Need include "asm/uaccess.h" to pass compiling.
The related error (with allmodconfig):
arch/c6x/mm/init.c: In function `paging_init':
arch/c6x/mm/init.c:46:2: error: implicit declaration of function `set_fs' [-Werror=implicit-function-declaration]
arch/c6x/mm/init.c:46:9: error: `KERNEL_DS' undeclared (first use in this function)
arch/c6x/mm/init.c:46:9: note: each undeclared identifier is reported only once for each function it appears in
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: <stable@vger.kernel.org> [3.10.x]
Use common help functions to free reserved pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Original port to early 2.6 kernel using TI COFF toolchain.
Brought up to date by Mark Salter <msalter@redhat.com>
The C6X architecture currently lacks an MMU so memory management is relatively
simple. There is no bus snooping between L2 and main memory but coherent DMA
memory is supported by making regions of main memory uncached. If such a region
is desired, it can be specified on the commandline with a "memdma=" argument.
Signed-off-by: Aurelien Jacquiot <a-jacquiot@ti.com>
Signed-off-by: Mark Salter <msalter@redhat.com>
