Signed-off-by: Yi Li <yi.li@analog.com>
Signed-off-by: Barry Song <barry.song@analog.com>
The NAND platform driver expects the registers to have a "mem"
resource type rather than "io".
With the recent kernel update the isp1362-hcd driver evaluates the
IORESOURCE_IRQ resource flags and requests the irq with the given
polarity/edge settings. However the ISP1362 config requires low
level/edge interrupts. Most of the Blackfin boards use some random
flag or no flag at all. Make all boards use a know good flag
IORESOURCE_IRQ_LOWEDGE.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Valentin Yakovenkov <yakovenkov@gmail.com>
Add platform resources for the on-chip CAN peripheral so we can use it.
Make sure we use the right Kconfig names and platform strings.
Now that we've rewritten the GPIO CS handling in the Blackfin SPI
peripheral, we need to update the platform resources accordingly.
Now that the common header defines everything and the SPI drivers are
using it, we can drop these duplicated global namespace polluters.
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags:
Fix IRQ flag handling naming
MIPS: Add missing #inclusions of <linux/irq.h>
smc91x: Add missing #inclusion of <linux/irq.h>
Drop a couple of unnecessary asm/system.h inclusions
SH: Add missing consts to sys_execve() declaration
Blackfin: Rename IRQ flags handling functions
Blackfin: Add missing dep to asm/irqflags.h
Blackfin: Rename DES PC2() symbol to avoid collision
Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header
Blackfin: Split PLL code from mach-specific cdef headers
While combining things, also switch to the proper SPI bit define names.
This lets us punt the rarely used SPI defines.
The common SPI layers take care of detecting CS conflicts and preventing
two devices from claiming the same CS. This causes problems for the GPIO
CS support we currently have as we are using CS0 to mean "GPIO CS". But
if we have multiple devices using a GPIO CS, the common SPI layers see
multiple devices using the virtual "CS0" and reject any such attempts.
To make both work, we introduce an offset define. This represents the
max number of hardware CS values that the SPI peripheral supports. If
the CS is below this limit, we know we can use the hardware CS. If it's
above, we treat it as a GPIO CS. This keeps the CS unique as seen by
the common code and prevents conflicts.
Expand the BIT_CTL defines to use the naming convention of the hardware,
and expand the masks to cover all documented bits.
As David points out, the cs_change_per_word option isn't standard, nor is
anyone actually using it. So punt all of the dead code considering it
makes up ~10% of the code size.
Reported-by: David Brownell <dbrownell@users.sourceforge.net>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration,
it maps:
local_irq_enable() -> raw_local_irq_enable()
local_irq_disable() -> raw_local_irq_disable()
local_irq_save() -> raw_local_irq_save()
and under the other configuration, it maps:
raw_local_irq_enable() -> local_irq_enable()
raw_local_irq_disable() -> local_irq_disable()
raw_local_irq_save() -> local_irq_save()
This is quite confusing. There should be one set of names expected of the
arch, and this should be wrapped to give another set of names that are expected
by users of this facility.
Change this to have the arch provide:
flags = arch_local_save_flags()
flags = arch_local_irq_save()
arch_local_irq_restore(flags)
arch_local_irq_disable()
arch_local_irq_enable()
arch_irqs_disabled_flags(flags)
arch_irqs_disabled()
arch_safe_halt()
Then linux/irqflags.h wraps these to provide:
raw_local_save_flags(flags)
raw_local_irq_save(flags)
raw_local_irq_restore(flags)
raw_irqs_disabled_flags(flags)
raw_irqs_disabled()
raw_safe_halt()
with type checking on the flags 'arguments', and then wraps those to provide:
local_irq_disable()
local_irq_enable()
irqs_disabled()
safe_halt()
with tracing included if enabled.
The arch functions can now all be inline functions rather than some of them
having to be macros.
Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300]
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile]
Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze]
Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR]
Acked-by: Tony Luck <tony.luck@intel.com> [IA-64]
Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R]
Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS]
Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC]
Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC]
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390]
Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score]
Acked-by: Matt Fleming <matt@console-pimps.org> [SH]
Acked-by: David S. Miller <davem@davemloft.net> [Sparc]
Acked-by: Chris Zankel <chris@zankel.net> [Xtensa]
Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha]
Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300]
Cc: starvik@axis.com [CRIS]
Cc: jesper.nilsson@axis.com [CRIS]
Cc: linux-cris-kernel@axis.com
Rename h/w IRQ flags handling functions to be in line with what is expected for
the irq renaming patch. This renames local_*_hw() to hard_local_*() using the
following perl command:
perl -pi -e 's/local_irq_(restore|enable|disable)_hw/hard_local_irq_\1/ or s/local_irq_save_hw([_a-z]*)[(]flags[)]/flags = hard_local_irq_save\1()/' `find arch/blackfin/ -name "*.[ch]"`
and then fixing up asm/irqflags.h manually.
Additionally, arch/hard_local_save_flags() and arch/hard_local_irq_save() both
return the flags rather than passing it through the argument list.
Add a missing dependency (mach/blackfin.h) to asm/irqflags.h so that
bfin_read_IMASK() can be used by inline functions.
Split the BF532 machine type BFIN_*_FIO_FLAG() functions to their own header
file to avoid circular #include problems as these functions require IRQ flag
handling, which requires asm/blackfin.h, which otherwise requires the header
file that defines these functions.
For good measure, also get rid of the inclusion of asm/blackfin.h from
mach/cdefBF532.h (which is circular) and defBF532.h (which is included by
asm/blackfin.h before including this header).
Split the PLL control code from the Blackfin machine-specific cdef headers so
that the irqflags functions can be renamed without incurring a header loop.
Now that the driver for the Blackfin on-chip NFC no longer uses/respects
the page_size from the platform resources (figures out the needs on the
fly), drop it from the platform resources. This fixes some build errors
since the defines no longer exists.
The common bfin_sport.h header now has unified definitions of these, so
stop polluting the global namespace.
The recent commit to add constant optimization to hweight implicitly broke
the Blackfin arch. Seems we were missed when all the other arches were
fixed with renames.
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
* git://git.infradead.org/mtd-2.6:
mtd/nand_ids: Fix buswidth
mtd/m25p80: fix test for end of loop
mtd/m25p80: retlen is never NULL
MIPS: Fix gen_nand probe structures contents
gen_nand: Test if nr_chips field is valid
BFIN: Fix gen_nand probe structures contents
nand/denali: move all hardware initialization work to denali_hw_init
nand/denali: Add a page check in denali_read_page & denali_read_page_raw
nand/denali: use cpu_relax() while waiting for hardware interrupt
nand/denali: change read_status function method
nand/denali: Fixed check patch warnings
ARM: Fix gen_nand probe structures contents
mtd/nand_base: fix kernel-doc warnings & typos
nand/denali: use dev_xx debug function to replace nand_dbg_print and some printk
nand/denali: Fixed handle ECC error bugs
nand/denali: use iowrite32() to replace denali_write32()
nand/denali: Fixed probe function bugs
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
unifdef-y and header-y have same semantic, so drop unifdef-y
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
These two platforms didn't properly fill nr_chips in gen_nand
registration and therefore depended on gen_nand bug fixed by by commit
81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for
multiple chips")
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
Now each architecture has the own dma_get_cache_alignment implementation.
define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed
buffer is DMA-safe; the buffer doesn't share a cache with the others). So
we can unify dma_get_cache_alignment implementations.
This patch:
dma_get_cache_alignment() needs to know if an architecture defines
ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA
alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if
architectures doesn't define it.
Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN.
ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub
(except for crypto).
fs/exofs/inode.c
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
* git://git.infradead.org/mtd-2.6: (79 commits)
mtd: Remove obsolete <mtd/compatmac.h> include
mtd: Update copyright notices
jffs2: Update copyright notices
mtd-physmap: add support users can assign the probe type in board files
mtd: remove redwood map driver
mxc_nand: Add v3 (i.MX51) Support
mxc_nand: support 8bit ecc
mxc_nand: fix correct_data function
mxc_nand: add V1_V2 namespace to registers
mxc_nand: factor out a check_int function
mxc_nand: make some internally used functions overwriteable
mxc_nand: rework get_dev_status
mxc_nand: remove 0xe00 offset from registers
mtd: denali: Add multi connected NAND support
mtd: denali: Remove set_ecc_config function
mtd: denali: Remove unuseful code in get_xx_nand_para functions
mtd: denali: Remove device_info_tag structure
mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip
mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips
mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips
Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to
redwood driver removal.
arch/arm/mach-omap1/board-nokia770.c
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (32 commits)
Blackfin: gpio: add a debounce stub
Blackfin: update defconfigs
Blackfin: remove CONFIG_MEM_GENERIC_BOARD
Blackfin: dpmc: punt unnecessary RTC_ISTAT clearing
Blackfin: unify rotary encoder bitmasks
Blackfin: unify SDH/RSI bitmasks
Blackfin: BF54x: tweak DMAC MMR naming to match other ports
Blackfin: TWI: clean up the MMR names
Blackfin: add EVT_OVERRIDE/IPRIO core MMR helpers
Blackfin: add support for dynamic ftrace
Blackfin: add support for LZO compressed kernels
Blackfin: portmux: fix peripheral map overflow when requesting pins
Blackfin: document SPI CS limitations with CPHA=0
Blackfin: remove useless and outdated documentation
Blackfin: BF51x/BF52x: support GPIO Hysteresis/Schmitt Trigger options
Blackfin: gpio/portmux: clean up whitespace corruption
Blackfin: make sure mmiowb inserts a write barrier with SSYNC
Blackfin: fix DMA/cache bug when resuming from suspend to RAM
Blackfin: BF51x: fix handling of PH8 (the "internal" SPI0SEL4 pin)
Blackfin: add a GPIO_DEFAULT_BOOT_SPI_CS
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
Architectures don't need to define ISA_DMA_THRESHOLD anymore.
Acked-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Fix read_persistent_clock fallout
kgdb: Do not access xtime directly
powerpc: Clean up obsolete code relating to decrementer and timebase
powerpc: Rework VDSO gettimeofday to prevent time going backwards
clocksource: Add __clocksource_updatefreq_hz/khz methods
x86: Convert common clocksources to use clocksource_register_hz/khz
timekeeping: Make xtime and wall_to_monotonic static
hrtimer: Cleanup direct access to wall_to_monotonic
um: Convert to use read_persistent_clock
timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset
powerpc: Cleanup xtime usage
powerpc: Simplify update_vsyscall
time: Kill off CONFIG_GENERIC_TIME
time: Implement timespec_add
x86: Fix vtime/file timestamp inconsistencies
Trivial conflicts in Documentation/feature-removal-schedule.txt
Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as
per Thomas' earlier merge commit 47916be4e28c ("Merge branch
'powerpc.cherry-picks' into timers/clocksource")
The GPIO API was extended recently to include debounce functions, but
since the on-chip Blackfin GPIO modules don't support this stuff, make
a stub in the non-GPIOLIB case so drivers build properly.
MEM_GENERIC_BOARD depends on GENERIC_BOARD, but this flag was removed
in 4f25eb85d64640bc656e72917113a84701521b99, therefore all references
to it from the source can be removed.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
The RTC ISTAT bits do not affect wakeups, and the RTC driver already
takes care of clearing this MMR when necessary. So drop the useless
clearing in the core Blackfin power code.
Avoid duplication and ugly global namespace pollution.
The standard short name for control is CTL and not CTRL. Use TWI0_xxx
even on parts that only have one TWI bus to keep things simple. Drop
all the cdef helpers since the bus driver takes care of everything.
These were partially defined, so fill out the def/cdef pieces properly.
