path: root/arch/c6x
2017-11-02License cleanup: add SPDX license identifier to uapi header files with a licenseGreg Kroah-Hartman
Many user space API headers have licensing information, which is either incomplete, badly formatted or just a shorthand for referring to the license under which the file is supposed to be. This makes it hard for compliance tools to determine the correct license. Update these files with an SPDX license identifier. The identifier was chosen based on the license information in the file. GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license identifier with the added 'WITH Linux-syscall-note' exception, which is the officially assigned exception identifier for the kernel syscall exception: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". This exception makes it possible to include GPL headers into non GPL code, without confusing license compliance tools. Headers which have either explicit dual licensing or are just licensed under a non GPL license are updated with the corresponding SPDX identifier and the GPLv2 with syscall exception identifier. The format is: ((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE) SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. The update does not remove existing license information as this has to be done on a case by case basis and the copyright holders might have to be consulted. This will happen in a separate step. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02License cleanup: add SPDX license identifier to uapi header files with no ↵Greg Kroah-Hartman
license Many user space API headers are missing licensing information, which makes it hard for compliance tools to determine the correct license. By default are files without license information under the default license of the kernel, which is GPLV2. Marking them GPLV2 would exclude them from being included in non GPLV2 code, which is obviously not intended. The user space API headers fall under the syscall exception which is in the kernels COPYING file: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". otherwise syscall usage would not be possible. Update the files which contain no license information with an SPDX license identifier. The chosen identifier is 'GPL-2.0 WITH Linux-syscall-note' which is the officially assigned identifier for the Linux syscall exception. SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-22arch: remove unused *_segments() macros/functionsTobias Klauser
Some architectures define the no-op macros/functions copy_segments, release_segments and forget_segments. These are used nowhere in the tree, so removed them. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Vineet Gupta <vgupta@synopsys.com> [for arch/arc] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-24c6x: Convert to using %pOF instead of full_nameRob Herring
Now that we have a custom printf format specifier, convert users of full_name to use %pOF instead. This is preparation to remove storing of the full path string for each node. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Signed-off-by: Mark Salter <msalter@redhat.com>
2017-08-24c6x: defconfig: Cleanup from old Kconfig optionsKrzysztof Kozlowski
Remove old, dead Kconfig options (in order appearing in this commit): - EXPERIMENTAL is gone since v3.9; - MISC_DEVICES: commit 7c5763b8453a ("drivers: misc: Remove MISC_DEVICES config option"); Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Mark Salter <msalter@redhat.com>
2017-07-15Merge branch 'work.uaccess-unaligned' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uacess-unaligned removal from Al Viro: "That stuff had just one user, and an exotic one, at that - binfmt_flat on arm and m68k" * 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: kill {__,}{get,put}_user_unaligned() binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
2017-07-10c6x: move generic-y of exported headers to uapi/asm/KbuildMasahiro Yamada
Since commit fcc8487d477a ("uapi: export all headers under uapi directories"), all (and only) headers under uapi directories are exported, but asm-generic wrappers are still exceptions. To complete de-coupling the uapi from kernel headers, move generic-y of exported headers to uapi/asm/Kbuild. With this change, "make headers_install" will just need to parse uapi/asm/Kbuild to build up exported headers. Also, move "generic-y += kprobes.h" up in order to keep the entries sorted. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-06Merge tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull dma-mapping infrastructure from Christoph Hellwig: "This is the first pull request for the new dma-mapping subsystem In this new subsystem we'll try to properly maintain all the generic code related to dma-mapping, and will further consolidate arch code into common helpers. This pull request contains: - removal of the DMA_ERROR_CODE macro, replacing it with calls to ->mapping_error so that the dma_map_ops instances are more self contained and can be shared across architectures (me) - removal of the ->set_dma_mask method, which duplicates the ->dma_capable one in terms of functionality, but requires more duplicate code. - various updates for the coherent dma pool and related arm code (Vladimir) - various smaller cleanups (me)" * tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits) ARM: dma-mapping: Remove traces of NOMMU code ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus ARM: NOMMU: Introduce dma operations for noMMU drivers: dma-mapping: allow dma_common_mmap() for NOMMU drivers: dma-coherent: Introduce default DMA pool drivers: dma-coherent: Account dma_pfn_offset when used with device tree dma: Take into account dma_pfn_offset dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs dma-mapping: remove dmam_free_noncoherent crypto: qat - avoid an uninitialized variable warning au1100fb: remove a bogus dma_free_nonconsistent call MAINTAINERS: add entry for dma mapping helpers powerpc: merge __dma_set_mask into dma_set_mask dma-mapping: remove the set_dma_mask method powerpc/cell: use the dma_supported method for ops switching powerpc/cell: clean up fixed mapping dma_ops initialization tile: remove dma_supported and mapping_error methods xen-swiotlb: remove xen_swiotlb_set_dma_mask arm: implement ->dma_supported instead of ->set_dma_mask mips/loongson64: implement ->dma_supported instead of ->set_dma_mask ...
