path: root/arch/cris
2013-01-03ARCH: drivers remove __dev* attributes.Greg Kroah-Hartman
This fixes up all of the smaller arches that had __dev* markings for their platform-specific drivers. CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Bob Liu <lliubbo@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Myron Stowe <myron.stowe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-20UAPI: Fix up empty files in arch/cris/David Howells
Fix up three empty files in arch/cris/ by sticking placeholder comments in there to prevent the patch program from deleting them. I decided not to delete the arch-v*/Kbuild files as it's possibly someone might want to use them for genhdr-y lines in the future, but they could be deleted and the pointer lines removed from asm/Kbuild. The uapi/arch-v*/Kbuild files ought to be uneffected by such a change. asm/swab.h didn't have anything outside of __KERNEL__ so nothing appeared in uapi/asm/swab.h. The latter, however, is exported by Kbuild.asm. This needs to be applied after the CRIS UAPI disintegration patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-12-20CRIS: locking: fix the return value of arch_read_trylock()Wei Yongjun
arch_write_trylock() should return 'ret' instead of always return 1. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-12-20Merge tag 'disintegrate-cris-20121009' of ↵Jesper Nilsson
git://git.infradead.org/users/dhowells/linux-headers into for-linus2 UAPI Disintegration 2012-10-09 * tag 'disintegrate-cris-20121009' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate arch/cris/include/asm UAPI: (Scripted) Disintegrate arch/cris/include/arch-v32/arch UAPI: (Scripted) Disintegrate arch/cris/include/arch-v10/arch
2012-12-20CRIS: use kbuild.h instead of defining macros in asm-offset.cJames Hogan
This is modelled on commits such as the one below: Commit fc1c3a003edb8a6778e64e10ef671a38c76c969e ("sh: use kbuild.h instead of defining macros in asm-offsets.c") introduced in v2.6.26. Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-12-19unify SS_ONSTACK/SS_DISABLE definitionsAl Viro
2012-12-19new helper: current_user_stack_pointer()Al Viro
Cross-architecture equivalent of rdusp(); default is user_stack_pointer(current_pt_regs()) - that works for almost all platforms that have usp saved in pt_regs. The only exception from that is ia64 - we want memory stack, not the backing store for register one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-18CRIS: fix I/O macrosCorey Minyard
The inb/outb macros for CRIS are broken from a number of points of view, missing () around parameters and they have an unprotected if statement in them. This was breaking the compile of IPMI on CRIS and thus I was being annoyed by build regressions, so I fixed them. Plus I don't think they would have worked at all, since the data values were missing "&" and the outsl had a "3" instead of a "4" for the size. From what I can tell, this stuff is not used at all, so this can't be any more broken than it was before, anyway. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-14modules: don't hand 0 to vmalloc.Rusty Russell
In commit d0a21265dfb5fa8a David Rientjes unified various archs' module_alloc implementation (including x86) and removed the graduitous shortcut for size == 0. Then, in commit de7d2b567d040e3b, Joe Perches added a warning for zero-length vmallocs, which can happen without kallsyms on modules with no init sections (eg. zlib_deflate). Fix this once and for all; the module code has to handle zero length anyway, so get it right at the caller and remove the now-gratuitous checks within the arch-specific module_alloc implementations. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42608 Reported-by: Conrad Kostecki <ConiKost@gmx.de> Cc: David Rientjes <rientjes@google.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-11-29unify default ptrace_signal_deliverAl Viro
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28cris: switch to generic fork/vfork/cloneAl Viro
same braindamage as on s390 - the first two arguments of clone(2) in the wrong order. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-19various: Fix spelling of "registered" in comments.Adam Buchbinder
Some comments misspell "registered"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-13tracing,x86: Add a TSC trace_clockDavid Sharp
In order to promote interoperability between userspace tracers and ftrace, add a trace_clock that reports raw TSC values which will then be recorded in the ring buffer. Userspace tracers that also record TSCs are then on exactly the same time base as the kernel and events can be unambiguously interlaced. Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large timestamp values. v2: Move arch-specific bits out of generic code. v3: Rename "x86-tsc", cleanups v7: Generic arch bits in Kbuild. Google-Bug-Id: 6980623 Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Signed-off-by: David Sharp <dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-11-01sk-filter: Add ability to get socket filter program (v2)Pavel Emelyanov
