path: root/arch/c6x
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23c6x: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-05-24Merge tag 'asm-generic-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanup from Arnd Bergmann: "I have only one patch for asm-generic in this release, this one is from James Hogan and updates the generic system call table for renameat2 so we don't need to provide both renameat and renameat2 in newly added architectures" * tag 'asm-generic-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: Drop renameat syscall from default list
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-05asm-generic: Drop renameat syscall from default listJames Hogan
The newer renameat2 syscall provides all the functionality provided by the renameat syscall and adds flags, so future architectures won't need to include renameat. Therefore drop the renameat syscall from the generic syscall list unless __ARCH_WANT_RENAMEAT is defined by the architecture's unistd.h prior to including asm-generic/unistd.h, and adjust all architectures using the generic syscall list to define it so that no in-tree architectures are affected. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: linux-arch@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ley Foon Tan <lftan@altera.com> Cc: nios2-dev@lists.rocketboards.org Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-04-18c6x: Fix misspellings in comments.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-03-25arch, ftrace: for KASAN put hard/soft IRQ entries into separate sectionsAlexander Potapenko
KASAN needs to know whether the allocation happens in an IRQ handler. This lets us strip everything below the IRQ entry point to reduce the number of unique stack traces needed to be stored. Move the definition of __irq_entry to <linux/interrupt.h> so that the users don't need to pull in <linux/ftrace.h>. Also introduce the __softirq_entry macro which is similar to __irq_entry, but puts the corresponding functions to the .softirqentry.text section. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-17mn10300, c6x: CONFIG_GENERIC_BUG must depend on CONFIG_BUGAndrew Morton
CONFIG_BUG=n && CONFIG_GENERIC_BUG=y make no sense and things break: In file included from include/linux/page-flags.h:9:0, from kernel/bounds.c:9: include/linux/bug.h:91:47: warning: 'struct bug_entry' declared inside parameter list static inline int is_warning_bug(const struct bug_entry *bug) ^ include/linux/bug.h:91:47: warning: its scope is only this definition or declaration, which is probably not what you want include/linux/bug.h: In function 'is_warning_bug': >> include/linux/bug.h:93:12: error: dereferencing pointer to incomplete type return bug->flags & BUGFLAG_WARNING; Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-09locking/lockdep: Eliminate lockdep_init()Andrey Ryabinin
Lockdep is initialized at compile time now. Get rid of lockdep_init(). Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Krinkin <krinkin.m.u@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Cc: mm-commits@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20c6x: convert to dma_map_opsChristoph Hellwig
[dan.carpenter@oracle.com: C6X: fix build breakage] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12Merge branch 'for-linux-next' of ↵Linus Torvalds
git://linux-c6x.org/git/projects/linux-c6x-upstreaming Pull tiny c6x update from Mark Salter. * 'for-linux-next' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: c6x: Use generic clkdev.h header
2015-12-04locking/cmpxchg, arch: Remove tas() definitionsDavidlohr Bueso
It seems that commit 5dc12ddee93 ("Remove tas()") missed some files. Correct this and fully drop this macro, for which we should be using cmpxchg() like calls. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <linux-arch@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@re hat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave@stgolabs.net Link: http://lkml.kernel.org/r/1445975631-17047-2-git-send-email-dave@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-13irqdomain: Use irq_domain_get_of_node() instead of direct field accessMarc Zyngier
The struct irq_domain contains a "struct device_node *" field (of_node) that is almost the only link between the irqdomain and the device tree infrastructure. In order to prepare for the removal of that field, convert all users to use irq_domain_get_of_node() instead. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-and-tested-by: Hanjun Guo <hanjun.guo@linaro.org> Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: Tomasz Nowicki <tomasz.nowicki@linaro.org> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Graeme Gregory <graeme@xora.org.uk> Cc: Jake Oshins <jakeo@microsoft.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Link: http://lkml.kernel.org/r/1444737105-31573-2-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-09-16c6x: Use generic clkdev.h headerStephen Boyd
The c6x clkdev.h header is the same as the asm-generic header, so just use the asm-generic one. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This updated pull request does not contain the last few GIC related patches which were reported to cause a regression. There is a fix available, but I let it breed for a couple of days first. The irq departement provides: - new infrastructure to support non PCI based MSI interrupts - a couple of new irq chip drivers - the usual pile of fixlets and updates to irq chip drivers - preparatory changes for removal of the irq argument from interrupt flow handlers - preparatory changes to remove IRQF_VALID" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2 irqchip: Add documentation for the bcm2836 interrupt controller irqchip/bcm2835: Add support for being used as a second level controller irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ PCI: xilinx: Fix typo in function name irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance irqchip/gic: Only allow the primary GIC to set the CPU map PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove unicore32/irq: Prepare puv3_gpio_handler for irq argument removal tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal m68k/irq: Prepare irq handlers for irq argument removal C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal blackfin: Prepare irq handlers for irq argument removal arc/irq: Prepare idu_cascade_isr for irq argument removal sparc/irq: Use access helper irq_data_get_affinity_mask() sparc/irq: Use helper irq_data_get_irq_handler_data() parisc/irq: Use access helper irq_data_get_affinity_mask() mn10300/irq: Use access helper irq_data_get_affinity_mask() irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal ...