2017-07-03Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather large update for timers/timekeeping: - compat syscall consolidation (Al Viro) - Posix timer consolidation (Christoph Helwig / Thomas Gleixner) - Cleanup of the device tree based initialization for clockevents and clocksources (Daniel Lezcano) - Consolidation of the FTTMR010 clocksource/event driver (Linus Walleij) - The usual set of small fixes and updates all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (93 commits) timers: Make the cpu base lock raw clocksource/drivers/mips-gic-timer: Fix an error code in 'gic_clocksource_of_init()' clocksource/drivers/fsl_ftm_timer: Unmap region obtained by of_iomap clocksource/drivers/tcb_clksrc: Make IO endian agnostic clocksource/drivers/sun4i: Switch to the timer-of common init clocksource/drivers/timer-of: Fix invalid iomap check Revert "ktime: Simplify ktime_compare implementation" clocksource/drivers: Fix uninitialized variable use in timer_of_init kselftests: timers: Add test for frequency step kselftests: timers: Fix inconsistency-check to not ignore first timestamp time: Add warning about imminent deprecation of CONFIG_GENERIC_TIME_VSYSCALL_OLD time: Clean up CLOCK_MONOTONIC_RAW time handling posix-cpu-timers: Make timespec to nsec conversion safe itimer: Make timeval to nsec conversion range limited timers: Fix parameter description of try_to_del_timer_sync() ktime: Simplify ktime_compare implementation clocksource/drivers/fttmr010: Factor out clock read code clocksource/drivers/fttmr010: Implement delay timer clocksource/drivers: Add timer-of common init routine clocksource/drivers/tcb_clksrc: Save timer context on suspend/resume ...
