path: root/arch/blackfin
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM subsystem from Thierry Reding: "The new PWM subsystem aims at collecting all implementations of the legacy PWM API and to eventually replace it completely. The subsystem has been in development for over half a year now and many drivers have already been converted. It has been in linux-next for a couple of weeks and there have been no major issues so I think it is ready for inclusion in your tree." Arnd Bergmann <arnd@arndb.de>: "Very much Ack on the new subsystem. It uses the interface declarations as the previously separate pwm drivers, so nothing changes for now in the drivers using it, although it enables us to change those more easily in the future if we want to. This work is also one of the missing pieces that are required to eventually build ARM kernels for multiple platforms, which is currently prohibited (amongs other things) by the fact that you cannot have more than one driver exporting the pwm functions." Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Fix up trivial conflicts with other cleanups and DT updates. * 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits) pwm: pwm-tiehrpwm: PWM driver support for EHRPWM pwm: pwm-tiecap: PWM driver support for ECAP APWM pwm: fix used-uninitialized warning in pwm_get() pwm: add lpc32xx PWM support pwm_backlight: pass correct brightness to callback pwm: Use pr_* functions in pwm-samsung.c file pwm: Convert pwm-samsung to use devm_* APIs pwm: Convert pwm-tegra to use devm_clk_get() pwm: pwm-mxs: Return proper error if pwmchip_remove() fails pwm: pwm-bfin: Return proper error if pwmchip_remove() fails pwm: pxa: Propagate pwmchip_remove() error pwm: Convert pwm-pxa to use devm_* APIs pwm: Convert pwm-vt8500 to use devm_* APIs pwm: Convert pwm-imx to use devm_* APIs pwm: Conflict with legacy PWM API pwm: pwm-mxs: add pinctrl support pwm: pwm-mxs: use devm_* managed functions pwm: pwm-mxs: use global reset function stmp_reset_block pwm: pwm-mxs: encode soc name in compatible string pwm: Take over maintainership of the PWM subsystem ...
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David S Miller: 1) Remove the ipv4 routing cache. Now lookups go directly into the FIB trie and use prebuilt routes cached there. No more garbage collection, no more rDOS attacks on the routing cache. Instead we now get predictable and consistent performance, no matter what the pattern of traffic we service. This has been almost 2 years in the making. Special thanks to Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who have helped along the way. I'm sure that with a change of this magnitude there will be some kind of fallout, but such things ought the be simple to fix at this point. Luckily I'm not European so I'll be around all of August to fix things :-) The major stages of this work here are each fronted by a forced merge commit whose commit message contains a top-level description of the motivations and implementation issues. 2) Pre-demux of established ipv4 TCP sockets, saves a route demux on input. 3) TCP SYN/ACK performance tweaks from Eric Dumazet. 4) Add namespace support for netfilter L4 conntrack helpers, from Gao Feng. 5) Add config mechanism for Energy Efficient Ethernet to ethtool, from Yuval Mintz. 6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet. 7) Support for connection tracker helpers in userspace, from Pablo Neira Ayuso. 8) Allow userspace driven TX load balancing functions in TEAM driver, from Jiri Pirko. 9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with embedded gotos. 10) TCP Small Queues, essentially minimize the amount of TCP data queued up in the packet scheduler layer. Whereas the existing BQL (Byte Queue Limits) limits the pkt_sched --> netdevice queuing levels, this controls the TCP --> pkt_sched queueing levels. From Eric Dumazet. 11) Reduce the number of get_page/put_page ops done on SKB fragments, from Alexander Duyck. 12) Implement protection against blind resets in TCP (RFC 5961), from Eric Dumazet. 13) Support the client side of TCP Fast Open, basically the ability to send data in the SYN exchange, from Yuchung Cheng. Basically, the sender queues up data with a sendmsg() call using MSG_FASTOPEN, then they do the connect() which emits the queued up fastopen data. 14) Avoid all the problems we get into in TCP when timers or PMTU events hit a locked socket. The TCP Small Queues changes added a tcp_release_cb() that allows us to queue work up to the release_sock() caller, and that's what we use here too. From Eric Dumazet. 15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits) genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP r8169: revert "add byte queue limit support". ipv4: Change rt->rt_iif encoding. net: Make skb->skb_iif always track skb->dev ipv4: Prepare for change of rt->rt_iif encoding. ipv4: Remove all RTCF_DIRECTSRC handliing. ipv4: Really ignore ICMP address requests/replies. decnet: Don't set RTCF_DIRECTSRC. net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse. ipv4: Remove redundant assignment rds: set correct msg_namelen openvswitch: potential NULL deref in sample() tcp: dont drop MTU reduction indications bnx2x: Add new 57840 device IDs tcp: avoid oops in tcp_metrics and reset tcpm_stamp niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value niu: Fix to check for dma mapping errors. net: Fix references to out-of-scope variables in put_cmsg_compat() net: ethernet: davinci_emac: add pm_runtime support net: ethernet: davinci_emac: Remove unnecessary #include ...