2015-08-10c6x/timer64: Migrate to new 'set-state' interfaceViresh Kumar
Migrate c6x driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. We weren't doing anything in ->set_mode(RESUME) and so tick_resume() isn't implemented. Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-07-31C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removalThomas Gleixner
The irq argument of most interrupt flow handlers is unused or merily used instead of a local variable. The handlers which need the irq argument can retrieve the irq number from the irq descriptor. Search and update was done with coccinelle and the invaluable help of Julia Lawall. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Mark Salter <msalter@redhat.com> Cc: linux-c6x-dev@linux-c6x.org
2015-07-30Merge branch 'linus' into irq/coreThomas Gleixner
Pull in upstream fixes before applying conflicting changes
2015-07-27C6X/meagmod-pic: Consolidate chained IRQ handler install/removeThomas Gleixner
Chained irq handlers usually set up handler data as well. We now have a function to set both under irq_desc->lock. Replace the two calls with one. Search and conversion was done with coccinelle. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Julia Lawall <Julia.Lawall@lip6.fr> Link: http://lkml.kernel.org/r/20150713130429.697731509@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-08Make asm/word-at-a-time.h available on all architecturesChris Metcalf
Added the x86 implementation of word-at-a-time to the generic version, which previously only supported big-endian. Omitted the x86-specific load_unaligned_zeropad(), which in any case is also not present for the existing BE-only implementation of a word-at-a-time, and is only used under CONFIG_DCACHE_WORD_ACCESS. Added as a "generic-y" to the Kbuilds of all architectures that didn't previously have it. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-19remove scatterlist.h generation from arch Kbuild filesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-16Merge tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreamingLinus Torvalds
Pull arch/c6x fixes from Mark Salter. * tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: c6x: platforms: cache: Export symbol L1P_cache_block_invalidate and L1D_cache_block_writeback c6x: kernel: setup: Export symbol memory_end c6x: kernel: setup: Add screen_info global variable c6x: include: asm: Kbuild: Add generic serial.h c6x: include: asm: dma-mapping: Add dummy dma_sync_single_range_for_device c6x: include: asm: setup: Include "linux/types.h" c6x: asm: Add default flat.h according to xtensa architecture c6x: kernel: setup: Remove 'const' for local variables in machine_init c6x: Makefile: Add -D__linux__ C6x: time: Ensure consistency in __init c6x: kernel: setup: Include "linux/console.h"
2015-04-15Merge branch 'exec_domain_rip_v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull exec domain removal from Richard Weinberger: "This series removes execution domain support from Linux. The idea behind exec domains was to support different ABIs. The feature was never complete nor stable. Let's rip it out and make the kernel signal handling code less complicated" * 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits) arm64: Removed unused variable sparc: Fix execution domain removal Remove rest of exec domains. arch: Remove exec_domain from remaining archs arc: Remove signal translation and exec_domain xtensa: Remove signal translation and exec_domain xtensa: Autogenerate offsets in struct thread_info x86: Remove signal translation and exec_domain unicore32: Remove signal translation and exec_domain um: Remove signal translation and exec_domain tile: Remove signal translation and exec_domain sparc: Remove signal translation and exec_domain sh: Remove signal translation and exec_domain s390: Remove signal translation and exec_domain mn10300: Remove signal translation and exec_domain microblaze: Remove signal translation and exec_domain m68k: Remove signal translation and exec_domain m32r: Remove signal translation and exec_domain m32r: Autogenerate offsets in struct thread_info frv: Remove signal translation and exec_domain ...