2017-07-03binfmt_flat: flat_{get,put}_addr_from_rp() should be able to failAl Viro
on MMU targets EFAULT is possible here. Make both return 0 or error, passing what used to be the return value of flat_get_addr_from_rp() by reference. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-28arch: remove unused macro/function thread_saved_pc()Tobias Klauser
The only user of thread_saved_pc() in non-arch-specific code was removed in commit 8243d5597793 ("sched/core: Remove pointless printout in sched_show_task()"). Remove the implementations as well. Some architectures use thread_saved_pc() in their arch-specific code. Leave their thread_saved_pc() intact. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-06-20c6x: remove DMA_ERROR_CODEChristoph Hellwig
2017-06-04signal: Remove non-uapi <asm/siginfo.h>Christoph Hellwig
By moving the kernel side __SI_* defintions right next to the userspace ones we can kill the non-uapi versions of <asm/siginfo.h> include include/asm-generic/siginfo.h and untangle the unholy mess of includes. [ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-ia64@vger.kernel.org Cc: Arnd Bergmann <arnd@arndb.de> Cc: sparclinux@vger.kernel.org Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
2017-05-11uapi: export all headers under uapi directoriesNicolas Dichtel
Regularly, when a new header is created in include/uapi/, the developer forgets to add it in the corresponding Kbuild file. This error is usually detected after the release is out. In fact, all headers under uapi directories should be exported, thus it's useless to have an exhaustive list. After this patch, the following files, which were not exported, are now exported (with make headers_install_all): asm-arc/kvm_para.h asm-arc/ucontext.h asm-blackfin/shmparam.h asm-blackfin/ucontext.h asm-c6x/shmparam.h asm-c6x/ucontext.h asm-cris/kvm_para.h asm-h8300/shmparam.h asm-h8300/ucontext.h asm-hexagon/shmparam.h asm-m32r/kvm_para.h asm-m68k/kvm_para.h asm-m68k/shmparam.h asm-metag/kvm_para.h asm-metag/shmparam.h asm-metag/ucontext.h asm-mips/hwcap.h asm-mips/reg.h asm-mips/ucontext.h asm-nios2/kvm_para.h asm-nios2/ucontext.h asm-openrisc/shmparam.h asm-parisc/kvm_para.h asm-powerpc/perf_regs.h asm-sh/kvm_para.h asm-sh/ucontext.h asm-tile/shmparam.h asm-unicore32/shmparam.h asm-unicore32/ucontext.h asm-x86/hwcap2.h asm-xtensa/kvm_para.h drm/armada_drm.h drm/etnaviv_drm.h drm/vgem_drm.h linux/aspeed-lpc-ctrl.h linux/auto_dev-ioctl.h linux/bcache.h linux/btrfs_tree.h linux/can/vxcan.h linux/cifs/cifs_mount.h linux/coresight-stm.h linux/cryptouser.h linux/fsmap.h linux/genwqe/genwqe_card.h linux/hash_info.h linux/kcm.h linux/kcov.h linux/kfd_ioctl.h linux/lightnvm.h linux/module.h linux/nbd-netlink.h linux/nilfs2_api.h linux/nilfs2_ondisk.h linux/nsfs.h linux/pr.h linux/qrtr.h linux/rpmsg.h linux/sched/types.h linux/sed-opal.h linux/smc.h linux/smc_diag.h linux/stm.h linux/switchtec_ioctl.h linux/vfio_ccw.h linux/wil6210_uapi.h rdma/bnxt_re-abi.h Note that I have removed from this list the files which are generated in every exported directories (like .install or .install.cmd). Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all subdirs with a pure makefile command. For the record, note that exported files for asm directories are a mix of files listed by: - include/uapi/asm-generic/Kbuild.asm; - arch/<arch>/include/uapi/asm/Kbuild; - arch/<arch>/include/asm/Kbuild. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Acked-by: Mark Salter <msalter@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-01Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm updates from Ingo Molnar: "The main changes in this cycle were: - unwinder fixes and enhancements - improve ftrace interaction with the unwinder - optimize the code footprint of WARN() and related debugging constructs - ... plus misc updates, cleanups and fixes" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) x86/unwind: Dump all stacks in unwind_dump() x86/unwind: Silence more entry-code related warnings x86/ftrace: Fix ebp in ftrace_regs_caller that screws up unwinder x86/unwind: Remove unused 'sp' parameter in unwind_dump() x86/unwind: Prepend hex mask value with '0x' in unwind_dump() x86/unwind: Properly zero-pad 32-bit values in unwind_dump() x86/unwind: Ensure stack pointer is aligned debug: Avoid setting BUGFLAG_WARNING twice x86/unwind: Silence entry-related warnings x86/unwind: Read stack return address in update_stack_state() x86/unwind: Move common code into update_stack_state() debug: Fix __bug_table[] in arch linker scripts debug: Add _ONCE() logic to report_bug() x86/debug: Define BUG() again for !CONFIG_BUG x86/debug: Implement __WARN() using UD0 x86/ftrace: Use Makefile logic instead of #ifdef for compiling ftrace_*.o x86/ftrace: Add -mfentry support to x86_32 with DYNAMIC_FTRACE set x86/ftrace: Clean up ftrace_regs_caller x86/ftrace: Add stack frame pointer to ftrace_caller x86/ftrace: Move the ftrace specific code out of entry_32.S ...
