37xx.
- Meson driver supports HDMI CEC, AO, I2S, SPDIF and PWM.
- Rockchip driver now supports iomux-route switching for RK3228,
RK3328 and RK3399.
- Rockchip A10 and A20 are merged into a single driver.
- STM32 has improved GPIO support.
- Samsung Exynos drivers are split per ARMv7 and ARMv8.
- Marvell MVEBU is converted to use regmap for register access.
Maintenance:
- Several Renesas SH-PFC refactorings and updates.
- Serious code size cut for Mediatek MT7623.
- Misc janitorial and MAINTAINERS fixes"
* tag 'pinctrl-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (137 commits)
pinctrl: samsung: Remove bogus irq_[un]mask from resource management
pinctrl: rza1: make structures rza1_gpiochip_template and rza1_pinmux_ops static
pinctrl: rza1: Remove unneeded wrong check for wrong variable
pinctrl: qcom: Add ipq8074 pinctrl driver
pinctrl: freescale: imx7d: make of_device_ids const.
pinctrl: DT: extend the pinmux property to support integers array
pinctrl: generic: Add output-enable property
pinctrl: armada-37xx: Fix number of pin in sdio_sb
pinctrl: armada-37xx: Fix uart2 group selection register mask
pinctrl: bcm2835: Avoid warning from __irq_do_set_handler
pinctrl: sh-pfc: r8a7795: Add PWM support
MAINTAINERS: Add Qualcomm pinctrl drivers section
arm: dts: dt-bindings: Add Renesas RZ/A1 pinctrl header
dt-bindings: pinctrl: Add RZ/A1 bindings doc
pinctrl: Renesas RZ/A1 pin and gpio controller
pinctrl: sh-pfc: r8a7792: Add SCIF1 and SCIF2 pin groups
pinctrl.txt: move it to the driver-api book
pinctrl: ingenic: checking for NULL instead of IS_ERR()
pinctrl: uniphier: fix WARN_ON() of pingroups dump on LD20
pinctrl: uniphier: fix WARN_ON() of pingroups dump on LD11
include/linux/i2c is not for client devices. Move the header file to a
more appropriate location.
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Move the header file to a more appropriate location.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
on MMU targets EFAULT is possible here. Make both return 0 or error,
passing what used to be the return value of flat_get_addr_from_rp()
by reference.
Currently, internals of dma_common_mmap() is compiled out if build is
done for either NOMMU or target which explicitly says it does not
have/want coherent DMA mmap. It turned out that dma_common_mmap() can
be handy in NOMMU setup (at least for ARM).
This patch converts exitent NOMMU targets to use ARCH_NO_COHERENT_DMA_MMAP,
thus when CONFIG_MMU is gone from dma_common_mmap() their behaviour stays
unchanged.
ARM is not converted to ARCH_NO_COHERENT_DMA_MMAP because it 1)
already has mmap callback which can handle (at some extent) NOMMU 2)
already defines dummy pgprot_noncached() for NOMMU build.
c6x and frv stay untouched since they already have ARCH_NO_COHERENT_DMA_MMAP.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
This moves the mcp23s08 driver from gpio to pinctrl. Actual
pinctrl support for configuration of the pull-up resistors
follows in its own patch.
Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
no callers, no consistent semantics, no sane way to use it...
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
In many of clk_disable() implementations, it is a no-op for a NULL
pointer input, but this is one of the exceptions.
Making it treewide consistent will allow clock consumers to call
clk_disable() without NULL pointer check.
