path: root/arch/cris
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25cris: add arch/cris/include/asm/serial.hWANG Cong
Fix the following build errors: drivers/tty/serial/8250_early.c:160: error: 'BASE_BAUD' undeclared (first use in this function): 1 errors in 1 logs drivers/tty/serial/8250_early.c:37:24: error: asm/serial.h: No such file or directory: 1 errors in 1 logs I am not sure if (1843200 / 16) is suitable for cris, but most other arch's define it as this value. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03cris: add missing declaration of kgdb_init() and breakpoint()WANG Cong
Fix: arch/cris/arch-v10/kernel/irq.c:239: error: implicit declaration of function 'kgdb_init' arch/cris/arch-v10/kernel/irq.c:240: error: implicit declaration of function 'breakpoint' Declare these two functions. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03cris: fix the prototype of sync_serial_ioctl()WANG Cong
Fix: arch/cris/arch-v10/drivers/sync_serial.c:961: error: conflicting types for 'sync_serial_ioctl' Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03cris: fix a build error in sync_serial_open()WANG Cong
Fix: arch/cris/arch-v10/drivers/sync_serial.c:628: error: 'ret' undeclared (first use in this function) 'ret' should be 'err'. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03cris: fix a build error in kernel/fork.cWANG Cong
Fix this error: kernel/fork.c:267: error: implicit declaration of function 'alloc_thread_info_node' This is due to renaming alloc_thread_info() to alloc_thread_info_node(). [akpm@linux-foundation.org: coding-style fixes] Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25cris, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25cris: fix some build warnings in pinmux.cWANG Cong
Fix some harmless warnings such as arch/cris/arch-v32/mach-a3/pinmux.c:273: warning: ISO C90 forbids mixed declarations and code: Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25cris: convert old cpumask API into new oneKOSAKI Motohiro
Adapt to the new API. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mtd: cris: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-18cris: typo in mach-fs MakefileSarah Nadi
Signed-off-by: Sarah Nadi <snadi@uwaterloo.ca> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-28Merge branch 'for-linus' of git://www.jni.nu/crisLinus Torvalds
* 'for-linus' of git://www.jni.nu/cris: Correct auto-restart of syscalls via restartblock CRISv10: Fix return before mutex_unlock in pcf8563 Drop the CRISv32 version of pcf8563
2011-03-25Merge branch 'master' of ↵Artem Bityutskiy
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits) [media] rc: update for bitop name changes fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock lib, arch: add filter argument to show_mem and fix private implementations SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu() ... NOTE! This merge commit was created to fix compilation error. The block tree was merged upstream and removed the 'elv_queue_empty()' function which the new 'mtdswap' driver is using. So a simple merge of the mtd tree with upstream does not compile. And the mtd tree has already be published, so re-basing it is not an option. To fix this unfortunate situation, I had to merge upstream into the mtd-2.6.git tree without committing, put the fixup patch on top of this, and then commit this. The result is that we do not have commits which do not compile. In other words, this merge commit "merges" 3 things: the MTD tree, the upstream tree, and the fixup patch.
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-23remove dma64_addr_tFUJITA Tomonori
There is no user now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: David Miller <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Correct auto-restart of syscalls via restartblockJesper Nilsson
This would for example be poll(2) Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2011-03-21CRISv10: Fix return before mutex_unlock in pcf8563Jesper Nilsson
Signed-off-by: Simone Contini <s.contini@oltrelinux.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2011-03-21Drop the CRISv32 version of pcf8563Jesper Nilsson
No longer used. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2011-03-18Merge branches 'irq-fixes-for-linus' and 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix incorrect unlock in __setup_irq() cris: Use generic show_interrupts() genirq: show_interrupts: Check desc->name before printing it blindly cris: Use accessor functions to set IRQ_PER_CPU flag cris: Fix irq conversion fallout * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, kernel-doc: Fix runqueue_is_locked() description
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17cris: Use generic show_interrupts()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jesper Nilsson <jesper.nilsson@axis.com>
2011-03-17cris: Use accessor functions to set IRQ_PER_CPU flagThomas Gleixner
2011-03-17cris: Fix irq conversion falloutThomas Gleixner
arch/cris/arch-v10/kernel/irq.c: In function 'init_IRQ': arch/cris/arch-v10/kernel/irq.c:202:3: error: implicit declaration of function 'set_irq_desc_and_handler' Should have been set_irq_chip_and_handler() Fix it and convert to the new function names while at it. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-03-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtmutex: tester: Remove the remaining BKL leftovers lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause rtmutex: Simplify PI algorithm and make highest prio task get lock rwsem: Remove redundant asmregparm annotation rwsem: Move duplicate function prototypes to linux/rwsem.h rwsem: Unify the duplicate rwsem_is_locked() inlines rwsem: Move duplicate init macros and functions to linux/rwsem.h rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h x86: Cleanup rwsem_count_t typedef rwsem: Cleanup includes locking: Remove deprecated lock initializers cred: Replace deprecated spinlock initialization kthread: Replace deprecated spinlock initialization xtensa: Replace deprecated spinlock initialization um: Replace deprecated spinlock initialization sparc: Replace deprecated spinlock initialization mips: Replace deprecated spinlock initialization cris: Replace deprecated spinlock initialization alpha: Replace deprecated spinlock initialization rtmutex-tester: Remove BKL tests
2011-03-11CRIS: stop checking for MTD_CONCATDmitry Eremin-Solenikov
As MTD_CONCAT support is becoming an integral part of MTD core, there is no need for it's special treatment. So stop checking for MTD_CONCAT availability. Acked by Jesper Nilsson <jesper.nilsson@axis.com> for merging this via the MTD tree. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-02-23Drop redundant __param section for CRISv32.Jesper Nilsson
The __param section is already brought in by RODATA above. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