2017-05-01Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "The timer departement delivers: - more year 2038 rework - a massive rework of the arm achitected timer - preparatory patches to allow NTP correction of clock event devices to avoid early expiry - the usual pile of fixes and enhancements all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits) timer/sysclt: Restrict timer migration sysctl values to 0 and 1 arm64/arch_timer: Mark errata handlers as __maybe_unused Clocksource/mips-gic: Remove redundant non devicetree init MIPS/Malta: Probe gic-timer via devicetree clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver clocksource: arm_arch_timer: add GTDT support for memory-mapped timer acpi/arm64: Add memory-mapped timer support in GTDT driver clocksource: arm_arch_timer: simplify ACPI support code. acpi/arm64: Add GTDT table parse driver clocksource: arm_arch_timer: split MMIO timer probing. clocksource: arm_arch_timer: add structs to describe MMIO timer clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call clocksource: arm_arch_timer: refactor arch_timer_needs_probing clocksource: arm_arch_timer: split dt-only rate handling x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks um/time: Set ->min_delta_ticks and ->max_delta_ticks tile/time: Set ->min_delta_ticks and ->max_delta_ticks score/time: Set ->min_delta_ticks and ->max_delta_ticks ...
2017-05-01Merge branch 'work.uaccess' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uaccess unification updates from Al Viro: "This is the uaccess unification pile. It's _not_ the end of uaccess work, but the next batch of that will go into the next cycle. This one mostly takes copy_from_user() and friends out of arch/* and gets the zero-padding behaviour in sync for all architectures. Dealing with the nocache/writethrough mess is for the next cycle; fortunately, that's x86-only. Same for cleanups in iov_iter.c (I am sold on access_ok() in there, BTW; just not in this pile), same for reducing __copy_... callsites, strn*... stuff, etc. - there will be a pile about as large as this one in the next merge window. This one sat in -next for weeks. -3KLoC" * 'work.uaccess' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (96 commits) HAVE_ARCH_HARDENED_USERCOPY is unconditional now CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional now m32r: switch to RAW_COPY_USER hexagon: switch to RAW_COPY_USER microblaze: switch to RAW_COPY_USER get rid of padding, switch to RAW_COPY_USER ia64: get rid of copy_in_user() ia64: sanitize __access_ok() ia64: get rid of 'segment' argument of __do_{get,put}_user() ia64: get rid of 'segment' argument of __{get,put}_user_check() ia64: add extable.h powerpc: get rid of zeroing, switch to RAW_COPY_USER esas2r: don't open-code memdup_user() alpha: fix stack smashing in old_adjtimex(2) don't open-code kernel_setsockopt() mips: switch to RAW_COPY_USER mips: get rid of tail-zeroing in primitives mips: make copy_from_user() zero tail explicitly mips: clean and reorder the forest of macros... mips: consolidate __invoke_... wrappers ...