Link: http://lkml.kernel.org/r/1490692624-11931-4-git-send-email-yamada.masahiro@socionext.com
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Michael Turquette <mturquette@baylibre.com>
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- unwinder fixes and enhancements
- improve ftrace interaction with the unwinder
- optimize the code footprint of WARN() and related debugging
constructs
- ... plus misc updates, cleanups and fixes"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
x86/unwind: Dump all stacks in unwind_dump()
x86/unwind: Silence more entry-code related warnings
x86/ftrace: Fix ebp in ftrace_regs_caller that screws up unwinder
x86/unwind: Remove unused 'sp' parameter in unwind_dump()
x86/unwind: Prepend hex mask value with '0x' in unwind_dump()
x86/unwind: Properly zero-pad 32-bit values in unwind_dump()
x86/unwind: Ensure stack pointer is aligned
debug: Avoid setting BUGFLAG_WARNING twice
x86/unwind: Silence entry-related warnings
x86/unwind: Read stack return address in update_stack_state()
x86/unwind: Move common code into update_stack_state()
debug: Fix __bug_table[] in arch linker scripts
x86/debug: Define BUG() again for !CONFIG_BUG
x86/debug: Implement __WARN() using UD0
x86/ftrace: Use Makefile logic instead of #ifdef for compiling ftrace_*.o
x86/ftrace: Add -mfentry support to x86_32 with DYNAMIC_FTRACE set
x86/ftrace: Clean up ftrace_regs_caller
x86/ftrace: Add stack frame pointer to ftrace_caller
x86/ftrace: Move the ftrace specific code out of entry_32.S
Pull timer updates from Thomas Gleixner:
"The timer departement delivers:
- more year 2038 rework
- a massive rework of the arm achitected timer
- preparatory patches to allow NTP correction of clock event devices
to avoid early expiry
- the usual pile of fixes and enhancements all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits)
timer/sysclt: Restrict timer migration sysctl values to 0 and 1
arm64/arch_timer: Mark errata handlers as __maybe_unused
Clocksource/mips-gic: Remove redundant non devicetree init
MIPS/Malta: Probe gic-timer via devicetree
clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK
acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver
clocksource: arm_arch_timer: add GTDT support for memory-mapped timer
acpi/arm64: Add memory-mapped timer support in GTDT driver
clocksource: arm_arch_timer: simplify ACPI support code.
acpi/arm64: Add GTDT table parse driver
clocksource: arm_arch_timer: split MMIO timer probing.
clocksource: arm_arch_timer: add structs to describe MMIO timer
clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call
clocksource: arm_arch_timer: refactor arch_timer_needs_probing
clocksource: arm_arch_timer: split dt-only rate handling
x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks
unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks
um/time: Set ->min_delta_ticks and ->max_delta_ticks
tile/time: Set ->min_delta_ticks and ->max_delta_ticks
score/time: Set ->min_delta_ticks and ->max_delta_ticks
all architectures converted
In preparation for making the clockevents core NTP correction aware,
all clockevent device drivers must set ->min_delta_ticks and
->max_delta_ticks rather than ->min_delta_ns and ->max_delta_ns: a
clockevent device's rate is going to change dynamically and thus, the
ratio of ns to ticks ceases to stay invariant.
Make the blackfin arch's clockevent driver initialize these fields
properly.
This patch alone doesn't introduce any change in functionality as the
clockevents core still looks exclusively at the (untouched) ->min_delta_ns
and ->max_delta_ns. As soon as this has changed, a followup patch will
purge the initialization of ->min_delta_ns and ->max_delta_ns from this
driver.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
The kbuild test robot reported this build failure on a number
of architectures:
> make.cross ARCH=arm
> lib/lib.a(bug.o): In function `find_bug':
> >> lib/bug.c:135: undefined reference to `__start___bug_table'
> >> lib/bug.c:135: undefined reference to `__stop___bug_table'
Caused by:
Which moved the BUG_TABLE from RO_DATA_SECTION() to RW_DATA_SECTION(),
but a number of architectures don't use RW_DATA_SECTION(), so they
ended up with no __bug_table[] ...
Ideally all those would use RW_DATA_SECTION() in their linker scripts,
but that's for another day.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: kbuild test robot <fengguang.wu@intel.com>
Cc: kbuild-all@01.org
Cc: tipbuild@zytor.com
Link: http://lkml.kernel.org/r/20170330154927.o6qmgfp4bdhrajbm@hirez.programming.kicks-ass.net
Move the following task->mm helper APIs into a new header file,
<linux/sched/mm.h>, to further reduce the size and complexity
of <linux/sched.h>.
