path: root/arch/blackfin
2012-04-26blackfin: fix ifdef fustercluck in mach-bf538/boards/ezkit.cPaul Gortmaker
This file has lots and lots of ifdef, around structure decls and structure usages. The failure issue was that we would build the BF538-EZKIT_defconfig and get: arch/blackfin/mach-bf538/boards/ezkit.c:924:3: error: 'bfin_lq035q1_device' undeclared here (not in a function) even though the same ifdef _appeared_ to enable both the struct declaration and the code that used it. Yet cpp was telling us we didn't have the struct, but we still had the usage of it. However, _appeared_ is the operative word. After marking all the anonymous #endif with their parent #ifdef config options, it was _then_ clear that there was a misplaced #endif that was hiding the struct declaration. The real guts of the patch boils down to this: -#endif +#endif /* CONFIG_MTD_M25P80 */ +#endif /* CONFIG_SPI_BFIN5XX */ [...] -#endif /* spi master and devices */ but since I had to tag the #endif with their respective #ifdef options to find this misplaced SPI endif, it would be silly to then go and delete them all. So they stay. Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: Bob Liu <lliubbo@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-06blackfin: update defconfig for bf527-ezkitBob Liu
To fix compile error: drivers/usb/musb/blackfin.h:51:3: error: #error "Please use PIO mode in MUSB driver on bf52x chip v0.0 and v0.1" make[4]: *** [drivers/usb/musb/blackfin.o] Error 1 Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-04-06blackfin: gpio: fix compile error if !CONFIG_GPIOLIBBob Liu
Add __gpio_get_value()/__gpio_set_value() to fix compile error if CONFIG_GPIOLIB = n. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-04-06blackfin: fix L1 data A overflow link issueMike Frysinger
This patch fix below compile error: "bfin-uclinux-ld: L1 data A overflow!" It is due to the recent lib/gen_crc32table.c change: 46c5801eaf86e83cb3a4142ad35188db5011fff0 crc32: bolt on crc32c it added 8KiB more data to __cacheline_aligned which cause blackfin L1 data cache overflow. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-04-02blackfin: fix cmpxchg build fails from system.h falloutPaul Gortmaker
Commit 3bed8d67469c ("Disintegrate asm/system.h for Blackfin [ver #2]") introduced arch/blackfin/include/asm/cmpxchg.h but has it also including the asm-generic one which causes this: CC arch/blackfin/kernel/asm-offsets.s In file included from arch/blackfin/include/asm/cmpxchg.h:125:0, from arch/blackfin/include/asm/atomic.h:10, from include/linux/atomic.h:4, from include/linux/spinlock.h:384, from include/linux/seqlock.h:29, from include/linux/time.h:8, from include/linux/timex.h:56, from include/linux/sched.h:57, from arch/blackfin/kernel/asm-offsets.c:10: include/asm-generic/cmpxchg.h:24:15: error: redefinition of '__xchg' arch/blackfin/include/asm/cmpxchg.h:82:29: note: previous definition of '__xchg' was here make[2]: *** [arch/blackfin/kernel/asm-offsets.s] Error 1 It really only needs two simple defines from asm-generic, so just use those instead. Cc: Bob Liu <lliubbo@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second try at vfs part d#2 from Al Viro: "Miklos' first series (with do_lookup() rewrite split into edible chunks) + assorted bits and pieces. The 'untangling of do_lookup()' series is is a splitup of what used to be a monolithic patch from Miklos, so this series is basically "how do I convince myself that his patch is correct (or find a hole in it)". No holes found and I like the resulting cleanup, so in it went..." Changes from try 1: Fix a boot problem with selinux, and commit messages prettied up a bit. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits) vfs: fix out-of-date dentry_unhash() comment vfs: split __lookup_hash untangling do_lookup() - take __lookup_hash()-calling case out of line. untangling do_lookup() - switch to calling __lookup_hash() untangling do_lookup() - merge d_alloc_and_lookup() callers untangling do_lookup() - merge failure exits in !dentry case untangling do_lookup() - massage !dentry case towards __lookup_hash() untangling do_lookup() - get rid of need_reval in !dentry case untangling do_lookup() - eliminate a loop. untangling do_lookup() - expand the area under ->i_mutex untangling do_lookup() - isolate !dentry stuff from the rest of it. vfs: move MAY_EXEC check from __lookup_hash() vfs: don't revalidate just looked up dentry vfs: fix d_need_lookup/d_revalidate order in do_lookup ext3: move headers to fs/ext3/ migrate ext2_fs.h guts to fs/ext2/ext2.h new helper: ext2_image_size() get rid of pointless includes of ext2_fs.h ext2: No longer export ext2_fs.h to user space mtdchar: kill persistently held vfsmount ...