2012-07-24bf60x: fix build warningBob Liu
Fix several build warning while using bf609-ezkit_defconfig. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24PM: add BF60x flash suspend and resume supportSteven Miao
Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: twi: read twi mmr via bfin_read macroSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24dpm: deepsleep: reserve stackSteven Miao
Reserve 12 bytes on the stack for deepsleep use. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: cpufreq: fix anomaly 05000273Sonic Zhang
Anomaly 05000273 doesn't apply to bf60x. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add adv7511 display supportScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: cplb-nompu: fix ROM cplb size for bf609-ezkitBob Liu
In user xip test, there is a cplb error when ROMKERNEL try to mount romfs using 'mount -t romfs /dev/mtdblock2 /mnt', becasue the CPLB setting is not correct. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: Add double fault, hardware error and NMI SEC handlerSonic Zhang
2012-07-24bf60x: update anomaly id in serial and twi driver headers.Sonic Zhang
2012-07-24bf60x: vs6624 pin updateVivi Li
Change ce pin to PE4 according to new adaptor board and re-define ppi for vs6624 to avoid gpio conflict. Signed-off-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: add default anomaly setting.Sonic Zhang
2012-07-24bf60x: update bf60x anomaly list.Sonic Zhang
2012-07-24bf60x: sec: Enable sec interrupt source priority configuration.Sonic Zhang
Customize the SEC interrupt priority array in machine ints-priority.c. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: sec: Clean up interrupt initialization code for SEC.Sonic Zhang
Turn SEC related macro CONFIG_BF60x into SEC_GCTL. Move machine specific GPIO_PINT macros to machine gpio header. Split SEC init_arch_irq() and vec_to_irq() from old SIC. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: reuse bf5xx-i2s-pcm.c as i2s pcm driverScott Jiang
It's the same for both bf5xx and bf6xx soc. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf561: add capabilities in adv7183_inputsScott Jiang
Add capabilities in adv7183_inputs to indicate that S_STD is supported. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: convert vs6624 blank_clocks to black_pixelsScott Jiang
PPI driver has changed blank units from clocks to pixels. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: fix musb macro nameBob Liu
Musb can't work since the marco name has been changed. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24cleanup: sec and linkport only built on bf60xSteven Miao
2012-07-24bfin: pint: add pint suspend and resumeSteven Miao
Add pint suspend and resume if defined BFIN_GPIO_PINT. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: pm: add pint suspend and resume supportSteven Miao
save and restore pint sec CTL save and restore pint registers add pint suspend and resume when suspend to mem Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add HDMI support for adv7842Scott Jiang
2012-07-24bf609: add CVBS and S-Video support for adv7842Scott Jiang
2012-07-24gpiokeys: add gpio keyboard platform deviceSteven Miao
2012-07-24bf60x: pm: pass wakeup paramSteven Miao
Pass wake up source mask and wakeup source polarity to deepsleep and hibernate. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: pm: add smc nor flash syscore opsSteven Miao
2012-07-24bfin: simple_timer: add READ_COUNTER ioctl and add NOIRQ timer modeSteven Miao
2012-07-24blackfin: bf609-ezkit: add probe_type for norflashBob Liu
Set .probe_type = "map_rom" for norflash so that xip_test can run correctly. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24i2c: i2c-bfin-twi: Always access 16 bit MMR by bfin 16 bit access Macro.Sonic Zhang
Otherwise, the compiler may optimize assemble code into 8bit access instruction when target register is 8 bit width. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add ssm2602 support on bf609 platformScott Jiang
2012-07-24blackfin: mach-common: ints-priority add irq_set_wakeBob Liu
Add irq_set_wake to bfin_sec_irqchip, drivers like stmmac need it. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24v4l2: add adv7842 video decoder driverScott Jiang
2012-07-24cache: enable L2 sram icache in menuconfigSteven Miao
2012-07-24cpufreq: change debug message level to show clock change errorSteven Miao
2012-07-24bf60x: Add wake up latency bench for deep sleep mode.Sonic Zhang
2012-07-24bfin: pm: add deepsleep for bf60xSonic Zhang
Add add deepsleep for bf60x. 1. Call DMC init functions to enter and exit DDR self refresh mode. 2. Wait till CGU PLL is locked after wake up and exit DDR self refresh mode. 3. Make asessembly function enter_deepsleep comply with C funtion ABI in order to call other C functions. 4. Switch kernel stack by register EX_SCRATCH_REG. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24irq: set cgu event handle to fasteoi handleSteven Miao
2012-07-24blackfin: Kconfig: fix ROM range for bf60xBob Liu
ROM range of bf60x is above 0xb0000000. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin: reorg clock init steps for bf609Bob Liu
So that user can set the clocks through menuconfig. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin-dma: only use MDMA3 on bf609Steven Miao
2012-07-24bf609: bfin_crc: Remove unused CRC TX DMA platform resources.Sonic Zhang
2012-07-24pm: dpmc macro typo fixSteven Miao
2012-07-24bf60x: bfin_crc: move structure bfin_crc out of head file.Sonic Zhang
2012-07-24bf60x: Enable Blackfin CRC crypto driver by default.Sonic Zhang
2012-07-24bf609: crypto: Add blackfin crypto crc driver platform data.Sonic Zhang
2012-07-24blackfin: Call sg_for_each to pass through the whole sg list.Sonic Zhang
Otherwise, chained sg list may be missed. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