The SO_ATTACH_FILTER option is set only. I propose to add the get ability by using SO_ATTACH_FILTER in getsockopt. To be less irritating to eyes the SO_GET_FILTER alias to it is declared. This ability is required by checkpoint-restore project to be able to save full state of a socket. There are two issues with getting filter back. First, kernel modifies the sock_filter->code on filter load, thus in order to return the filter element back to user we have to decode it into user-visible constants. Fortunately the modification in question is interconvertible. Second, the BPF_S_ALU_DIV_K code modifies the command argument k to speed up the run-time division by doing kernel_k = reciprocal(user_k). Bad news is that different user_k may result in same kernel_k, so we can't get the original user_k back. Good news is that we don't have to do it. What we need to is calculate a user2_k so, that reciprocal(user2_k) == reciprocal(user_k) == kernel_k i.e. if it's re-loaded back the compiled again value will be exactly the same as it was. That said, the user2_k can be calculated like this user2_k = reciprocal(kernel_k) with an exception, that if kernel_k == 0, then user2_k == 1. The optlen argument is treated like this -- when zero, kernel returns the amount of sock_fprog elements in filter, otherwise it should be large enough for the sock_fprog array. changes since v1: * Declared SO_GET_FILTER in all arch headers * Added decode of vlan-tag codes Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-14cris: switch to generic kernel_execve/sys_execveAl Viro
2012-10-14cris: switch to generic kernel_thread()Al Viro
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09UAPI: (Scripted) Disintegrate arch/cris/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-09UAPI: (Scripted) Disintegrate arch/cris/include/arch-v32/archDavid Howells
2012-10-09UAPI: (Scripted) Disintegrate arch/cris/include/arch-v10/archDavid Howells
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09readahead: fault retry breaks mmap file read random detectionShaohua Li
.fault now can retry. The retry can break state machine of .fault. In filemap_fault, if page is miss, ra->mmap_miss is increased. In the second try, since the page is in page cache now, ra->mmap_miss is decreased. And these are done in one fault, so we can't detect random mmap file access. Add a new flag to indicate .fault is tried once. In the second try, skip ra->mmap_miss decreasing. The filemap_fault state machine is ok with it. I only tested x86, didn't test other archs, but looks the change for other archs is obvious, but who knows :) Signed-off-by: Shaohua Li <shaohua.li@fusionio.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-06cross-arch: don't corrupt personality flags upon exec()Jiri Kosina
Historically, the top three bytes of personality have been used for things such as ADDR_NO_RANDOMIZE, which made sense only for specific architectures. We now however have a flag there that is general no matter the architecture (UNAME26); generally we have to be careful to preserve the personality flags across exec(). This patch tries to fix all architectures that forcefully overwrite personality flags during exec() (ppc32 and s390 have been fixed recently by commits f9783ec862ea ("[S390] Do not clobber personality flags on exec") and 59e4c3a2fe9c ("powerpc/32: Don't clobber personality flags on exec") in a similar way already). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04Merge branch 'disintegrate-asm-generic' of ↵Arnd Bergmann
git://git.infradead.org/users/dhowells/linux-headers into asm-generic Patches from David Howells <dhowells@redhat.com>: This is to complete part of the UAPI disintegration for which the preparatory patches were pulled recently. Note that there are some fixup patches which are at the base of the branch aimed at you, plus all arches get the asm-generic branch merged in too. * 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/asm-generic UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k) c6x: remove c6x signal.h UAPI: Split compound conditionals containing __KERNEL__ in Arm64 UAPI: Fix the guards on various asm/unistd.h files Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-03Merge tag 'uapi-prep-20121002' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull preparatory patches for user API disintegration from David Howells: "The patches herein prepare for the extraction of the Userspace API bits from the various header files named in the Kbuild files. New subdirectories are created under either include/uapi/ or arch/x/include/uapi/ that correspond to the subdirectory containing that file under include/ or arch/x/include/. The new subdirs under the uapi/ directory are populated with Kbuild files that mostly do nothing at this time. Further patches will disintegrate the headers in each original