2017-04-26CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional nowAl Viro
all architectures converted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-14c6x/timer64: Set ->min_delta_ticks and ->max_delta_ticksNicolai Stange
In preparation for making the clockevents core NTP correction aware, all clockevent device drivers must set ->min_delta_ticks and ->max_delta_ticks rather than ->min_delta_ns and ->max_delta_ns: a clockevent device's rate is going to change dynamically and thus, the ratio of ns to ticks ceases to stay invariant. Make the c6x arch's clockevent driver initialize these fields properly. This patch alone doesn't introduce any change in functionality as the clockevents core still looks exclusively at the (untouched) ->min_delta_ns and ->max_delta_ns. As soon as this has changed, a followup patch will purge the initialization of ->min_delta_ns and ->max_delta_ns from this driver. Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2017-04-03debug: Fix __bug_table[] in arch linker scriptsPeter Zijlstra
The kbuild test robot reported this build failure on a number of architectures: > make.cross ARCH=arm > lib/lib.a(bug.o): In function `find_bug': > >> lib/bug.c:135: undefined reference to `__start___bug_table' > >> lib/bug.c:135: undefined reference to `__stop___bug_table' Caused by: 19d436268dde ("debug: Add _ONCE() logic to report_bug()") Which moved the BUG_TABLE from RO_DATA_SECTION() to RW_DATA_SECTION(), but a number of architectures don't use RW_DATA_SECTION(), so they ended up with no __bug_table[] ... Ideally all those would use RW_DATA_SECTION() in their linker scripts, but that's for another day. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: kbuild test robot <fengguang.wu@intel.com> Cc: kbuild-all@01.org Cc: tipbuild@zytor.com Link: http://lkml.kernel.org/r/20170330154927.o6qmgfp4bdhrajbm@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-29Merge branch 'regset' (PTRACE_SETREGSET data leakage)Linus Torvalds
Merge PTRACE_SETREGSET leakage fixes from Dave Martin: "This series is the collection of fixes I proposed on this topic, that have not yet appeared upstream or in the stable branches, The issue can leak kernel stack, but doesn't appear to allow userspace to attack the kernel directly. The affected architectures are c6x, h8300, metag, mips and sparc. [ Mark Salter points out that c6x has no MMU or other mechanism to prevent userspace access to kernel code or data on c6x, but it doesn't hurt to clean that case up too. ] The bugs arise from use of user_regset_copyin(). Users of user_regset_copyin() can work in one of two ways: 1) Copy directly to thread_struct or equivalent. (This seems to be the design assumption of the regset API, and is the most common approach.) 2) Copy to a local variable and then transfer to thread_struct. (A significant minority of cases.) Buggy code typically involves approach 2" * emailed patches from Dave Martin <Dave.Martin@arm.com>: sparc/ptrace: Preserve previous registers for short regset write mips/ptrace: Preserve previous registers for short regset write metag/ptrace: Reject partial NT_METAG_RPIPE writes metag/ptrace: Provide default TXSTATUS for short NT_PRSTATUS metag/ptrace: Preserve previous registers for short regset write h8300/ptrace: Fix incorrect register transfer count c6x/ptrace: Remove useless PTRACE_SETREGSET implementation
2017-03-29c6x/ptrace: Remove useless PTRACE_SETREGSET implementationDave Martin
gpr_set won't work correctly and can never have been tested, and the correct behaviour is not clear due to the endianness-dependent task layout. So, just remove it. The core code will now return -EOPNOTSUPPORT when trying to set NT_PRSTATUS on this architecture until/unless a correct implementation is supplied. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-28c6x: switch to RAW_COPY_USERAl Viro
2017-03-28c6x: remove duplicate definition of __access_okAl Viro
2017-03-28asm-generic/uaccess.h: don't mess with __copy_{to,from}_userAl Viro
only h8300 actually used those; might as well define them there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-28new helper: uaccess_kernel()Al Viro
2017-03-27add asm-generic/extable.hAl Viro