Here are how the APIs are used in various kernel files:
# mm_alloc():
arch/arm/mach-rpc/ecard.c
fs/exec.c
include/linux/sched/mm.h
kernel/fork.c
# __mmdrop():
arch/arc/include/asm/mmu_context.h
kernel/fork.c
# mmdrop():
arch/m68k/sun3/mmu_emu.c
arch/x86/mm/tlb.c
drivers/gpu/drm/amd/amdkfd/kfd_process.c
drivers/gpu/drm/i915/i915_gem_userptr.c
drivers/infiniband/hw/hfi1/file_ops.c
drivers/vfio/vfio_iommu_spapr_tce.c
fs/exec.c
fs/proc/base.c
fs/proc/task_mmu.c
fs/proc/task_nommu.c
fs/userfaultfd.c
include/linux/mmu_notifier.h
kernel/fork.c
kernel/futex.c
kernel/sched/core.c
mm/khugepaged.c
mm/ksm.c
mm/mmu_context.c
mm/mmu_notifier.c
mm/oom_kill.c
virt/kvm/kvm_main.c
# mmdrop_async_fn():
# mmdrop_async():
kernel/fork.c
# mmget_not_zero():
fs/userfaultfd.c
mm/oom_kill.c
# mmput():
arch/arc/kernel/troubleshoot.c
arch/frv/mm/mmu-context.c
arch/powerpc/platforms/cell/spufs/context.c
arch/sparc/include/asm/mmu_context_32.h
drivers/android/binder.c
drivers/gpu/drm/etnaviv/etnaviv_gem.c
drivers/infiniband/core/umem.c
drivers/infiniband/core/umem_odp.c
drivers/infiniband/core/uverbs_main.c
drivers/infiniband/hw/mlx4/main.c
drivers/infiniband/hw/mlx5/main.c
drivers/infiniband/hw/usnic/usnic_uiom.c
drivers/iommu/amd_iommu_v2.c
drivers/iommu/intel-svm.c
drivers/lguest/lguest_user.c
drivers/misc/cxl/fault.c
drivers/misc/mic/scif/scif_rma.c
drivers/oprofile/buffer_sync.c
drivers/vfio/vfio_iommu_type1.c
drivers/vhost/vhost.c
drivers/xen/gntdev.c
fs/exec.c
fs/proc/array.c
fs/proc/base.c
fs/proc/task_mmu.c
fs/userfaultfd.c
kernel/cpuset.c
kernel/events/core.c
kernel/events/uprobes.c
kernel/exit.c
kernel/fork.c
kernel/ptrace.c
kernel/sys.c
kernel/trace/trace_output.c
kernel/tsacct.c
mm/memcontrol.c
mm/memory.c
mm/mempolicy.c
mm/migrate.c
mm/mmu_notifier.c
mm/nommu.c
mm/oom_kill.c
mm/process_vm_access.c
mm/rmap.c
mm/swapfile.c
mm/util.c
virt/kvm/async_pf.c
# mmput_async():
kernel/fork.c
mm/oom_kill.c
# get_task_mm():
fs/proc/array.c
fs/proc/base.c
fs/proc/task_mmu.c
kernel/cpuset.c
kernel/exit.c
kernel/fork.c
kernel/ptrace.c
kernel/sys.c
kernel/tsacct.c
mm/memcontrol.c
mm/memory.c
mm/mempolicy.c
mm/migrate.c
mm/mmu_notifier.c
mm/nommu.c
mm/util.c
# mm_access():
fs/proc/base.c
kernel/fork.c
# mm_release():
fs/exec.c
include/uapi/linux/sched.h
kernel/exit.c
kernel/fork.c
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched.h>
Update code that relied on sched.h including various MM types for them.
This will allow us to remove the <linux/mm_types.h> include from <linux/sched.h>.