2015-04-12arch: Remove exec_domain from remaining archsRichard Weinberger
Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-11whack-a-mole: no need to set_fs(USER_DS) in {start,flush}_thread()Al Viro
flush_old_exec() has already done that. Back on 2011 a bunch of instances like that had been kicked out, but that hadn't taken care of then-out-of-tree architectures, obviously, and they served as reinfection vector... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-26c6x: platforms: cache: Export symbol L1P_cache_block_invalidate and ↵Chen Gang
L1D_cache_block_writeback They are needed by other modules, the related error with allmodconfig: MODPOST 3327 modules ERROR: "L1P_cache_block_invalidate" [drivers/misc/lkdtm.ko] undefined! ERROR: "L1D_cache_block_writeback" [drivers/misc/lkdtm.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: kernel: setup: Export symbol memory_endChen Gang
It is needed by several modules, the related error with allmodconfig: MODPOST 3327 modules ERROR: "memory_end" [net/wireless/lib80211_crypt_tkip.ko] undefined! ERROR: "memory_end" [net/sunrpc/sunrpc.ko] undefined! ERROR: "memory_end" [net/sunrpc/auth_gss/rpcsec_gss_krb5.ko] undefined! ERROR: "memory_end" [net/rxrpc/rxkad.ko] undefined! ERROR: "memory_end" [net/mac802154/mac802154.ko] undefined! ERROR: "memory_end" [net/mac80211/mac80211.ko] undefined! ERROR: "memory_end" [net/ipv6/esp6.ko] undefined! ERROR: "memory_end" [net/ipv6/ah6.ko] undefined! ERROR: "memory_end" [net/ipv4/esp4.ko] undefined! ERROR: "memory_end" [net/ipv4/ah4.ko] undefined! ERROR: "memory_end" [net/ceph/libceph.ko] undefined! ERROR: "memory_end" [net/9p/9pnet_virtio.ko] undefined! ERROR: "memory_end" [drivers/usb/wusbcore/wusbcore.ko] undefined! ERROR: "memory_end" [drivers/usb/misc/usbtest.ko] undefined! ERROR: "memory_end" [drivers/usb/core/usbcore.ko] undefined! ERROR: "memory_end" [drivers/target/target_core_file.ko] undefined! ERROR: "memory_end" [drivers/net/wireless/brcm80211/brcmfmac/brcmfmac.ko] undefined! ERROR: "memory_end" [drivers/net/wireless/ath/ath6kl/ath6kl_sdio.ko] undefined! ERROR: "memory_end" [drivers/net/virtio_net.ko] undefined! ERROR: "memory_end" [drivers/net/usb/usbnet.ko] undefined! ERROR: "memory_end" [drivers/net/ppp/ppp_mppe.ko] undefined! ERROR: "memory_end" [drivers/mtd/nand/nand.ko] undefined! ERROR: "memory_end" [drivers/mmc/card/mmc_block.ko] undefined! ERROR: "memory_end" [drivers/crypto/qce/qcrypto.ko] undefined! ERROR: "memory_end" [drivers/block/drbd/drbd.ko] undefined! ERROR: "memory_end" [drivers/block/aoe/aoe.ko] undefined! ERROR: "memory_end" [crypto/tcrypt.ko] undefined! ERROR: "memory_end" [crypto/gcm.ko] undefined! ERROR: "memory_end" [crypto/cts.ko] undefined! ERROR: "memory_end" [crypto/ccm.ko] undefined! ERROR: "memory_end" [crypto/authencesn.ko] undefined! ERROR: "memory_end" [crypto/authenc.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: kernel: setup: Add screen_info global variableChen Gang
Or can not pass building with allmodconfig: LD init/built-in.o drivers/built-in.o: In function `vgacon_switch': vgacon.c:(.text+0x47f8): undefined reference to `screen_info' vgacon.c:(.text+0x4810): undefined reference to `screen_info' drivers/built-in.o: In function `vgacon_resize': vgacon.c:(.text+0x4ac8): undefined reference to `screen_info' vgacon.c:(.text+0x4acc): undefined reference to `screen_info' drivers/built-in.o: In function `vgacon_save_screen': vgacon.c:(.text+0x4cc8): undefined reference to `screen_info' drivers/built-in.o:vgacon.c:(.text+0x4cd0): more undefined references to `screen_info' follow Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: include: asm: Kbuild: Add generic serial.hChen Gang
Or it will cause building break with allmodconfig: CC [M] drivers/tty/serial/8250/8250_core.o drivers/tty/serial/8250/8250_core.c:102:24: fatal error: asm/serial.h: No such file or directory Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: include: asm: dma-mapping: Add dummy dma_sync_single_range_for_deviceChen Gang
c6x does not implement get_dma_ops() for dma-mapping-common.h. And in dma-mapping-common.h, dma_sync_single_range_for_device() may be dummy. So c6x can just define a dummy function for allmodconfig building. CC [M] drivers/net/ethernet/micrel/ks8851.o drivers/net/ethernet/micrel/ks8842.c: In function 'ks8842_tx_frame_dma': drivers/net/ethernet/micrel/ks8842.c:453:2: error: implicit declaration of function 'dma_sync_single_range_for_device' [-Werror=implicit-function-declaration] dma_sync_single_range_for_device(adapter->dev, ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: include: asm: setup: Include "linux/types.h"Chen Gang