... and make the users of generic uaccess.h use that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/task_stack.h> We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task_stack.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/task.h> We are going to split <linux/sched/task.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/debug.h> We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/debug.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-27kprobes: move kprobe declarations to asm-generic/kprobes.hLuis R. Rodriguez
Often all is needed is these small helpers, instead of compiler.h or a full kprobes.h. This is important for asm helpers, in fact even some asm/kprobes.h make use of these helpers... instead just keep a generic asm file with helpers useful for asm code with the least amount of clutter as possible. Likewise we need now to also address what to do about this file for both when architectures have CONFIG_HAVE_KPROBES, and when they do not. Then for when architectures have CONFIG_HAVE_KPROBES but have disabled CONFIG_KPROBES. Right now most asm/kprobes.h do not have guards against CONFIG_KPROBES, this means most architecture code cannot include asm/kprobes.h safely. Correct this and add guards for architectures missing them. Additionally provide architectures that not have kprobes support with the default asm-generic solution. This lets us force asm/kprobes.h on the header include/linux/kprobes.h always, but most importantly we can now safely include just asm/kprobes.h on architecture code without bringing the full kitchen sink of header files. Two architectures already provided a guard against CONFIG_KPROBES on its kprobes.h: sh, arch. The rest of the architectures needed gaurds added. We avoid including any not-needed headers on asm/kprobes.h unless kprobes have been enabled. In a subsequent atomic change we can try now to remove compiler.h from include/linux/kprobes.h. During this sweep I've also identified a few architectures defining a common macro needed for both kprobes and ftrace, that of the definition of the breakput instruction up. Some refer to this as BREAKPOINT_INSTRUCTION. This must be kept outside of the #ifdef CONFIG_KPROBES guard. [mcgrof@kernel.org: fix arm64 build] Link: http://lkml.kernel.org/r/CAB=NE6X1WMByuARS4mZ1g9+W=LuVBnMDnh_5zyN0CLADaVh=Jw@mail.gmail.com [sfr@canb.auug.org.au: fixup for kprobes declarations moving] Link: http://lkml.kernel.org/r/20170214165933.13ebd4f4@canb.auug.org.au Link: http://lkml.kernel.org/r/20170203233139.32682-1-mcgrof@kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-25Merge tag 'for-next-dma_ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma DMA mapping updates from Doug Ledford: "Drop IB DMA mapping code and use core DMA code instead. Bart Van Assche noted that the ib DMA mapping code was significantly similar enough to the core DMA mapping code that with a few changes it was possible to remove the IB DMA mapping code entirely and switch the RDMA stack to use the core DMA mapping code. This resulted in a nice set of cleanups, but touched the entire tree and has been kept separate for that reason." * tag 'for-next-dma_ops' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (37 commits) IB/rxe, IB/rdmavt: Use dma_virt_ops instead of duplicating it IB/core: Remove ib_device.dma_device nvme-rdma: Switch from dma_device to dev.parent RDS: net: Switch from dma_device to dev.parent IB/srpt: Modify a debug statement IB/srp: Switch from dma_device to dev.parent IB/iser: Switch from dma_device to dev.parent IB/IPoIB: Switch from dma_device to dev.parent IB/rxe: Switch from dma_device to dev.parent IB/vmw_pvrdma: Switch from dma_device to dev.parent IB/usnic: Switch from dma_device to dev.parent IB/qib: Switch from dma_device to dev.parent IB/qedr: Switch from dma_device to dev.parent IB/ocrdma: Switch from dma_device to dev.parent IB/nes: Remove a superfluous assignment statement IB/mthca: Switch from dma_device to dev.parent IB/mlx5: Switch from dma_device to dev.parent IB/mlx4: Switch from dma_device to dev.parent IB/i40iw: Remove a superfluous assignment statement IB/hns: Switch from dma_device to dev.parent ...
