path: root/arch/frv/Makefile
2010-08-03frv: clean up arch/frv/MakefileSam Ravnborg
- removed a lot of unused variable assignmnets - removed unused bootstrap target - replaced ARCHMODFLAGS with proper KBUILD_{A,C}FLAGS_MODULE assignmnets The resuting Makefile has not been tested due to lack of toolchain, but these were all trivial changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-19FRV: work around a possible compiler bugDavid Howells
Work around a possible bug in the FRV compiler. What appears to be happening is that gcc resolves the __builtin_constant_p() in kmalloc() to true, but then fails to reduce the therefore constant conditions in the if-statements it guards to constant results. When compiling with -O2 or -Os, one single spurious error crops up in cpuup_callback() in mm/slab.c. This can be avoided by making the memsize variable const. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-22[PATCH] sanitize frv archcleanAl Viro
2006-02-14[PATCH] FRV: Use virtual interrupt disablementDavid Howells
Make the FRV arch use virtual interrupt disablement because accesses to the processor status register (PSR) are relatively slow and because we will soon have the need to deal with multiple interrupt controls at the same time (separate h/w and inter-core interrupts). The way this is done is to dedicate one of the four integer condition code registers (ICC2) to maintaining a virtual interrupt disablement state whilst inside the kernel. This uses the ICC2.Z flag (Zero) to indicate whether the interrupts are virtually disabled and the ICC2.C flag (Carry) to indicate whether the interrupts are physically disabled. ICC2.Z is set to indicate interrupts are virtually disabled. ICC2.C is set to indicate interrupts are physically enabled. Under normal running conditions Z==0 and C==1. Disabling interrupts with local_irq_disable() doesn't then actually physically disable interrupts - it merely sets ICC2.Z to 1. Should an interrupt then happen, the exception prologue will note ICC2.Z is set and branch out of line using one instruction (an unlikely BEQ). Here it will physically disable interrupts and clear ICC2.C. When it comes time to enable interrupts (local_irq_enable()), this simply clears the ICC2.Z flag and invokes a trap #2 if both Z and C flags are clear (the HI integer condition). This can be done with the TIHI conditional trap instruction. The trap then physically reenables interrupts and sets ICC2.C again. Upon returning the interrupt will be taken as interrupts will then be enabled. Note that whilst processing the trap, the whole exceptions system is disabled, and so an interrupt can't happen till it returns. If no pending interrupt had happened, ICC2.C would still be set, the HI condition would not be fulfilled, and no trap will happen. Saving interrupts (local_irq_save) is simply a matter of pulling the ICC2.Z flag out of the CCR register, shifting it down and masking it off. This gives a result of 0 if interrupts were enabled and 1 if they weren't. Restoring interrupts (local_irq_restore) is then a matter of taking the saved value mentioned previously and XOR'ing it against 1. If it was one, the result will be zero, and if it was zero the result will be non-zero. This result is then used to affect the ICC2.Z flag directly (it is a condition code flag after all). An XOR instruction does not affect the Carry flag, and so that bit of state is unchanged. The two flags can then be sampled to see if they're both zero using the trap (TIHI) as for the unconditional reenablement (local_irq_enable). This patch also: (1) Modifies the debugging stub (break.S) to handle single-stepping crossing into the trap #2 handler and into virtually disabled interrupts. (2) Removes superseded fixup pointers from the second instructions in the trap tables (there's no a separate fixup table for this). (3) Declares the trap #3 vector for use in .org directives in the trap table. (4) Moves irq_enter() and irq_exit() in do_IRQ() to avoid problems with virtual interrupt handling, and removes the duplicate code that has now been folded into irq_exit() (softirq and preemption handling). (5) Tells the compiler in the arch Makefile that ICC2 is now reserved. (6) Documents the in-kernel ABI, including the virtual interrupts. (7) Renames the old irq management functions to different names. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] frv: miscellaneous changesDavid Howells
Fix a number of miscellanous items: (1) Declare lock sections in the linker script. (2) Recurse in the correct manner in the arch makefile. (3) asm/bug.h requires asm/linkage.h to be included first. One C file puts asm/bug.h first. (4) Add an empty RTC header file to avoid missing header file errors. (5) sg_dma_address() should use the dma_address member of a scatter list. (6) Add trivial pci_unmap support. (7) Add pgprot_noncached() (8) Discard u_quad_t. (9) Use ~0UL rather than ULONG_MAX in unistd.h in case the latter isn't declared. (10) Add an empty VGA header file to avoid missing header file errors. (11) Add an XOR header file to use the generic XOR stuff. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