Some modules may assume "asm/setup.h" already include all headers which needed by itself. So need let "asm/setup.h" include "linux/types.h", the related error: C [M] drivers/input/joydev.o In file included from include/asm-generic/page.h:23:0, from ./arch/c6x/include/asm/page.h:9, from include/asm-generic/io.h:14, from arch/c6x/include/generated/asm/io.h:1, from drivers/input/joydev.c:15: ./arch/c6x/include/asm/setup.h:17:27: error: unknown type name 'phys_addr_t' extern int c6x_add_memory(phys_addr_t start, unsigned long size); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: asm: Add default flat.h according to xtensa architectureChen Gang
For supporting uClinux flat-format executables, c6x needs to define the fewest features to support it, at present, xtensa architecture has the fewest feature for it, so just copy xtensa flat.h. The related error: CC fs/binfmt_flat.o In file included from fs/binfmt_flat.c:36:0: include/linux/flat.h:12:22: fatal error: asm/flat.h: No such file or directory Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: kernel: setup: Remove 'const' for local variables in machine_initChen Gang
early_init_dt_scan() accepts "void *", the related warning: CC arch/c6x/kernel/setup.o arch/c6x/kernel/setup.c: In function 'machine_init': arch/c6x/kernel/setup.c:290:21: warning: passing argument 1 of 'early_init_dt_scan' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers] early_init_dt_scan(fdt); ^ In file included from arch/c6x/kernel/setup.c:19:0: include/linux/of_fdt.h:75:13: note: expected 'void *' but argument is of type 'const void *' extern bool early_init_dt_scan(void *params); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26c6x: Makefile: Add -D__linux__Chen Gang
For gcc5 c6x raw compiler, at present, it may not define __linux__, so c6x kernel still needs to define __linux__ just like another archs have done. The related error: CC [M] fs/coda/psdev.o In file included from include/linux/coda.h:64:0, from fs/coda/psdev.c:45: include/uapi/linux/coda.h:221:2: error: unknown type name 'u_quad_t' u_quad_t va_size; /* file size in bytes */ ^ include/uapi/linux/coda.h:229:2: error: unknown type name 'u_quad_t' u_quad_t va_bytes; /* bytes of disk space held by file */ ^ include/uapi/linux/coda.h:230:2: error: unknown type name 'u_quad_t' u_quad_t va_filerev; /* file modification number */ ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-26C6x: time: Ensure consistency in __initNishanth Menon
time_init invokes timer64_init (which is __init annotation) since all of these are invoked at init time, lets maintain consistency by ensuring time_init is marked appropriately as well. This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init() The function time_init() references the function __init timer64_init(). This is often because time_init lacks a __init annotation or the annotation of timer64_init is wrong. Fixes: 546a39546c64 ("C6X: time management") Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Mark Salter <msalter@redhat.com>
2015-03-12arch/c6x/include/asm/pgtable.h: define dummy pgprot_writecombine for !MMUChen Gang
When !MMU, asm-generic will not define default pgprot_writecombine, so c6x needs to define it by itself. The related error: CC [M] fs/pstore/ram_core.o fs/pstore/ram_core.c: In function 'persistent_ram_vmap': fs/pstore/ram_core.c:399:10: error: implicit declaration of function 'pgprot_writecombine' [-Werror=implicit-function-declaration] prot = pgprot_writecombine(PAGE_KERNEL); ^ fs/pstore/ram_core.c:399:8: error: incompatible types when assigning to type 'pgprot_t {aka struct <anonymous>}' from type 'int' prot = pgprot_writecombine(PAGE_KERNEL); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-03c6x: kernel: setup: Include "linux/console.h"Chen Gang
Or c6x will cause building break for allmodconfig, the related error: CC arch/c6x/kernel/setup.o arch/c6x/kernel/setup.c: In function 'setup_arch': arch/c6x/kernel/setup.c:433:2: error: 'conswitchp' undeclared (first use in this function) conswitchp = &dummy_con; ^ arch/c6x/kernel/setup.c:433:2: note: each undeclared identifier is reported only once for each function it appears in arch/c6x/kernel/setup.c:433:16: error: 'dummy_con' undeclared (first use in this function) conswitchp = &dummy_con; ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> [removed unnecessary #ifdef around include] Signed-off-by: Mark Salter <msalter@redhat.com>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10c6x: drop pte_file()Kirill A. Shutemov
We've replaced remap_file_pages(2) implementation with emulation. Nobody creates non-linear mapping anymore. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13irq_work: Introduce arch_irq_work_has_interrupt()Peter Zijlstra
The nohz full code needs irq work to trigger its own interrupt so that the subsystem can work even when the tick is stopped. Lets introduce arch_irq_work_has_interrupt() that archs can override to tell about their support for this ability. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