2017-02-01sched/cputime: Remove generic asm headersFrederic Weisbecker
cputime_t is now only used by two architectures: * powerpc (when CONFIG_VIRT_CPU_ACCOUNTING_NATIVE=y) * s390 And since the core doesn't use it anymore, we don't need any arch support from the others. So we can remove their stub implementations. A final cleanup would be to provide an efficient pure arch implementation of cputime_to_nsec() for s390 and powerpc and finally remove include/linux/cputime.h . Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Link: http://lkml.kernel.org/r/1485832191-26889-36-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-01-24treewide: Consolidate get_dma_ops() implementationsBart Van Assche
Introduce a new architecture-specific get_arch_dma_ops() function that takes a struct bus_type * argument. Add get_dma_ops() in <linux/dma-mapping.h>. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-01-24treewide: Constify most dma_map_ops structuresBart Van Assche
Most dma_map_ops structures are never modified. Constify these structures such that these can be write-protected. This patch has been generated as follows: git grep -l 'struct dma_map_ops' | xargs -d\\n sed -i \ -e 's/struct dma_map_ops/const struct dma_map_ops/g' \ -e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \ -e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \ -e 's/const const struct dma_map_ops /const struct dma_map_ops /g'; sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops intel_dma_ops'); sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc); sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \ -e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \ -e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \ drivers/pci/host/*.c sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-12-25clocksource: Use a plain u64 instead of cycle_tThomas Gleixner
There is no point in having an extra type for extra confusion. u64 is unambiguous. Conversion was done with the following coccinelle script: @rem@ @@ -typedef u64 cycle_t; @fix@ typedef cycle_t; @@ -cycle_t +u64 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14arch/c6x: add option to skip sync on DMA map and unmapAlexander Duyck
This change allows us to pass DMA_ATTR_SKIP_CPU_SYNC which allows us to avoid invoking cache line invalidation if the driver will just handle it later via a sync_for_cpu or sync_for_device call. Link: http://lkml.kernel.org/r/20161110113442.76501.7673.stgit@ahduyck-blue-test.jf.intel.com Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Acked-by: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-17locking/core: Provide common cpu_relax_yield() definitionChristian Borntraeger
No need to duplicate the same define everywhere. Since the only user is stop-machine and the only provider is s390, we can use a default implementation of cpu_relax_yield() in sched.h. Suggested-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Hildenbrand <david@redhat.com> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-s390 <linux-s390@vger.kernel.org> Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1479298985-191589-1-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core, arch: Remove cpu_relax_lowlatency()Christian Borntraeger
As there are no users left, we can remove cpu_relax_lowlatency() implementations from every architecture. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Cc: <linux-arch@vger.kernel.org> Link: http://lkml.kernel.org/r/1477386195-32736-6-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core: Introduce cpu_relax_yield()Christian Borntraeger
For spinning loops people do often use barrier() or cpu_relax(). For most architectures cpu_relax and barrier are the same, but on some architectures cpu_relax can add some latency. For example on power,sparc64 and arc, cpu_relax can shift the CPU towards other hardware threads in an SMT environment. On s390 cpu_relax does even more, it uses an hypercall to the hypervisor to give up the timeslice. In contrast to the SMT yielding this can result in larger latencies. In some places this latency is unwanted, so another variant "cpu_relax_lowlatency" was introduced. Before this is used in more and more places, lets revert the logic and provide a cpu_relax_yield that can be called in places where yielding is more important than latency. By default this is the same as cpu_relax on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1477386195-32736-2-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-25locking/mutex: Kill arch specific codePeter Zijlstra
Its all generic atomic_long_t stuff now. Tested-by: Jason Low <jason.low2@hpe.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23c6x: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-05-24Merge tag 'asm-generic-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanup from Arnd Bergmann: "I have only one patch for asm-generic in this release, this one is from James Hogan and updates the generic system call table for renameat2 so we don't need to provide both renameat and renameat2 in newly added architectures" * tag 'asm-generic-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: Drop renameat syscall from default list
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-05asm-generic: Drop renameat syscall from default listJames Hogan
The newer renameat2 syscall provides all the functionality provided by the renameat syscall and adds flags, so future architectures won't need to include renameat. Therefore drop the renameat syscall from the generic syscall list unless __ARCH_WANT_RENAMEAT is defined by the architecture's unistd.h prior to including asm-generic/unistd.h, and adjust all architectures using the generic syscall list to define it so that no in-tree architectures are affected. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: linux-arch@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ley Foon Tan <lftan@altera.com> Cc: nios2-dev@lists.rocketboards.org Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-04-18c6x: Fix misspellings in comments.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