2012-03-31new helper: ext2_image_size()Al Viro
... implemented that way since the next commit will leave it almost alone in ext2_fs.h - most of the file (including struct ext2_super_block) is going to move to fs/ext2/ext2.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-26Kbuild: centralize MKIMAGE and cmd_uimage definitionsStephen Warren
All ARCHs have the same definition of MKIMAGE. Move it to Makefile.lib to avoid duplication. All ARCHs have similar definitions of cmd_uimage. Place a sufficiently parameterized version in Makefile.lib to avoid duplication. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Mike Frysinger <vapier@gentoo.org> [Blackfin] Tested-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [unicore32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-23nmi watchdog: do not use cpp symbol in KconfigCong Wang
ARCH_HAS_NMI_WATCHDOG is a macro defined by arch, but config HARDLOCKUP_DETECTOR depends on it. This is wrong, ARCH_HAS_NMI_WATCHDOG has to be a Kconfig config, and arch's need it should select it explicitly. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21blackfin: clean up string bfin_dma_5xx after rename.Sonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin:dma: rename bfin_dma_5xx.c to bfin_dma.cBob Liu
bfin_dma_5xx is not a generic name for all blackfin chips. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bf548: ssm2602: Add ssm2602 platform data into bf548 ezkit board file.Sonic Zhang
2012-03-21Blackfin: s/#if CONFIG/#ifdef CONFIG/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21Blackfin: pnav: delete duplicate linux/export.h includeDanny Kukawka
arch/blackfin/mach-bf537/boards/pnav10.c includes 'linux/export.h' twice. No need to include the file a second time in a #ifdef block if already included at top. Remove the duplicate. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bf561: add ppi DLEN macro for 10bits to 16bitsScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21arch: blackfin: udpate defconfigBob Liu
choose musb by default for bf527 and bf548. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21Disintegrate asm/system.h for Blackfin [ver #2]David Howells
Disintegrate asm/system.h for Blackfin. Signed-off-by: David Howells <dhowells@redhat.com> cc: uclinux-dist-devel@blackfin.uclinux.org Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21arch/blackfin: don't generate random mac in bfin_get_ether_addr()Danny Kukawka
Changed bfin_get_ether_addr() to return a state and to set no random mac address if the board don't provide one. Let the caller of bfin_get_ether_addr() set a random mac address if the return value is not 0. v2: don't set random mac in bfin_get_ether_addr() Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21Blackfin: wire up new process_vm syscallsMike Frysinger
2012-03-21blackfin: cleanup anomaly workaroundsBob Liu
cleanup ANOMALY_05000312 and ANOMALY_05000244 Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: update default defconfigBob Liu
Update default defconfig by selecting correct net device driver. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: thread_info: add suspend flagBob Liu
Add suspend flag to thread_info for suspend/resume. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bfin: add bfin_ad73311_machine platform deviceBob Liu
we can pass sport enable pin through platform data if customer board has reset pin, add it in ad73311_gpio array and modify id to 2 Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: bf537: stamp: update board file for 193xBob Liu
2012-03-21blackfin: kgdb: skip hardware watchpoint testBob Liu
blackfin doesn't support hardware watchpoint except for over JTAG emulator. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bf548: add ppi interrupt mask and blanking clocksScott Jiang
2012-03-21blackfin: bf561: forgot CSYNC in get_core_lock_noflushBob Liu
SMP kgdb runs into dead loop without this CSYNC when one core single steps over get_core_lock_noflush and the other executes get_core_lock as a slave node. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21spi/bfin_spi: drop bits_per_word from client dataMike Frysinger
No other SPI controller has this field, and SPI clients should be setting this up in their own drivers. So drop it from the Blackfin controller to keep people from using it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: cplb-mpu: fix page mask table overflowBarry Song
page mask table will overflow without xip related macros. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: restore L1 base address and lengthBarry Song
Restore L1 base address and length to 0 after free else the value will be wrong. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: timer: refine bfin simple timer driverSteven Miao
Add ioctl cmd for gptimer test app and do some codecleanup(remove spaces). Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21BF561 MDMA : fixed BF561 DMA MMRs definition mismatchSteven Miao
MDMA io base defined in arch/blackfin/mach-bf561/dma.c do not match the definition of MDMA MMRs in arch/blackfin/mach-bf561/include/mach/defBF561.h Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bfin_sport: add support for ADC/DAC.Bob Liu
In order to support ADC/DAC demo, add NDSO_MODE mode to bfin_sport.c. After that userspace apps like ndso/awg can work fine. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-09blackfin: bf561: add adv7183 capture supportBob Liu
2012-01-09blackfin: bf537: add capture supportBob Liu
2012-01-09blackfin: bf548: add capture supportScott Jiang
2012-01-09blackfin: time-ts: rm unused func broadcast_timer_setup()Bob Liu
broadcast_timer_setup() has no user now, drop it. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: i2c-lcd: change default clock rateAaron Wu
Change default clock rate of GPIO based I2C operation for BF533 and BF561 to bring up the I2C interface LCD display Signed-off-by: Aaron Wu <Aaron.Wu@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: mac: dsa: add vlan mask in board fileSteven Miao
Else push file through ftp/rcp will fail. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: bf537: change num_chipselect for spi-sportScott Jiang
spi sport driver can support any gpio as its cs pin. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: serial: bfin-uart: remove unused fieldSonic Zhang
Remove unused field for hardware flow control. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09bf54x: get mem size: missing break in switchSteven Miao
2012-01-09blackfin: smp: fix msg queue overflow issueSteven Miao
disable preemption when icache flush and use wait mode cross call, hold the msg queue lock while handle cross function call to avoid overflow Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: config: update macro SPI_BFIN in board fileSonic Zhang
Macro name for spi controller driver has been modified, so update default board file accordingly. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: config: update def config for all boardsScott Jiang
Config name for spi controller driver has been modified in previous commit, so update default config accordingly. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