directory and fill in the Kbuild files as they do it. These patches also: (1) fix up #inclusions of "foo.h" rather than <foo.h>. (2) Remove some redundant #includes from the DRM code. (3) Make the kernel build infrastructure handle Kbuild files both in the old places and the new UAPI place that both specify headers to be exported. (4) Fix some kernel tools that #include kernel headers during their build. I have compile tested this with allyesconfig against x86_64, allmodconfig against i386 and a scattering of additional defconfigs of other arches. Prepared for main script Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com>" * tag 'uapi-prep-20121002' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Plumb the UAPI Kbuilds into the user header installation and checking UAPI: x86: Differentiate the generated UAPI and internal headers UAPI: Remove the objhdr-y export list UAPI: Move linux/version.h UAPI: Set up uapi/asm/Kbuild.asm UAPI: x86: Fix insn_sanity build failure after UAPI split UAPI: x86: Fix the test_get_len tool UAPI: (Scripted) Set up UAPI Kbuild files UAPI: Partition the header include path sets and add uapi/ header directories UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel system headers UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/ UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/. UAPI: Refer to the DRM UAPI headers with <...> and from certain headers only
2012-10-03asm-generic: Add default clkdev.hMark Brown
Ease the deployment of clkdev by providing a default asm/clkdev.h for use if the arch does not have an include/asm/clkdev.h. Due to limitations in Kbuild we manually add clkdev.h to all architectures that don't have one rather than having the header appear by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-03Merge tag 'cris-for-linus-3.7' of git://jni.nu/crisLinus Torvalds
Pull CRIS changes from Jesper Nilsson: "Removal of some unused code from the CRIS port" * tag 'cris-for-linus-3.7' of git://jni.nu/cris: CRIS: Remove VCS simulator specific code cris/PCI: remove pcibios_assign_resources()
2012-10-03CRIS: Remove VCS simulator specific codeJesper Nilsson
The VCS simulator was a tool used in the development of the chip and is no longer used or necessary. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-10-03cris/PCI: remove pcibios_assign_resources()Bjorn Helgaas
There's no caller of pcibios_assign_resources() in the tree. It is exported, so an out-of-tree module *could* call it, but no other arch exports pcibios_assign_resources(), so it would have to be a CRIS-specific module. I doubt such a caller exists. CC: Mikael Starvik <starvik@axis.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-10-02UAPI: (Scripted) Set up UAPI Kbuild filesDavid Howells
Set up empty UAPI Kbuild files to be populated by the header splitter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Partition the header include path sets and add uapi/ header directoriesDavid Howells
Partition the header include path flags into two sets, one for kernelspace builds and one for userspace builds. Add the following directories to build after the ordinary include directories so that #include will pick up the UAPI header directly if the kernel header has been moved there. The userspace set (represented by the USERINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include/uapi -I arch/$(hdr-arch)/include/generated/uapi -I $(srctree)/include/uapi -I include/generated/uapi -include $(srctree)/include/linux/kconfig.h and the kernelspace set (represented by the LINUXINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include -I arch/$(hdr-arch)/include/generated -I $(srctree)/include -I include --- if not building in the source tree plus everything in the USERINCLUDE set. Then use USERINCLUDE in building the x86 boot code. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel ↵David Howells
system headers Convert #include "..." to #include <path/...> in kernel system headers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01sanitize tsk_is_polling()Al Viro
Make default just return 0. The current default (checking TIF_POLLING_NRFLAG) is taken to architectures that need it; ones that don't do polling in their idle threads don't need to defined TIF_POLLING_NRFLAG at all. ia64 defined both TS_POLLING (used by its tsk_is_polling()) and TIF_POLLING_NRFLAG (not used at all). Killed the latter... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01bury _TIF_RESTORE_SIGMASKAl Viro
never used... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-23cris: Add missing RCU idle APIs on idle loopFrederic Weisbecker
In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the Cris's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Cris <linux-cris-kernel@axis.com> Cc: <stable@vger.kernel.org> # 3.3+ Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-09-20get rid of generic instances of asm/exec.hAl Viro
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
